395-060-521-188
395-060-521-188
    插件,P=2.54mm
    2.54MM P数:60P
395-060-521-188 数据手册
Contact Dimensions: 521-P.C. Tail .025 Sq.(0.64 Sq.) - Tail LG=.150(3.81) .100 (2.54) Contact Spacing x .200 (5.08) Row Spacing CARD SLOT ACCEPTS .054" [1.37] TO .070"[1.78] THICK PCB 2x ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .156 3.96 .330 8.38 CARD SLOT .160 4.06 POINT OF CONTACT 6.100 154.94 6.260 159 6.575 167.01 .600 15.24 .150 [3.81] A SECTION A-A A 6.835 173.61 345/395 SERIES CARD EDGE CONNECTOR PART NUMBER: 395-060-521-188 • • • INSULATOR MATERIAL: THERMOPLASTIC PBT BLACK, UL 94V-0 CONTACT MATERIAL; COPPER TIN ALLOY CONTACT PLATING: GOLD ON THE MATING AREA, TIN PLATING ON THE CONTACT TAILS, NICKEL UNDERPLATE EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. 345-ENG-MASTER DRAWN: R.STA.MONICA DATE:MAY.16/2017 CHECKED: DATE: SCALE: 1:1 DRAWING NUMBER 345-ENG-MASTER SHEET 1 OF 2 ISSUE 1 Contact Description: 559-90 Degree Bend (Code 541 Contacts) .107 2.72 ORIGINAL .157 4 .125(3.18) to .210(5.33) Outside Tails .125(3.18) to .210(5.33) Outside Tails .045(1.14) to .060(1.52) Between Tails .045(1.14) to .060(1.52) Between Tails Contact Code 555 Contact Code 556 .060 .152 3.86 .060 .150 .200 .285 7.24 .635 16.13 1 .082 2.08 .232 5.89 .235 5.97 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. .362 9.19 .125(3.18) to .210(5.33) Outside Tails .635 16.13 .045(1.14) to .060(1.52) Between Tails Contact Code 558 • • • INSULATOR MATERIAL: THERMOPLASTIC POLYESTER, UL 94V-0 DAP MATERIAL AVAILABLE UPON REQUEST CONTACT MATERIAL; COPPER ALLOY CONTACT PLATING: GOLD ON THE MATING AREA, TIN PLATING ON THE CONTACT TAILS, NICKEL UNDERPLATE Contact Code 559 Contact Code 560 345/395 SERIES CARD EDGE CONNECTOR CONTACT CODE 555,556,558,559,560 DIMENSIONS EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. DRAWN: R.STA.MONICA DATE: CHECKED: SCALE: 345-ENG-MASTER DATE:MAY.16/2017 1:1 DRAWING NUMBER 345-ENG-MASTER SHEET 2 OF 2 ISSUE 1
395-060-521-188
物料型号:345-ENG-MASTER
器件简介:345/395系列卡边缘连接器
引脚分配:该文档中未提供详细的引脚分配信息,但提到了不同的接触码,如555、556、558、559、560。
参数特性: - 绝缘材料:热塑性聚对苯二甲酸丁二醇酯(PBT),黑色,符合UL 94V-0标准 - 接触材料:铜合金 - 接触镀层:接触区域为金,接触尾部为锡,底层为镍 - 尺寸信息:接触尺寸为521-P.C.尾部0.025平方英寸(0.64平方英寸),尾部长度为0.150英寸(3.81毫米),接触间距为0.100英寸(2.54毫米),行间距为0.200英寸(5.08毫米)
功能详解:文档中没有提供详细的功能描述,但提到了90度弯曲的接触(代码541接触)。
应用信息:卡槽可接受0.054英寸(1.37毫米)至0.070英寸(1.78毫米)厚的PCB。
封装信息:文档中没有提供封装信息,但提到了绝缘材料和接触材料的类型。
请注意,这些信息是从PDF文档中提取的,可能不完整。
如果需要更详细的信息,建议参考原始文档或联系制造商。
395-060-521-188 价格&库存
很抱歉,暂时无法提供与“395-060-521-188”相匹配的价格&库存,您可以联系我们找货
