338 SERIES
Card Edge Connector 0.156” (3.96mm) Pitch
Features:
0.156” (3.96mm) contact spacing x 0.200” (5.08mm) row spacing
Accepts 0.062” (1.57mm) nominal thickness P.C. board
Low profile insulator body, 0.473” (12.01mm)
Contact termination 0.045” (1.14mm) square wire wrap
Single or dual row configurations
Large variety of mounting options
Pre-assembled card guides available
Accepts between contact and in-contact polarizing keys
RoHS Compliant
Specifications:
Insulator Material
UL 94V-0 DAP(Diallyl Phthalate), Green Color
Contact Material
Copper Alloy
Contact Plating
Gold plating all over with Nickel underplating
Current Rating
5 amps
Contact Resistance
10 milliohms maximum
Dielectric Withstanding Voltage
1800 V AC rms at sea level between adjacent contacts
Insulation Resistance
5000 megaohms minimum
Operating Temperature
-65°C to +125°C
Insertion Force
16 oz (4.45 N) maximum per contact pair when tested with .070” (1.78mm) thick gauge
Withdrawal Force
1 oz (0.28 N) minimum per contact pair when tested with .054” (1.37mm) thick gauge
Example Part Number:
338-044-541-208
Series
Total Number of Contacts
Contact Code
Contact Rows
Mounting Options
Series:
338
Total Number of Contacts:
Contact Rows:
010, 015, 018, 022 or 028
Single Row
020, 030, 036, 044 or 056
Dual Row
Contact Code:
Tail Description:
Tail Size:
Tail Length “G”:
541
Wire Wrap
.045 Square (1.14 Square)
.730 (18.54)
Contact Rows:
Description:
1
Single Row
2
Dual Row
Mounting Options:
Description:
01
No Mounting Lug
02
Ø.128" (Ø3.25mm) Mounting Holes
03
Ø.116" (Ø2.95mm) I.D. Floating Eyelets
04
Ø.156" (Ø3.96mm) Mounting Holes
07
M3-0.5 Metric Threaded Inserts
08
#4-40 Unified Threaded Inserts
58
.468" (11.89mm) Offset Card Guides
68
.344 (8.74) Offset Card Guides
78
In-Line Card Guides
www.edac.net
Ordering Code Notes:
For details of the mounting options refer to page 3.
customerservice@edac.net
338 SERIES
Card Edge Connectors 0.156” (3.96mm) Pitch
IN-CONTACT
POLARIZING KEY
A
BETWEEN CONTACT
POLARIZING KEY
P/N 338-240-328
B
P/N 306-240-318
C
D
.343
(8.71)
.156 (3.96)
CARD SLOT ACCEPTS .054 (1.37)
TO .070 (1.78) THICK P.C. BOARD
.295 (7.49)
CARD SLOT
.473 (12.01)
.250 (6.35)
.200 (5.08)
POINT OF
CONTACT
G
.100 (2.54)
BACK UP SPRINGS
LOCATED IN POSITIONS
B, E, J, M, R, U, X,
AA & AD
NUMBERED SIDE
OF CONNECTOR
DUAL
ROW
E
.200 (5.08)
1
2
3
4
5
6
7
8
9 10
A
B
C
D
E
F
H
J
K
SINGLE
ROW
( D MINUS .012 (0.30)) +.000
-.015 (0.38)
L
.125 (3.18)
.315 (8.00)
.380
(9.65)
.136 (3.45) DIA
REF
.125 (3.18)
.055 (1.40)
CUT OUT FOR IN-CONTACT CUT OUT FOR
BETWEEN CONTACT
POLARIZING KEY
POLARIZING KEY
B
RECOMMENDED DAUGHTER BOARD
CONNECTOR MOUNTING PATTERN
PANEL MOUNT CUT OUT
NUMBER OF CONTACTS
"A"
"B"
"C"
"D"
"E"
Single
Double
Inch
mm
Inch
mm
Inch
mm
Inch
mm
Inch
mm
10
62.64
2.156
54.76
1.870
47.50
1.724
43.79
1.404
35.66
15
30
3.246
82.45
2.936
74.57
2.650
67.31
2.504
63.60
2.184
55.47
18
36
3.714
94.34
3.404
86.46
3.118
79.20
2.972
75.49
2.652
67.36
22
44
4.338
110.19
4.028
102.31
3.742
95.05
3.596
91.34
3.276
83.21
28
56
5.274
133.96
4.964
126.09
4.678
118.82
4.532
115.11
4.212
106.98
www.edac.net
338 SERIES
.250 (6.35) DIA
A
DIA THROUGH
HOLES
CODE x07
M3-0.5 METRIC
CODE x08
#4-40 UNC
THREADED INSERTS
.010 (0.25) RADIAL
FLOAT
0.328(8.33)
CONNECTOR
DIMENSION
CONNECTOR
B
DIMENSION
MOUNTING OPTION
CODES x02 AND xO4
(THROUGH MOUNTING HOLES)
CONNECTOR
C
DIMENSION
MOUNTING OPTION
CODE x01
(NO MOUNTING LUGS)
.005 (0.51) VERTICAL
CONNECTOR
FLOAT
B
DIMENSION
.116 (2.95) I.D.
FLOATING EYELETS
B
MOUNTING OPTION
CODES x07 & xO8
(THREADED INSERTS)
MOUNTING OPTION
CODE x03
(FLOATING EYLETS)
"A"
0.090(2.20)
"C"
CARD GUIDE
CARD GUIDE
1.550
(39.37)
"B"
CONNECTOR
CONNECTOR
.250 (6.35)
.250 (6.35)
#4-40 UNC
THREADED
INSERT
CONNECTOR
"B"
DIMENSION
"D"
#4-40 UNC
THREADED
INSERT
CONNECTOR "B"
DIMENSION
MOUNTING OPTION
CODE x78
(IN-LINE CARD GUIDE)
MOUNTING OPTION
CODES x58 & x68
(OFFSET CARD GUIDES)
CODE X02 AND X04- THROUGH MTG. HOLES CODES X58 AND X68- OFFSET CARD GUIDES
"A" DIA.
CODE X02
CODE X04
0.128(3.25)
0.156(3.96)
CODE X58
CODE X68
"A"
0.468(11.89)
0.344(8.74)
"B"
2.755(69.98)
2.505(63.63)
CODE X08
"C"
0.125(3.18)
0.060(1.52)
#4-40 UNC
"D"
0.423(10.74)
0.242(6.15)
CODE X07 AND X08- THREADED INSERTS
CODE X07
INSERT
www.edac.net
M3-0.5(METRIC)
很抱歉,暂时无法提供与“338-020-541-268”相匹配的价格&库存,您可以联系我们找货
