Mounting Option
07-M3-0.5 Metric Threaded Inserts
Contact Detail
524-P.C. Tail .018 Sq.(0.46 Sq.) - Tail LG=.185(4.70)
.100 [2.54] Contact Spacing x .200 [5.08] Row Spacing
ISSUE NUMBER
THIS IS A C.A.D. GENERATED DRAWING
DO NOT MAKE MANUAL REVISIONS TO MASTER.
ORIGINAL
1
6.600 167.64
6.322 160.58
6.046 153.57
0.100 2.54
Card Slot Accepts
.054 [1.37] to .070 [1.78]
Thick P.C. Board
0.270 6.86
0.590 14.99
A
0.410 10.41
0.240 6.10
Point of Contact
0.370 9.40
5.900 149.86
SECTION A-A
A
See Accompanying Pages for:
Contact Bend Details
Mounting Options
342 / 392 Card Edge Connector
Part Number: 392-116-524-207
EDAC INC
TORONTO, ONTARIO
CANADA
YOUR CONNECTION TO QUALITY & SERVICE
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF EDAC INC.,AND
SHALL NOT BE REPRODUCED,OR COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
ACAD REFERENCE NO.
J.LEE
DRAWN:
CHECKED:
SCALE:
NTS
DRAWING NUMBER
342 Assembly
342 ENG MASTER
DATE: OCT. 06/09
DATE:
SHEET 1 OF 3
ISSUE
1
ISSUE NUMBER
0.120 3.05
0.645 16.38
0.645 16.38
0.245 6.22
0.295 7.49
0.095 2.41
0.255 6.48
.125 [3.18] to .185 [4.70]
Outside Tails
.045 [1.14] to .060 [1.52]
Between Tails
Between Tails
556 Contact Code
1
0.165 4.19
0.180 4.57
.125 [3.18] to .210 [5.33]
Outside Tails
555 Contact Code
ORIGINAL
0.385 9.78
0.200 5.08
0.060 1.52
558 Contact Code
0.150 3.81
Outside Tails
Between Tails
0.060 1.52
559 Contact Code
560 Contact Code
342 / 392 Series Card Edge Connector
Contact Bend Detail
EDAC INC
TORONTO, ONTARIO
CANADA
ACAD REFERENCE NO.
J.LEE
DRAWN:
CHECKED:
SCALE:
NTS
DRAWING NUMBER
342 Assembly
342 ENG MASTER
DATE: OCT. 06/09
DATE:
SHEET 2 OF 3
ISSUE
1
ISSUE NUMBER
ORIGINAL
1
.010 [0.25]
Radial Float
.156 [3.96] Dia
Through Holes
0.116 2.95 I.D.
Floating Eyelets
.128 [3.25] x
.146 [3.71] Slot
M3-0.5 Metric
Threaded Insert
#4-40 UNC
Threaded Insert
0.250 6.35 Dia.
0.135 3.43
.128 [3.25] Dia
Through Holes
0.005 0.13
0.348 8.84
Code x01
Code x02
Code x03
Code x04
Code x07
Code x08
Mounting Options
EDAC INC
TORONTO, ONTARIO
CANADA
Code x12
ACAD REFERENCE NO.
J.LEE
DRAWN:
CHECKED:
SCALE:
NTS
DRAWING NUMBER
342 Assembly
342 ENG MASTER
DATE: OCT. 06/09
DATE:
SHEET 3 OF 3
ISSUE
1
很抱歉,暂时无法提供与“392-116-524-207”相匹配的价格&库存,您可以联系我们找货
