396-043-540-612
396-043-540-612
    插件,P=3.18mm
396-043-540-612 数据手册
ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. .330 8.38 Slot Depth .160 4.06 Point of Contact A .560 14.22 6.185 150.37 157.1 5.920 • • • 1 5.500 139.7 5.660 143.76 .250 6.35 .600 15.24 .180 4.57 .370 9.4 .125 3.18 ORIGINAL A INSULATOR MATERIAL: THERMOPLASTIC POLYESTER, UL 94V-0 CONTACT MATERIAL; COPPER, NICKEL, TIN ALLOY CA-725 CONTACT PLATING: GOLD ON THE MATING AREA, TIN-LEAD ON THE CONTACT TAILS, NICKEL UNDERPLATE 346/396 SERIES CARD EDGE CONNECTOR PART NUMBER: 396-043-540-612 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SECTION A-A ACAD REFERENCE NO. DRAWN: J.LEE DATE: CHECKED: SCALE: 346-ENG-MASTER DATE: APR. 22/09 1:1 DRAWING NUMBER 346-ENG-MASTER SHEET 1 OF 2 ISSUE 1 Contact Description: 555-Extender Board Bend (Code 500 Contacts) .125(3.18) to .210(5.33) Outside Tails .125(3.18) to .210(5.33) Outside Tails .045(1.14) to .060(1.52) Between Tails .125(3.18) to .210(5.33) Outside Tails Contact Code 555 Contact Code 556 .060 1.52 .060 1.52 .260 6.6 .660 16.76 .660 16.76 INSULATOR MATERIAL: THERMOPLASTIC POLYESTER, UL 94V-0 CONTACT MATERIAL; COPPER, NICKEL, TIN ALLOY CA-725 CONTACT PLATING: GOLD ON THE MATING AREA, TIN-LEAD ON THE CONTACT TAILS, NICKEL UNDERPLATE .165 4.19 .150 3.81 .200 5.08 .210 5.33 1 .170 4.33 .245 6.22 • • • ORIGINAL .095 2.41 .120 3.05 Contact Code 558 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. .375 9.54 .125(3.18) to .210(5.33) Outside Tails .125(3.18) to .210(5.33) Outside Tails Contact Code 559 Contact Code 560 346/396 SERIES CARD EDGE CONNECTOR CONTACT CODE 555,556,558,559,560 DIMENSIONS EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. DRAWN: J.LEE DATE: CHECKED: SCALE: 346-ENG-MASTER DATE: APR. 22/09 1:1 DRAWING NUMBER 346-ENG-MASTER SHEET 2 OF 2 ISSUE 1
396-043-540-612
1. 物料型号:文档中提到的物料型号为“346/396系列卡边缘连接器”,具体型号为“396-043-540-612”。
2. 器件简介:文档描述了一种卡边缘连接器,具体为555-Extender板弯曲(代码500个接触点)。
3. 引脚分配:文档提供了不同接触代码(如555、556、558、559、560)的详细尺寸和引脚分配信息。
4. 参数特性:连接器具有以下材料特性: - 绝缘体材料:热塑性聚酯,UL 94V-0 - 接触材料:铜、镍、锡合金CA-725在接触尾端,镍底层 - 接触镀层:接触区域为金,接触尾端为锡铅,镍底层
5. 功能详解:文档中没有提供具体的功能详解,但可以推断该连接器主要用于电路板之间的连接,提供电气连接。
6. 应用信息:文档未明确提供应用信息,但根据连接器的描述,它可能用于电子设备中的信号或电源传输。
7. 封装信息:文档提供了详细的尺寸和规格信息,但没有明确提及封装类型的描述。
396-043-540-612 价格&库存
很抱歉,暂时无法提供与“396-043-540-612”相匹配的价格&库存,您可以联系我们找货
