RNCP Series
Stackpole Electronics, Inc.
High Power Anti-Sulfur Thin Film Chip Resistor
Resistive Product Solutions
Features:
Higher power ratings than standard thick film chips
Absolute TCRs to ± 100 ppm/C
Inner termination engineered to deter sulfur contamination
Absolute tolerances to 1%
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Electrical Specifications
Type / Code
(1)
(2)
Power Rating (W)
@ 70°C
(1)
Maximum Working
Voltage (V)(2)
Maximum Overload
Voltage (V)
RNCP0402
0.1
50
100
RNCP0603
0.125
150
300
RNCP0805
0.25
RNCP1206
0.5
200
400
TCR (ppm/ºC)
Ohmic Range (Ω) and Tolerance
1%, 5%
1 - 10K
1 - 47K
± 100
1 - 100K
Power rating for each package size is valid if ambient temp ≤ 80ºC and terminal temp ≤ 105ºC
Lesser of √PR or maximum working voltage
Certain resistance values will require a higher minimum order quantity. Contact Stackpole Customer Service for details.
Please refer to the High-Power Resistor Application Note (page 5) for more information on designing and implementing high power
resistor types.
Mechanical Specifications
Type / Code
L
Body Length
W
Body Width
H
Body Height
a
Top Termination
b
Bottom Termination
Unit
RNCP0402
0.039 ± 0.004
1.00 ± 0.10
0.020 ± 0.002
0.50 ± 0.05
0.012 ± 0.002
0.30 ± 0.05
0.010 ± 0.006
0.25 ± 0.15
0.012 ± 0.006
0.30 ± 0.15
inches
mm
RNCP0603
0.061 ± 0.008
1.55 ± 0.20
0.031 ± 0.004
0.80 ± 0.10
0.016 ± 0.006
0.40 ± 0.15
0.012 ± 0.008
0.30 ± 0.20
0.014 ± 0.010
0.35 ± 0.25
inches
mm
RNCP0805
0.079 ± 0.006
2.00 ± 0.15
0.049 ± 0.006
1.25 ± 0.15
0.020 ± 0.006
0.50 ± 0.15
0.016 ± 0.010
0.40 ± 0.25
0.020 ± 0.012
0.50 ± 0.30
inches
mm
RNCP1206
0.122 ± 0.008
3.10 ± 0.20
0.059 ± 0.008
1.50 ± 0.20
0.020 ± 0.006
0.50 ± 0.15
0.022 ± 0.024
0.55 ± 0.60
0.024 ± 0.012
0.60 ± 0.30
inches
mm
Performance Characteristics
Test Item
Temperature Coefficient
of Resistance
Short Time Overload
Reference Standard
MIL-STD-202F Method 304;
JIS-C5201-1-4.8
MIL-R-55342D Paragraph 4.7.5;
JIS-C5201-1-4.13
High Temperature
Exposure (Storage)
MIL-STD-202
Method 108
Rev Date: 03/09/2020
This specification may be changed at any time without prior notice
Please confirm technical specifications before you order and/or use.
Condition of Test
Test Limits (ΔR)
+ 25 ~ +125ºC
±100 ppm/ºC
2.5 times rated voltage for 5 seconds.
F: ± (1% + 0.1 Ω)
J: ± (2% + 0.1 Ω)
1000 hours at T = 125ºC. Unpowered.
Measurement at 24 ± 2 hours
after test conclusion.
F: ± (2% + 0.1 Ω)
J: ± (2% + 0.1 Ω)
1
www.seielect.com
marketing@seielect.com
RNCP Series
Performance Characteristics (cont.)
Test Item
Reference Standard
Temperature Cycling
JESD22
Method JA-104
Moisture Resistance
MIL-STD-202
Method 106
Biased Humidity
MIL-STD-202
Method 103
Operational Life
MIL-STD-202
Method 108
Resistance to Soldering
Heat
MIL-STD-202
Method 210
Solderability
J-STD-002
Board Flex (Bending)
AEC-Q200-005
3 mm deflection.
F: ± (0.5% + 0.05 Ω)
J: ± (1% + 0.1 Ω)
AEC-Q200-006
Pressure X kgf a R0.5 pressure rod
for 60 seconds.
0201: NA
0402: 0.5 Kg, 0805: 1 Kg
0603: 0.5 Kg, 1206: 1.8 Kg
J: ± (1% + 0.1 Ω)
Terminal Strength (SMD)
Condition of Test
1000 cycles (-55ºC to +125ºC).
1000 hours, T = 24 hours/cycle
Notes: Steps 7a & 7b not required.
Unpowered.
1000 hours 85ºC / 85% RH.
Specified conditions: 10% of operating
power. Measurement at 24 ± 2 hours
1000 hours TA = 125ºC at rated power.
Measurement at 24 ± 2 hours after test
conclusion. Remark: Mounted quantity:
Mounted 2 pieces on 1 PCB.
Condition B: Immerse the specimens in an
eutectic solder at 260 ± 5ºC
for 10 ± 1 seconds.
245 ± 5ºC solder, 2 ± 0.5 seconds. dwell
Solder: Sn 96.5 / Ag 3.0 / Cu 0.5.
Test Limits (ΔR)
J: ± (1% + 0.1 Ω)
Note: R ≤ 10 Ω: F/J: ± (1% + 0.1 Ω)
F: ± (1% + 0.05 Ω)
J: ± (2% + 0.1 Ω)
F: ± (3% + 0.1 Ω)
J: ± (3% + 0.1 Ω)
F: ± (1% + 0.05 Ω)
J: ± (3% + 0.1 Ω)
J: ± (1% + 0.1 Ω)
>95% area covered with tin
Operating temperature range is -55°C to +155°C
Power Derating Curve:
100
-55 ºC
70 ºC
Power Load (%)
80
60
40
155 ºC
60
80
100
120
140
160
180
Ambient Temperature (ºC)
2
www.seielect.com
RNCP Series
Packaging Specifications
RNCP0402
(2 mm Pitch Paper)
RNCP0603, 0805, 1206
(4 mm Pitch Paper)
Type / Code
Paper Tape Pitch
A
B
W
E
F
Unit
0.079
2.00
0.157
4.00
0.157
4.00
0.157
4.00
0.028 ± 0.002
0.70 ± 0.05
0.047 ± 0.002
1.20 ± 0.05
0.315 ± 0.008
8.00 ± 0.20
0.069 ± 0.004
1.75 ± 0.10
0.138 ± 0.002
3.50 ± 0.05
inches
mm
0.043 ± 0.004
1.10 ± 0.10
0.075 ± 0.004
1.90 ± 0.10
0.315 ± 0.008
8.00 ± 0.20
0.069 ± 0.004
1.75 ± 0.10
0.138 ± 0.002
3.50 ± 0.05
inches
mm
0.063 ± 0.006
1.60 0.15
0.094 ± 0.008
2.40 ± 0.20
0.315 ± 0.008
8.00 ± 0.20
0.069 ± 0.004
1.75 ± 0.10
0.138 ± 0.002
3.50 ± 0.05
inches
mm
0.079 ± 0.006
2.00 ± 0.15
0.142 ± 0.008
3.60 ± 0.20
0.315 ± 0.008
8.00 ± 0.20
0.069 ± 0.004
1.75 ± 0.10
0.138 ± 0.002
3.50 ± 0.05
inches
mm
Type / Code
P1
P2
P0
D0(ø)
T
Unit
RNCP0402
0.079 ± 0.004
2.00 ± 0.10
0.079 ± 0.004
2.00 ± 0.10
0.157 ± 0.004
4.00 ± 0.10
0.059 ± 0.004
1.50 ± 0.10
0.018 ± 0.004
0.45 ± 0.10
inches
mm
RNCP0603
0.157 ± 0.004
4.00 ± 0.10
0.079 ± 0.002
2.00 ± 0.05
0.157 ± 0.004
4.00 ± 0.10
0.059 ± 0.004
1.50 ± 0.10
0.025 ± 0.004
0.64 ± 0.10
inches
mm
RNCP0805
0.157 ± 0.004
4.00 ± 0.10
0.079 ± 0.002
2.00 ± 0.05
0.157 ± 0.004
4.00 ± 0.10
0.059 ± 0.004
1.50 ± 0.10
0.033 ± 0.004
0.84 ± 0.10
inches
mm
RNCP1206
0.157 ± 0.004
4.00 ± 0.10
0.079 ± 0.002
2.00 ± 0.05
0.157 ± 0.004
4.00 ± 0.10
0.059 ± 0.004
1.50 ± 0.10
0.033 ± 0.004
0.84 ± 0.10
inches
mm
RNCP0402
RNCP0603
RNCP0805
RNCP1206
3
www.seielect.com
RNCP Series
Reel Specifications
Type / Code
RNCP
ØA
7.008 ± 0.079
178.00 ± 2.00
ØB
2.362 ± 0.039
60.00 ± 1.00
Øc
0.512 ± 0.039
13.00 ± 1.00
W
0.354 ± 0.039
9.00 ± 1.00
T
0.453 ± 0.039
11.50 ± 1.00
Unit
inches
mm
Peel-off Force Specifications
Peel-off force of paper and blister tape is in accordance with “JIS-C5202”, that is, 0.1 to 0.7N at a
peel-off speed of 300 mm/minute.
Solder Land Pattern
Type / Code
0402
0603
0805
1206
A
0.016
0.40
0.026
0.65
0.039
1.00
0.079
2.00
B
0.059
1.50
0.083
2.10
0.118
3.00
0.165
4.20
4
C
0.024
0.60
0.035
0.90
0.051
1.30
0.063
1.60
Unit
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
RNCP Series
Recommended IR – Reflow Profile
(Solder: Sn96.5 / Ag3 / Cu0.5)
Peak: 250 +5 / -0 °C, 5 seconds
Pre-heat Zone: 150 °C to 180 °C, 90 ± 30 seconds
Soldering Zone: 230 °C or higher, 30 ± 10 seconds
High Power Chip Resistors and Thermal Management
Stackpole has developed several surface mount resistor series in addition to our current sense resistors, which have had higher power
ratings than standard resistor chips. This has caused some uncertainty and even confusion by users as to how to reliably use these
resistors at the higher power ratings in their designs.
The data sheets for the RHC, RMCP, RNCP, CSR, CSRN, CSRF, CSS, and CSSH state that the rated power assumes an ambient
temperature of no more than 100°C for the CSS / CSSH series and 70°C for all other high power resistor series. In addition, IPC and
UL best practices dictate that the combined temperature on any resistor due to power dissipated and ambient air shall be no more than
105°C. At first glance this wouldn’t seem too difficult, however the graph below shows typical heat rise for the CSR ½ 100 milliohms
at full rated power. The heat rise for the RMCP and RNCP would be similar. The RHC with its unique materials, design, and processes
would have less heat rise and therefore would be easier to implement for any given customer.
5
www.seielect.com
RNCP Series
The 102°C heat rise shown here would indicate there will be additional thermal reduction techniques needed to keep this part under
105°C total hot spot temperature if this part is to be used at 0.75 watts of power. However, this same part at the usual power rating
for this size would have a heat rise of around 72°C. This additional heat rise may be dealt with using wider conductor traces, larger
solder pads and land patterns under the solder mask, heavier copper in the conductors, via through PCB, air movement, and heat
sinks, among many other techniques. Because of the variety of methods customers can use to lower the effective heat rise of the
circuit, resistor manufacturers simply specify power ratings with the limitations on ambient air temperature and total hot spot
temperatures and leave the details of how to best accomplish this to the design engineers. Design guidelines for products in various
market segments can vary widely so it would be unnecessarily constraining for a resistor manufacturer to recommend the use of any
of these methods over another.
Note:
The final resistance value can be affected by the board layout and assembly process, especially the size of the mounting
pads and the amount of solder used. This is especially notable for resistance values ≤ 50 milliohms.
This should be taken into account when designing.
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
RNCP
Description
Package /
Termination
Type
Standard
Series
RoHS
Compliant
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
Lead-Free
Effective Date
Code
(YY/WW)
SMD
YES
100% Matte Sn over Ni
Always
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive
to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
6
www.seielect.com
RNCP Series
How to Order
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
R
N
C
P
F
T
D
4
K
7
5
Product Series
High Power
RNCP Anti-Sulfur
Thin Film
Power Rating
Size
W
0402
0.1
0603
0.125
0805
0.25
0.5
1206
Tolerance
Code Tol
Value
F
1% E96, E24
J
5%
E24
Packaging
Code
Description
T
7" Reel - Paper Tape
Size
Quantity
0402
10000
0603, 0805, 1206
5000
7
TCR
Code ppm
D
100
Resistance Value
Four characters
with the multiplier
used as the
decimal holder.
1 ohm = 1R00
47 Kohm = 47K0
100 Kohm = 100K
www.seielect.com
