2x
ISSUE NUMBER
THIS IS A C.A.D. GENERATED DRAWING
DO NOT MAKE MANUAL REVISIONS TO MASTER.
ORIGINAL
.156 3.96
6.600 167.64
6.760 171.7
7.075 179.71
.600 15.24
.250 6.35
A
A
SECTION A-A
7.335 186.31
345/395 SERIES CARD EDGE CONNECTOR
PART NUMBER: 395-130-560-578
1
.330 8.38 CARD SLOT
.160 4.06 POINT OF CONTACT
CARD SLOT ACCEPTS
.054" [1.37] TO .070"[1.78]
THICK PCB
Contact Dimensions:
560-Extender Board Bend (Code 523 Contacts)
See Sheet 2 for Contact Code 555, 556, 558, 559, 560 Dimensions
INSULATOR MATERIAL: THERMOPLASTIC PBT BLACK, UL 94V-0
CONTACT MATERIAL; COPPER TIN ALLOY
CONTACT PLATING: GOLD ON THE MATING AREA, TIN PLATING
ON THE CONTACT TAILS, NICKEL UNDERPLATE
EDAC INC
TORONTO, ONTARIO
CANADA
YOUR CONNECTION TO QUALITY & SERVICE
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF EDAC INC.,AND
SHALL NOT BE REPRODUCED,OR COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
ACAD REFERENCE NO.
345-ENG-MASTER
DRAWN: R.STA.MONICA
DATE:MAY.16/2017
CHECKED:
DATE:
SCALE:
1:1
DRAWING NUMBER
345-ENG-MASTER
SHEET 1
OF 2
ISSUE
1
Contact Description:
559-90 Degree Bend (Code 541 Contacts)
.107 2.72
ORIGINAL
.157 4
.125(3.18) to .210(5.33)
Outside Tails
Outside Tails
.045(1.14) to .060(1.52)
Between Tails
Between Tails
Contact Code 555
Contact Code 556
.060
.152 3.86
.060
.150
.200
.285 7.24
.635 16.13
1
.082 2.08
.232 5.89
.235 5.97
ISSUE NUMBER
.362 9.19
Outside Tails
.635 16.13
Between Tails
Contact Code 558
INSULATOR MATERIAL: THERMOPLASTIC POLYESTER, UL 94V-0
DAP MATERIAL AVAILABLE UPON REQUEST
CONTACT MATERIAL; COPPER ALLOY
Contact Code 559
Contact Code 560
CONTACT CODE 555,556,558,559,560 DIMENSIONS
EDAC INC
TORONTO, ONTARIO
CANADA
ACAD REFERENCE NO.
DRAWN: R.STA.MONICA
DATE:
CHECKED:
SCALE:
345-ENG-MASTER
DATE:MAY.16/2017
1:1
DRAWING NUMBER
345-ENG-MASTER
SHEET
2 OF 2
ISSUE
1
很抱歉,暂时无法提供与“395-130-560-578”相匹配的价格&库存,您可以联系我们找货
