FH*.0B.304.CLAD42
FH*.0B.304.CLAD42
    LEMO(雷莫)
    LB90 KEYG 4C CHR 4.2MM D
FH*.0B.304.CLAD42 数据手册
UNIPOLE & MULTIPOLE CONNECTORS No reproduction or use without express permission of editorial or pictorial content, in any manner. LEMO reserve the right at all times to modify and improve specifications without any notification. Printed in Switzerland, 2010 © LEMO SA Pdf updated, October, 20th 2011 ® ® LEMO unipole and multipole connectors This catalogue gives the complete description of LEMO unipole and multipole type connectors. The LEMO manufacturing programme has been extended to almost 40 series divided into 7 product families with specific mating and environmental characteristics. Each series includes a wide variety of plug, socket, coupler and bridge plug models, available in contact configurations adapted to all round cables, including up to 106 conductors, and a maximum diameter of 30 mm. Watertight and vacuumtight models are also available. Since LEMO connectors are perfectly screened and designed to guarantee very low resistance to shell electrical continuity, they are particularly adapted to applications where electromagnetic compatibility (EMC) is important. Table of Contents 3 steps to select the right connector ................................................................................................................................................................................3 B Series (indoor, keyed) Part Numbering system .........................................................................................................................................................................................11 Metal Housing models ............................................................................................................................................................................................12 Elbow socket models..............................................................................................................................................................................................22 Plastic housing models...........................................................................................................................................................................................24 Watertight and vacuumtight models .......................................................................................................................................................................26 Bridge models ........................................................................................................................................................................................................29 Threaded-latching models ......................................................................................................................................................................................30 Alignment Key and Polarized Keying System ........................................................................................................................................................31 K Series (outdoor, keyed) Part Numbering system ..........................................................................................................................................................................................33 Metal Housing models ............................................................................................................................................................................................34 Watertight and vacuumtight models .......................................................................................................................................................................41 Alignment Key and Polarized Keying System ........................................................................................................................................................43 B and K Series Insert configuration, Housings, Insulators, Contacts .................................................................................................................................45 S Series (indoor, stepped insert) Part Numbering system .........................................................................................................................................................................................57 Metal Housing models ............................................................................................................................................................................................58 Elbow socket models..............................................................................................................................................................................................68 Plastic housing models...........................................................................................................................................................................................70 E Series (outdoor, stepped insert) Part Numbering system ..........................................................................................................................................................................................75 Metal Housing models ............................................................................................................................................................................................76 Watertight and vacuumtight models .......................................................................................................................................................................82 L Series (outdoor, stepped insert) Part Numbering system ..........................................................................................................................................................................................85 Metal Housing models ............................................................................................................................................................................................86 Vacuumtight models ...............................................................................................................................................................................................89 Alignment Key and Polarized Keying System ........................................................................................................................................................90 S, E and L Series Insert configuration, Housings, Insulators, Contacts .................................................................................................................................91 2G Series (indoor, keyed)...............................................................................................................................................................................................110 2C Series (indoor, stepped insert).................................................................................................................................................................................116 1D Series (indoor, 4 concentric contacts) ....................................................................................................................................................................124 Spare parts ......................................................................................................................................................................................................................130 Accessories .....................................................................................................................................................................................................................136 Tooling .............................................................................................................................................................................................................................146 Panel cut-outs .................................................................................................................................................................................................................152 PCB drilling pattern ........................................................................................................................................................................................................154 Cable assembly (B, K, S and E series) ...........................................................................................................................................................................161 Technical characteristics ...............................................................................................................................................................................................171 www.lemo.com 1 ® ® Precision modular connectors to suit your application Since it’s creation in Switzerland in 1946 the LEMO Group has been recognized as a global leader of circular Push-Pull connectors and connector solutions. Today LEMO and its affiliated companies, REDEL and COELVER, are active in more than 80 countries with the help of over 40 subsidiaries and distributors. Over 50’000 connectors The modular design of the LEMO range provides over 50’000 connectors from miniature ø 3 mm to ø 50 mm, capable of handling cable diameters up to 30 mm and for up to 106 contacts. This vast portfolio enables you to select the ideal connector configuration to suit almost any specific requirement in most markets, including medical devices, test and measurement instruments, machinery, audio video broadcast, telecommunications and military. LEMO’s Push-Pull Self-Latching Connection System This self-latching system is renowned worldwide for its easy and quick mating and unmating features. It provides absolute security against vibration, shock or pull on the cable, and facilitates operation in a very limited space. The LEMO self-latching system allows the connector to be mated by simply pushing the plug axially into the socket. Once firmly latched, connection cannot be broken by pulling on the cable or any other component part other than the outer release sleeve. When required, the connector is disengaged by a single axial pull on the outer release sleeve. This first disengages the latches and then withdraws the plug from the socket. UL Recognition LEMO connectors are recognized by the Underwriters Laboratories (UL). The approval of the complete system (LEMO connector, cable and your equipment) will be easier because LEMO connectors are approved. CE marking CE marking means that the appliance or equipment bearing it complies with the protection requirements of one or several European safety directives. CE marking applies to complete products or equipment, but not to electromechanical components, such as connectors. RoHS LEMO connector specifications exceed the requirements of the RoHS directives (2002/95/EC) of the European Parliament and the latest amendments. This directive specifies the restrictions of the use of hazardous substances in electrical and electronic equipment marketed in Europe. LEMO guarantees that its connectors are free of mercury, cadmium, lead, hexavalent chromium and polybromide biphenyl (PBB), polybromide diphenyl ether (PBDE), or DecaBDE. 2 www.lemo.com ® ® 3 steps to select the right connector ● Step 1: Select connector series Select the appropriate LEMO connector series according to the environmental parameters that will affect your device or cable such as indoor, outdoor, temperature range, ingress protection of the mated connector and of your device. Use the table shown on page 4. . Part number coding . . B, K, S, E, L, G, C or D ● Step 2: Select connector size Use the section (mm2) or the AWG of your cable wire to select the optimal contact diameter (values vary between solder, crimp or print contact), see page 7. Use this optimal contact diameter to determine the right connector size as well as the insert configuration, see page 6. . Part number coding . . 0, 1, 2, 3, 4, 5 or 6 ● Step 3: Complete the part number Now that you know the series, as well as the insulator configuration, complete the part numbering system with the help of the following table. . Part number coding B Series (indoor, keyed) K Series (outdoor, keyed) S Series (indoor, stepped insert) E Series (outdoor, stepped insert) L Series (outdoor, keyed, stepped insert) G Series (indoor, keyed) C Series (indoor, stepped insert) D Series (indoor, 4 concentric contacts) . . Model Series Insert configuration Housing material Insulator material Contact Collet Variant 12 34 58 76 86 111 117 125 12 34 58 76 86 111 117 125 45 45 91 91 92 112 120 127 50 50 99 99 99 112 120 127 50 50 99 99 99 110 116 124 50 50 99 99 99 113 120 127 52 53 102 105 106 113 121 127 54 54 107 107 107 113 121 128 Note: Figures in the above table refer to the catalogue pages. www.lemo.com 3 ® ® Step 1: Select Connector Series LEMO unipole and multipole connectors The standard keyed Series (B, 00, G) The characteristic feature of these connector series is a keying system which allows higher contact density and prevents all errors in alignment. The various keying alternatives prevent unwanted cross mating of otherwise similar connectors. It is also possible to use crimp contacts to reduce cable assembly time. These connector series, include the 0B to 5B range as well as the 00 multipole and 2G (shortened version of the 2B series), some vacuumtight models are also available. The watertight keyed Series (K, L) These series are watertight when mated and assembled to an appropriate cable. They include the 0K to 5K series, available in the same types as the 0B to 5B series, and the 0L to 2L series with keying and hermaphroditic insulator. The standard Series (S, 00, C, D) The characteristic feature of these connector series is the hermaphroditic insulator in the multipole version. They include principally the 0S and 6S series, as well as the 00 unipole series, the 2C (shortened version) and the 1D quadrax type (with 4 concentric contacts). The watertight Series (E) These series are watertight when mated and assembled to an appropriate cable. They include the 0E to 6E series and are available in the same types as the S series. 00 multipole B K 00 unipole S indoor outdoor or harsh env. indoor outdoor or harsh environment indoor Ingress 1) protection IP50 IP66 to IP68 IP50 IP66 to IP68 IP50 Ingress 2) protection IP50 to IP68 vacuumtight IP66 to IP68 vacuumtight IP50 to IP68 vacuumtight IP66 to IP68 vacuumtight Temperature range - 55 to 250°C - 55 to 200°C - 55 to 250°C - 55 to 200°C Series Environment L G C IP50 IP50 to IP68 vacuumtight - 55 to 250°C D IP50 - 40 to 120°C Push-Pull self-latching Latching Shell sizes E 7 metal and 4 plastic 6 metal 7 metal and 5 plastic 6 metal 3 metal 4 metal 1 metal Multipole Multipole hermaphroditic Quadrax Insulator type Multipole Unipole or multipole hermaphroditic Multipole hermaphroditic Contact type Solder, crimp or print Solder or print Solder, crimp or print Stepped insert Stepped insert 1 keyway Stepped insert 4 concentric contacts 84 to 90 109 to 115 116 to 122 123 to 128 Features Page 13 keyways 9 keyways 9 to 31 32 to 44 55 to 73 74 to 83 Solder or print Solder Note: 1) Mated connector. See ingress protection code page 5. 2) Your device. For selection of connectors for watertight and vacuumtight devices, see page 5. 4 www.lemo.com ® ® Definition of Ingress Protection (IP code) IEC 60529 outlines an international classification system for the sealing effectiveness of enclosures of electrical equipment against the intrusion into the equipment of foreign bodies (i.e. tools, dust, fingers) and moisture. This classification system utilizes the letters «IP» (Ingress Protection) followed by two digits. Example: IP 50 = IP Degrees of protection - First digit Degrees of protection - Second digit The first digit of the IP code indicates the degree to which persons are protected against contact with moving parts and the degree that equipment is protected against solid foreign bodies intruding into an enclosure. The second digit indicates the degree of protection of the equipment inside the enclosure against the harmful entry of various forms of moisture (e.g. dripping, spraying, submersion, etc.) First digit description Code 5 0 IP letter code 1st digit 2nd digit Second digit description Code 0 No special protection 0 No special protection 1 Protection from a large part of the body such as hand or from solid objects greater than 50 mm in diameter 1 Protection from vertically dripping water 2 Protection against objects not greater than 80 mm in length and 12 mm in diameter 2 Protection from dripping water when tilted up to 15° 3 Protection from entry by tools, wires, etc., with a diameter or thickness greater than 2.5 mm 3 Protection from sprayed water 4 Protection from entry by solid objects with a diameter or thickness greater than 1.0 mm 4 Protection from splashed water 5 Protection from the amount of dust that would interfere with the operation of the equipment 5 Protection from water projected from a nozzle 6 Dust-tight 6 Protection against heavy seas, or powerful jets of water 7 – 7 Protection against temporary immersion 8 – 8 Protection against complete continuous submersion in water Selection of connectors for watertight or vacuumtight devices LEMO B and S series are rated IP50 only when mated. LEMO E, K and L series are rated IP66 (and over) only when mated. If a device must be watertight or vacuumtight when the connectors are unmated, it is important to select a watertight or vacuumtight socket. You can consider the following two situations: A) Figure 1 shows a typical outdoor device. To ensure this device retains IP66 or above when connectors are unmated, it is important to choose a watertight socket from B, S, E, K or L series. Fig. 1 your device B) Figure 2 shows a device which is subjected to pressure difference such as a near vacuum or pressurized gas and must exhibit no leakage. To ensure the device maintains its sealing, the socket is additionally tested for helium leakage (according MIL 1344A). Fig. 2 your device epoxy resin seal FGG plug K series EGG socket K series FGG plug B series HGG socket B series Check temperature range (see section on pages 26, 41, 72, 82 and 89). www.lemo.com 5 ® ® Step 2: Select Connector Size Select the right connector size and insert configuration To be able to select the right connector size (0 to 6), it is important to define the contact diameter (ø A). Find out the available contact diameter (ø A) of the LEMO connector depending on the number of contacts required and depending on the rating required (see pages 45 to 49 and 91 to 98). The following table shows the contact diameter (ø A), or the solder pot diameter (ø C) for the 1D series. 2C 1D (ø C) 2G 4.0 6.0 6S-6E 4.0 6.0 5S-5E 4S-4E 2S-2E-2L 1) 1S-1E-1L 1) 0S-0E-0L 1) 00 5B-5K 4B-4K 3S-3E Unipole Multipole 3B-3K 302 303 304 305 306 307 308 309 310 312 313 314 316 318 319 320 322 324 326 330 332 336 340 344 348 350 354 360 362 364 372 106 2B-2K 2 3 4 5 6 7 8 9 10 12 13 14 16 18 19 20 22 24 26 30 32 36 40 44 48 50 54 60 62 64 72 106 1B-1K 113 116 120 130 140 160 112 0B-0K Insert configuration 1 1 1 1 1 1 1 00 Number of contacts Series 1.6 1.3 1.3 0.6 1.3 1.6 2.0 3.0 3.0 4.0 12.0 0.5 0.5 0.5 0.9 0.9 0.7 0.7 0.5 0.5 1.3 1.3 0.9 0.9 0.7 0.7 0.7 2.0 1.6 1.3 1.3 1.3 1.3 0.9 0.5 0.9 0.7 0.5 0.5 0.5 0.7 0.7 0.7 0.7 0.5 3.0 2.0 2.0 1.6 1.6 1.6 1.3 1.3/2.0 1.3 0.9 0.9 0.9 0.9 0.7 0.7 0.7 0.7 0.7 6.0 3.0 4.0 2.0 2.0 1.6 1.3 0.9 0.9 3.0 2.0 2.0 0.9 0.7 0.7 1.3 0.9 0.9 0.9/0.7 0.7 1.6 2.0 4.0 1.3 2.0 3.0 1.3 2.0 3.0 1.3 2.0/1.3 3.0/2.0 1.3 1.3 2.0 1.3/0.9 1.3 2.0/1.3 0.9 1.3 1.3 1.3 0.9 1.3 1.3 0.9 1.3 0.9 1.3 0.9 1.3 0.9 0.9 0.9 0.9 1.6 0.9 0.9 1.3 0.7 1.3 0.7 1.3 0.9 0.9 0.9 0.9 0.9 6.0 6.0/4.0 4.0 4.0/3.0 3.0 1.3 3.0 0.7 2.0 2.0 4.0/5.0 3.0/2.0 2.0 3.0/1.6 3.0 4.0 1.6 3.0/1.6 1.6 1.3 0.5 0.9 6.0 8.0 1.3 1.3 1.3 1.3 0.7 0.7 0.7 0.7 3.0 3.0 2.0 2.0 2.0 2) 2.0 2.0 1.6 1.6 1.3 1.3 0.9 Note: 1) L series not available in unipole version. 2) 2.0 is for 6S series, for 6E the values are 1.3 and 5.0. 6 www.lemo.com ® ® Verify the fitting to your wire Verify if the selected contact diameter (ø A) of the LEMO connector fits to your cable wire diameter (AWG number or max. available section). Contact Contact type øA (mm) 0.52) Solder øA øC 0.55) Crimp fig. 1 øA øC øA øC 0.7 0.9 1.3 øC øA 1.6 fig. 2 0.402) 0.5 0.45 0.73) 0.603) 0.7 0.80 0.9 0.80 1.3 1.00 1.6 1.40 2.0 1.80 3.0 2.70 4.0 3.70 5.0 5.20 6.0 5.20 8.0 7.00 12.0 11.50 øC øA øC Form (mm) per fig. øC øA 2.0 3.0 4.0 0.45 0.80 0.45 1.10 0.80 0.45 1.40 1.10 0.80 1.90 1.40 2.40 1.90 2.90 4.00 Solid AWG Section max. max. (mm2) Conductor Stranded AWG Section (mm2) min. max. min. max. Fr 1) (N) Note ● – – – – – – – – – – – – – – 28 28 24 22 22 20 16 14 10 10 – – – – 0.09 0.09 0.25 0.34 0.34 0.50 1.00 1.50 4.00 6.00 – – – – – – – – – – – – – – – – – – 30 28 26 224) 224) 204) 18 16 12 10 8 8 4 0 – – – – – – – – – – – – – – 0.05 0.09 0.14 0.34 0.34 0.50 1.00 1.50 4.00 6.00 10.00 10.00 21.00 50.00 – – – – – – – – – – – – – – 1 1 2 1 2 2 1 2 2 1 2 1 2 1 1 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 32 26 32 24 26 32 20 24 26 18 22 16 18 14 12 28 224) 28 20 224) 28 18 20 224) 144) 18 124) 14 104) 10 0.035 0.140 0.035 0.250 0.140 0.035 0.500 0.250 0.140 1.000 0.340 1.500 1.000 2.500 4.000 0.09 0.34 0.09 0.50 0.34 0.09 1.00 0.50 0.34 1.50 1.00 2.50 1.50 4.00 6.00 12 22 30 40 50 65 75 90 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Print L øC øA øA øC L dimensions and C are detailed in the section on PCB drilling pattern. See page 156 and 159. ● L dimensions and C are detailed in the section on PCB drilling pattern. See page 157 and 160. ● L Print (elbow) øA L øC Note: 1) contact retention force in the insulator (according to IEC 60512-8 test 15 a). 2) for 00 multipole series. 3) for S, E, 2C, 2G and 1D series. 4) for a given AWG, the diameter of some stranded conductor designs is larger than the solder cup diameter. Make sure that the maximum conductor diameter is smaller than ø C. 5) for 00 multipole series or for 0B and 1B series with male contacts. www.lemo.com 7 ® ® Verify the fitting to your cable Verify if the selected connector size fits to your cable diameter. Cable diameter range (mm) Series Collet for fitting a bend relief Collet min. max. min. max. 001) 0B 1B 2B 3B 4B 5B 1.1 1.5 2.2 1.5 4.1 5.1 9.6 3.4 5.5 7.5 9.7 11.7 16.0 25.0 1.1 1.5 2.2 1.5 4.1 5.1 9.6 3.4 5.0 7.0 9.0 11.0 15.0 15.5 0K 1K 2K 3K 4K 5K 1.0 1.3 1.3 2.6 4.6 9.6 5.0 8.53) 10.53) 15.03) 23.53) 23.5 1.0 1.3 1.3 2.6 4.6 – 5.0 8.5 10.5 15.0 15.0 – Cable diameter range (mm) Series Collet for fitting a bend relief Collet min. max. min. max. 002) 0S 1S 2S 3S 4S 5S 6S 1.1 1.3 1.3 1.3 2.5 4.1 6.1 11.1 4.1 6.7 8.5 10.5 13.0 22.0 30.0 30.0 1.1 1.3 1.3 1.3 2.5 4.1 – – 4.1 6.1 8.0 10.0 13.0 13.0 – – 0E 1E 2E 3E 4E 5E 6E 1.0 1.3 1.3 2.6 4.6 9.6 13.0 5.0 8.53) 10.53) 15.03) 23.53) 23.5 30.0 1.0 1.3 1.3 2.6 4.6 – – 5.0 8.5 10.5 15.0 15.0 – – 0L 1L 2L 1.0 1.3 1.3 5.0 8.53) 10.53) 1.0 1.3 1.3 5.0 8.5 10.5 Cable diameter range (mm) Series Collet for fitting a bend relief Collet min. max. min. max. 2C 2G 2.2 4.5 8.1 7.9 2.2 4.5 8.1 7.9 1D 3.1 7.5 3.1 7.0 Note: 1) for multipole only. 2) for unipole only. 3) for these series the maximum cable diameter require models with oversized cable collet (type K). 8 www.lemo.com K SERIES (watertight) B SERIES ® ® B Series B series connectors provide the following main features: – security of the Push-Pull self-latching system – solder, crimp or print contacts (straight or elbow) – multiple key options to avoid cross mating of similar connectors – 360° screening for full EMC shielding. – multipole types 2 to 64 contacts – high packing density for space savings – keying system («G» key standard) for connector alignment Metal housing models (page 12) Fixed plugs Straight plugs Fixed sockets Free sockets FWG FGG EGG ECG PHG FAG FGG ENG ECG PHG JGG EKG EZG PNG Elbow plugs Fixed sockets FHG FFG ESG EYG PKG FNG FMG EHG XPF PFG Fixed coupler FEG EJG FKG PEG RGG FDG EEG Elbow socket models (page 22) FIG EFG Elbow sockets ECG EPG Plastic housing models (page 24) Bridge models (page 29) Straight plugs Fixed sockets FGG XBG, EXG FGG Plug with two parallel sockets Bridge plugs ENG FTG FGY FGY Watertight or vacuumtight models (page 26) Fixed plug Fixed sockets HGG Threaded-latching models (page 30) Fixed coupler HHG CFF, CRG ENY Straight plugs FVG HEG Fixed socket ESG Elbow socket YHG SGG HNG 10 HCG HMG FVB XRB www.lemo.com ® ® Part Numbering System Plug FG G . 1B . 306 . C L A D 62 Free socket PH G . 1B . 306 . C L L D 62 Z Variant: (page 54) Cable ø: (page 52) Collet type: (page 52) Fixed socket EG G . 1B . 306 . C Y M Coupler RJ G . 1B . 306 . C L A Model: (page 12) Variant: (page 54) Alignment key: (page 31) Contact: (page 50) Series: (page 12) Insulator: (page 50) Insert configuration: (page 45) Housing: (page 50) Part Number Example Straight plug with cable collet: FGG.1B.306.CLAD62 = straight plug with key (G) and cable collet, 1B series, multipole type with 6 contacts, outer shell in chrome-plated brass, PEEK insulator, male solder contacts, D type collet for 6.0 mm diameter cable. Free socket: PHG.1B.306.CLLD62Z = free socket with key (G) and cable collet, 1B series, multipole type with 6 contacts, outer shell in chrome-plated brass, PEEK insulator, female solder contacts, D type collet for 6.0 mm diameter cable and nut for fitting a bend relief. Fixed socket: EGG.1B.306.CYM = fixed socket, nut fixing, with key (G), 1B series, multipole type with 6 contacts, outer shell in chromeplated brass, PEEK extended insulator, female crimp contacts. Fixed coupler: RJG.1B.306.CLA = straight fixed coupler with keys (J) at the flange end and key (G) at the other end, 1B series, multipole type with 6 contacts, outer shell in chrome-plated brass, PEEK insulator, male-female contacts. Part Section Showing Internal Components Straight plug Fixed socket 7 1 2 3 4 5 6 7 outer shell earthing crown retaining ring hexagonal nut locking washer insulator female contact www.lemo.com 6 2 3 4 5 1 1 6 5 4 2 7 3 1 2 3 4 5 6 7 outer shell latch sleeve collet nut split insert carrier insulator male contact collet 11 ® ® Metal housing models Technical Characteristics Electrical Mechanical and Climatical Characteristics Value Endurance Humidity Temperature range Resistance to vibration Shock resistance Salt spray corrosion test Protection index (mated) Climatical category Standard > 5000 cycles IEC 60512-5 test 9a up to 95% at 60° C - 55° C, +250° C 10-2000 Hz, 15 g IEC 60512-4 test 6d 100 g, 6 ms IEC 60512-4 test 6c > 144h IEC 60512-6 test 11f IP50 IEC 60529 55/175/21 IEC 60068-1 Characteristics Value at 10 MHz at 1 GHz Shielding efficiency Standard > 75 dB > 40 dB IEC 60169-1-3 IEC 60169-1-3 Note: the various tests have been carried out with FGG and EGG connector pairs, with chrome-plated brass shell and PEEK insulator. Detailed electrical characteristics, as well as materials and treatment are presented in the chapter Technical Characteristics on page 171. FGG Straight plug, key (G) or keys (A…M and R), cable collet Reference ~L øA ~M S2 Model Series FGG FGG FGG FGG FGG FGG FGG 001) 0B 1B 2B 3B 4B 5B Dimensions (mm) A L 6.4 28.5 9.5 36.0 12.0 43.0 15.0 50.0 18.0 58.0 25.0 75.0 35.0 103.0 M S1 S2 20.5 26.0 32.0 38.0 43.0 57.0 78.0 5.5 8.0 10.0 13.0 15.0 21.0 31.0 5 7 9 12 14 20 30 S1 M1 Cable assembly (page 161) Note: 1) the surface design of the 00 series is different. FGG Straight plug, key (G) or keys (A…M), cable collet and nut for fitting a bend relief 2) Reference ~L øA ~M S2 Dimensions (mm) Model Series A L M S1 S2 FGG FGG FGG FGG FGG FGG 001) 6.4 9.5 12.0 15.0 18.0 25.0 28.7 35.0 42.0 49.0 56.5 71.0 20.7 25.0 31.0 37.0 41.5 53.0 5.5 8.0 10.0 13.0 15.0 21.0 6 7 9 12 15 20 0B 1B 2B 3B 4B M1 Cable assembly (page 161) Note: 1) the surface design of the 00 series is different. 2) to order, add a «Z» at the end of the reference. S1 The bend relief must be ordered separately (see page 141). JGG Straight plug, short version, key (G), cable collet Reference Dimensions (mm) ~L Model Series A JGG 0B 9.5 L M S1 S2 8.0 7 øA ~M S2 12 32.0 22.0 M4 Cable assembly (page 161) S1 www.lemo.com ® ® FFG Straight plug, non-latching, key (G) or keys (A…M), cable collet Reference ~L øA ~M S2 Dimensions (mm) Model Series A L M S1 S2 FFG FFG FFG FFG FFG 0B 1B 2B 3B 4B 9.5 12.0 15.0 18.0 25.0 36 43 50 58 75 26 32 38 43 57 8 10 13 15 21 7 9 12 14 20 M1 Cable assembly (page 161) S1 FNG Straight plug, key (G) or keys (A…M and R), cable collet and lanyard release Reference ~L Model Series A FNG FNG FNG FNG FNG FNG 0B 1B 2B 3B 4B 5B 9.5 12.0 15.0 18.0 25.0 35.0 B L 15.5 36.0 18.0 43.0 21.0 49.0 25.0 58.0 32.0 75.0 42.0 103.0 M N S1 S2 26.0 32.0 37.0 43.0 57.0 78.0 140 140 160 190 230 300 8 10 13 15 21 31 7 9 12 14 20 30 B N øA ~M Dimensions (mm) M1 Cable assembly (page 161) Note: cable material: stainless steel with Polyamide sheath. S2 S1 FEG Straight plug, key (G) or keys (A…L), cable collet, front seal and nut for fitting a bend relief 1) (IP 54 protection index when mated) Reference ~L øA ~M S2 Dimensions (mm) Model Series A L M S1 S2 FEG FEG FEG FEG 0B 1B 2B 3B 11.0 13.5 16.5 19.0 35.0 42.0 48.0 56.5 25.0 33.0 36.0 41.5 8 10 13 15 7 9 12 15 M1 Cable assembly (page 161) Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see page 141). S1 FDG Straight plug, long version, key (G) or keys (A…L), cable collet Reference ~L øA ~M S2 www.lemo.com Dimensions (mm) Model Series A L M S1 S2 FDG FDG 1B 2B 12 15 68 79 57 67 10 13 9 12 M2 Cable assembly (page 162) S1 13 ® ® FIG Straight plug for remote handling, key (G) or keys (A…L and R), special alignment mark, knurled handling surface, cable collet Reference Dimensions (mm) Model Series A L M N S1 S2 S3 FIG FIG FIG FIG 2B 3B 4B 5B 20 22 30 40 49 58 75 103 37 43 57 78 17.5 21.5 28.5 41.0 13 15 21 31 12 14 20 30 15 18 25 35 ~L N øA ~M S2 S1 M1 Cable assembly (page 161) S3 FWG Fixed plug, nut fixing, key (G) or keys (A…L) L maxi øA M e øB Dimensions (mm) Reference N S3 Model Series A B e E L M N1) FWG FWG FWG FWG 0B 1B 2B 3B 14.0 18.0 19.5 25.0 12.4 15.8 19.2 25.0 M9x0.6 M12x1.0 M15x1.0 M18x1.0 1.8 2.9 4.1 4.2 22.5 24.9 28.6 32.1 14.5 17.0 18.0 23.0 19.5 24.8 27.3 31.5 S1 S3 8.2 10.5 13.5 16.5 11 14 17 22 S1 E maxi P9 Panel cut-out (page 152) Note: 1) maximum length with crimp contacts FAG Fixed plug, non-latching, nut fixing, key (G) or keys (A…M and R) Reference L maxi Dimensions (mm) Model Series A B e E L M N1) FAG FAG FAG FAG FAG FAG FAG 00 0B 1B 2B 3B 4B 5B 8 10 14 18 22 29 40 10.2 12.4 15.8 19.2 25.0 34.0 40.0 M7x0.5 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M25x1.0 M35x1.0 2.9 4.2 5.4 6.0 5.8 6.8 6.8 18.1 20.8 25.2 28.7 32.1 37.1 47.1 9.0 11.5 12.5 13.8 17.0 20.5 28.0 15.0 18.9 21.6 23.9 30.2 34.7 42.8 S1 S3 N øA M e øB S3 E maxi S1 6.3 8.2 10.5 13.5 16.5 23.5 33.5 9 11 14 17 22 30 – P1 Panel cut-out (page 152) Note: 1) maximum length with crimp contacts. The 5B series is delivered without locking washer or tapered washer and with a round nut. FHG Elbow (90°) plug, key (G) or keys (A…M and R), cable collet L S1 Reference ~H øA M S3 S2 D Model Series FHG FHG FHG FHG FHG FHG FHG 001) 0B 1B 2B 3B 4B 5B Dimensions (mm) A D H L 7.7 5.2 18.0 24.5 11.0 6.5 26.0 30.0 13.5 8.0 30.5 36.0 16.5 9.0 34.0 41.5 19.0 10.0 37.0 50.0 26.0 15.0 52.0 67.0 36.0 21.0 74.0 90.0 M S1 S2 S3 16.5 21.6 25.0 29.5 35.0 49.0 65.0 7 10 11 14 17 22 32 5 7 9 12 14 20 30 5.5 8.0 10.0 13.0 15.0 21.0 31.0 M3 Cable assembly (page 161) Note: 1) the surface design of the 00 series is different. 14 www.lemo.com ® ® FMG Elbow (90°) plug, key (G) or keys (A…M), cable collet and lanyard release, long key 1) L S1 øA M ~H Reference S3 B N S2 Dimensions (mm) Model Series A B H FMG FMG 0B 3B 11 19 17 26 26 31.6 21.6 140 39 50.0 35.0 190 L M N S1 S2 S3 10 17 7 14 8 15 M3 Cable assembly (page 161) Note: 1) long key: only in 0B series and with key (G). Cable material: stainless steel with Polyamide sheath. FKG Elbow (90°) plug for remote handling, key (G) or keys (A…L), special alignment mark, knurled handling surface, cable collet L S1 M ~H Reference S4 S3 Model Series S2 FKG FKG FKG 3B 4B 5B øA N Dimensions (mm) A H L M N S1 S2 S3 S4 25 37.0 50.0 35.0 21.0 17 32 52.0 67.0 49.0 28.5 22 46 74.2 89.5 64.5 40.0 32 14 20 30 15 21 31 21 26 38 M3 Cable assembly (page 161) Note: dimension D is the same as for the FHG model. EGG Fixed socket, nut fixing, key (G) or keys (A…M and R) Dimensions (mm) Reference L maxi Model Series A B e E L M EGG EGG EGG EGG EGG EGG EGG 00 0B 1B 2B 3B 4B 5B 8 10 14 18 22 28 40 10.2 12.4 15.8 19.2 25.0 34.0 40.0 M7x0.5 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M25x1.0 M35x1.0 6.0 7.0 7.5 8.5 11.5 12.0 11.0 15.5 20.7 23.0 26.7 30.7 35.7 43.5 1.0 1.2 1.5 1.8 2.0 2.5 3.0 N1) S1 S3 N M øA e øB S3 E maxi S1 13.7 19.1 21.1 24.6 28.1 34.1 39.6 6.3 8.2 10.5 13.5 16.5 23.5 33.5 9 11 14 17 22 30 – P1 Panel cut-out (page 152) Note: 1) maximum length with crimp contacts. The 5B series is delivered with a tapered washer and a round nut. ENG Fixed socket with earthing tag, nut fixing, key (G) or keys (A…M) L maxi Reference N M øA e øB S3 E maxi Dimensions (mm) Model Series A B e E L M ENG ENG ENG ENG ENG 0B 1B2) 2B 3B 4B 10 14 18 22 28 12.4 15.8 19.2 25.0 34.0 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M25x1.0 7.0 7.5 8.5 11.5 12.0 20.7 23.0 26.7 30.7 35.7 1.2 1.5 1.8 2.0 2.5 N1) S1 19.1 21.1 24.6 28.1 34.1 8.2 10.5 13.5 16.5 23.5 S3 11 14 17 22 30 S1 P1 Panel cut-out (page 152) Note: www.lemo.com 1) 2) maximum length with crimp contacts. for the 1B series the earthing tag is on the same side of the key. 15 ® ® EKG Fixed socket, nut fixing, key (G) or keys (A…L and R), special alignment mark on the front L maxi Reference N øA e øB Dimensions (mm) M S3 E maxi S1 Model Series A B e E L M EKG EKG EKG EKG 2B 3B 4B 5B 18 22 28 40 19.2 25.0 34.0 40.0 M15x1.0 M18x1.0 M25x1.0 M35x1.0 8.5 11.5 12.0 11.0 26.7 30.7 35.7 43.5 1.8 2.0 2.5 3.0 N1) S1 24.6 28.1 34.1 39.6 13.5 16.5 23.5 33.5 S3 17 22 30 – P1 Panel cut-out (page 152) Note: 1) maximum length with crimp contacts. The 5B series is delivered with a tapered washer and a round nut. ESG Fixed socket with two round nuts, key (G) or keys (A…L), long threaded shell (back panel mounting) L maxi N Reference Dimensions (mm) øA 3.2 mini e øB øC M S1 E maxi Model Series ESG ESG 00 1B A B C e E L 9 9 9.5 M7x0.5 3.2 15.5 14 14 16.0 M12x1.0 8.0 23.0 M 2 2 N1) S1 13.7 – 21.1 10.5 P1 Panel cut-out 1B series (page 152) P2 Panel cut-out 00 series (page 152) Note: 1) maximum length with crimp contacts. EHG Fixed socket, nut fixing, key (G) or keys (A…M and R), and protruding shell Reference L maxi N øA M e øB S3 E maxi S1 Dimensions (mm) Model Series A B e E L M N1) EHG EHG EHG EHG EHG EHG 00 0B 1B 2B 3B 5B 8.0 10.0 14.0 18.0 22.0 40.0 10.2 12.4 15.8 19.2 25.0 40.0 M7x0.5 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M35x1.0 2.0 2.0 4.0 5.1 7.1 2.5 15.5 19.5 21.7 22.7 30.7 43.5 8.5 12.5 12.0 12.5 13.5 28.0 13.7 19.1 21.1 24.6 30.3 38.5 S1 S3 6.3 8.2 10.5 13.5 16.5 33.5 9 11 14 17 22 – P1 Panel cut-out (page 152) Note: 1) maximum length with crimp contacts. The 5B series is delivered without locking washer or tapered washer and with a round nut. EJG Fixed socket, press or adhesive fit, key (G) or keys (A…M) L maxi Reference N øA øB M Model Series EJG EJG EJG 0B 1B 2B Dimensions (mm) A B L 9.2 8.35 20.7 12.5 11.20 23.0 16.5 14.00 26.7 M N1) 1.5 1.5 1.5 19.1 21.1 24.6 P5 Panel cut-out (page 152) Note: 1) maximum length with crimp contacts. 16 www.lemo.com ® ® EEG Fixed socket, nut fixing, key (G) or keys (A…M and R) (back panel mounting) L maxi Reference N Dimensions (mm) Model Series A B e E L M N1) EEG EEG EEG EEG EEG EEG 00 0B 1B 2B 3B 5B 10 12 16 20 24 41 9.5 12.5 16.0 20.0 25.0 40.0 M7x0.5 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M35x1.0 2.3 2.4 6.5 3.0 5.0 13.5 15.5 20.7 23.0 26.7 30.7 43.5 2.5 2.5 3.5 3.5 4.5 5.0 13.7 6.0 6.3 7.5 19.1 6.3 8.2 9.0 21.1 11.0 10.5 13.0 24.6 9.0 13.5 15.0 28.1 12.0 16.5 20.0 39.6 19.5 33.5 38.0 P S1 S2 P e øB øA M S1 E maxi S2 P1 Panel cut-out (page 152) Note: 1) maximum length with crimp contacts. The 3B and 5B series are delivered with a conical nut. The 5B series is delivered without locking washer or tapered washer. EFG Fixed socket, nut fixing, key (G) or keys (A…M), with two flats on the shell and O-ring (back panel mounting) L maxi N P Reference øA e øB M Model Series EFG 0B Dimensions (mm) N1) P S2 12 12.5 M9x0.6 5.5 20.7 2.5 19.1 9 8 A B e E L M P2 Panel cut-out (page 152) E maxi S2 Note: 1) maximum length with crimp contacts. ECG Fixed socket with two nuts, key (G) or keys (A…M and R) (back panel mounting) Reference L maxi Dimensions (mm) Model Series A B e E L M N1) S1 S3 ECG ECG ECG ECG ECG ECG ECG 00 0B 1B 2B 3B 4B 5B 10 12 16 20 24 30 41 10.2 12.4 15.8 19.2 25.0 34.0 40.0 M7x0.5 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M25x1.0 M35x1.0 4.3 5.5 6.0 6.5 9.0 10.0 9.0 13.7 20.7 23.0 26.7 30.7 35.7 43.5 2.5 2.5 3.5 3.5 4.5 4.5 5.0 13.7 19.1 21.1 24.6 28.1 32.6 39.6 6.3 8.2 10.5 13.5 16.5 23.5 33.5 9 11 14 17 22 30 – N øA M e øB S3 S1 E maxi P1 Panel cut-out (page 152) Note: 1) maximum length with crimp contacts. The 3B, 4B and 5B series are delivered with a conical nut. The 5B series is delivered with a tapered washer and a round nut. ECG Fixed socket with two nuts, key (G) or keys (A…F and R) and straight contact for printed circuit (back panel mounting) Reference L N M øA e øB S3 S1 E maxi Dimensions (mm) Model Series A B ECG ECG ECG ECG ECG ECG ECG 00 0B 1B 2B 3B 4B 5B 10 12 16 20 24 30 41 10.2 12.4 15.8 19.2 25.0 34.0 40.0 e E M7x0.5 4.3 M9x0.6 5.5 M12x1.0 6.0 M15x1.0 6.5 M18x1.0 9.0 M25x1.0 10.0 M35x1.0 9.0 M N S1 S3 2.5 2.5 3.5 3.5 4.5 4.5 5.0 13.7 16.4 19.8 21.8 25.8 29.8 36.8 6.3 8.2 10.5 13.5 16.5 23.5 33.5 9 11 14 17 22 30 – P1 Panel cut-out (page 152) P15 PCB drilling pattern (page 154) Note: this contact type is available for E●● socket models fitted with female contacts. Length «L» depends on the number of contacts, see table on page 156. The 5B series is delivered with a tapered washer and a round nut. The 3B, 4B and 5B series are delivered with a conical nut. www.lemo.com 17 ® ® ECG Fixed socket with two nuts, key (G) or keys (A…F) with elbow (90°) contact for printed circuit (back panel mounting) Reference N 20 mini øB M S1 e S3 øA L Dimensions (mm) Model Series A ECG ECG ECG ECG 0B 1B 2B 3B 12 16 20 24 B e E M 12.4 M9x0.6 2.4 15.8 M12x1.0 6.0 19.2 M15x1.0 6.5 25.0 M18x1.0 9.0 2.5 3.5 3.5 4.5 N S1 max 18.3 8.2 20.3 10.5 22.3 13.5 25.8 16.5 S3 11 14 17 22 P1 Panel cut-out (page 152) E maxi 2 P17 PCB drilling pattern (page 157) Note: this female contact type is available for all back panel mounting socket models. Length «L» depends on the number of contacts, see PCB drilling pattern on page 157. For male contacts, sockets are available upon request, with J, K or L keys. The 3B series is delivered with a conical nut. EZG Straight socket for printed circuit, key (G) or keys (A, B) Reference B Model Series A B H K N EZG 00 6.8 7 5.08 7 14 H N øA ø 0.5 ø 0.7 3 Dimensions (mm) P15 + P16 PCB drilling pattern (pages 154 and 156) K EZG Straight socket for printed circuit, key (G) or keys (A…F) Reference Dimensions (mm) Model Series A EZG EZG EZG 0B 1B 2B 9 11 14 B H K N 8 8 9 15.0 19.0 22.5 L H N øA M 1.6 B 10 7.62 12 7.62 15 10.16 P15 + P16 PCB drilling pattern (pages 154 and 156) Note: Length «L» depends on the number of contacts, see table on page 156. K EYG Fixed socket for printed circuit, nut fixing, key (G) or keys (A…F) (back panel mounting) Reference N L 9 P B M M 1.6 S1 øA e øC D Model Series EYG EYG EYG 0B 1B 2B Dimensions (mm) A B C D e E M N P S1 12 10 12.5 7.62 M9x0.6 2.6 2.5 15.0 6.0 8.2 14 12 16.0 7.62 M11x0.5 5.0 3.5 19.0 10.0 – 20 15 19.5 10.16 M15x1.0 7.5 3.5 22.5 13.5 13.5 P1 Panel cut-out 0B and 2B series (page 152) P10 Panel cut-out 1B series (page 152) P15 + P16 PCB drilling pattern (pages 154 and 156) E maxi Note: Length «L» depends on the number of contacts, see page 156. 18 www.lemo.com ® ® XPF Fixed socket, nut fixing, long shell, keys (F) for printed circuit (back panel mounting) N L Reference P 5.08 Model Series XPF 0B A B e E M N P R 12 11 M9x0.6 1.5 2.5 19 5 4 P2 Panel cut-out (page 152) øA e øB M Dimensions (mm) P15 + P16 PCB drilling pattern (pages 154 and 156) R 1 E maxi Note: Length «L» depends on the number of contacts, see table on page 156. PHG Free socket, key (G) or keys (A…M and R), cable collet Reference øA ~L S2 Dimensions (mm) Model Series A L S1 S2 PHG PHG PHG PHG PHG PHG PHG 001) 6.8 9.5 12.5 16.5 19.0 26.0 36.0 26.0 35.5 40.5 47.0 56.0 73.0 99.0 5.5 8.0 10.0 13.0 15.0 21.0 31.0 5 7 9 12 14 20 30 0B 1B 2B 3B 4B 5B S1 M1 Cable assembly (page 161) Note: 1) the surface design of the 00 series is different. PHG Free socket, key (G) or keys (A…M), cable collet and nut for fitting a bend relief 2) Reference øA ~L S2 S1 Dimensions (mm) Model Series A L S1 S2 PHG PHG PHG PHG PHG PHG 001) 0B 1B 2B 3B 4B 6.8 9.5 12.5 16.5 19.0 26.0 34.0 34.5 39.5 46.0 54.5 69.0 5.5 8.0 10.0 13.0 15.0 21.0 6 7 9 12 15 20 M1 Cable assembly (page 161) Note: 1) the surface design of the 00 series is different. 2) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see page 141). www.lemo.com 19 ® ® PNG Free socket, nut fixing, key (G) or keys (A…L and R), cable collet with lanyard release Reference Model Series A B L N S1 S2 PNG PNG PNG PNG PNG 1B 2B 3B 4B 5B 12.4 16.5 19.0 26.0 36.0 18.4 22.5 26.0 33.0 43.0 40.5 47.0 56.0 73.0 99.0 140 160 190 230 300 10 13 15 21 31 9 12 14 20 30 B N øA ~L Dimensions (mm) M1 Cable assembly (page 161) Note: cable material: stainless steel with Polyamide sheath S2 S1 PKG Fixed socket, nut fixing, key (G) or keys (A…M and R), cable collet Reference ~L M øB e øA S3 Dimensions (mm) Model Series A B PKG PKG PKG PKG PKG PKG PKG 00 0B 1B 2B 3B 4B 5B 8 10 14 18 22 28 40 10.2 12.4 15.8 19.2 25.0 34.0 40.0 e E L M M7x0.5 6.5 26.0 1.0 M9x0.6 7.0 35.5 1.2 M12x1.0 7.5 40.5 1.5 M15x1.0 8.5 47.0 1.8 M18x1.0 11.5 56.0 2.0 M25x1.0 12.0 73.0 2.5 M35x1.0 11.0 99.0 3.0 S1 S2 S3 6.3 8.2 10.5 13.5 16.5 23.5 33.5 5 7 9 12 14 20 30 9 11 14 17 22 30 – P1 Panel cut-out (page 152) S2 E maxi S1 M1 Cable assembly (page 161) Note: the 5B series is delivered with a tapered washer and a round nut. PFG Fixed socket, with two nuts, key (G) or keys (A…M and R), cable collet (back panel mounting) Reference ~L M øA e øB S3 Dimensions (mm) Model Series A B e E L M PFG PFG PFG PFG PFG PFG PFG 00 0B 1B 2B 3B 4B 5B 10 12 16 20 24 30 41 10.2 12.4 15.8 19.2 25.0 34.0 40.0 M7x0.5 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M25x1.0 M35x1.0 5.3 5.0 5.0 6.5 9.0 11.0 10.0 26.0 35.5 40.5 47.0 56.0 73.0 99.0 2.5 2.5 3.5 3.5 4.5 4.5 5.0 S1 S2 S3 6.3 8.2 10.5 13.5 16.5 23.5 33.5 5 7 9 12 14 20 30 9 11 14 17 22 30 – P1 Panel cut-out (page 152) S2 S 1 E maxi M1 Cable assembly (page 161) Note: the 3B, 4B and 5B series are delivered with a conical nut. The 5B series is delivered with a tapered washer and a round nut. 20 www.lemo.com ® ® PEG Fixed socket, nut fixing, key (G) or keys (A…L), cable collet (back panel mounting) Reference ~L P S1 S2 øA e øB M Model Series A B e E PEG PEG 3B 4B 24 32 25 M18x1.0 5.0 34 M25x1.0 12.5 L M S1 56 73 4.5 16.5 5.0 23.5 S2 S4 P 14 20 20 27 12 20 P1 Panel cut-out (page 152) M1 Cable assembly (page 161) S4 E maxi Dimensions (mm) Note: the 4B series has an o-ring on the flange. R ● ● Fixed coupler, nut fixing, key (G) or keys (A and J) at the flange end and keys (J, K or M) at the other end M E maxi S1 e øA S3 Reference G RGG G J RJG G G RGJ J A RAK K G M RGM Example Type 0B 0B female – female female – female male – female female – male female – male female – male female – female male – female female – male male – female female – male female – male female – male 0B 1B 1B 2B 3B 4B A B e E L M S1 S3 12 13.8 M10x0.75 12 13.8 M10x0.75 8.0 34 2.0 8.0 43 2.0 9.0 12 9.0 12 12 13.8 M10x0.75 8.0 34 2.0 9.0 12 16 19.2 M14x1.00 8.5 47 2.5 12.5 17 16 19.2 M14x1.00 8.5 39 2.5 12.5 17 20 21.5 M16x1.00 12.0 44 4.0 15.0 19 25 27.0 M20x1.00 32.0 53 4.0 18.5 24 34 34.0 M25x1.00 50.0 65 4.0 23.5 30 Plug with key J Alignment key see page 31. www.lemo.com RGG 1) RGG 2) RJG RGJ RAK RGM RGG 3) RJG RGJ RJG RGJ RGJ RGJ Series Dimensions (mm) P4 Panel cut-out (page 152) RGJ Plug with key G Model Contacts øB L Note: 1) only available with two contacts. 2) only available with three and four contacts. 3) only available with three contacts. For this fixed coupler, the first contact type mentioned is always the one at the flange end. On request, these couplers can be produced in other series, with other keys. 21 ® ® Elbow socket models Technical Characteristics Materials and Treatment Types Surface treat. (µm) Material Component Cu PPS Brass Brass Bronze PEEK Bronze Housing Type 1 1 0B, 1B 00 302 1 1 2 1 303 3 1 1 Electrical 2 0B, 1B 00 4 3 2 3 2 304 3 1 4 3 2 3 1 4 2 3 Model Series EPG-XBG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG-EXG EPG 00 0B 0B 0B 0B 0B 0B 0B 1B 1B 1B 1B 1B 1B 1B 1B 1B Types 1 305 0B, 1B 1 5 4 2 3 0B, 1B 306 6 5 4 1 2 3 2 5 4 3 1 6 3 4 5 2 1 0B, 1B 307 7 2 6 1B 5 4 2 3 4 8 1 7 1 6 2 5 7 4 3 6 308 1 2 7 3 8 6 4 5 309 2 3 5 3 4 1 8 0B 1B 9 8 7 1 2 6 3 7 6 7 6 4 310 10 8 9 4 5 5 9 1.5 Note: The surface treatment standards are as follows: – Nickel: FS QQ-N-290A. – Gold: ISO 4523 2 0B, 1B 00 0.5 2 2 5 1 8 2 9 7 3 10 6 4 5 302-303-304 302 303 304 305 306 307 309 302 303 304 305 306 307 308 310 314 Rated current (A)1) Series 2 – – – Test voltage (kV rms)1) Contact-shell 1 0.5 0.5 0.5 Au – 3 3 3 – 3 Test voltage (kV rms)1) Contact-contact Series Metallic parts Earthing crown Insulator Female contact Ni 0.80 1.30 1.20 0.85 1.00 0.85 0.80 0.60 1.50 1.30 1.35 1.25 1.05 0.95 0.95 0.90 0.80 0.65 1.05 0.90 0.70 0.70 0.65 0.70 0.50 1.35 1.55 1.45 1.15 1.20 1.05 1.15 1.50 1.20 2.0 4.5 4.5 4.5 4.5 2.5 2.0 1.5 4.5 4.5 4.5 4.5 4.5 2.0 2.0 1.5 1.0 Note: 1) see calculation method, caution and suggested standard on page 178. øA 12.7 EPG Elbow (90°) socket for printed circuit, key (G) or keys (A…F) (solder or screw fixing) L N Reference K EPG.1B.314.NLN A D 11 21 Dimensions (mm) H I K L 7.7 14.3 19 N 36 15.4 3 H I P20 PCB drilling pattern (page 158) 22 Note: to replace the 4 ground pins by 4 screws (M1.6) add an «S» to the end of the part number. (e.g.: EPG.1B.314.NLNS) ø 0.7 ø 0.6 M 1.6 D www.lemo.com ® ® EPG Elbow (90°) socket for printed circuit, key (G) or keys (A…F) (solder or screw fixing) Reference øA R EPG.00.302.HLN EPG.00.303.HLN EPG.00.304.HLN EPG.0B.302.HLN EPG.0B.303.HLN EPG.0B.304.HLN EPG.0B.305.HLN EPG.0B.306.HLN EPG.0B.307.HLN EPG.0B.309.HLN EPG.1B.302.HLN EPG.1B.303.HLN EPG.1B.304.HLN EPG.1B.305.HLN EPG.1B.306.HLN EPG.1B.307.HLN EPG.1B.308.HLN EPG.1B.310.HLN L N 3.0 (00) 3.2 (0B-1B) H I K ø 0.7 M 1.6 A Dimensions (mm) H I K L D 6.8 11.5 3.5 7.0 8.7 19 N R 7.1 5.08 9.0 14.6 6.7 12.7 13.3 25 11.7 7.62 11.0 16.6 7.5 14.0 13.3 27 12.6 7.62 D P18 PCB drilling pattern 00 series (page 158) ø 0.5 (00) ø 0.7 (0B-1B) P19 PCB drilling pattern 0B, 1B series (page 158) Note: In the 0B and 1B series, it is possible to replace the 4 ground pins by 4 screws (M1.6) add an «S» to the end of the part number. (e.g.: EPG.0B.307.HLNS) EXG Elbow (90°) socket for printed circuit with two nuts, key (G) or keys (A…F) (solder or screw fixing) (back panel mounting) XBG Elbow (90°) socket fixing nut for printed circuit, key (G) or keys (A, B) (back panel mounting) R N Reference K L S3 e øB 3.0 (00) 3.2 (0B-1B) H I øA M M 1.6 ø 0.5 (00) ø 0.7 (0B-1B) E maxi D XBG.00.302.HLN XBG.00.303.HLN XBG.00.304.HLN EXG.0B.302.HLN EXG.0B.303.HLN EXG.0B.304.HLN EXG.0B.305.HLN EXG.0B.306.HLN EXG.0B.307.HLN EXG.0B.309.HLN EXG.1B.302.HLN EXG.1B.303.HLN EXG.1B.304.HLN EXG.1B.305.HLN EXG.1B.306.HLN EXG.1B.307.HLN EXG.1B.308.HLN EXG.1B.310.HLN A B D e Dimensions (mm) E H I K L M N R S3 10 10.2 11.5 M7x0.5 2.1 3.5 7.0 8.7 19 2.5 7.1 5.08 9 12 12.4 14.6 M9x0.6 6.0 6.7 12.7 13.3 25 2.5 11.7 7.62 11 14 15.0 16.6 M11x0.5 7.5 7.5 14.0 13.3 27 3.5 12.6 7.62 13 P2 Panel cut-out 00, 0B series (page 152) P10 Panel cut-out 1B series (page 152) Note: In the 0B and 1B series, it is possible to replace the 4 ground pins by 4 screws (M1.6) add an «S» to the end of the part number. (e.g.: EXG.0B.307.HLNS). www.lemo.com P18 PCB drilling pattern 00 series (page 158) P19 PCB drilling pattern 0B, 1B series (page 158) 23 ® ® Plastic housing models These connectors are particularly recommended for all applications requiring maximum electrical insulation when mated. The design, including a latch sleeve and a metal earthing crown, guarantees EMC screening efficiency to meet most requirements. Technical Characteristics Mechanical and Climatical Characteristics Value PSU PEEK Colour Endurance Humidity Temperature range Sterilization resistance 1) Resistance to solvents Standard PPSU natural (beige) > 5000 cycles white or grey cream – > 5000 cycles > 5000 cycles IEC 60512-5 test 9a up to 95% at 60° C – - 50° C/+250° C - 50° C/+150° C - 50° C/+180° C – > 200 cycles ~20 cycles > 100 cycles IEC 60601-1 § 44.7 very good limited good – Note: 1) Steam sterilization FGG Straight plug, key (G or J), cable collet, PEEK outer shell Reference ~L øA ~M Model Series FGG FGG FGG 1B 3B 4B Dimensions (mm) A L M S2 13.5 43.0 32.0 19.0 62.0 47.0 26.0 78.5 60.5 10 15 20 M1 Cable assembly (page 161) S2 FGG Straight plug, key (G or J), cable collet, PEEK outer shell and nut for fitting a bend relief 1) Reference Dimensions (mm) Note on availability ~L øA ~M Model Series FGG FGG 1B 4B A L M S2 13.5 42.2 31.2 10 for all collet type 26.0 83.2 65.2 20 only from collet M82 and up M1 Cable assembly (page 161) Note: 1) to order, add a «Z» at the end of the reference. S2 The bend relief must be ordered separately (see page 141). FGY Straight plug, keys (Y), cable collet and PSU or PPSU outer shell Reference Model Series FGY FGY FGY 2B 3B 4B Dimensions (mm) A L M S2 ~L 16.5 50.5 39.5 19.0 58.0 43.0 26.0 76.2 58.2 13 15 20 øA ~M M1 Cable assembly (page 161) S2 24 www.lemo.com ® ® FGY Straight plug, keys (Y), cable collet and PSU or PPSU outer shell and nut for fitting a bend relief 1) Reference Dimensions (mm) Note on availability ~L øA ~M Model Series FGY FGY FGY 2B 3B 4B A L M S2 16.5 49.5 38.5 13 19.0 56.5 41.5 15 26.0 74.4 56.4 20 only for collet M42 and up only for collet D62 and up only for collet M82 and up M1 Cable assembly (page 161) Note: 1) to order, add a «Z» at the end of the reference. S2 The bend relief must be ordered separately (see page 141). ENG Fixed socket with earthing tag, nut fixing, key (G or J), PEEK outer shell L maxi N øA e øB Reference Dimensions (mm) M S3 E maxi S1 Model Series ENG ENG ENG 1B 3B 4B A B e E L M N1) S1 S3 14 15.8 M12x1.0 7.5 23.0 1.5 21.1 10.5 14 22 25.0 M18x1.0 11.5 30.7 2.0 28.1 16.5 22 28 34.0 M25x1.0 12.0 35.7 2.5 32.6 23.5 30 P1 Panel cut-out (page 152) Note: 1) maximum length with crimp contacts. ENY Fixed socket with earthing tag, nut fixing, keys (Y), PSU or PPSU outer shell L maxi N E maxi Dimensions (mm) Reference M øA e øB S3 S1 Model Series ENY ENY ENY 2B 3B 4B A B e E L M N1) S1 S3 18 19.2 M15x1.0 8.5 26.7 1.8 24.6 13.5 17 22 25.0 M18x1.0 11.5 30.7 2.0 28.1 16.5 22 28 34.0 M25x1.0 12.0 35.7 2.5 32.6 23.5 30 P1 Panel cut-out (page 152) Note: 1) maximum length with crimp contacts. Note: other models with plastic outer shell are available on request. www.lemo.com 25 ® ® Watertight or vacuumtight models These plug, socket and coupler models allow the device on which they are fitted to reach a protection index of IP68 as per IEC 60529. They are fully compatible with plugs of the same series and are widely used for portable radios, military, laboratory equipment, aviation, etc. These models are identified by a letter «P» at the end of the reference. Most of these models are also available in a vacuumtight version. Such models are identified by an additional letter «V» at the end of the part number (certificate on request). Epoxy resin is used to seal these models. Technical Characteristics Mechanical and Climatical Characteristics Endurance Humidity Temperature range (00 to 1B) Temperature range (2B to 5B) Salt spray corrosion test Climatical category Leakage rate (He)1) Value Standard Characteristics > 5000 cycles IEC 60512-5 test 9a up to 95% at 60° C - 20° C/+100° C - 20° C/+80° C > 144h IEC 60512-6 test 11f 20/80/21 IEC 60068-1 < 10-7 mbar.l.s-1 IEC 60512-7 test 14b Note: 1) only for vacuumtight models. Value 00 0B 1B 2B 3B 4B 5B Maximum operating pressure2) Standard 60 bars 60 bars 60 bars 40 bars 30 bars 15 bars 5 bars IEC 60512-7 test 14d Note: 2) this value corresponds to the maximum allowed pressure difference for the assembled socket. YHG Fixed plug, nut fixing, non-latching, key (G) or keys (A…M) øA M e øB S3 Dimensions (mm) Reference L maxi Model Series A YHG YHG YHG YHG 0B 1B 2B 3B 13.0 16.0 19.0 22.0 B e E 12.4 M9x0.6 2.4 15.8 M12x1.0 3.9 19.2 M15x1.0 5.5 25.0 M18x1.0 5.1 L 24.1 28.0 33.1 38.2 M S1 S3 14.2 8.2 16.2 10.5 17.8 13.5 22.2 16.5 11 14 17 22 S1 E maxi P9 Panel cut-out (page 152) Note: this model does not include an O-ring behind the flange, it ensures only IP61 protection index. Consequently, it is not vacuumtight. Watertightness (when mated) is only ensured with HHG and HCG sockets. HGG Fixed socket, nut fixing, key (G) or keys (A…M and R), watertight or vacuumtight Dimensions (mm) Reference L maxi øA M e øB S3 E maxi S1 Model Series A B HGG HGG HGG HGG HGG HGG HGG 00 0B 1B 2B 3B 4B 5B 11 13 18 20 25 34 45 10.2 12.4 15.8 19.2 25.0 34.0 40.0 e E L M S1 S3 M7x0.5 8.0 18.0 1.5 M9x0.6 7.0 20.2 3.0 M12x1.0 7.0 26.6 4.5 M15x1.0 8.0 31.6 4.0 M18x1.0 11.5 36.1 4.0 M25x1.0 11.0 43.1 4.0 M35x1.0 11.0 53.6 5.0 – 8.2 10.5 13.5 16.5 23.5 33.5 9 11 14 17 22 30 – P9 Panel cut-out (page 152) Note: the 5B series is delivered with a tapered washer and a round nut. 26 www.lemo.com ® ® HNG Fixed socket, nut fixing, with earthing tag, key (G) or keys (A…M), watertight or vacuumtight Dimensions (mm) Reference L maxi øA M e øB S3 Model Series HNG 0B A B e 13 12.4 M9x0.6 E L M S1 S3 7 20.2 3 8.2 11 P9 Panel cut-out (page 152) S1 E maxi HHG Fixed socket, nut fixing, key (G) or keys (A…M), watertight or vacuumtight (watertight when mated) Dimensions (mm) Reference L maxi M øA e øB S3 Model Series A HHG HHG HHG HHG 0B 1B 2B 3B 13 18 22 25 B e E 12.4 M9x0.6 7.0 15.8 M12x1.0 7.0 19.2 M15x1.0 8.0 25.0 M18x1.0 11.5 L 23.2 30.3 35.6 41.3 M S1 S3 4.8 8.2 5.2 10.5 6.0 13.5 7.2 16.5 11 14 17 22 P9 Panel cut-out (page 152) E maxi S1 Note: this model ensures watertightness (IP66) in the mating area when mated with FGG or similar plug. HCG Fixed socket, nut fixing, key (G) or keys (A…M), watertight or vacuumtight (watertight when mated) (back panel mounting) Dimensions (mm) Reference L maxi P e e1 øB øC øA M F maxi Model Series A B C e e1 E F L M P S1 HCG HCG HCG 0B 1B 2B 18 20 24 18 12.0 M14x1.0 M9x0.6 3.9 1.0 23.2 3.5 7.5 12.5 20 14.5 M16x1.0 M12x1.0 6.2 2.0 30.3 3.5 10.0 14.5 24 17.5 M19x1.0 M14x1.0 6.7 1.5 35.6 3.5 11.3 17.0 P3 Panel cut-out (page 152) E maxi S1 Note: this model ensures watertightness (IP66) in the mating area when mated with FGG or similar plug. HEG Fixed socket, nut fixing, key (G) or keys (A…M), watertight or vacuumtight (back panel mounting) Dimensions (mm) Reference L maxi P Series A B e E HEG HEG HEG HEG 00 0B 1B 2B 10 12 16 20 11 M7x0.5 2.5 13 M9x0.6 5.5 18 M12x1.0 5.5 20 M15x1.0 5.5 L 18.2 21.5 26.6 31.6 M P S1 S2 2.5 6.0 6.3 2.5 9.0 8.2 3.5 11.0 10.5 3.5 9.6 13.5 – – – 15 øA M e øB S2 S1 Model P9 Panel cut-out (page 152) E maxi www.lemo.com 27 ® ® HMG Fixed socket with earthing tag, nut fixing, key (G) or keys (A…M), watertight or vacuumtight (back panel mounting) L maxi e øA M øB Dimensions (mm) Reference P S1 E maxi Model Series A B e E L HMG HMG HMG HMG HMG 00 0B 1B 2B1) 3B 10 12 16 20 24 11 M7x0.5 2.5 18.0 13 M9x0.6 5.5 21.5 18 M12x1.0 5.5 26.6 20 M15x1.0 5.5 31.6 25 M18x1.0 7.5 36.1 M P S1 2.5 6.0 6.3 2.5 9.0 8.2 3.5 11.0 10.5 3.5 9.6 13.5 4.5 14.0 16.5 P9 Panel cut-out (page 152) Note: 1) the surface design of the 2B series is different. The 3B series is delivered with a conical nut. S ● ● Fixed coupler, nut fixing, key (G) or keys (A, B, J, K and L) at the flange end and key (G) or keys (A, B, J, K and L) at the other end, watertight or vacuumtight L S1 øA M e øB S3 E maxi Reference Model G SGJ J J SJG G K A SKA L SLB B A SAK K B SBL L Example 0B 1B 2B 3B 4B 5B Type female – male male – female female – male male – female female – male male – female female – male male – female female – male female – male female – male female – male female – male male – female female – male male – female male – female male – female female – male female – male Dimensions (mm) A B e E L M S1 S3 14 13.8 M10x0.75 17 34 2.0 9.0 12 17 15.8 M12x1.00 28 39 2.5 10.5 14 20 21.5 M16x1.00 25 44 4.0 15.0 19 25 27.0 M20x1.00 30 53 4.0 18.5 24 34 34.0 M25x1.00 50 65 4.0 23.5 30 45 40.0 M35x1.00 58 80 5.0 33.5 – P4 Panel cut-out (page 152) SGJ Plug with key G SGJ SJG SGJ SJG SGJ SJG SGJ SJG SAK SBL SAK SBL SGJ SJG SGJ SJG SKA SLB SAK SBL Series Contacts Plug with key J P9 Panel cut-out 1B series (page 152) Alignment key see page 31. 28 Note: for this fixed coupler, the first contact type mentioned is always the one at the flange end. On request these couplers can be produced in other series, with other keys. The 5B series is delivered with a round nut. www.lemo.com ® ® Bridge models Technical Characteristics Mechanical and Climatical Characteristics IEC 60512-2 test 2a Rated current (A) < 6 mΩ 0B 0B 0B 0B 0B 1B 1B 1B 1B ● ● ● ● – ● ● – – – – – – ● – – ● ● 1.05 1.05 0.80 0.80 0.40 1.25 1.25 0.80 0.80 4 4 4 4 2 5 5 3 3 Materials and Treatment Component Plastic housing Polyamide Brass Brass PEEK Brass Bronze Metallic parts Insulator Male contact Female contact – 0.5 0.5 3 3 0.5 0.5 3 3 – 0.3 – – – – 1.0 1.5 – Note: the surface treatment standards are as follows: – Nickel: FS QQ-N-290A, chrome: FS QQ-C-320B, gold: ISO 4523 CFF Reference Surface treat. (µm) Cu Ni Cr Au Material CRG Standard Test voltage (kV rms) 1) 2) Contact resistance > 1000 cycles IEC 60512-5 test 9a maximum 90° C Endurance Working temperature Value Audio-Stereo Standard Audio-Mono Value Series Characteristics Electrical CFF.0B.302.PLCG CRG.0B.302.PLEG CFF.0B.303.PLCG CRG.0B.303.PLEG CRG.0B.306.PLEG CFF.1B.303.PLCG CRG.1B.303.PLEG CFF.1B.306.PLCG CRG.1B.306.PLEG Note: the last letter of the part number indicates the colour of the housing. Ex. G (standard) is grey. To obtain another colour, replace this letter by the letter corresponding to the selected colour (see table on page 54). 1) see calculation method, caution and suggested standard on page 178. 2) lowest measured value; contact to contact or contact to shell. CFF Bridge plug with two non-latching plugs CRG Bridge plug with two non-latching plugs, and monitoring socket, key (G) or keys (A…M) M maxi A N B H Reference Dimensions (mm) Model Series A B H CFF-CRG CFF-CRG 0B 1B 13.5 15.0 14 20 L M N 27.5 37.2 27.2 22.5 35.0 42.0 31.0 22.0 Note: in order to provide the user with a coding system, the bridge plug housing, the double panel washers and the bend reliefs are available in nine colours. L maxi Nominal current (A) 2 3 4 1.05 0.80 0.80 4 4 3 FTG.0B.302.PLFG FTG.0B.303.PLFG FTG.0B.304.PLFG 37.8 15 Test voltage (kV rms) 1) Reference Number of contacts FTG Straight plug, key (G) and two parallel sockets 27.8 Type 302 Type 303 Type 304 1 1 12 24 1 1 3 2 1 1 2 www.lemo.com 3 2 2 2 Note: 1) see calculation method, caution and suggested standard on page 178. 2 3 4 1 3 2 1 4 2 3 1 4 2 3 29 ® ® Threaded-latching models FVG Straight plug, key (G) or keys (B), cable collet Dimensions (mm) Reference ~L ~M Series A L M S1 S2 FVG 00 9 28.5 24 5 8 Note: to be ordered with nut for fitting a bend relief to obtain the rating IP 64. øA S1 Model S2 ESG Fixed socket with two round nuts, key (G) or keys (B), long threaded shell (back panel mounting) L maxi N øA 3.2 mini 1) e øB øC M Reference Dimensions (mm) Model Series A B ESG 00 9 9 C e E L M N 2 13.7 9.5 M7x0.5 3.2 15.5 P2 Panel cut-out (page 152) E maxi Note: 1) minimum length of free thread to ensure mating. FVB Straight plug, keys (B), short shell for special cable crimping and for fitting a bend relief Reference L M Model Series A L M FVB 00 9 20 15.4 øA Note: after assembly the special bend relief GMF.00.018.D● (to be ordered separately) is to be fitted. XRB Elbow (90°) socket for printed circuit, keys (B), short shell with one nut, screw fixing (back panel mounting) 2.05 5.5 = = 8 1.2 Dimensions (mm) L e øA 3.2 mini 1) Model Series A e I L M P XRB 00 10 M7x0.5 7 14 2.5 7 P2 Panel cut-out (page 152) 3 I Dimensions (mm) Reference P M 2 x M 1.4 P18 PCB drilling pattern for contact only (page 158) Note: 1) minimum length of free thread to ensure mating. 30 www.lemo.com ® ® Alignment Key (B series) Alignment Key and Polarized Keying System Nb of keys 5 δ γ R β γ δ – – 1B 0° 30° 60° – – – – 45° – – – – – 0° 30° 60° 90° 135° 145° 155° 45° 70° 80° 110° – – 0° 30° 60° 90° 135° 145° 155° 45° 70° 80° – – – Series 00 0B 1B α β γ δ – – – – – – – – – – – – G A B C D E F J K L M 1 2 2 2 2 2 2 2 2 2 2 Y 3 Nb of keys 5 R Angles 3 Angles Y α 0B Nb of keys α γ β α γ – β γ Series Contact type Note 2B 3B 4B 5B Plug Socket 0° 30° 45° 60° 95° 120° 145° 37.5° 52.5° 70° – 112.5° 100° 0° 30° 45° 60° 95° 120° 145° 37.5° 52.5° 70° – 126° 102° 0° 30° 45° 60° 95° 120° 145° 37.5° 52.5° 70° – 112.5° 147.5° 0° 30° 45° 60° 95° 120° 145° 37.5° 52.5° 70° – – – male male male male male male male female female female female female female female female female female female male male male male ● ● ● ● ● ● ● ● ● ● ● male female ●1) Series Contact type Angles β 1 2 2 2 2 2 2 2 2 2 2 00 Reference α Front view of a socket G A B C D E F J K L M Series Reference δ γ Nb of keys Angles ) β β (5 B α Reference Front view of a socket Reference B series connector model part numbers are composed of three letters. The LAST LETTER indicates the key position and the contact type (male or female). 2B 3B 4B 5B Plug Socket α β γ δ – – – – – – – – – – – – 95° 115° 20° 30° male female Note ● Note: FTG, FGY, ENY models are not available with all the keys. Please consult pages corresponding to these models. For R●● models see explanation on page 21 and for S●● models see explanation on page 28. 1) only FGY and ENY models are available. ● First choice alternative ● Special order alternative www.lemo.com 31 ® ® K Series K series connectors have been specifically designed for outdoor applications. They include an inner sleeve and two seals to prevent penetration of solids or liquids into the housing formed by the plug, free socket, fixed socket or coupler. All models of this series are watertight when mated to give a protection index of IP68 as per IEC 60529 standard (in mated condition) when correctly assembled to an appropriate cable (IP66 otherwise). K series connectors have the same insulators as the B series and have the following main features: – security of the Push-Pull latching system – watertight connection (IP 68/IP 66) – multipole types 2 to 64 contacts – solder, crimp or print (straight or elbow) contacts – keying system («G» key standard) – multiple key options to avoid cross mating for connector alignment of similar connectors – 360° screening for full EMC shielding – high packing density for space savings – rugged housing for extreme working conditions. Metal housing models (page 34) Fixed plugs Straight plugs FGG FXG Fixed sockets EGG EBG Free sockets Free coupler PHG TGL T-plug with sockets (90°) FAG FGG ENG EDG EEG EHG PHG Elbow plug FGG FHG PHG FTG Fixed sockets FNG EEG EVG PKG EEG PBG Watertight or vacuumtight models (page 41) Fixed sockets HGG 32 Fixed coupler HEG PEG S•• www.lemo.com ® ® Part Numbering System Plug FG G . 3K . 310 . C L A C 65 Free socket PH G . 3K . 310 . C L L C 65 Z Variant: (page 54) Cable ø: (page 53) Collet type: (page 53) Fixed socket EG G . 3K . 310 . C Y M Coupler SL G . 3K . 310 . T L A PV Model: (page 34) Variant: (page 54) Alignment key: (page 43) Contact: (page 50) Series: (page 34) Insulator: (page 50) Insert configuration: (page 45) Housing: (page 50) Part Number Example Straight plug with cable collet: FGG.3K.310.CLAC65 = straight plug with key (G) and cable collet, 3K series, multipole type with 10 contacts, outer shell in chrome-plated brass, PEEK insulator, male solder contacts, C type collet for 6.5 mm diameter cable. Free socket: PHG.3K.310.CLLC65Z = free socket with key (G) and cable collet, 3K series, multipole type with 10 contacts, outer shell in chrome-plated brass, PEEK insulator, female solder contacts, C type collet for 6.5 mm diameter cable and nut for fitting a bend relief. Fixed socket: EGG.3K.310.CYM = fixed socket, nut fixing, with key (G), 3K series, multipole type with 10 contacts, outer shell in chromeplated brass, PEEK extended insulator, female crimp contacts. Fixed coupler: SLG.3K.310.TLAPV = fixed coupler, nut fixing, keys (L) on the flange end and key (G) at the other end, 3K series, multipole type with 10 contacts, outer shell in stainless steel, PEEK insulator, male-female contacts, vacuumtight. Part Section Showing Internal Components Straight plug 1 outer shell Fixed socket 5 2 3 4 7 7 1 6 8 2 3 7 6 4 1 9 11 12 10 5 2 latch sleeve 1 outer shell 3 inner shell 2 earthing crown 4 retaining ring 3 retaining ring 5 collet nut 4 hexagonal nut 6 split insert carrier 5 insulator 7 insulator 6 female contact 8 male contact 7 o-ring 9 earthing cone 10 collet 11 gasket 12 washer www.lemo.com 33 ® ® Metal housing models Technical Characteristics Electrical Mechanical and Climatical Characteristics Value Endurance Humidity Temperature range1) Resistance to vibrations Shock resistance Salt spray corrosion test Protection index (mated)2) Climatical category Standard > 5000 cycles IEC 60512-5 test 9a up to 95% at 60° C - 55° C, +200° C 10-2000 Hz, 15 g IEC 60512-4 test 6d 100 g, 6 ms IEC 60512-4 test 6c > 144h IEC 60512-6 test 11f IP 68/IP 66 IEC 60529 50/175/21 IEC 60068-1 Characteristics Value at 10 MHz at 1 GHz Shielding efficiency Standard > 95 dB > 80 dB IEC 60169-1-3 IEC 60169-1-3 Note: the various tests have been carried out with FGG and EGG connector pairs, with chrome-plated brass shell, PEEK insulator and silicone O-ring. Detailed electrical characteristics, as well as materials and treatment are presented in the chapter Technical Characteristics on page 171. 1) minimum operating temperature is -20°C for sockets fitted with an FPM (Viton®) O-ring. 2) IP68 achieved providing that the cable is perfectly circular and that assembly process ensures a high integrity seal. FGG Straight plug, key (G) or keys (A to F, L and R), cable collet Reference ~L øA ~M Dimensions (mm) Model Series A L M S2 FGG FGG FGG FGG FGG FGG 0K 1K 2K 3K 4K 5K 11 13 16 19 25 38 34 42 52 61 71 92 23.0 28.0 36.0 41.0 50.5 67.0 8 9 12 15 19 30 S2 M1 Cable assembly (page 162) FGG Straight plug, key (G) or keys (A to F, L and R), cable collet and oversize cable collet 1) Reference ~L øB øA ~M S2 S1 Dimensions (mm) Model Series A FGG FGG FGG FGG 1K 2K 3K 4K 13 16 19 25 B L 14.5 60.0 17.0 68.0 22.0 85.0 36.0 119.5 M S1 S2 46 52 65 99 12 15 19 30 12 15 19 32 M2 Cable assembly (page 163) Note: 1) correspond to K type of collet, the fitting of oversize collets onto this model allows them to be fitted to the cables that can be accommodated by the next housing size up (see page 53). FGG Straight plug, key (G) or keys (A to F, L and R), cable collet and nut for fitting a bend relief 1) Reference ~L ~M S2 34 Dimensions (mm) Model Series A L M S2 FGG FGG FGG FGG FGG 0K 1K 2K 3K 4K 11 13 16 19 25 34 42 52 60 71 23.0 28.0 36.0 40.0 50.5 7 9 12 15 19 M1 Cable assembly (page 162) Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see page 141). www.lemo.com ® ® FNG Straight plug, key (G) or keys (A to F and L), cable collet and lanyard release Reference ~L Model Series A B L M N S2 FNG FNG 2K 4K 16 25 23.6 35.2 52 71 36.0 50.5 160 230 12 19 M1 Cable assembly (page 162) B N øA ~M Dimensions (mm) Note: cable material: stainless steel with Polyamide sheath S2 FXG Fixed plug with round flange, key (G) or keys (A to F, L and R) and screw fixing Reference ~L P M øB øG Model Series A B G H FXG FXG FXG 3K 4K 5K 38 47 65 22.5 28.5 42.5 3.4 3.4 4.4 20.6 27.0 38.0 L M P 61 10.0 30.0 71 11.0 32.0 100 12.5 38.5 S2 15 19 30 P6 Panel cut-out (page 153) øA H Dimensions (mm) Note: this model does not include an O-ring behind the flange, it allows the device on which it is fitted to reach only IP50 protection index. It does not have a cable collet. S2 FAG Fixed plug, nut fixing, non-latching, key (G) or keys (A to F, L and R) L maxi Reference Dimensions (mm) N øA M e øB S3 S1 E maxi Model Series A B e E L M N1) FAG FAG FAG FAG FAG 1K 2K 3K 4K 5K 20 25 31 37 55 21.5 27.0 34.0 40.5 54.0 M16x1.0 M20x1.0 M24x1.0 M30x1.0 M45x1.5 2.3 4.5 4.0 4.0 4.0 22.6 33.6 34.3 35.3 43.5 16.0 18.0 22.5 23.0 28.5 22.5 28.3 33.8 36.3 42.3 S1 S3 14.5 18.5 22.5 28.5 42.5 19 24 30 36 – P1 Panel cut-out (page 153) Note: 1) maximum length with crimp contacts. The 1K series is delivered with a locking washer. The 5K series is delivered with a round nut. FHG Elbow (90°) plug, key (G) or keys (A to F, L and R), cable collet ~L S1 ~M ~H øA Reference S3 S2 Model Series FHG FHG FHG FHG FHG 0K 1K 2K 3K 4K Dimensions (mm) A D 11.5 7.6 14.0 8.8 17.5 10.5 21.0 11.5 27.5 15.5 H L M S1 S2 S3 27 33 40 47 57 36 43 51 60 72 25.0 29.0 35.0 40.0 51.5 10 12 15 18 24 8 9 12 15 19 8 10 13 15 20 D M3 Cable assembly (page 162) www.lemo.com 35 ® ® EGG Fixed socket, nut fixing, key (G) or keys (A to F, L and R) N S3 Model Series A B EGG EGG EGG EGG EGG EGG 0K 1K 2K 3K 4K 5K 18 20 25 31 37 55 19.2 21.5 27.0 34.0 40.5 54.0 e E L N1) M S1 S3 øA M e øB Dimensions (mm) Reference L maxi E maxi M14x1.0 6 21.7 4.0 M16x1.0 9 27.0 4.5 M20x1.0 9 30.7 5.0 M24x1.0 11 36.2 6.0 M30x1.0 9 40.2 6.5 M45x1.5 10 47.5 9.0 20.1 25.1 28.6 33.6 38.6 43.6 12.5 14.5 18.5 22.5 28.5 42.5 17 19 24 30 36 – S1 P1 Panel cut-out (page 153) Note: 1) maximum length with crimp contacts. The 5K series is delivered with a round nut. ENG Fixed socket, nut fixing, key (G) or keys (A to F, L and R) and earthing tag L maxi N S3 M Dimensions (mm) øA e øB Reference Model Series A B e E L ENG 3K 31 34 M24x1.0 11.3 36.2 M N1) 6 33.6 22.5 30 S1 S3 P1 Panel cut-out (page 153) E maxi S1 Note: 1) maximum length with crimp contacts. EEG Fixed socket, nut fixing, key (G) or keys (A to F, L and R) (back panel mounting) L maxi Reference N P S1 Dimensions (mm) M N1) Model Series A B e E L EEG EEG EEG EEG EEG 0K 1K 2K 3K 4K 18.0 20.0 25.0 30.0 41.5 18 20 25 31 37 M14x1.0 M16x1.0 M20x1.0 M24x1.0 M30x1.0 3.4 6.2 5.0 7.5 6.0 21.7 27.0 30.7 36.2 40.2 P S1 e øA øB M 3.5 3.5 3.5 4.5 7.0 20.1 7.0 25.1 10.0 28.6 10.0 33.6 12.0 38.6 13.5 12.5 14.5 18.5 22.5 28.5 P1 Panel cut-out (page 153) E maxi Note: 1) maximum length with crimp contacts. The 3K and 4K series are delivered with a conical nut. EEG Fixed socket, nut fixing, key (G) or keys (A to F and R) with straight print contacts for printed circuit (back panel mounting) L Reference Dimensions (mm) N P e M øA øB S1 Model Series A B e E M EEG EEG EEG EEG EEG 0K 1K 2K 3K 4K 18.0 20.0 25.0 30.0 41.5 18 20 25 31 37 M14x1.0 M16x1.0 M20x1.0 M24x1.0 M30x1.0 3.4 6.2 5.0 7.5 6.0 3.5 3.5 3.5 4.5 7.0 N P 17.6 7.0 23.8 10.0 25.8 10.0 31.3 12.0 34.3 13.5 S1 12.5 14.5 18.5 22.5 28.5 P1 Panel cut-out (page 153) E maxi P15 PCB drilling pattern (page 154) Note: this contact type is available for E● ● socket models fitted with female contact. Length «L» depends on the number of contacts, see table page 156. The 3K and 4K series are delivered with a conical nut. 36 www.lemo.com ® L ® EEG Fixed socket, nut fixing, key (G) or keys (A to F and R) with elbow (90°) contacts for printed circuit (back panel mounting) N P S1 Reference 20 mini øA e øB M Dimensions (mm) Model Series A B e E M N P S1 EEG EEG EEG EEG 0K 1K 2K 3K 18 20 25 30 18 20 25 31 M14x1.0 M16x1.0 M20x1.0 M24x1.0 3.4 6.2 5.0 7.5 3.5 3.5 3.5 4.5 19.3 24.3 26.6 31.3 7 10 10 12 12.5 14.5 18.5 22.5 E maxi P1 Panel cut-out (page 153) P17 PCB drilling pattern (page 157) 2 Note: length «L» depends on the number of contacts, see PCB drilling pattern page 157. The 3K series is delivered with a conical nut. EBG Fixed socket with square flange, key (G) or keys (A to F, L and R) and screw fixing Reference L N A M Model Series A B F G EBG EBG EBG 3K 4K 5K 29 37 54 23 30 45 3 3 4 3.4 3.4 4.4 H L M N1) 23 36.2 6.0 32.6 29 40.2 6.5 36.6 44 47.5 8.0 42.1 øB H Dimensions (mm) P7 Panel cut-out (page 153) Note: 1) maximum length with crimp contacts. F øG EDG Fixed socket with square flange, key (G) or keys (A to F, L and R), protruding shell and earthing tag, screw fixing L Reference Dimensions (mm) N A M øB Model Series A B C F G EDG 3K 29 18 23 3 3.4 H L M N1) 23 36.2 22.5 32.6 P7 Panel cut-out (page 153) øC H Note: 1) maximum length with crimp contacts. F øG EHG Fixed socket, nut fixing, key (G) or keys (A to F and L), protruding shell L maxi N S 3 E maxi Reference øA M e øB S4 S1 Model Series EHG EHG EHG 0K 1K 2K Dimensions (mm) A B e E L M N1) S1 S3 S4 18 19.2 M14x1.0 1.5 21.7 10.5 20.1 12.5 17 15 20 21.5 M16x1.0 1.5 27.0 15.5 25.1 14.5 19 17 25 27.0 M20x1.0 1.5 30.7 17.0 27.1 18.5 24 20 P1 Panel cut-out (page 153) Note: 1) maximum length with crimp contacts. www.lemo.com 37 ® ® EVG Fixed socket, nut fixing, key (G) or keys (A to F and L) and dust cap (spring loaded) L maxi N M Dimensions (mm) Reference øA P e øB S3 Model Series EVG 0K A B e E L M N1) P S1 S3 18 19.2 M14x1.0 6.5 24.8 6.3 23.3 23.3 12.5 17 P1 Panel cut-out (page 153) E maxi S1 Note: 1) maximum length with crimp contacts. PHG Free socket, key (G) or keys (A to F, L and R), cable collet Reference øA ~L Dimensions (mm) Model Series A L S2 PHG PHG PHG PHG PHG PHG 0K 1K 2K 3K 4K 5K 13 15 19 23 29 42 34.0 45.0 54.0 65.0 75.5 95.0 8 9 12 15 19 32 S2 M1 Cable assembly (page 162) PHG Free socket, key (G) or keys (A to F, L and R), cable collet and oversize cable collet 1) Dimensions (mm) Reference øB øA ~L Model Series A B L S1 S2 PHG PHG PHG PHG 1K 2K 3K 4K 15 19 23 29 14.5 17.0 22.0 36.0 63 70 89 124 12 15 19 30 12 15 19 32 M2 Cable assembly (page 163) S2 S1 Note: 1) correspond to K type of collet, the fitting of oversize collets onto this model allows them to be fitted to the cables that can be accommodated by the next housing size up (see page 53). PHG Free socket, key (G) or keys (A to F, L and R), cable collet and nut for fitting a bend relief 1) Reference øA ~L Dimensions (mm) Model Series A L S2 PHG PHG PHG PHG PHG 0K 1K 2K 3K 4K 13 15 19 23 29 34.0 45.0 54.0 64.0 75.5 7 9 12 15 19 M1 Cable assembly (page 162) S2 Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see page 141). 38 www.lemo.com ® ® PKG Fixed socket, nut fixing, key (G) or keys (A to F, L and R), cable collet Dimensions (mm) Reference ~L øA M e øB S3 Model Series A B PKG PKG PKG PKG PKG PKG 0K 1K 2K 3K 4K 5K 18 20 25 31 37 55 19.2 21.5 27.0 34.0 40.5 54.0 e E M14x1.0 6.0 M16x1.0 9.0 M20x1.0 9.0 M24x1.0 11.5 M30x1.0 9.0 M45x1.0 15.0 L M S1 S2 S3 34.0 45.0 54.0 65.0 75.5 98.0 4.0 4.5 5.0 6.0 6.5 9.0 12.5 14.5 18.5 22.5 28.5 42.5 8 9 12 15 19 30 17 19 24 30 36 – P1 Panel cut-out (page 153) S2 E maxi M1 Cable assembly (page 162) S1 Note: the 5K series is delivered with a round nut. PBG Fixed socket, key (G) with square flange, cable collet and screw fixing Reference ~L A M øB øC H Dimensions (mm) Model Series A B C F G H L M S2 PBG 3K 29 19 23 3 3.4 23 65 22.5 15 P7 Panel cut-out (page 153) M1 Cable assembly (page 162) S2 øG F PEG Fixed socket, nut fixing, key (G) or keys (A to F, L and R), cable collet (back panel mounting) Reference ~L P S2 E maxi e M øA øB S1 Dimensions (mm) Model Series A B e E L M P PEG PEG PEG PEG 0K 1K 2K 3K 18 20 25 30 18 20 25 31 M14x1.0 M16x1.0 M20x1.0 M24x1.0 5.0 6.5 4.0 7.5 34 45 54 65 3.5 3.5 3.5 4.5 8.5 10.0 7.5 12.0 S1 S2 12.5 14.5 18.5 22.5 8 9 12 15 P1 Panel cut-out (page 153) M1 Cable assembly (page 162) Note: the 3K series is delivered with a conical nut. www.lemo.com 39 ® ® TGL Free coupler, key (G) on one side and keys (L) on the other Dim. (mm) Reference L TGL.3K.3●●.CLLP A L 24 64.2 øA Note: this model is only available in type 308, 310, 316, 318, 320, 324 and 330. FTG T-plug, key (G) with sockets (90°), key (G) Dimensions (mm) L Reference M H L M 16 16 19 19 48 48 77 77 60 60 øA B H øB FTG.2K.304.CLF FTG.2K.308.CLF A 40 www.lemo.com ® ® Watertight or vacuumtight models These socket and coupler models allow the device on which they are fitted to reach a protection index of IP68 as per IEC 60529. They are fully compatible with plugs of the same series and are widely used for portable radios, military, laboratory equipment, aviation, etc. These models are identified by a letter «P» at the end of the reference. Most of these models are also available in a vacuumtight version. Such models are identified by an additional letter «V» at the end of the part number (certificate on request). Epoxy resin is used to seal these models. Technical Characteristics Mechanical and Climatical Characteristics Endurance Humidity Temperature range (0K-1K) Temperature range (2K to 5K) Salt spray corrosion test Climatical category Leakage rate (He)1) Note: 1) Value Standard Characteristics > 5000 cycles IEC 60512-5 test 9a up to 95% at 60° C - 20° C/+100° C - 20° C/+80° C > 144h IEC 60512-6 test 11f 20/80/21 IEC 60068-1 < 10-7 mbar.l.s-1 IEC 60512-7 test 14b only for vacuumtight models. Value 0K 1K 2K 3K 4K 5K Maximum operating pressure2) Standard 60 bars 60 bars 40 bars 30 bars 15 bars 5 bars IEC 60512-7 test 14d Note: 2) this value corresponds to the maximum allowed pressure difference for the assembled socket. HGG Fixed socket, nut fixing, key (G) or keys (A to F and L), watertight or vacuumtight L maxi Reference Dimensions (mm) øA M e øB S3 E maxi S1 Model Series A B e E L M S1 S3 HGG HGG HGG HGG HGG HGG 0K 1K 2K 3K 4K 5K 18 20 25 31 37 55 19.2 21.5 27.0 34.0 40.5 54.0 M14x1.0 M16x1.0 M20x1.0 M24x1.0 M30x1.0 M45x1.5 5.5 9.0 13.0 16.0 14.0 10.0 22.5 30.0 33.7 41.7 49.2 55.7 4.0 4.5 5.0 6.0 6.5 9.0 12.5 14.5 18.5 22.5 28.5 42.5 17 19 24 30 36 – P1 Panel cut-out (page 153) Note: the 5K series is delivered with a round nut. HEG Fixed socket, nut fixing, key (G) or keys (A to F and L), watertight or vacuumtight (back panel mounting) L maxi P E maxi www.lemo.com M Dimensions (mm) øA Reference e øB S1 Model Series HEG HEG HEG 0K 1K 2K A B e E L M P S1 18 18 M14x1.0 2.4 22.5 3.5 7 12.5 20 20 M16x1.0 6.2 30.0 3.5 10 14.5 25 25 M20x1.0 5.0 33.7 3.5 10 18.5 P1 Panel cut-out (page 153) 41 ® ® S ● ● Fixed coupler, nut fixing, key (G) or keys (L) at the flange end, and key (G) or keys (C or L) at the other end, watertight or vacuumtight L M øA S1 e øB S3 E maxi G SGL L L SLG G Reference Model SLC L C Example SGL SLG SLG SLG SLC SLG SLC Series Contacts Type Dimensions (mm) A B e E L M S1 S3 3K female – male male – female male – female 4K male – female 37 40.5 M30x1.0 48 74.0 6.5 28.5 36 5K male – female 55 54.0 M45x1.5 58 88.0 9.0 42.5 2K 25 27.0 M20x1.0 25 52.4 5.0 18.5 24 31 34.0 M24x1.0 33 64.0 6.0 22.5 30 – SGL Plug with key G Plug with key L Alignment key see page 43. 42 P1 Panel cut-out (page 153) Note: for this fixed coupler, the first contact type mentioned is always the one at the flange end. On request, these couplers can be produced in other series, with other keys. The 5K series is delivered with a round nut. www.lemo.com ® ® Alignment Key (K series) Alignment Key and Polarized Keying System β δ γ α Front view of a socket 1 2 2 2 2 2 2 2 Nb of keys 5 Angles G A B C D E F L α γ β γ Contact type Series Note 0K 1K 2K 3K 4K 5K Plug Socket 0° 30° 45° 60° 95° 120° 145° 75° 0° 30° 45° 60° 95° 120° 145° 75° 0° 30° 45° 60° 95° 120° 145° 75° 0° 30° 45° 60° 95° 120° 145° 75° 0° 30° 45° 60° 95° 120° 145° 75° 0° 30° 45° 60° 95° 120° 145° 75° male male male male male male male female female female female female female female female male ● ● ● ● ● ● ● ● Contact type Series 0K 1K 2K 3K 4K 5K Plug Socket α β γ δ – – – – – – – – – – – – 95° 115° 35° 25° – – – – – – – – male female Note β Nb of keys Angles α Reference Front view of a socket Reference K series connector model part numbers are composed of three letters. The LAST LETTER indicates the key position and the contact type (male or female). δ γ R ● Note: S●● and TGL models are not available with all the keys. For S●● models see explication on page 42. Please consult the pages corresponding to these models. ● First choice alternative ● Special order alternative www.lemo.com 43 ® 44 ® www.lemo.com ® ® Insert configuration (B and K series) Multipole Female solder contacts ● First choice alternative ● Special order alternative www.lemo.com Note: 1) 2) 3) 4) 5) 302 2 0.5 ● ● ● ● 1.00 0.95 1.15 1.20 5.0 303 3 0.5 ● ● ● ● 0.80 0.95 1.35 1.10 3.0 304 4 0.5 ● ● ● ● 0.80 0.65 1.05 1.05 2.0 302 2 0.9 ● ● ● ● 1.30 1.05 1.45 1.20 10.02) 303 3 0.9 ● ● ● ● 1.20 0.90 1.70 1.60 8.02) 304 4 0.7 ● ● ● ● 0.85 0.70 1.35 1.10 7.02) 305 5 0.7 ● ● ● ● 1.00 0.70 1.25 1.20 6.52) 306 6 0.5 ● ● 4) ● ● 0.85 0.65 1.40 1.20 2.5 307 7 0.5 ● ● 4) ● ● 0.80 0.70 1.40 1.20 2.5 309 9 0.5 ● ● 4) ● ● 0.60 0.50 1.00 0.85 2.0 302 2 1.3 ● ● ● ● 1.50 1.35 1.70 1.45 15.03) 303 3 1.3 ● ● ● ● 1.30 1.55 1.60 1.85 304 4 0.9 ● ● ● ● 1.35 1.45 1.70 1.80 10.02) 305 5 0.9 ● ● ● ● 1.25 1.15 1.30 1.55 9.02) 306 6 0.7 ● ● ● ● 1.05 1.20 1.35 1.45 7.02) 307 7 0.7 ● ● ● ● 0.95 1.05 1.45 1.45 7.02) 308 8 0.7 ● ● ● ● 0.95 1.15 1.30 1.30 5.0 310 10 0.5 ● ● 4) ● ● 0.90 1.50 1.20 1.80 2.5 314 14 0.5 ● ● 4) ● ● 0.80 1.20 0.95 1.60 2.0 316 16 0.5 ● ● 4) ● ● 0.80 1.25 0.95 1.60 1.5 Test voltage (kV rms)1) Contact-contact Rated current (A)1) 1B 1K Test voltage (kV rms)1) 5) Contact-shell 0B 0K Test voltage (kV rms)1) 5) Contact-shell 00 Test voltage (kV rms)1) Contact-contact Female crimp contacts Print (elbow) 2 Print (straight) 3 Crimp 3 Solder 2 ø A (mm) 1 Number of contacts 4 Crimp contact Reference 4 øA 1 Male crimp contacts Solder contact Contact type øA Male solder contacts 12.0 see calculation method, caution and suggested standard on page 178. rated current = 6A for socket with elbow (90°) contact for printed circuit. rated current = 12A for socket with elbow (90°) contact for printed circuit. available only for connectors fitted with male contacts. test voltage (kV) contact-shell may be lower for K series (values shown here are for B series). 45 ® ® Multipole Female solder contacts ● First choice alternative ● Special order alternative 46 Note: 1) 2) 3) 4) Print (elbow) Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) 4) Contact-shell Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) 4) Contact-shell 302 2 2.0 ● ● ● ● 2.10 1.75 2.85 2.70 25.03) 303 3 1.6 ● ● ● ● 2.40 1.85 1.90 1.90 17.03) 304 4 1.3 ● ● ● ● 1.85 1.85 2.20 2.20 15.03) 305 5 1.3 ● ● ● ● 1.75 1.60 2.15 2.15 14.03) 306 6 1.3 ● ● ● ● 1.35 1.45 2.00 2.35 12.0 307 7 1.3 ● ● ● ● 1.75 1.60 1.95 2.15 11.0 308 8 0.9 ● ● ● ● 1.50 1.25 1.95 1.95 10.02) 310 10 0.9 ● ● ● ● 1.45 1.30 1.80 2.10 8.02) 312 12 0.7 ● ● ● ● 1.25 1.35 1.65 2.00 7.02) 314 14 0.7 ● ● ● ● 1.15 1.35 1.55 1.55 6.52) 316 16 0.7 ● ● ● ● 0.95 1.25 1.55 1.75 6.0 318 18 0.7 ● ● ● ● 0.85 1.20 1.45 2.10 5.5 319 19 0.7 ● ● ● ● 0.95 1.25 1.55 1.65 5.0 326 26 0.5 ● – ● ● 0.95 1.30 1.20 1.80 2.0 332 32 0.5 ● – ● ● 0.80 0.95 1.60 1.5 1.2 Rated current (A)1) Print (straight) 2B 2K Crimp Female crimp contacts Solder 2 ø A (mm) 1 3 Number of contacts 4 3 Crimp contact Reference 4 2 øA 1 Male crimp contacts Solder contact Contact type øA Male solder contacts see calculation method, caution and suggested standard on page 178. rated current = 6A for socket with elbow (90°) contact for printed circuit. rated current = 12A for socket with elbow (90°) contact for printed circuit. test voltage (kV) contact-shell is a little bit lower for K series (values here are for B series). www.lemo.com ® ® Multipole ● First choice alternative ● Special order alternative www.lemo.com Note: 1) 2) 3) 302 2 3.0 ● ● ● – 2.10 1.55 2.30 1.80 35.0 303 3 2.0 ● ● ● ● 1.90 1.50 3.20 2.65 25.0 304 4 2.0 ● ● ● ● 1.45 1.25 2.50 2.20 19.0 305 5 1.6 ● ● ● ● 1.90 1.25 2.40 1.75 19.0 306 6 1.6 ● ● ● ● 1.60 1.15 1.90 1.80 17.0 307 7 1.6 ● ● ● ● 1.70 1.25 2.00 2.05 15.0 308 8 1.3 ● ● ● ● 1.65 1.15 1.85 1.75 13.0 309 8 1 1.3 2.0 ● ● ● – 1.35 1.05 1.35 1.05 1.10 1.05 1.10 1.05 6.0 15.0 310 10 1.3 ● ● ● ● 1.25 0.90 1.50 1.80 12.0 312 12 0.9 ● ● ● ● 1.45 1.00 1.65 1.85 9.0 314 14 0.9 ● ● ● ● 1.20 1.20 1.80 1.65 9.02) 316 16 0.9 ● ● ● ● 1.20 0.85 1.80 1.50 8.0 318 18 0.9 ● ● ● ● 1.20 1.05 1.85 1.60 7.0 320 20 0.7 ● ● ● ● 1.00 0.90 1.35 1.55 6.0 322 22 0.7 ● ● ● ● 1.00 0.90 1.70 1.45 5.5 324 24 0.7 ● ● ● ● 0.95 0.80 1.35 1.35 4.0 326 26 0.7 ● ● ● ● 0.95 0.70 1.50 1.30 4.0 330 30 0.7 ● ● ● ● 0.80 0.70 1.35 1.20 3.5 Rated current (A)1) Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) 3) Contact-shell Print (elbow) Test voltage (kV rms)1) Contact-contact Print (straight) 3B 3K Crimp Female crimp contacts Solder 2 ø A (mm) 1 3 Number of contacts 4 3 Crimp contact Reference 4 2 øA 1 Male crimp contacts Solder contact Contact type Test voltage (kV rms)1) 3) Contact-shell Female solder contacts øA Male solder contacts see calculation method, caution and suggested standard on page 178. rated current = 6A for socket with elbow (90°) contact for printed circuit. test voltage (kV) contact-shell is a little bit lower for K series (values here are for B series). 47 ® ® Multipole Female solder contacts Contact type ● First choice alternative ● Special order alternative 48 Note: 1) 2) Test voltage (kV rms)1) 2) Contact-shell Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) 2) Contact-shell Rated current (A)1) 4B 4K Test voltage (kV rms)1) Contact-contact Female crimp contacts Print (straight) Male crimp contacts Crimp 2 Solder 1 3 ø A (mm) 4 3 Crimp contact Number of contacts 4 2 øA 1 Solder contact Reference øA Male solder contacts 304 4 3.0 ● ● ● 2.10 1.50 1.80 1.20 30.0 306 6 2.0 ● ● ● 2.00 1.75 2.75 2.40 24.0 307 7 2.0 ● ● ● 2.00 1.80 1.50 1.35 20.0 310 10 1.6 ● ● ● 1.85 1.30 1.90 1.95 17.0 312 12 1.3 ● ● ● 1.45 1.60 1.90 1.85 12.0 316 16 0.9 ● ● ● 1.35 1.50 2.30 2.10 10.0 320 20 0.9 ● ● ● 1.35 1.00 1.05 0.95 8.0 324 24 0.9 ● ● ● 1.20 1.45 1.80 2.05 7.0 330 30 0.9 ● ● ● 0.95 0.85 1.75 1.45 5.0 340 40 0.7 ● ● ● 0.90 0.90 1.30 1.30 2.0 348 48 0.7 ● ● ● 0.70 0.70 1.00 1.00 1.5 see calculation method, caution and suggested standard on page 178. test voltage (kV) contact-shell is a little bit lower for K series (values here are for B series). www.lemo.com ® ® Multipole Female solder contacts Contact type ● First choice alternative ● Special order alternative www.lemo.com Note: 1) 2) Test voltage (kV rms)1) 2) Contact-shell Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) 2) Contact-shell Rated current (A)1) 5B 5K Test voltage (kV rms)1) Contact-contact Female crimp contacts Print (straight) Male crimp contacts Crimp 2 Solder 1 3 ø A (mm) 4 3 Crimp contact Number of contacts 4 2 øA 1 Solder contact Reference øA Male solder contacts 302 2 6.0 ● – – 3.60 2.95 – – 50.0 304 4 4.0 ● ● ● 2.95 2.65 3.20 2.40 35.0 310 10 3.0 ● ● ● 2.35 2.30 2.65 3.20 20.0 314 14 2.0 ● ● ● 2.10 2.00 2.85 2.95 18.0 316 16 2.0 ● ● ● 1.85 1.95 2.45 3.05 12.0 320 20 1.6 ● ● ● 1.90 1.70 2.20 2.40 10.0 330 30 1.3 ● ● ● 1.45 1.60 2.05 2.45 8.0 340 40 1.3 ● ● ● 1.30 1.45 2.00 1.95 7.0 348 48 1.3 ● ● ● 1.20 1.10 2.00 1.55 6.0 350 50 0.9 ● ● ● 1.30 1.60 1.20 1.45 6.0 354 54 0.9 ● ● ● 1.15 1.55 2.00 2.10 5.0 364 64 0.9 ● ● ● 1.30 1.55 1.35 1.85 3.0 see calculation method, caution and suggested standard on page 178. test voltage (kV) contact-shell is a little bit lower for K series (values here are for B series). 49 ® ® Housings (B and K series) Ref. Outer shell and collet nut Material C N K S T U L X G P R H P Latch sleeve + earthing crown Surf. treatment Brass chrome Brass nickel Brass black chrome Stainless steel – Stainless steel – Stainless steel – Aluminium alloy anodized Aluminium alloy nickel anthracite PEEK (natural) – PSU – PPSU – PPS/brass –/nickel PA.6 – Other metallic components Material Surf. treatment Material Surf. treatment brass/bronze brass/bronze brass/bronze brass/bronze stainless steel stainless steel brass/bronze brass/bronze brass/bronze brass/bronze brass/bronze brass/bronze brass/bronze nickel 2) nickel 2) nickel 2) nickel 2) – – nickel 2) nickel 2) nickel 2) nickel 2) nickel 2) nickel 2) nickel 2) brass brass brass brass brass stainless steel brass brass brass brass brass brass brass nickel nickel nickel nickel nickel – nickel nickel nickel nickel nickel nickel nickel Remarks Note Only for FGG and ENG (B series) Only for FGY and ENY (B series) 1) Only for FGY and ENY (B series) 1) Only for elbow sockets (B series) Only for CRF and CRG bridge plug 1) ● ● ● ● ● ● ● ● ● ● ● ● ● 1) Note: detailed characteristics of these materials and treatments are presented on page 171. 1) see «variant» for the colour. 2) in the K series, the latch sleeve is chrome-plated. ● First choice alternative ● Special order alternative Insulators (B and K series) Ref. Y L Material PEEK PEEK Contact type Crimp Solder or print Remarks extended design, with contacts that recess into insulator Note ● ● Note: detailed characteristics of these materials are presented on page 175. Contacts (B and K series) Soldering characteristics Crimping characteristics – no need to order specific tools, a simple soldering iron is sufficient – ideal for very small and fragile conductors – contacts with solder cups to allow the solder to flow – – – – practical, quick contact fixing outside the insulator possible use at high temperature need to order specific tools no risk of heating the insulator during the conductorcontact fixing – high tensile strength – totally lead-free solution Note: see page 176 for more information. 50 www.lemo.com ® ® Contacts reference for plugs, free or fixed sockets Reference Contact type Male Female Solder øA øC øA øC fig. 1 Crimp øA øC øA øC fig. 2 øC øA øC øA Contact øA (mm) øC Form (mm) per fig. Solid AWG Section max. max. (mm2) Conductor Stranded AWG Section (mm2) min. max. min. max. Fr 1) (N) Notes 0.52) 0.5 0.7 0.9 1.3 1.6 2.0 3.0 4.0 6.0 0.402) 0.45 0.80 0.80 1.00 1.40 1.80 2.70 3.70 5.20 – – – – – – – – – – 28 28 22 22 20 16 14 10 10 – 0.09 0.09 0.34 0.34 0.50 1.00 1.50 4.00 6.00 – – – – – – – – – – – 30 28 223) 223) 203) 18 16 12 10 8 – – – – – – – – – – 0.05 0.09 0.34 0.34 0.50 1.00 1.50 4.00 6.00 10.00 – – – – – – – – – – 0.54) 0.45 0.80 0.45 1.10 0.80 0.45 1.40 1.10 0.80 1.90 1.40 2.40 1.90 2.90 4.00 1 1 2 1 2 2 1 2 2 1 2 1 2 1 1 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 32 26 32 24 26 32 20 24 26 18 22 16 18 14 12 28 223) 28 20 223) 28 18 20 223) 143) 18 123) 14 103) 10 0.035 0.140 0.035 0.250 0.140 0.035 0.500 0.250 0.140 1.000 0.340 1.500 1.000 2.500 4.000 0.09 0.34 0.09 0.50 0.34 0.09 1.00 0.50 0.34 1.50 1.00 2.50 1.50 4.00 6.00 12 ● A L C C B C B G C B G C B C B C C M M P M P U M P U M P M P M M D N L dimensions and C are detailed in the section on PCB drilling pattern. See page 156. ● V V L dimensions and C are detailed in the section on PCB drilling pattern. See page 157. ● 0.7 0.9 1.3 1.6 2.0 3.0 4.0 22 30 40 50 65 75 90 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Print L øC øA øA øC L Print (elbow) L øA øC Note: 1) 2) 3) 4) contact retention force in the insulator (according to IEC 60512-8 test 15 a). for 00 multipole series. for a given AWG, the diameter of some stranded conductor designs is larger than the solder cup diameter. Make sure that the maximum conductor diameter is smaller than ø C. available only for 00 multipole series and connectors fitted with male contacts of the 0B and 1B series. ● First choice alternative ● Special order alternative Contacts reference for couplers R●●, S●● and TGL Contact type Ref. A L M Male - Female Female - Male Female - Female www.lemo.com Remarks contact configuration is explained on page 21, 28, 42 contact configuration is explained on page 21, 28, 42 contact configuration is explained on page 21 51 ® ® Collets (B and K series) D and M type collets for B series øB øA D type Reference øA øB M type Collet ø Cable ø Reference Collet ø Cable ø Notes Type Code 00 0B 1B 2B øA øB max. Notes min. Type Code D D D 22 27 35 2.2 2.7 3.5 – – 2.8 2.2 2.7 3.5 1.4 > 2.2 > 2.7 NEW NEW NEW D D D D D 21 31 42 52 56 2.1 3.1 4.2 5.2 5.6 – – – 4.7 4.7 2.2 3.2 4.2 5.2 5.6 1.4 > 2.2 > 3.2 > 4.2 > 5.2 NEW NEW NEW NEW NEW1) M M D D D D D 27 31 42 52 62 72 76 2.7 3.1 4.2 5.2 6.2 7.2 7.6 – – – – – 6.7 6.7 2.7 3.1 4.2 5.2 6.2 7.2 7.5 > 2.2 > 2.7 2.5 > 4.2 > 5.2 > 6.2 7.1 NEW NEW NEW NEW NEW NEW M M D D D D D D D 21 31 42 52 62 72 82 92 99 2.1 3.1 4.2 5.2 6.2 7.2 8.2 9.2 9.9 – – – – – – – 8.6 8.6 2.2 3.2 4.2 5.2 6.2 7.2 8.2 9.2 9.7 1.4 > 2.2 > 3.2 > 4.2 > 5.2 > 6.2 > 7.2 > 8.2 9.1 NEW NEW NEW NEW NEW NEW NEW NEW 3B 4B 1) 5B 1) øA øB max. min. M D D D D D D D 52 62 72 82 92 10 11 12 5.2 6.2 7.2 8.2 9.2 10.2 11.2 11.9 – – – – – – 10.2 10.2 5.0 6.2 7.7 8.0 9.2 10.7 11.0 11.7 4.1 4.9 > 6.2 7.1 > 7.7 > 9.2 10.1 11.1 M M M M D D D D D 62 72 82 92 10 12 13 15 16 6.2 7.2 8.2 9.2 10.8 12.3 13.8 15.3 16.3 – – – 8.6 – – 12.5 12.5 12.5 6.0 7.0 8.0 9.0 10.5 12.0 13.5 15.0 16.0 5.1 6.1 7.1 8.1 9.1 10.6 12.1 13.6 15.1 D D D D D D D D 11 13 15 17 19 21 23 25 11.8 13.8 15.8 17.8 19.8 21.8 23.8 25.3 – – – – – – 21.8 21.8 11.5 13.5 15.5 17.5 19.5 21.5 23.5 25.0 9.6 11.6 13.6 15.6 17.6 19.6 21.6 23.6 NEW NEW NEW NEW 1) 1) 1) 1) 1) 1) 1) Note: all dimensions are in millimetres. 1) these collets cannot be used for connector models with nut for fitting a bend relief. 52 www.lemo.com ® ® C and K type collets for K series øB K type oversize cable collet Reference Type Code 0K 1K 2K 3K øA øA øB C type Collet ø Cable ø Reference øA øB max. min. C C C C C C C C C 10 15 20 25 30 35 40 45 50 1.6 1.6 2.1 3.1 3.1 4.2 4.2 5.2 5.2 – – – – – 4.2 4.2 5.2 5.2 1.2 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 1.0 1.3 1.6 2.1 2.6 3.1 3.6 4.1 4.6 C C C C C C C C C C C K K K K 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 1.6 2.2 3.2 3.2 4.2 4.2 5.2 5.2 6.2 6.2 7.2 7.2 8.2 8.2 9.2 – – – – – – – – 6.2 6.2 6.7 – 8.2 8.2 8.6 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 1.3 1.6 2.1 2.6 3.1 3.6 4.1 4.6 5.1 5.6 6.1 6.6 7.1 7.6 8.1 C C C C C C C C C C C C C C C K K K K 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 90 95 10 11 2.2 2.2 3.2 3.2 4.2 4.2 5.2 5.2 6.2 6.2 7.2 7.2 8.2 8.2 9.2 9.2 10.2 10.2 11.2 – – – – – – – – – – – – 8.2 8.2 8.6 – 10.2 10.2 10.6 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.0 10.5 1.3 1.6 2.1 2.6 3.1 3.6 4.1 4.6 5.1 5.6 6.1 6.6 7.1 7.6 8.1 8.6 9.1 9.6 10.1 C C C C C C C C 30 35 40 45 50 55 60 65 3.2 4.2 4.2 5.2 5.2 6.2 6.2 7.2 – – – – – – – – 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 2.6 3.1 3.6 4.1 4.6 5.1 5.6 6.1 Type Code 3K 4K 5K Collet ø Cable ø øA øB max. min. C C C C C C C C K K K K K 70 75 80 85 90 95 10 11 11 12 13 14 15 7.2 8.2 8.2 9.2 9.2 10.2 10.2 11.2 12.3 13.8 13.8 15.3 15.3 – – – – – 10.2 10.2 10.6 – 13.8 13.8 15.3 15.3 7.0 7.5 8.0 8.5 9.0 9.5 10.0 10.5 12.0 12.8 13.5 14.0 15.0 6.6 7.1 7.6 8.1 8.6 9.1 9.6 10.1 10.6 12.1 12.9 13.6 14.1 C C C C C C C C C C C C C C C C K K K K K K K K 50 55 60 65 70 75 80 85 90 95 10 11 12 13 14 15 16 17 18 19 20 21 22 23 6.3 6.3 6.3 7.3 7.3 8.3 8.3 9.3 9.3 10.8 10.8 12.3 13.8 13.8 15.3 15.3 17.8 17.8 19.8 19.8 21.8 21.8 23.8 23.8 – – – – – – – – – – – – 13.8 13.8 15.3 15.3 – – – – – – 23.8 23.8 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.5 12.0 12.8 13.5 14.0 15.0 16.5 17.5 18.5 19.5 20.5 21.5 22.5 23.5 4.6 5.1 5.6 6.1 6.6 7.1 7.6 8.1 8.6 9.1 9.6 10.6 12.1 12.9 13.6 14.1 15.6 16.6 17.6 18.6 19.6 20.6 21.6 22.6 C C C C C C C C C C C C C C 10 11 12 13 14 15 16 17 18 19 20 21 22 23 11.8 11.8 13.8 13.8 15.8 15.8 17.8 17.8 19.8 19.8 21.8 21.8 23.8 23.8 – – – – – – – – – – – – 23.8 23.8 10.5 11.5 12.5 13.5 14.5 15.5 16.5 17.5 18.5 19.5 20.5 21.5 22.5 23.5 9.6 10.6 11.6 12.6 13.6 14.6 15.6 16.6 17.6 18.6 19.6 20.6 21.6 22.6 Note: all dimensions are in millimetres. www.lemo.com 53 ® ® Variant (B and K series) Bend relief for B series models with collet Bend relief for K series models with collet Need to be ordered Type Code Need to be ordered separately (see pages 141 and 142) Collet Ref. Ref. Collet Need to be ordered Type Code Need to be ordered separately (see pages 141 and 142) 00 Z D 22 to 35 GMA.00.●●●.●● GMB.00.●●●.●● 0K Z C 10 to 50 GMA.0B.●●●.●● 0B Z D 21 to 52 GMA.0B.●●●.●● 1K Z C K 15 to 65 70 to 85 GMA.1B.●●●.●● GMA.2B.●●●.●● 1B Z M D 27 and 31 42 to 72 GMA.1B.●●●.●● GMA.1B.●●●.●● 2K Z C K 15 to 85 90 to 10 GMA.2B.●●●.●● GMA.3B.●●●.●● Z M D D 21 and 31 42 52 to 92 GMA.0B.●●●.●● GMA.2B.●●●.●● GMA.2B.●●●.●● 3K Z C K 30 to 10 11 to 15 GMA.3B.●●●.●● GMA.4B.●●●.●● M D 52 62 to 11 GMA.1B.●●●.●● GMA.3B.●●●.●● 4K Z C 50 to 15 GMA.4B.●●●.●● Z Z M M D 62 and 72 82 and 92 10 to 15 GMA.2B.●●●.●● GMA.4B.●●●.●● GMA.4B.●●●.●● Z D 11 to 15 GMA.4B.●●●.●● 2B 3B 4B 5B Note: All dimensions are in millimetres. Colour of the bridge plug shells and connectors shell made of plastic material and aluminium alloys Bridge plug and plastic shell Reference Colour A B G J M N R S T V L X F blue white grey yellow brown black red orange natural green black natural cream PSU PPSU ● ● PA.6 Anodized colour ● ● ● ● ● ● ● ● ● ● B K 54 Anodized colour for bend relief collet nut ● ● ● ● ● ● ● ● Watertight and vacumtight socket and coupler models (B and K series) Model Aluminium alloys Reference Watertight Vacuumtight YH●, HG●, HN●, HH●, HC●, HE●, HM●, S●● P HG●, HE●, S●● P Note: other anodizing colours are available for connectors with collet nut for bend relief. Please consult us. O-ring and gasket material (K series) Standard connectors are delivered with silicone o-ring and gaskets. The vacuumtight models, identified with the letter «PV», are delivered with Viton® gaskets. Other gaskets material can be delivered upon special request. PV PV O-ring material Reference FPM (Viton®) EPDM FPM (Viton®) and collet nut for bend relief H E D www.lemo.com L SERIES (watertight keyed) E SERIES (watertight) S SERIES ® ® S Series S series connectors have main features as follows: – security of the Push-Pull self-latching system – unipole types transmitting current up to 230 A and multipole types with up to 106 contacts – 360° screening for full EMC shielding. – solder or print contacts (straight or elbow) – polarisation by stepped insert (half-moon) fitted with male and female contacts Metal housing models (page 58) Fixed plug Straight plugs FAA Fixed sockets Free sockets FFA, FFP ERA EEP PCA, PCP FFA ERN ERD PCA FFA, FFP ERC FFB ERS Elbow plugs FLA FLS PCA, PCP ECP PZP ECP Fixed sockets FFE EHP ECP PSA, PSP FFL Free coupler EBD PSS RMA FFF T-plug EBS Fixed coupler FFS FTA EBC RAD FZP Elbow socket models (page 68) Elbow sockets EXP EPL Plastic housing models (page 70) Straight plugs Watertight or vacuumtight models (page 72) Fixed socket Fixed sockets Fixed coupler FFA, FFP HGP FFP EWB ERN SWH FFL HCP 56 HGW www.lemo.com ® ® Part Numbering System Plug FFA . 1S . 304 . C L A C 32 Free socket PCA . 1S . 304 . C L L C 32 Z Variant: (page 107) Cable ø: (page 102) Collet type: (page 102) Fixed socket ERA . 1S . 304 . C L L Coupler RAD . 1S . 304 . C L L Variant: (page 107) Model: (page 58) Contact: (page 99) Series: (page 58) Insulator: (page 99) Insert configuration: (page 91) Housing: (page 99) Part Number Example Straight plug with cable collet: FFA.1S.304.CLAC32 = straight plug with cable collet, 1S series, multipole type with 4 contacts, outer shell in chromeplated brass, PEEK insulator, 2 male and 2 female solder contacts, C type collet for a 3.2 mm diameter cable. Free socket: PCA.1S.304.CLLC32Z = free socket, with cable collet, 1S series, multipole type with 4 contacts, outer shell in chromeplated brass, PEEK insulator, 2 female and 2 male solder contacts, C type collet for a 3.2 mm diameter cable and nut for fitting a bend relief. Fixed socket: ERA.1S.304.CLL = fixed socket, nut fixing, 1S series, multipole type with 4 contacts, outer shell in chrome-plated brass, PEEK insulator, 2 female and 2 male solder contacts. Fixed coupler: RAD.1S.304.CLL = straight coupler, nut fixing, 1S series, multipole type with 4 contacts, outer shell in chrome-plated brass, PEEK insulator, 2 female and 2 male contacts each end. Part Section Showing Internal Components Straight plug Fixed socket 6 1 2 3 4 5 6 7 8 www.lemo.com outer shell earthing crown retaining ring hexagonal nut locking washer insulator male contact female contact 2 3 1 4 5 8 7 1 7 6 5 4 2 8 3 1 outer shell 2 latch sleeve 3 collet nut 4 centre-piece 5 insulator 6 male contact 7 female contact 8 collet 57 ® ® Metal housing models Technical Characteristics Electrical Mechanical and Climatical Characteristics Value Endurance Humidity Temperature range Resistance to vibrations Shock resistance Salt spray corrosion test Protection index (mated) Climatical category Standard > 5000 cycles IEC 60512-5 test 9a up to 95% at 60° C - 55° C, +250° C 10-2000 Hz, 15 g IEC 60512-4 test 6d 100 g, 6 ms IEC 60512-4 test 6c > 144h IEC 60512-6 test 11f IP 50 IEC 60529 55/175/21 IEC 60068-1 Characteristics Value at 10 MHz at 1 GHz Shielding efficiency Standard > 75 dB > 40 dB IEC 60169-1-3 IEC 60169-1-3 Note: The various tests have been carried out with FFA and ERA connector pairs, with chrome-plated brass shell and PEEK insulator. Detailed electrical characteristics, as well as materials and treatment are presented in the chapter Technical Characteristics on page 171. FFA Straight plug, cable collet Reference ~L øA ~M S2 Model Series FFA FFA FFA FFA FFA FFA FFA FFA 00 0S 1S 2S 3S 4S 5S 6S Dimensions (mm) A L M 6.4 26.0 18.0 9.0 34.5 24.5 12.0 42.5 31.5 14.8 52.0 40.0 17.8 61.0 46.0 24.8 77.0 59.0 35.0 103.0 78.0 46.0 106.0 81.0 S2 4.5 6.5 8.5 11.0 14.0 19.0 29.0 38.0 M1 Cable assembly (pages 163 to 165) FFA Straight plug with oversize cable collet 1) Reference ~L ~M Model Series A FFA FFA FFA FFA FFA FFA FFA 00 0S 1S 2S 3S 4S 5S 6.4 9.0 12.0 14.8 17.8 24.8 35.0 B L M 8.0 34.0 26.0 10.0 45.5 35.5 13.0 57.0 46.0 18.0 67.0 55.0 21.0 85.0 70.0 31.8 107.0 89.0 41.8 138.0 113.0 S1 S2 7.0 9.0 12.0 14.0 19.0 28.5 37.5 6.5 8.5 11.0 14.0 19.0 29.0 38.0 M2 Cable assembly (pages 164 and 166) S1 S2 Dimensions (mm) Note: 1) correspond to K type of collet, the fitting of oversize collets onto this model allows them to be fitted to the cables that can be accommodated by the next housing size up (see page 102). FFA Straight plug, cable collet and nut for fitting a bend relief 1) Reference ~L ~M S2 58 Dimensions (mm) Model Series A L M S2 FFA FFA FFA FFA FFA FFA 00 0S 1S 2S 3S 4S 6.4 9.0 12.0 14.8 17.8 24.8 26.0 34.5 42.5 52.0 61.0 77.0 18.0 24.5 31.5 40.0 46.0 59.0 6 7 9 12 14 20 M1 Cable assembly (pages 163 and 164) Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see page 141). www.lemo.com ® ® FFP Straight plug, cable collet and inner anti-rotating device Reference ~L ~M S2 Dimensions (mm) Model Series A L FFP FFP FFP FFP FFP 0S 1S 2S 3S 4S 9.0 12.0 14.8 17.8 24.8 34.5 42.5 52.0 61.0 77.0 M S2 24.5 6.5 31.5 8.5 40.0 11.0 46.0 14.0 59.0 19.0 M1 Cable assembly (pages 163 and 164) FFB Straight plug, cable collet and safety locking ring Reference ~L øA ~M Dimensions (mm) Model Series A L FFB FFB FFB FFB 0S 1S 2S 3S 9.0 12.0 14.8 17.8 36.8 45.0 55.5 65.0 M S2 26.8 6.5 34.0 8.5 43.5 11.0 50.0 14.0 M1 Cable assembly (pages 163 and 164) S2 Note: nut for fitting a bend relief (available only for size 1S). FFE Straight plug, cable collet, front seal and nut for fitting a bend relief 1) (protected to IP54 when mated) Reference ~L øA ~M Dimensions (mm) Model Series A L M S2 FFE FFE FFE FFE FFE 00 0S 1S 2S 3S 7.4 10.0 13.0 16.0 19.0 26.0 34.5 42.5 52.0 61.0 18.0 24.5 31.5 40.0 46.0 6 7 9 12 14 M1 Cable assembly (pages 163 and 164) S2 Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see page 141). FFL Straight plug, flats on latch sleeve, cable collet and inner anti-rotating device Reference Dimensions (mm) ~L øA ~M S2 www.lemo.com S1 Model Series FFL 2S A L M 15.0 49.0 37.0 S1 S2 13 12 M4 Cable assembly (page 165) Note: this model is fitted with a «D or M» type collet system. It is also adapted for crimp contacts. Available only for multipole. 59 ® ® FFF Straight plug, non-latching, cable collet Reference ~L øA ~M Dimensions (mm) Model Series A L M FFF FFF FFF FFF 00 0S 1S 2S 6.4 9.0 12.0 14.8 26.0 34.5 42.5 52.0 S2 18.0 4.5 24.5 6.5 31.5 8.5 40.0 11.0 M1 Cable assembly (pages 163 and 164) S2 FFS Straight plug for cable crimping Reference L øA M S1 Dimensions (mm) Model Series A L M S1 S2 FFS 00 6.4 31 23 5.5 5.5 M5 Cable assembly (page 163) Note: Model available only with crimp backnut E31 similar to 00.250 series. S2 FZP Straight plug for remote handling, cable collet and inner anti-rotating device Reference ~L øA ~M S2 N Dimensions (mm) Model Series A L M N S2 S3 FZP FZP FZP FZP FZP FZP 1S 2S 3S 4S 5S 6S 16 24 24 35 43 60 42.5 52.0 61.0 77.0 103.0 106.0 31.5 40.0 46.0 59.0 78.0 81.0 15 21 24 30 44 44 8.5 11.0 14.0 19.0 29.0 38.0 12 18 18 28 35 50 S3 M1 Cable assembly (pages 163 to 165) FAA Fixed plug non-latching, nut fixing Reference L maxi øA M e øB S3 E maxi S1 Dimensions (mm) Model Series A B e E L L1) M S1 S3 FAA FAA FAA FAA FAA FAA FAA FAA 00 0S 1S 2S 3S 4S 5S 6S 8 10 14 18 22 28 40 54 10.2 12.4 15.8 19.2 25.0 34.0 40.0 54.0 M7x0.5 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M25x1.0 M35x1.0 M48x1.5 2.0 2.0 2.5 4.0 4.0 2.5 2.5 2.5 – 18.5 22.5 25.0 31.0 35.5 45.0 45.0 15.5 18.0 21.7 25.3 29.0 39.0 – – 9.0 11.2 12.5 13.8 17.0 20.5 28.0 28.0 6.3 8.2 10.5 13.5 16.5 23.5 33.5 – 9 11 14 17 22 30 – – P1 Panel cut-out (page 152) P2 Panel cut-out 6S series (page 152) Note: 1) unipole model 60 www.lemo.com ® ® FLA Elbow (90°) plug, cable collet Reference L M A A1 Dimensions (mm) Model Series A A1 H L M S1 S2 FLA FLA FLA FLA FLA FLA FLA FLA 00 0S 1S 2S 3S 4S 5S 6S 9 13 16 20 21 28 – – – 13 16 20 21 28 37 48 16.0 24.5 28.5 37.0 44.0 56.0 76.5 94.0 17.5 23.0 26.5 31.0 38.5 49.0 65.0 81.0 9.5 13.0 15.5 19.0 23.5 31.0 40.0 56.0 – 8 10 13 15 20 30 40 4.5 6.5 8.5 11.0 14.0 19.0 29.0 38.0 ~H S1 M3 Cable assembly (pages 163 to 165) S2 Note: fig. 1 is used for the unipole type, fig. 2 is used for the multipole type. fig. 1 fig. 2 ● Maximum operating temperature: 120°C FLS Elbow (90°) plug for cable crimping L A H M Dimensions (mm) Reference Model Series A H L M FLS 00 9 16 17.5 9.5 M6 Cable assembly (page 163) Note: Model available only with crimp backnut E31 similar to 00.250 series. ● Maximum operating temperature: 120°C ERA Fixed socket, nut fixing Reference Dimensions (mm) Model Series A B e E L L1) M S1 S3 ERA ERA ERA ERA ERA ERA ERA ERA 00 0S 1S 2S 3S 4S 5S 6S 8 10 14 18 22 28 40 54 10.2 12.4 15.8 19.2 25.0 34.0 40.0 54.0 M7x0.5 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M25x1.0 M35x1.0 M48x1.5 5.5 7.0 7.5 8.5 11.5 12.0 15.5 16.0 – 17.5 20.2 24.5 29.0 34.0 45.0 45.0 14.5 18.0 20.5 23.5 27.5 33.5 78.5 – 1.0 1.2 1.5 1.8 2.0 2.5 3.0 3.5 6.3 8.2 10.5 13.5 16.5 23.5 33.5 45.5 9 11 14 17 22 30 – – L maxi M øA e øB S3 E maxi S1 Note: 1) unipole model P1 Panel cut-out (page 152) Note: the 5S series is delivered with a tapered washer and a round nut. The 6S series is delivered without a locking washer and with a round nut. ERN Fixed socket, nut fixing, with earthing tag L maxi Reference E maxi Dimensions (mm) M øA e øB S3 S1 Model Series A B ERN ERN ERN ERN 0S 1S 2S 3S 10 14 18 22 12.4 15.8 19.2 25.0 e E M9x0.6 7.0 M12x1.0 7.5 M15x1.0 8.5 M18x1.0 11.5 L L1) 19.3 22.4 26.3 29.8 19.3 22.4 26.3 29.8 M S1 S3 1.2 8.2 11 1.5 10.5 14 1.8 13.5 17 2.0 16.5 22 P1 Panel cut-out (page 152) Note: 1) unipole model www.lemo.com 61 ® ® ERC Fixed socket, nut fixing with slot in the flange L maxi Reference F øA M e øB S3 Model Series ERC ERC ERC 00 0S 1S Dimensions (mm) A B e E F L1) L M S1 S3 8 10.2 M7x0.5 5.5 1.6 – 14.5 1.0 6.3 9 10 12.4 M9x0.6 7.0 2.0 17.5 18.0 1.2 8.2 11 14 15.8 M12x1.0 7.5 2.5 20.2 20.5 1.5 10.5 14 S1 E maxi P1 Panel cut-out (page 152) Note: 1) unipole model ERS Fixed socket, nut fixing, long threaded shell, without flats L maxi M Reference øA e øB S3 Model Series ERS 0S Dimensions (mm) A B e E L L1) M S3 10 12.4 M9x0.6 10.5 17.5 18.0 1.2 11 P2 Panel cut-out (page 152) E maxi Note: 1) unipole model EHP Fixed socket, nut fixing, protruding shell L maxi Reference Dimensions (mm) øA M e øB S3 E maxi Model Series EHP EHP EHP 0S 1S 3S A B e E L1) L M S1 S3 10 12.4 M9x0.6 2.0 20.5 18.0 12.5 8.2 11 14 15.8 M12x1.0 3.5 20.2 20.5 12.0 – 14 22 25.0 M18x1.0 4.0 29.0 29.0 18.7 – 22 S1 P1 Panel cut-out 0S series (page 152) P2 Panel cut-out (page 152) Note: 1) unipole model EBD Fixed socket with square flange and screw fixing L maxi A M H øB Reference øC Dimensions (mm) Model Series A B C EBD 2S 22 15 3.2 H L 15.5 24.5 L1) M 26 2 P6 Panel cut-out (page 152) Note: 1) unipole model 62 www.lemo.com ® ® EBS Fixed socket with round flange and screw fixing L maxi M H øB øA Reference Dimensions (mm) Model Series A B C EBS 1S 22 11 2.5 L1) M 12.4 20.2 20.5 1.5 H L P7 Panel cut-out (page 152) øC Note: 1) unipole model EBC Fixed socket with square flange, protruding shell and screw fixing A L maxi Reference M øB H øC N Dimensions (mm) Model Series A B C H L L1) M N EBC EBC EBC EBC 1S 2S 3S 5S 18 22 25 45 11.5 15.0 18.0 40.0 3.2 3.2 3.2 4.3 12.7 15.5 18.0 36.8 20.2 24.5 29.0 45.0 20.5 23.5 27.5 78.5 16.5 18.5 23.5 15.0 2.8 4.4 3.0 4.0 P6 Panel cut-out (page 152) Note: 1) unipole model EEP Fixed socket, nut fixing (back panel mounting) L maxi P M øA Reference e øB S2 S1 Model Series EEP 2S Dimensions (mm) A B e E L1) L M P S1 S2 20 19.5 M15x1 3.5 24.5 23.5 3.5 9 13.5 15 P1 Panel cut-out (page 152) E maxi Note: 1) unipole model ERD Fixed socket with two nuts (back panel mounting) Reference L maxi S 1 E maxi øA M e øB S3 Dimensions (mm) Model Series A B e E L L1) M ERD ERD ERD ERD ERD 0S 1S 2S 3S 4S 12 16 20 24 30 12.4 15.8 19.2 25.0 34.0 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M25x1.0 5.5 6.0 6.5 9.0 10.0 17.5 20.2 24.5 29.0 34.0 18.0 20.5 23.5 27.5 33.5 2.5 3.5 3.5 4.5 4.5 S1 S3 8.2 10.5 13.5 16.5 23.5 11 14 17 22 30 P1 Panel cut-out (page 152) Note: 1) unipole model. The 3S and 4S series are delivered with a conical nut. www.lemo.com 63 ® ® ECP Fixed socket with two nuts, long threaded shell (back panel mounting) L maxi M øA Reference e øB S3 S1 E maxi Dimensions (mm) Model Series A ECP ECP ECP ECP 0S 1S 2S 3S 12 16 20 24 B e E L 12.4 M9x0.6 8.5 17.5 15.8 M12x1.0 10.0 20.2 19.2 M15x1.0 11.0 24.5 25.0 M18x1.0 14.0 29.0 L1) 18.5 21.5 26.0 30.0 M S1 2.5 8.2 3.5 10.5 3.5 13.5 4.5 16.5 S3 11 14 17 22 P1 Panel cut-out (page 152) Note: 1) unipole model. The 3S series is delivered with a conical nut. ECP Fixed socket with two nuts, long threaded shell, with straight contact for printed circuit (back panel mounting) Reference N e øB S1 Dimensions (mm) Model Series A ECP ECP ECP ECP 0S 1S 2S 3S 12 16 20 24 B e E M N S1 S3 M S3 øA L 12.4 M9x0.6 8.5 2.5 15.8 M12x1.0 10.0 3.5 19.2 M15x1.0 11.0 3.5 25.0 M18x1.0 14.0 4.5 15.0 8.2 17.5 10.5 20.0 13.5 24.0 16.5 11 14 17 22 P1 Panel cut-out (page 152) E maxi P21 PCB drilling pattern (page 159) Note: this contact type is available for all E●● socket models. See page 159 for table of available types. Length «L» depends on the number of contacts, see table on page 159. The 3S series is delivered with a conical nut. ECP Fixed socket with two nuts, long threaded shell, with elbow (90°) contacts for printed circuit (back panel mounting) L Reference N 20 mini Dimensions (mm) øA M e øB S3S1 Model Series A ECP ECP ECP ECP 0S 1S 2S 3S 12 16 20 24 B e E M 12.4 M9x0.6 8.5 2.5 15.8 M12x1.0 10.0 3.5 19.2 M15x1.0 11.0 3.5 25.0 M18x1.0 14.0 4.5 N S1 15.0 8.2 17.5 10.5 20.0 13.5 24.0 16.5 S3 11 14 17 22 E maxi P1 Panel cut-out (page 152) 2 P24 PCB drilling pattern (page 160) Note: this contact type is available for all back panel mounting socket types. See page 160 for available types. Length «L» depends on the number of contacts, see PCB drilling pattern on page 160. The 3S series is delivered with a conical nut. 64 www.lemo.com ® ® PCA Free socket, cable collet Reference øA ~L S2 Model Series PCA PCA PCA PCA PCA PCA PCA PCA 00 0S 1S 2S 3S 4S 5S 6S Dimensions (mm) A L 6.5 25.0 8.9 33.5 11.9 40.5 14.8 50.0 17.8 59.0 24.8 75.0 34.7 99.0 46.0 102.0 S2 4.5 6.5 8.5 11.0 14.0 19.0 29.0 38.0 M1 Cable assembly (pages 163 to 165) PCA Free socket with oversize cable collet 1) Reference øA øB ~L S2 Dimensions (mm) Model Series A PCA PCA PCA PCA PCA PCA 00 0S 1S 2S 3S 4S 6.5 8.9 11.9 14.8 17.8 24.8 B L 8.0 33.0 10.0 44.5 13.0 55.0 18.0 65.0 21.0 83.0 31.8 105.0 S1 S2 7.0 9.0 12.0 14.0 19.0 28.5 6.5 8.5 11.0 14.0 19.0 29.0 M2 Cable assembly (pages 164 and 166) S1 Note: 1) correspond to K type of collet, the fitting of oversize collets onto this model allows them to be fitted to the cables that can be accommodated by the next housing size up (see page 102). PCA Free socket, cable collet and nut for fitting a bend relief 1) Reference øA ~L S2 Dimensions (mm) Model Series A L S2 PCA PCA PCA PCA PCA PCA 00 0S 1S 2S 3S 4S 6.5 8.9 11.9 14.8 17.8 24.8 25.0 33.5 40.5 50.0 59.0 75.0 6 7 9 12 14 20 M1 Cable assembly (pages 163 and 164) Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see page 141). PCP Free socket, cable collet and inner anti-rotating device Reference øA ~L S2 www.lemo.com Dimensions (mm) Model Series A PCP PCP PCP PCP PCP 0S 1S 2S 3S 4S 8.9 11.9 14.8 17.8 24.8 L S2 33.5 6.5 40.5 8.5 50.0 11.0 59.0 14.0 75.0 19.0 M1 Cable assembly (pages 163 and 164) 65 ® ® PZP Free socket for remote handling with cable collet and inner anti-rotating device Reference Dimensions (mm) Model Series A L N S2 S3 PZP PZP PZP 1S 2S 3S 16 24 24 40.5 50.0 59.0 15 21 24 8.5 11.0 14.0 12 18 18 øA ~L M1 Cable assembly (pages 163 and 164) S2 N S3 PSA Fixed socket, nut fixing, cable collet Reference ~L e øB M øA S3 Dimensions (mm) Model Series A B e E L M S1 PSA PSA PSA PSA PSA PSA PSA PSA 00 0S 1S 2S 3S 4S 5S 6S 8 10 14 18 22 28 40 54 10.2 12.4 15.8 19.2 25.0 34.0 40.0 54.0 M7x0.5 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M25x1.0 M35x1.0 M48x1.5 5.5 7.0 7.5 8.5 11.5 12.0 15.5 16.0 25.0 33.5 40.5 50.0 59.0 75.0 99.0 102.0 1.0 1.2 1.5 1.8 2.0 2.5 3.0 3.5 6.3 8.2 10.5 13.5 16.5 23.5 33.5 45.5 S2 S3 4.5 6.5 8.5 11.0 14.0 19.0 29.0 38.0 9 11 14 17 22 30 – – M1 Cable assembly (pages 163 to 165) E maxi S2 S1 P1 Panel cut-out (page 152) Note: the 5S series is delivered with a tapered washer and a round nut. The 6S series is delivered without a locking washer and with a round nut. PSP Fixed socket, nut fixing, cable collet and inner anti-rotating device Reference ~L e øB M øA S3 Dimensions (mm) Model Series A B e E L M PSP PSP PSP PSP PSP 0S 1S 2S 3S 4S 10 14 18 22 28 12.4 15.8 19.2 25.0 34.0 M9x0.6 M12x1.0 M15x1.0 M18x1.0 M25x1.0 7.0 7.5 8.5 11.5 12.0 33.5 40.5 50.0 59.0 75.0 1.2 1.5 1.8 2.0 2.5 S1 S2 S3 8.2 6.5 11 10.5 8.5 14 13.5 11.0 17 16.5 14.0 22 23.5 19.0 30 M1 Cable assembly (pages 163 and 164) E maxi S2 S1 P1 Panel cut-out (page 152) PSS Free socket, nut fixing for cable crimping Reference L øB øA M e S3 Model Series PSS 00 Dimensions (mm) A B e 8 10.2 M7x0.5 E L M S1 S2 S3 5.5 30 1 6.3 5.5 9 M5 Cable assembly (page 163) P1 Panel cut-out (page 152) S2 66 E maxi S1 Note: Model available only with crimp backnut E31 similar to 00.250 series. www.lemo.com ® ® RMA Free coupler Reference øA ~L Dim. (mm) Model Series A L RMA RMA RMA RMA RMA RMA RMA 00 0S 1S 2S 3S 4S 5S 6.4 8.9 11.9 14.8 17.8 24.8 34.7 22.0 25.0 28.5 31.5 38.5 46.5 60.5 Note: see page 101 for the available plug and contact configurations and in order to ensure correct contact alignment. RAD Fixed coupler, nut fixing Reference L e øA M E maxi øB S3 S1 Dimensions (mm) Model Series A B RAD RAD RAD RAD RAD RAD RAD 00 0S 1S 2S 3S 4S 5S 8 10 14 18 22 28 40 10.2 12.4 15.8 19.2 25.0 34.0 40.0 e E L M S1 S2 M7x0.5 5.5 22.0 1.0 6.3 9 M9x0.6 7.0 25.0 1.2 8.2 11 M12x1.0 7.5 28.5 1.5 10.5 14 M15x1.0 8.5 31.5 1.8 13.5 17 M18x1.0 11.5 38.5 2.0 16.5 22 M25x1.0 12.0 46.5 2.5 – 30 M35x1.0 15.5 60.5 3.0 – – P1 Panel cut-out (page 152) P2 Panel cut-out 4S and 5S series (page 152) Note: see page 101 for the available plug and contact configurations and in order to ensure correct contact alignment. Note: the 5S series is delivered with a tapered washer and a round nut. FTA T-plug with two in line sockets Reference A H I L Dimensions (mm) Model Series A FTA FTA FTA FTA 00 0S 1S 3S 9 13 16 21 H I 17.5 9.5 23.0 13.0 26.5 16.5 38.5 23.5 L 30 38 45 64 Note: multipole version available only with 2 contacts (type 302). www.lemo.com 67 ® ® Elbow socket models Technical Characteristics Materials and Treatment Types Component Surface Treat. (µm) Material Cu PPS Brass Brass Bronze PEEK Bronze 1) Housing Metallic parts Earthing crown Insulator Female contact Series Type 1 302 2 2 2 3 0S, 1S 303 2 304 2 3 305 3 0.5 – 3 3 3 – 3 Au – – – 1.5 Note: 1) not used for all sizes. The surface treatment standards are as follows: – Nickel FS QQ-N-290A – Gold: ISO 4523 1 0S, 1S 0.5 0.5 0.5 Ni Electrical 1 3 1 1 1 4 2 3 1 4 2 3 306 5 1 4 5 16 1S 6 Model Series EPL EXP EPL EXP EPL EXP 0S 0S 1S 1S 1S 1S 302-303-304 1.20 4.5 305-306 0.70 4.5 Types 2 1S 5 1 4 Rated current (A) 3 Test voltage (kV rms)1) 2 0S, 1S 2 5 3 4 4 Note: 1) see calculation method, caution and suggested standard on page 178. øA 7.62 EPL Elbow (90°) socket for printed circuit (solder or screw fixing) EPL.0S.302.HLN EPL.0S.303.HLN EPL.0S.304.HLN EPL.1S.302.HLN EPL.1S.303.HLN EPL.1S.304.HLN EPL.1S.305.HLN EPL.1S.306.HLN L K 3.2 H I N ø 0.7 M 1.6 Part Number D A 9 D Dimensions (mm) H I K L N 14.6 6.7 12.7 13.3 25 11.7 11 16.6 7.5 14.0 13.3 27 12.6 Note: to replace the 4 ground pins by 4 screws (M1.6) add an «S» to the end of the part number. (e.g.: EPL.1S.303.HLNS) P22 PCB drilling pattern (page 160) 68 www.lemo.com ® ® EPL Elbow (90°) socket for printed circuit 7 øA 5.08 Part Number L 6.8 10 7 H I EPL.00.113.NLN Dim. (mm) A H I P23 PCB drilling pattern (page 160) ø 0.7 EPL Elbow (90°) socket for printed circuit K 5.08 2.54 Part Number L N I øA EPL.0S.116.DTL A D 8.8 16 Dimensions (mm) H I K L 12 9 7.7 22.7 N 9 Note: available only in unipole version. 3 P23 PCB drilling pattern (page 160) Ø1 D EXP Elbow (90°) socket for printed circuit with two nuts (solder or screw fixing) 7.62 N Part Number K L S3 øA B D e Dimensions (mm) E H I K L M N S3 12 12.4 14.6 M9x0.6 6.0 6.7 12.7 13.3 25 2.5 11.7 11 14 15.0 16.6 M11x0.5 7.5 7.5 14.0 13.3 27 3.5 12.6 13 H I e M EXP.0S.302.HLN EXP.0S.303.HLN EXP.0S.304.HLN EXP.1S.302.HLN EXP.1S.303.HLN EXP.1S.304.HLN EXP.1S.305.HLN EXP.1S.306.HLN A 3.2 øB Note: to replace the 4 ground pins by 4 screws (M1.6) add an «S» to the end of the part number. (e.g.: EXP.1S.303.HLNS). ø 0.7 M 1.6 E maxi P2 Panel cut-out 0S series (page 152) D 2.54 P10 Panel cut-out 1S series (page 152) P22 PCB drilling pattern (page 160) www.lemo.com 69 ® ® Plastic housing models These connectors are particularly recommended for all applications requiring maximum electrical insulation when mated. The design, including a latch sleeve and a metal earthing crown, guarantees EMC screening efficiency to meet most requirements. Technical Characteristics Mechanical and Climatical Value Characteristics PEEK Colour Endurance Humidity Temperature range Sterilization resistance 1) Resistance to organic solvents POM natural (beige) > 5000 cycles PSU Standard PPSU black white or grey > 5000 cycles > 5000 cycles up to 95% at 60° C - 50° C/+250° C - 50° C/+115° C - 50° C/+150° C > 200 cycles none ~20 cycles very good very good limited cream > 5000 cycles – IEC 60512-5 test 9a – - 50° C/+180° C – > 100 cycles IEC 60601-1 § 44.7 good – Note: 1) Steam sterilization FFA Straight plug, cable collet, PEEK or POM outer shell FFP Straight plug, cable collet, PEEK or POM outer shell and inner anti-rotating device Reference Dimensions (mm) ~L Model Series A L FFA FFP FFP FFP FFP 00 0S 1S 2S 3S 7.0 9.5 12.0 15.0 18.0 33.5 34.5 42.5 52.0 61.0 M S2 øA ~M S2 25.5 6.0 24.5 8.0 31.5 10.0 40.0 12.0 46.0 14.0 M1 Cable assembly (pages 163 and 164) FFP Straight plug, cable collet, PEEK or POM outer shell, inner anti-rotating device and nut for fitting a bend relief 1) Reference ~L øA ~M Dimensions (mm) Model Series A L FFP FFP FFP FFP 0S 1S 2S 3S 9.5 12.0 15.0 18.0 33.5 41.5 51.0 61.0 M S2 23.5 7.0 30.5 10.0 39.0 12.0 46.0 14.0 M1 Cable assembly (pages 163 and 164) S2 Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see page 141). FFL Straight plug, cable collet, with PSU and PPSU outer shell, inner anti-rotating device and nut for fitting a bend relief 1) Reference ~L Model Series FFL 2S Dimensions (mm) A L M 16.5 51.5 39.5 S2 13 ~M øA M4 Cable assembly (page 165) S2 70 Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see page 141). This model is fitted with a «D or M» type collet system. It is also adapted for crimp contacts. Available only for multipole. www.lemo.com ® ® ERN Fixed socket, nut fixing, with earthing tag, PEEK or POM outer shell M øA e øB E maxi Dimensions (mm) Reference L maxi S3 S1 Model Series A B ERN ERN ERN ERN ERN 00 0S 1S 2S 3S 9 11 14 18 22 10.2 12.4 15.8 19.2 25.0 e E M7x0.5 5.5 M9x0.6 6.4 M12x1.0 7.5 M15x1.0 8.5 M18x1.0 11.5 L L1) – 19.3 22.4 26.3 29.8 14.5 19.3 22.4 26.3 29.8 M S1 S3 1.0 6.3 9 1.8 8.2 11 1.5 10.5 14 2.0 13.5 17 2.0 16.5 22 P1 Panel cut-out (page 152) Note: 1) unipole model www.lemo.com 71 ® ® Watertight or vacuumtight models These socket or coupler models allow the device on which they are fitted to reach a protection index of IP68 as per IEC 60529. They are fully compatible with plugs of the same series and are widely used for portable radios, military, laboratory equipment, aviation, etc. These models are identified by a letter «P» at the end of the reference. Most of these models are also available in a vacuumtight version. Such models are identified by an additional letter «V» at the end of the part number (certificate on request). Epoxy resin is used to seal these models. Technical Characteristics Mechanical and Climatical Characteristics Endurance Humidity Temperature range (0S-1S) Temperature range (2S-6S) Salt spray corrosion test Climatical category Leakage rate (He)1) Value Standard > 5000 cycles IEC 60512-5 test 9a up to 95% at 60° C - 20° C/+100° C - 20° C/+80° C > 144h IEC 60512-6 test 11f 20/80/21 IEC 60068-1 < 10-7 mbar.l.s-1 IEC 60512-7 test 14b Note: 1) only for vacuumtight models. Characteristics Value 0S 1S 2S 3S 4S 5S 6S Maximum operating pressure2) Standard 60 bars 60 bars 40 bars 30 bars 15 bars 5 bars 5 bars IEC 60512-7 test 14d Note: 2) this value corresponds to the maximum allowed pressure difference for the assembled socket. HGP Fixed socket, nut fixing, watertight or vacuumtight Dimensions (mm) Reference L maxi øA M e øB S3 S1 E maxi Model Series A B e E L L1) M S1 S3 HGP HGP HGP HGP HGP HGP HGP 0S 1S 2S 3S 4S 5S 6S 18 20 20 28 34 45 58 15.8 19.2 21.5 27.0 34.0 40.0 54.0 M12x1.0 M14x1.0 M16x1.0 M20x1.0 M25x1.0 M35x1.0 M48x1.5 11.5 15.5 17.0 18.0 22.5 28.0 22.0 20.5 25.0 29.5 33.0 39.0 50.5 51.0 21.5 22.0 28.0 34.0 43.0 78.5 – 4.0 4.0 4.0 6.0 6.5 7.5 6.0 10.5 12.5 14.5 18.5 23.5 33.5 45.5 14 17 19 24 30 – – Note: 1) unipole model P3 Panel cut-out (page 152) Note: the 5S and 6S series are delivered with a round nut. HGW Fixed socket, nut fixing, with back washer, watertight or vacuumtight L maxi S3 M Dimensions (mm) E mini/maxi øA e øB Reference Model Series HGW HGW 0S 1S A B e E E mini maxi 10 15 M9x0.6 2.0 14 18 M12x1.0 2.0 L M S3 3.0 17.5 1.2 4.0 25.0 1.5 11 14 P11 Panel cut-out (page 152) Note: vacuumtight version is only available in the 0S series. 72 www.lemo.com ® ® EWB Fixed socket, nut fixing, with two flats on the flange, watertight or vacuumtight L maxi Reference øA M e øB S3 S1 S4 E maxi Dimensions (mm) Model Series A B e E L L1) M EWB EWB EWB EWB 0S 1S 2S 4S 18 20 20 34 15.8 19.2 21.5 34.0 M12x1.0 M14x1.0 M16x1.0 M25x1.0 11.0 15.5 17.0 22.5 20.5 25.5 28.0 43.0 – 25.5 26.5 – 4.0 4.0 4.0 6.5 S1 S3 S4 10.5 12.5 14.5 23.5 14 17 19 30 14 16 16 27 P3 Panel cut-out (page 152) Note: 1) unipole model HCP Fixed socket, nut fixing, watertight or vacuumtight (back panel mounting) L maxi M S1 E maxi P øA e øB Reference Dimensions (mm) Model Series A B e E L M P S1 HCP HCP HCP 1S 2S 4S 18 20 27 20 M14x1.0 8.6 25.5 3.5 12.0 – 20 M16x1.0 12.5 29.0 3.5 16.5 14.5 34 M25x1.0 15.5 41.0 4.5 20.0 23.5 P3 Panel cut-out (page 152) Note: the 4S series is delivered with a conical nut. SWH Fixed coupler, nut fixing, watertight or vacuumtight Dimensions (mm) Reference L øA e øB M S3 E maxi S1 Model Series A B e E L M S1 S3 SWH SWH SWH SWH SWH SWH SWH 0S 1S 2S 3S 4S 5S 6S 14 17 20 25 34 45 58 13.8 15.8 21.5 27.0 34.0 40.0 54.0 M10x0.75 M12x1.00 M16x1.00 M20x1.00 M25x1.00 M35x1.00 M48x1.50 17 28 25 30 50 58 55 34 39 44 53 65 80 81 2.0 2.5 4.0 4.0 4.0 5.0 6.0 9.0 10.5 15.0 18.5 23.5 33.5 45.5 12 14 19 24 30 – – P4 Panel cut-out (page 152) Note: see page 101 for the available plug and contact configurations and in order to ensure correct contact alignment. The 5S and 6S series are delivered with a round nut. www.lemo.com 73 ® ® E Series E series connectors have been specifically designed for outdoor applications. They include an inner sleeve and two seals to prevent penetration of solids or liquids into the housing formed by the plug, free socket, fixed socket or coupler. All models of these series are watertight when mated and give a protection index of IP 68 as per IEC 60529 standard (in mated condition) when correctly assembled to an appropriate cable (IP 66 otherwise). – security of the Push-Pull latching system – watertight connection (IP 68/IP 66) – unipole types transmitting current up to 230 A – polarization by stepped insert (half-moon) and multipole types with up to 106 contacts fitted with male and female contacts – wide range of models satisfying most applications – solder or print contacts (straight or elbow) – 360° screening for full EMC shielding – rugged housing for extreme working condition. Metal housing models (page 76) Straight plug Straight plugs FZP FFA, FFP Fixed sockets Free sockets ERA EEP ERC EEP ERB EEP PCA, PCP Fixed plug FFA PCA FAA Elbow plug FFA PCA Fixed socket FLA FFF EHP Watertight or vacuumtight models (page 82) Fixed sockets HGP 74 EBR PSA Fixed coupler Free coupler SWH RMA www.lemo.com ® ® Part Numbering System Plug FFA . 1E . 304 . C L A C 35 Free socket PCA . 1E . 304 . C L L C 35 Z Variant: (page 107) Cable ø: (page 105) Collet type: (page 105) Fixed socket ERA . 1E . 304 . C L L Coupler RMA . 1E . 304 . C L L Variant: (page 107) Model: (page 76) Contact: (page 99) Series: (page 76) Insulator: (page 99) Insert configuration: (page 91) Housing: (page 99) Part Number Example Straight plug with cable collet: FFA.1E.304.CLAC35 = straight plug with cable collet, 1E series, multipole type with 4 contacts, outer shell in chromeplated brass, PEEK insulator, 2 male and 2 female solder contacts, C type collet for a 3.5 mm diameter cable. Free socket: PCA.1E.304.CLLC35Z = free socket with cable collet, 1E series, multipole type with 4 contacts, outer shell in chromeplated brass, PEEK insulator, 2 female and 2 male solder contacts, C type collet for a 3.5 mm diameter cable and collet nut for fitting a bend relief. Fixed socket: ERA.1E.304.CLL = fixed socket, nut fixing, 1E series, multipole type with 4 contacts, outer shell in chrome-plated brass, PEEK insulator, 2 female and 2 male solder contacts. Free coupler: RMA.1E.304.CLL = straight coupler, 1E series, multipole type with 4 contacts, outer shell in chrome-plated brass, PEEK insulator, 2 female and 2 male contacts each end. Part Section Showing Internal Components Straight plug Fixed socket 5 1 2 3 4 5 6 7 8 outer shell earthing crown retaining ring hexagonal nut insulator male contact female contact o-ring www.lemo.com 2 3 8 4 1 8 7 6 9 8 2 3 7 6 1 4 10 12 13 11 5 1 2 3 4 5 6 7 8 9 10 11 12 13 outer shell latch sleeve inner shell retaining ring collet nut centre-piece insulator male contact female contact earthing cone collet gasket washer 75 ® ® Metal housing models Technical Characteristics Mechanical and Climatical Characteristics Electrical Value Endurance Humidity Temperature range1) Resistance to vibrations Shock resistance Salt spray corrosion test Protection index (mated)2) Climatical category Standard > 5000 cycles IEC 60512-5 test 9a up to 95% at 60° C - 55° C, +200° C 10-2000 Hz, 15 g IEC 60512-4 test 6d 100 g, 6 ms IEC 60512-4 test 6c > 144h IEC 60512-6 test 11f IP 68/IP 66 IEC 60529 50/175/21 IEC 60068-1 Characteristics Value at 10 MHz at 1 GHz Shielding efficiency Standard > 95 dB > 80 dB IEC 60169-1-3 IEC 60169-1-3 Note: the various tests have been carried out with FFA and ERA connector pairs, with chrome-plated brass shell, PEEK insulator and silicone O-ring. Detailed electrical characteristics, as well as materials and treatment are presented in the chapter Technical Characteristics on page 171. 1) minimum operating temperature is -20°C for sockets fitted with an FPM (Viton®) O-ring. 2) IP68 achieved providing that the cable is perfectly circular and that assembly process ensures a high integrity seal. FFA Straight plug, cable collet Reference Model FFA FFA FFA FFA FFA FFA FGG1) ~L øA ~M Dimensions (mm) Series A L M S2 0E 1E 2E 3E 4E 5E 6E 11 13 16 19 25 38 47 34 42 52 61 71 92 118 23.0 28.0 36.0 41.0 50.5 67.0 89.0 8 9 12 15 19 32 38 S2 M1 Cable assembly (pages 167 and 168) Note: 1) with key (G) FFA Straight plug with oversize cable collet 1) Reference ~L øB øA ~M S2 Dimensions (mm) Model Series A B L M S1 S2 FFA FFA FFA FFA 1E 2E 3E 4E 13 16 19 25 14.5 17.0 22.0 36.0 55 65 80 118 41 49 60 84 12 15 19 30 12 15 19 32 M2 Cable assembly (pages 167 and 169) Note: 1) correspond to K type of collet, the fitting of oversize collets onto this model allows them to be fitted to the cables that can be accommodated by the next housing size up (see page 105). S1 FFA Straight plug, cable collet and nut for fitting a bend relief 1) Reference ~L øA ~M S2 76 Dimensions (mm) Model Series A L M S2 FFA FFA FFA FFA FFA 0E 1E 2E 3E 4E 11 13 16 19 25 34 42 52 60 71 23.0 28.0 36.0 40.0 50.5 7 9 12 15 19 M1 Cable assembly (pages 167 and 168) Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see page 141). www.lemo.com ® FFF Straight plug non-latching, cable collet Reference ~L øA ~M ® Dimensions (mm) Model Series A L M S2 FFF FFF 0E 1E 11 13 34 42 23 28 8 9 M1 Cable assembly (page 167) S2 FFP Straight plug, cable collet and inner anti-rotating device Reference ~L Model Series A L M S2 FFP FFP 3E 4E 19 25 61 71 41.0 50.5 15 19 øA ~M Dimensions (mm) M1 Cable assembly (pages 167 and 168) S2 FZP Straight plug for remote handling, cable collet and inner anti-rotating device ~L Reference øA ~M S2 N S1 Dimensions (mm) Model Series A L M N S1 S2 FZP FZP FZP FZP FZP 1E 2E 3E 4E 5E 20 22 23 32 44 42 52 61 71 92 28.0 36.0 41.0 50.5 67.0 15 16 20 29 40 15 16 19 25 36 9 12 15 19 32 M1 Cable assembly (pages 167 and 168) FAA Fixed plug non-latching, nut fixing L maxi Reference E maxi Dimensions (mm) øA M e øB S3 Model Series A B e E L L1) M FAA FAA FAA FAA 0E 1E 2E 3E 18 20 25 31 19.2 21.5 27.0 34.0 M14x1.0 M16x1.0 M20x1.0 M24x1.0 3.5 3.5 4.0 4.5 19.5 23.0 27.0 32.5 19.5 23.0 27.0 32.5 13.0 16.0 18.0 22.5 S1 S3 12.5 14.5 18.5 22.5 17 19 24 30 S1 P1 Panel cut-out (page 153) Note: 1) unipole model www.lemo.com 77 ® ® FLA Elbow (90°) plug, cable collet Reference ~L S1 H øA ~M Model Series FLA FLA FLA FLA FLA 0E 1E 2E 3E 4E Dimensions (mm) A D 11.5 7.6 14.0 8.8 17.5 10.5 21.0 11.5 27.5 15.5 H L M S1 S2 S3 27 33 40 47 57 36 43 51 60 72 25.0 29.0 35.0 40.0 51.5 10 12 15 18 24 8 9 12 15 19 8 10 13 15 20 S3 M3 Cable assembly (pages 167 and 168) S2 D ERA Fixed socket, nut fixing Reference Model L maxi øA M e øB S3 S1 E maxi ERA ERA ERA ERA ERA ERA EGG2) Dimensions (mm) Series A B e E L L1) M S1 S3 0E 1E 2E 3E 4E 5E 6E 18 20 25 31 37 55 65 19.2 21.5 27.0 34.0 40.5 54.0 65.0 M14x1.0 M16x1.0 M20x1.0 M24x1.0 M30x1.0 M45x1.5 M55x2.0 5.5 9.0 9.0 11.0 9.0 10.0 10.5 19.5 24.0 28.5 34.0 36.0 44.5 48.5 20.5 25.3 30.0 35.0 38.0 78.0 – 4.0 4.5 5.0 6.0 6.5 9.0 10.0 12.5 14.5 18.5 22.5 28.5 42.5 52.0 17 19 24 30 36 – – P1 Panel cut-out (page 153) Note: The 5E and 6E series are delivered with a round nut. 1) unipole model. 2) with key (G). ERC Fixed socket, nut fixing with slot in the flange L maxi M S3 Reference Series ERC ERC ERC 0E 3E 4E A B e E F L L1) M S1 S3 øA e øB F Model Dimensions (mm) 18 19.2 M14x1.0 5.5 1.5 19.5 20.5 4.0 12.5 17 31 34.0 M24x1.0 11 3.0 34.0 35.0 6.0 22.5 30 37 40.5 M30x1.0 9 3.0 36.0 38.0 6.5 28.5 36 S1 E maxi P1 Panel cut-out (page 153) Note: 1) unipole model ERB Fixed socket, nut fixing with two flats in the flange L maxi Reference M øA S4 e øB S3 E maxi Dimensions (mm) Model Series A B ERB ERB ERB ERB 0E 1E 2E 3E 18 20 25 31 19.2 21.5 27.0 34.0 e E L L1) M S1 M14x1.0 5.5 19.5 20.5 4.0 M16x1.0 9 24.0 25.3 4.5 M20x1.0 9 28.5 30.0 5.0 M24x1.0 11 34.0 35.0 6.0 12.5 14.5 18.5 22.5 S3 S4 17 19 24 30 14 17 20 24 S1 P1 Panel cut-out (page 153) Note: 1) unipole model 78 www.lemo.com ® ® EEP Fixed socket, nut fixing (back panel mounting) L maxi Reference Dimensions (mm) P e øB øA M S1 Model Series A B e E L L1) EEP EEP EEP EEP 0E 1E 2E 3E 18 20 25 30 18 20 25 31 M14x1.0 M16x1.0 M20x1.0 M24x1.0 3.5 6.5 6.5 7.5 19.5 24.0 28.5 34.0 20.5 25.3 30.0 35.0 M P S1 3.5 7 12.5 3.5 10 14.5 3.5 10 18.5 4.5 12 22.5 P1 Panel cut-out (page 153) E maxi Note: 1) unipole model Note: the 3E series is delivered with a conical nut. EEP Fixed socket, nut fixing, with straight contact for printed circuit (back panel mounting) Reference L Dimensions (mm) N P e øB øA M S1 Model Series A B e E M N P S1 EEP EEP EEP EEP 0E 1E 2E 3E 18 20 25 30 18 20 25 31 M14x1.0 M16x1.0 M20x1.0 M24x1.0 3.5 6.5 6.5 7.5 3.5 3.5 3.5 4.5 16.0 21.5 24.0 29.5 7 10 10 12 12.5 14.5 18.5 22.5 P1 Panel cut-out (page 153) P21 PCB drilling pattern (page 159) E maxi Note: this contact type is available for all E●● socket models. See page 159 for table of available types. Length «L» depends on the number of contacts, see PCB drilling pattern on page 159. The 3E series is delivered with a conical nut. L EEP Fixed socket, nut fixing, with elbow (90°) contacts for printed circuit (back panel mounting) N P Reference 20 mini e øB øA M S1 Model Series EEP EEP 1E 2E Dimensions (mm) A B e E M N P S1 20 20 M16x1.0 6.5 3.5 16.0 10 14.5 25 25 M20x1.0 6.5 3.5 24.0 10 18.5 P1 Panel cut-out (page 153) E maxi P24 PCB drilling pattern (page 160) Note: this contact type is available for all back panel mounting socket types. See page 160 for available types. Length «L» depends on the number of contacts, see PCB drilling pattern on page 160. 2 EHP Fixed socket, nut fixing, protruding shell L maxi S4 M Dimensions (mm) øA e øB Reference S 3 E maxi S1 Model Series EHP EHP EHP 0E 1E 2E A B e E L L1) M S1 S3 S4 18 19.2 M14x1.0 1.5 19.5 20.5 10.5 12.5 17 15 20 21.5 M16x1.0 1.5 24.0 25.3 15.5 14.5 19 17 25 27.0 M20x1.0 1.5 28.5 30.0 17.0 18.5 24 20 P1 Panel cut-out (page 153) Note: 1) unipole model www.lemo.com 79 ® ® PCA Free socket, cable collet Reference Model PCA PCA PCA PCA PCA PCA PHG1) øA ~L S2 Series 0E 1E 2E 3E 4E 5E 6E Dimensions (mm) A L 13 34.0 15 45.0 19 54.0 23 65.0 29 75.5 42 95.0 52 125.0 S2 8 9 12 15 19 32 38 M1 Cable assembly (pages 167 and 168) Note: 1) with key (G) PCA Free socket with oversize cable collet 1) Reference øB øA ~L S2 Dimensions (mm) Model Series A PCA PCA PCA PCA 1E 2E 3E 4E 15 19 23 29 B L 14.5 58.0 17.0 67.0 22.0 84.0 36.0 109.0 S1 S2 12 15 19 30 12 15 19 32 M2 Cable assembly (pages 167 and 169) Note: 1) correspond to K type of collet, the fitting of oversize collets onto this model allows them to be fitted to the cables that can be accommodated by the next housing size up (see page 105). S1 PCA Free socket, cable collet and nut for fitting a bend relief 1) Reference øA ~L Dimensions (mm) Model Series A L S2 PCA PCA PCA PCA PCA 0E 1E 2E 3E 4E 13 15 19 23 29 34.0 45.0 54.0 64.0 75.5 7 9 12 15 19 M1 Cable assembly (pages 167 and 168) S2 Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see page 141). PCP Free socket, cable collet and inner anti-rotating device Reference Dimensions (mm) Model Series A L S2 PCP PCP 3E 4E 23 29 65.0 75.5 15 19 øA ~L M1 Cable assembly (pages 167 and 168) S2 80 www.lemo.com ® ® PSA Fixed socket, nut fixing, cable collet Reference Model PSA PSA PSA PSA PSA PSA PKG1) L maxi Series A B e 0E 1E 2E 3E 4E 5E 6E 18 20 25 31 37 51 65 19.2 21.5 27.0 34.0 40.5 54.0 65.0 E L M M14x1.0 5.5 34.0 4.0 M16x1.0 9.0 45.0 4.5 M20x1.0 9.0 54.0 5.0 M24x1.0 11.0 65.0 6.0 M30x1.0 9.0 75.5 6.5 M45x1.5 10.0 95.0 9.0 M55x2.0 10.5 125.0 10.0 S1 S2 S3 12.5 14.5 18.5 22.5 28.5 – – 8 9 12 15 19 32 38 17 19 24 30 36 54 – øA M e øB S3 Dimensions (mm) P1 Panel cut-out (page 153) S2 E maxi S1 M1 Cable assembly (pages 167 and 168) Note: 1) with key (G). The 5E and 6E series are delivered with a round nut. RMA Free coupler Reference øA L maxi Dim. (mm) Model Series A L RMA RMA RMA RMA RMA RMA 0E 1E 2E 3E 4E 5E 14 16 20 25 30 44 30 40 44 54 57 67 Note: see page 101 for the available plug and contact configurations and in order to ensure correct contact alignment. www.lemo.com 81 ® ® Watertight or vacuumtight models These socket or coupler models allow the device on which they are fitted to reach a protection index of IP 68 as per IEC 60529. They are fully compatible with plugs of the same series and are widely used for portable radios, military, laboratory equipment, aviation, etc. These models are identified by a letter «P» at the end of the reference. Most of these models are also available in a vacuumtight version. Such models are identified by an additional letter «V» at the end of the part number (certificate on request). Epoxy resin is used to seal these models. Technical Characteristics Mechanical and Climatical Characteristics Endurance Humidity Temperature range (0E-1E) Temperature range (2E-6E) Salt spray corrosion test Climatical category Leakage rate (He)1) Value Standard Characteristics > 5000 cycles IEC 60512-5 test 9a up to 95% at 60° C - 20° C/+100° C - 20° C/+80° C > 144h IEC 60512-6 test 11f 20/80/21 IEC 60068-1 < 10-7 mbar.l.s-1 IEC 60512-7 test 14b 0E 1E 2E 3E 4E 5E 6E Maximum operating pressure2) Note: 1) only for vacuumtight models. Value 60 bars 60 bars 40 bars 30 bars 15 bars 5 bars 5 bars Standard IEC 60512-7 test 14d Note: 2) this value corresponds to the maximum allowed pressure difference for the assembled socket. HGP Fixed socket, nut fixing, watertight or vacuumtight Dimensions (mm) Reference Model L maxi M HGP HGP HGP HGP HGP HGP HGP2) øA e øB S3 S1 E maxi Series A B e E L 0E 1E 2E 3E 4E 5E 6E 18 20 25 31 37 55 65 19.2 21.5 27.0 34.0 40.5 54.0 65.0 M14x1.0 M16x1.0 M20x1.0 M24x1.0 M30x1.0 M45x1.5 M55x2.0 5.5 9.0 10.5 15.5 17.5 20.0 20.5 23.5 28.0 32.5 39.5 43.0 52.0 52.0 L1) M 22.0 4.0 28.0 4.5 28.0 5.0 38.5 6.0 44.0 6.5 76.0 9.0 – 10.0 S1 S3 12.5 14.5 18.5 22.5 28.5 42.5 52.0 17 19 24 30 36 – – P1 Panel cut-out (page 153) Note: The 5E and 6E series are delivered with a round nut. 1) unipole model. 2) with key (G). EBR Fixed socket with round flange, watertight, protruding shell and screw fixing N ~L H1 øC Reference øA H2 øB ~M Dimensions (mm) Model Series A B EBR 2E 28 15 C H1 H2 L L1) M N 2.8 11.8 20.4 32.5 28.0 19 25 P6 Panel cut-out (page 153) Note: 1) unipole model. This model is only available in a watertight version. 82 www.lemo.com ® ® SWH Fixed coupler, nut fixing, watertight or vacuumtight Reference Model L M øA e øB S3 E maxi S1 SWH SWH SWH SWH SWH SWH SWH1) Dimensions (mm) Series A B e E 0E 1E 2E 3E 4E 5E 6E 18 20 25 31 37 55 65 19.2 21.5 27.0 34.0 40.5 54.0 65.0 M14x1.0 M16x1.0 M20x1.0 M24x1.0 M30x1.0 M45x1.5 M55x2.0 22.5 30.5 28.0 33.0 44.5 47.0 12.0 L M 36.0 4.0 47.0 4.5 52.4 5.0 64.2 6.0 70.0 6.5 81.0 9.0 76.0 10.0 S1 S3 12.5 14.5 18.5 22.5 28.5 42.5 – 17 19 24 30 36 – – P1 Panel cut-out (page 153) Note: 1) with key (G). The 5E and 6E series are delivered with a round nut. See page 101 for the available plug and contact configurations and in order to ensure correct contact alignment. www.lemo.com 83 ® ® L Series L series connectors have been specifically designed for outdoor applications. This series offer superior polarization combining the stepped insert (half-moon) of the S/E series with the keying system of the K series. They include an inner sleeve and two seals to prevent penetration of solids or liquids into the housing formed by the plug, free socket, fixed socket or coupler. All models of this series are watertight when mated to give a protection index of IP68 as per IEC 60529 standard (in mated condition) when correctly assembled to an appropriate cable (IP66 otherwise). L series connectors have the same insulators as the S series and have the following main features: – security of the Push-Pull latching system – watertight connection (IP 68/IP 66) – multipole types 2 to 10 contacts – solder, crimp or print (straight) contacts – stepped insert (half-moon) fitted – multiple key options to avoid cross mating with male and female contacts of similar connectors – high packing density for space savings – 360° screening for full EMC shielding – keying system («G» key standard) for connector alignment – rugged housing for extreme working conditions. Metal housing models (page 86) Fixed plug Straight plugs FAG FGG Fixed sockets EGG Free sockets PHG Elbow plug FHG FGG FGG Vacuumtight model (page 89) EEG PHG PHG Fixed socket Fixed socket PKG HGG 84 www.lemo.com ® ® Part Numbering System Plug FG G . 2L . 306 . C L A C 65 Variant: (page 107) Cable ø: (page 106) Collet type: (page 106) Fixed socket EG G . 2L . 306 . C Y M Model: (page 86) Variant: (page 107) Alignment key: (page 90) Contact: (page 99) Series: (page 86) Insulator: (page 99) Insert configuration: (page 92) Housing: (page 99) Part Number Example Straight plug with cable collet: FGG.2L.306.CLAC65 = straight plug with key (G) and cable collet, 2L series, multipole type with 6 contacts, outer shell in chrome-plated brass, PEEK insulator, with 3 male and 3 female solder contacts, C type collet for 6.5 mm diameter cable. Fixed socket: EGG.2L.306.CYM = fixed socket, nut fixing, with key (G), 2L series, multipole type with 6 contacts, outer shell in chromeplated brass, PEEK extended insulator, with 3 female and 3 male crimp contacts. Part Section Showing Internal Components Straight plug Fixed socket 1 2 3 4 5 6 7 8 outer shell earthing crown retaining ring hexagonal nut insulator male contact female contact o-ring www.lemo.com 5 2 3 8 4 1 8 7 6 9 8 2 3 7 6 1 4 10 12 13 11 5 1 2 3 4 5 6 7 8 9 10 11 12 13 outer shell latch sleeve inner shell retaining ring collet nut split insert carrier insulator male contact female contact earthing cone collet gasket washer 85 ® ® Metal housing models Technical Characteristics Electrical Mechanical and Climatical Characteristics Value Endurance Humidity Temperature range1) Resistance to vibrations Shock resistance Salt spray corrosion test Protection index (mated)2) Climatical category Standard > 5000 cycles IEC 60512-5 test 9a up to 95% at 60° C - 55° C, +200° C 10-2000 Hz, 15 g IEC 60512-4 test 6d 100 g, 6 ms IEC 60512-4 test 6c > 144h IEC 60512-6 test 11f IP 68/IP 66 IEC 60529 50/175/21 IEC 60068-1 Characteristics Value at 10 MHz at 1 GHz Shielding efficiency Standard > 95 dB > 80 dB IEC 60169-1-3 IEC 60169-1-3 Note: The various tests have been carried out with FGG and EGG connector pairs, with chrome-plated brass shell, PEEK insulator and silicone O-ring. Detailed electrical characteristics, as well as materials and treatment are presented in the chapter Technical Characteristics on page 171. 1) minimum operating temperature is -20°C for sockets fitted with an FPM (Viton®) O-ring. 2) IP68 achieved providing that the cable is perfectly circular and that assembly process ensures a high integrity seal. FGG Straight plug, key (G) or keys (A to C and L), cable collet Reference ~L øA ~M Dimensions (mm) Model Series A L M S2 FGG FGG FGG 0L 1L 2L 11 13 16 34 42 52 23.0 28.0 36.0 8 9 12 M1 Cable assembly (page 170) S2 FGG Straight plug, key (G) or keys (A to C and L), cable collet and oversize cable collet 1) Reference ~L øB øA ~M S2 S1 Dimensions (mm) Model Series A B L M S1 S2 FGG FGG 1L 2L 13 16 14.5 17.0 60 68 46 52 12 15 12 15 M2 Cable assembly (page 170) Note: 1) correspond to K type of collet, the fitting of oversize collets onto this model allows them to be fitted to the cables that can be accommodated by the next housing size up (see page 106). FGG Straight plug, key (G) or keys (A to C and L), cable collet and nut for fitting a bend relief 1) Reference Dimensions (mm) Model Series A L M S2 FGG FGG FGG 0L 1L 2L 11 13 16 34 42 52 23 28 36 7 9 12 ~L ~M M1 Cable assembly (page 170) S2 86 Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see page 141). www.lemo.com ® ® FAG Fixed plug, nut fixing, non-latching, key (G) or keys (A to C and L) L maxi N S3 M øA e øB Reference Model Series FAG 2L Dimensions (mm) A B e E L N1) M S1 S3 25 27.0 M20x1.0 4.5 28.2 18.0 28.3 18.5 24 P1 Panel cut-out (page 153) S1 E maxi Note: 1) maximum length with crimp contacts. FHG Elbow (90°) plug, key (G) or keys (A to C and L), cable collet ~L S1 ~M ~H øA Reference S3 S2 Model Series FHG FHG FHG 0L 1L 2L Dimensions (mm) A D 11.5 7.6 14.0 8.8 17.5 10.5 H L M S1 S2 S3 27 33 40 36 43 51 25.0 29.0 35.0 10 12 15 8 9 12 8 10 13 M3 Cable assembly (page 170) D EGG Fixed socket, nut fixing, key (G) or keys (A to C and L) L maxi N S3 M øA e øB Reference E maxi Model Series EGG EGG EGG 0L 1L 2L Dimensions (mm) A B e E 18 19.2 M14x1.0 20 21.5 M16x1.0 25 27.0 M20x1.0 6 9 9 L M N1) S1 S3 21.7 4.0 20.1 12.5 17 27.0 4.5 25.1 14.5 19 30.7 5.0 28.6 18.5 24 S1 P1 Panel cut-out (page 153) Note: 1) maximum length with crimp contacts. EEG Fixed socket, nut fixing, key (G) or keys (A to C and L) (back panel mounting) L maxi N P Reference E maxi øA M e øB S1 Model Series EEG EEG EEG 0L 1L 2L Dimensions (mm) A B e E L M N1) P S1 18.0 18 M14x1.0 3.4 21.7 3.5 20.1 7.0 12.5 20.0 20 M16x1.0 6.2 27.0 3.5 25.1 10.0 14.5 25.0 25 M20x1.0 5.0 30.7 3.5 28.6 10.0 18.5 P1 Panel cut-out (page 153) Note: 1) maximum length with crimp contacts. www.lemo.com 87 ® ® PHG Free socket, key (G) or keys (A to C and L), cable collet Reference øA ~L Dimensions (mm) Model Series A L S2 PHG PHG PHG 0L 1L 2L 13 15 19 34.0 45.0 54.0 8 9 12 M1 Cable assembly (page 170) S2 PHG Free socket, key (G) or keys (A to C and L), cable collet and oversize cable collet 1) Dimensions (mm) Reference øB øA ~L Model Series A B L S1 S2 PHG PHG 1L 2L 15 19 14.5 17.0 63 70 12 15 12 15 M2 Cable assembly (page 170) S1 S2 Note: 1) correspond to K type of collet, the fitting of oversize collets onto this model allows them to be fitted to the cables that can be accommodated by the next housing size up (see page 106). PHG Free socket, key (G) or keys (A to C and L), cable collet and nut for fitting a bend relief 1) Reference Dimensions (mm) Model Series A L S2 PHG PHG PHG 0L 1L 2L 13 15 19 34.0 45.0 54.0 7 9 12 øA ~L M1 Cable assembly (page 170) S2 Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see page 141). PKG Fixed socket, nut fixing, key (G) or keys (A to C and L), cable collet øA M e øB S3 Dimensions (mm) Reference ~L Model Series PKG PKG PKG 0L 1L 2L A B e 18 19.2 M14x1.0 20 21.5 M16x1.0 25 27.0 M20x1.0 E 6 9 9 L M S1 S2 S3 34.0 4.0 12.5 8 45.0 4.5 14.5 9 54.0 5.0 18.5 12 17 19 24 M1 Cable assembly (page 170) S2 88 E maxi S1 P1 Panel cut-out (page 153) www.lemo.com ® ® Watertight or vacuumtight models This socket model allow the device on which they are fitted to reach a protection index of IP68 as per IEC 60529. This model is also available in a vacuumtight version. It is identified by the letter «PV» at the end of the part number (certificate on request). Epoxy resin is used to seal this model. Technical Characteristics Mechanical and Climatical Characteristics Endurance Humidity Temperature range (0L-1L) Temperature range (2L) Salt spray corrosion test Value Standard Characteristics > 5000 cycles IEC 60512-5 test 9a up to 95% at 60° C - 20° C/+100° C - 20° C/+80° C > 144h IEC 60512-6 test 11f Value Climatical category Leakage rate (He) 0L 1L 2L Maximum operating pressure1) Standard 20/80/21 IEC 60068-1 < 10-7 mbar.l.s-1 IEC 60512-7 test 14b 60 bars 60 bars IEC 60512-7 test 14d 40 bars Note: 1) this value corresponds to the maximum allowed pressure difference for the assembled socket. HGG Fixed socket, nut fixing, key (G) or keys (A to C and L), vacuumtight L maxi S3 M øA e øB Reference E maxi Model Series HGG HGG HGG 0L 1L 2L Dimensions (mm) A B e E L M S1 S3 18 19.2 M14x1.0 5.5 21.7 4.0 12.5 17 20 21.5 M16x1.0 9.0 30.0 4.5 14.5 19 25 27.0 M20x1.0 13.0 33.7 5.0 18.5 24 S1 P1 Panel cut-out (page 153) www.lemo.com 89 ® ® Alignment Key (L series) Alignment Key and Polarized Keying System L series connector model part numbers are composed of three letters. The LAST LETTER indicates the key position and the contact type (male or female). γ Nb of keys G A B J L 1 2 2 2 2 Series Angles α Reference Front view of a socket α γ Contact type Note 0L 1L 2L Plug Socket 0° 30° 45° 105° 75° 0° 30° 45° 105° 75° 0° 30° 45° 105° 75° male male male female male female female female male female ● ● ● ● ●1) Note: 1) that contact type is not as for the K series. ● First choice alternative ● Special order alternative 90 www.lemo.com ® ® Insert configuration (S, E and L series) Unipole Contact type Standard Watertight ø A (mm) Solder Crimp Test voltage (kV rms)1) Test voltage (kV dc)1) Rated current (A)1) 00 113 00 – 1.3 ●2) ● 0.8 1.2 8 0S 0E 116 0S 0E 1.6 ●2) – 1.5 2.1 12 1S 1E 120 1S 1E 2.0 ●2) – 1.7 2.4 18 130 1S 1E 3.0 ● – 1.5 2.1 25 130 2S 2E 3.0 ● – 2.1 3.0 30 140 2S 2E 4.0 ● – 1.7 2.4 40 140 3S 3E 4.0 ● – 2.3 3.3 43 160 3S 3E 6.0 ● – 1.7 2.4 65 140 4S – 4.0 ● – 3.0 4.2 46 160 4S 4E 6.0 ● – 2.7 3.9 70 112 5S 5E 12.0 ● – 1.5 2.1 230 øA Reference Series Male solder contacts 2S 2E 3S 3E 4S 4E Female solder contacts 5S 5E Note: 1) see calculation method, caution and suggested standard on page 178. 2) also available with inversed contacts: plug = female, socket = male. www.lemo.com 91 ® ® Multipole Contact type Standard Watertight Number of contacts ø A (mm) Solder Crimp Print (straight) Print (elbow) Test voltage (kV rms)1) 2) Test voltage (kV dc)1) 2) Rated current (A)1) 302 0S 0E 2 0.9 ● ● ● ● 1.5 2.1 103) 303 0S 0E 3 0.7 ● ● ● ● 1.0 1.5 73) 304 0S 0E 4 0.7 ● ● ● ● 1.0 1.5 73) 302 1S 1E 2 1.3 ● ● ● ● 1.2 1.8 153) 303 1S 1E 3 0.9 ● ● ● ● 1.2 1.8 103) 304 1S 1E 4 0.9 ● ● ● ● 1.2 1.8 103) 305 1S 1E 2 3 0.9 0.7 ● ● ● ● 1.5 1.5 2.1 2.1 103) 73) 306 1S 1E 6 0.7 ● ● ● ● 1.5 2.1 73) 302 2S 2E 2 1.6 ● ● ● ● 1.7 2.4 204) 303 2S 2E 3 1.3 ● ● ● ● 1.5 2.1 154) 304 2S 2E 4 1.3 ● ● ● ● 1.7 2.4 154) 305 2S 2E 5 1.3 ● ● ● ● 1.5 2.1 134) 306 2S 2E 6 1.3 ● ●5) ● ● 1.5 2.1 12 307 2S 2E 3 4 1.3 0.9 ● ● ● ● 0.8 0.8 1.2 1.2 123) 93) 308 2S 2E 8 0.9 ● ● ● ● 0.8 1.2 93) 310 2S 2E 10 0.9 ● ● ● ● 0.8 1.2 73) 302 3S 3E 2 2.0 ● – ● – 3.0 4.2 23 303 3S 3E 3 2.0 ● – ● – 1.5 2.1 20 304 3S 3E 4 2.0 ● – ● – 1.5 2.1 18 305 3S 3E 2 3 2.0 1.3 ● – ● – 1.5 1.5 2.1 2.1 18 14 306 3S 3E 6 1.3 ● – ● – 2.1 3.0 14 307 3S 3E 7 1.3 ● – ● – 1.0 1.5 12 øA øA Reference Series Male solder contacts 0S 0E 0L 2 3 1 1 2 2 1 1 2 3 2 3 1S 1E 1L Female solder contacts 1 4 1 4 1 1 2 2 2 1 2 3 1 2 3 3 2 3 1 4 1 4 2 3 2 2 3 3 1 1 4 4 5 5 2 2 3 1 3 1 4 4 2S 2E 2L 6 6 5 2 5 1 1 2 2 1 1 2 3 3 2 3 1 4 1 4 2 3 2 1 2 3 3 1 4 4 5 5 2 2 3 1 3 1 4 4 5 3 4 6 6 3 2 2 1 5 4 1 5 5 7 7 6 3 4 6 1 6 3 4 1 2 6 7 3S 3E 5 10 8 8 7 1 1 2 2 1 6 7 4 9 1 10 6 5 8 3 2 2 9 5 4 1 8 7 3 2 2 5 1 2 3 3 2 1 1 2 3 4 4 3 2 2 3 1 3 1 4 4 5 5 2 2 3 1 3 1 4 3 4 4 5 6 6 2 2 1 3 4 1 5 5 6 7 5 7 6 Note: 1) see calculation method, caution and suggested standard on page 178. 2) lowest measured value; contact to contact or contact to shell. 3) rated current = 6A for socket with elbow (90°) contacts for printed circuit. 4) rated current = 12A for socket with elbow (90°) contacts for printed circuit. 5) only for FFL model. 92 ● First choice alternative ● Special order alternative www.lemo.com ® ® Multipole Contact type Standard Watertight Number of contacts ø A (mm) Solder Crimp Print (straight) Print (elbow) Test voltage (kV rms)1) 2) Test voltage (kV dc)1) 2) Rated current (A)1) 308 3S 3E 8 1.3 ● – ● ● 1.0 1.5 10 310 3S 3E 10 1.3 ● – ● ● 1.0 1.5 9 312 3S 3E 12 0.9 ● – ● ● 1.5 2.1 8 313 3S 3E 13 0.9 ● – ● ● 1.5 2.1 8 314 3S 3E 14 0.9 ● – ● ● 1.5 2.1 7 316 3S 3E 16 0.9 ● – ● ● 1.0 1.5 7 318 3S 3E 18 0.9 ● – ● ● 1.0 1.5 6 302 4S 4E 2 4.0 ● – ● – 2.1 3.0 35 303 4S 4E 3 3.0 ● – ● – 2.1 3.0 25 304 4S 4E 4 3.0 ● – ● – 2.1 3.0 22 305 4S 4E 2 3 3.0 2.0 ● – ● – 2.1 2.1 3.0 3.0 22 16 306 4S 4E 6 2.0 ● – ● – 2.1 3.0 16 307 4S 4E 3 4 2.0 1.3 ● – ● – 2.1 2.1 3.0 3.0 16 13 308 4S 4E 8 1.3 ● – ● – 2.7 3.9 13 309 4S 4E 9 1.3 ● – ● – 2.1 3.0 12 310 4S 4E 10 1.3 ● – ● – 2.1 3.0 11 312 4S 4E 12 1.3 ● – ● – 2.1 3.0 9 313 4S – 13 1.3 ● – ● – 2.1 3.0 9 øA øA Reference Series Male solder contacts 3S 3E 3 Female solder contacts 3 2 2 4 1 4 1 5 5 7 2 4 1 4 1 9 10 10 2 1 6 10 3 7 3 1 13 12 7 11 4 8 3 12 13 12 1 5 5 9 6 10 3 12 14 7 11 8 12 16 13 4 1 4 9 13 9 12 4 8 1 12 11 7 11 4 8 14 8 2 1 7 11 4 1 4 8 3 1 3 7 11 12 1 1 5 10 14 5 4 18 15 1 1 2 2 2 9 14 10 15 18 4S 4E 6 7 7 16 5 8 8 6 6 7 3 2 9 5 8 8 6 3 1 1 2 3 3 2 1 1 2 3 4 4 3 2 2 3 1 3 1 4 4 5 2 3 5 2 3 1 1 4 4 6 6 5 3 5 2 4 3 2 1 4 1 5 3 5 7 7 6 2 1 4 1 8 5 6 6 3 2 4 8 4 7 5 7 3 3 6 4 2 2 5 5 1 1 6 6 9 9 4 7 3 3 8 8 4 2 2 5 1 7 5 1 6 6 10 7 10 9 8 4 9 3 12 10 7 3 8 13 9 8 9 4 10 11 6 7 8 5 1 13 6 7 3 9 2 1 12 10 2 11 10 5 11 12 6 4 2 1 1 11 4 3 8 2 5 5 7 12 6 9 8 7 Note: 1) see calculation method, caution and suggested standard on page 178. 2) lowest measured value; contact to contact or contact to shell. www.lemo.com ● First choice alternative ● Special order alternative 93 ® ® Multipole Contact type Standard Watertight Number of contacts ø A (mm) Solder Print (straight) Print (elbow) Test voltage (kV rms)1) 2) Test voltage (kV dc)1) 2) Rated current (A)1) 314 4S 4E 14 1.3 ● ● – 2.1 3.0 9 316 4S 4E 16 0.9 ● ● – 2.1 3.0 7 318 4S 4E 18 0.9 ● ● – 2.1 3.0 7 320 4S 4E 20 0.9 ● ● – 2.1 3.0 7 322 4S 4E 22 0.9 ● ● – 2.1 3.0 7 324 4S 4E 24 0.9 ● ● – 2.1 3.0 7 302 5S 5E 2 6.0 ● – – 3.7 5.2 50 303 5S 5E 1 2 6.0 4.0 ● – – 3.7 3.7 5.2 5.2 50 35 304 5S 5E 4 4.0 ● – – 3.7 5.2 35 305 5S 5E 2 3 4.0 3.0 ● – – 3.0 3.0 4.2 4.2 35 25 306 5S 5E 6 3.0 ● – – 3.0 4.2 25 308 5S 5E 8 3.0 ● – – 2.1 3.0 22 310 5S 5E 10 2.0 ● – – 2.1 3.0 18 øA øA Reference Series Male solder contacts 4S 4E Female solder contacts 3 3 4 12 11 13 14 1 1 6 4 9 8 1 8 1 5 12 3 5 15 1 4 2 10 18 6 3 22 17 1 21 4 24 21 12 17 18 21 22 22 5S 5E 22 7 13 13 18 20 3 8 8 17 11 16 12 4 21 6 7 17 1 2 3 7 20 7 1 20 12 16 18 17 1 11 12 15 15 16 18 14 5 11 16 3 9 3 6 11 20 4 10 6 15 8 1 4 17 24 1 1 2 2 6 7 5 10 18 5 16 5 1 10 9 1 9 14 13 12 13 4 14 8 9 13 12 4 5 9 16 11 10 10 7 4 2 2 5 2 1 1 2 3 3 2 1 1 2 3 4 4 3 2 3 2 1 3 1 4 4 5 5 2 2 3 1 3 1 4 4 6 6 5 3 2 2 4 1 5 3 4 1 5 5 8 8 6 7 7 4 6 3 3 2 2 5 1 4 5 1 6 6 10 7 8 9 10 7 9 8 Note: 1) see calculation method, caution and suggested standard on page 178. 2) lowest measured value; contact to contact or contact to shell. 94 www.lemo.com ® ® Multipole Contact type Standard Watertight Number of contacts ø A (mm) Solder Print (straight) Print (elbow) Test voltage (kV rms)1) 2) Test voltage (kV dc)1) 2) Rated current (A)1) 312 5S 5E 12 2.0 ● – – 2.1 3.0 18 314 5S 5E 2 12 3.0 2.0 ● – – 1.8 1.8 2.4 2.4 20 15 316 5S 5E 16 2.0 ● – – 1.8 2.4 15 318 5S 5E 2 16 3.0 1.6 ● – – 1.8 1.8 2.4 2.4 18 11 320 5S 5E 20 1.6 ● – – 1.8 2.4 11 322 5S 5E 2 20 3.0 1.6 ● – – 1.8 1.8 2.4 2.4 16 9 324 5S 5E 24 1.6 ● – – 2.7 3.9 9 330 5S 5E 30 1.3 ● – – 1.8 2.4 8 336 5S 5E 36 1.3 ● – – 1.8 2.4 7 340 5S 5E 40 1.3 ● – – 1.2 1.8 7 344 5S 5E 44 1.3 ● – – 1.2 1.8 6 348 5S 5E 48 1.3 ● – – 1.2 1.8 6 øA øA Reference Series Male solder contacts 5S 5E 4 Female solder contacts 4 3 3 5 5 2 2 6 6 1 1 7 7 8 5 4 3 5 2 2 6 13 7 13 1 1 14 14 8 11 9 11 10 4 13 1 1 6 13 7 15 12 16 12 16 8 11 11 9 5 14 15 8 9 10 10 5 4 4 6 3 3 7 5 2 2 14 7 4 3 3 5 7 2 2 8 9 10 6 6 7 12 12 8 9 10 10 3 6 8 11 11 9 4 12 12 8 17 17 1 1 9 9 18 10 16 16 12 5 6 4 17 13 4 5 18 7 18 19 2 2 8 17 1 1 9 20 20 10 16 22 21 11 12 16 21 8 8 13 13 1 15 16 22 23 23 28 29 29 1 12 12 25 19 19 12 7 13 13 21 21 20 28 29 29 40 25 31 34 35 35 40 1 1 7 2 9 3 1 4 32 33 45 40 48 46 1 3 10 25 39 37 38 38 4 17 30 31 10 24 22 23 31 44 14 15 23 37 7 8 15 30 16 2 8 14 22 43 36 6 1 7 34 18 32 1 28 11 26 26 32 36 5 6 6 18 31 6 30 1 11 12 8 9 9 16 24 2 3 5 21 22 22 3 15 17 18 1 22 7 12 18 24 3 4 4 17 20 12 1 7 30 13 1 12 28 21 11 14 3 2 22 14 8 10 15 15 13 12 13 6 3 17 11 14 14 4 19 10 19 15 3 7 9 16 16 15 12 8 20 19 11 7 18 20 10 6 17 1 1 9 5 3 2 2 18 8 12 3 8 5 13 4 7 6 11 14 14 13 10 15 15 11 9 18 44 43 9 16 17 24 25 32 33 40 39 45 46 48 Note: 1) see calculation method, caution and suggested standard on page 178. 2) lowest measured value; contact to contact or contact to shell. www.lemo.com 95 ® ® Multipole Standard Watertight Number of contacts ø A (mm) Solder contacts Test voltage (kV rms)1) 2) Test voltage (kV dc)1) 2) Rated current (A)1) 303 – 6E 3 6.0 ● 3.0 4.2 50 304 6S 6E 4 8.0 ● 3.0 4.2 60 6S – 12 4.0 3.0 22 6E 12 5.0 ● 2.1 – 316 – 6E 16 3.0 ● 1.5 2.1 14 318 6S – 18 4.0 ● 1.2 1.8 16 320 6S – 20 3.0 ● 1.5 2.1 14 320 – 6E 20 3.0 ● 1.5 2.1 14 øA øA Reference Series Male solder contacts 6S 6E Female solder contacts 1 1 2 3 3 2 2 1 1 2 3 4 4 3 3 3 4 11 6 4 2 2 5 1 5 1 11 3 9 2 10 12 6 15 16 10 13 5 9 6 13 10 14 14 16 17 17 2 11 15 19 5 2 6 16 10 6 15 11 16 19 20 5 4 16 7 18 1 1 10 20 3 3 6 2 3 6 16 4 5 2 2 15 16 1 1 17 9 6 17 7 15 18 8 6 7 1 3 9 5 14 15 1 5 13 8 5 18 12 8 7 2 4 11 9 1 16 14 10 1 9 13 8 3 2 11 18 19 20 11 12 14 13 10 312 7 9 8 5 10 10 7 4 6 12 12 14 20 19 13 12 11 8 9 10 Note: 1) see calculation method, caution and suggested standard on page 178. 2) lowest measured value; contact to contact or contact to shell. 96 www.lemo.com ® ® Multipole Standard Watertight Number of contacts ø A (mm) Solder contacts Test voltage (kV rms)1) 2) Test voltage (kV dc)1) 2) Rated current (A)1) 324 6S – 24 3.0 ● 1.2 1.8 12 324 – 6E 24 3.0 ● 1.2 1.8 12 330 6S 6E 30 2.0 ● 2.1 3.0 10 332 – 6E 32 2.0 ● 1.5 2.1 10 336 6S – 36 2.0 ● 1.5 2.1 8 336 – 6E 30 6 1.3 5.0 ● 1.5 1.5 2.1 2.1 4 22 340 – 6E 40 2.0 ● 1.5 2.1 8 øA øA Reference Series Male solder contacts 6S 6E 3 Female solder contacts 1 1 4 7 12 17 13 21 12 18 21 5 21 1 16 24 23 16 23 13 4 5 10 10 21 16 16 26 22 9 15 21 22 26 27 27 4 1 5 24 16 17 25 24 25 28 29 29 1 3 4 12 13 13 24 19 19 29 34 5 1 6 24 29 33 34 36 1 5 11 6 12 20 30 12 21 20 21 35 35 31 34 32 18 30 30 36 12 25 25 33 7 8 8 36 3 4 18 11 32 1 7 31 33 1 1 7 20 28 34 32 6 12 7 13 13 21 21 29 35 30 36 34 33 12 40 8 9 17 28 4 5 9 6 30 1 16 32 4 5 15 8 12 1 1 30 10 22 11 14 9 9 21 15 13 8 20 24 14 12 7 17 1 15 11 6 19 18 2 17 22 5 3 2 18 20 10 24 4 3 19 9 22 4 6 8 17 22 7 7 8 13 18 24 3 4 8 20 28 34 29 35 40 Note: 1) see calculation method, caution and suggested standard on page 178. 2) lowest measured value; contact to contact or contact to shell. www.lemo.com 97 ® ® Multipole Standard Watertight Number of contacts ø A (mm) Solder contacts Test voltage (kV rms)1) 2) Test voltage (kV dc)1) 2) Rated current (A)1) 348 6S 6E 48 2.0 ● 1.5 2.1 7 360 6S 6E 60 1.6 ● 1.5 2.1 5 362 – 6E 62 1.6 ● 1.5 2.1 5 364 6S 6E 64 1.3 ● 1.2 1.8 4 372 6S 6E 72 1.3 ● 1.2 1.8 4 106 – 6E 106 0.9 ● 0.8 1.2 2 106 6S – 106 0.9 ● 0.8 1.2 2 øA øA Reference Series Male solder contacts 6S 6E 3 Female solder contacts 1 1 9 9 10 10 24 17 32 25 39 33 45 16 17 24 25 32 33 40 48 3 4 4 16 39 40 45 46 46 1 6 6 1 13 7 7 21 14 30 39 31 47 21 30 22 39 31 40 40 54 13 14 22 48 60 48 47 48 55 54 55 60 1 1 7 2 2 14 8 15 22 31 40 32 31 32 40 48 49 49 61 22 23 41 41 48 14 15 23 55 7 8 55 56 56 61 62 62 5 1 1 13 14 42 33 51 43 22 32 23 33 42 43 51 52 52 64 13 14 23 32 59 59 60 60 2 1 3 26 18 36 46 37 55 47 63 17 26 27 36 37 46 47 56 55 56 63 64 64 71 2 1 10 36 47 59 80 37 48 60 60 71 89 17 26 36 47 59 70 71 81 81 80 89 90 90 98 97 98 105 1 12 41 53 42 65 54 76 66 77 87 96 104 11 20 21 31 95 103 3 12 21 86 106 4 4 30 104 105 1 11 20 9 27 27 37 48 70 106 2 10 18 18 97 104 72 1 3 3 17 106 70 71 26 3 9 18 27 70 2 3 10 10 9 64 1 9 17 72 5 6 6 22 30 31 41 42 53 54 65 66 76 77 86 87 96 95 103 104 106 Note: 1) see calculation method, caution and suggested standard on page 178. 2) lowest measured value; contact to contact or contact to shell. 98 www.lemo.com ® ® Housings (S, E and L series) Ref. Outer shell and collet nut Material C D N K S T U L B G P R H Latch sleeve + earthing crown Surf. treatment Brass chrome Brass gold-plated Brass nickel Brass black chrome Stainless steel – Stainless steel – Stainless steel – Aluminium alloy anodized POM (black) – PEEK (natural) – PSU – PPSU – PPS/brass –/nickel Other metallic components Material Surf. treatment Material Surf. treatment brass/bronze brass/bronze brass/bronze brass/bronze brass/bronze stainless steel stainless steel brass/bronze brass/bronze brass/bronze brass/bronze brass/bronze brass/bronze nickel 2) nickel 2) nickel 2) nickel 2) nickel 2) – – nickel 2) nickel 2) nickel 2) nickel 2) nickel 2) nickel 2) brass brass brass brass brass brass stainless steel brass brass brass brass brass brass nickel nickel nickel nickel nickel nickel – nickel nickel nickel nickel nickel nickel Remarks Note Only for FFP, ERN and PCP (S series) Only for FFP, ERN and PCP (S series) Only for FFL (S series) 1) Only for FFL (S series) 1) Only for EPL and EXP (S series) ● ● ● ● ● ● ● ● ● ● ● ● ● 1) Note: detailed characteristics of these materials and treatments are presented on page 171. 1) see «variant» for the colour. 2) in the E and L series, the latch sleeve is chrome-plated. ● First choice alternative ● Special order alternative Insulators (S, E and L series) Material Ref. L Y T T V N PEEK PEEK PTFE FEP PI PA6.6 Contact type Solder or print Crimp Solder Solder Solder Solder Remarks only for unipole types only for multipole types of the S or E series only for multipole types of the S or E series material for 5S/5E and 6S/6E series multipole inserts Note ● ● ● ● ● ● Note: detailed characteristics of these materials are presented on page 175. ● First choice alternative ● Special order alternative Contacts (S, E and L series) Soldering characteristics Crimping characteristics – no need to order specific tools, a simple soldering iron is sufficient – ideal for very small and fragile conductors – contacts with solder cups to allow the solder to flow – – – – practical, quick contact fixing outside the insulator possible use at high temperature need to order specific tools no risk of heating the insulator during the conductorcontact fixing – high tensile strength – totally lead-free solution Note: see page 176 for more information. www.lemo.com 99 ® ® Contacts reference for plugs, free or fixed sockets Reference Contact Contact type Female A L 0.7 0.9 1.3 1.6 2.0 3.0 4.0 5.0 6.0 8.0 12.0 0.60 0.80 1.00 1.40 1.80 2.70 3.70 5.20 5.20 7.00 11.50 – – – – – – – – – – – 24 22 20 16 14 10 10 – – – – C B C B G C B G C B C B M P M P U M P U M P M P 0.80 0.45 1.10 0.80 0.45 1.40 1.10 0.80 1.90 1.40 2.40 1.90 1 2 1 2 2 1 2 2 1 2 1 2 – – – – – – – – – – – – D N L dimensions and C are detailed in the section on PCB drilling pattern. See page 159. ● V V L dimensions and C are detailed in the section on PCB drilling pattern. See page 160. ● øC øC fig. 1 Crimp øA øC øA øC fig. 2 øA øC øA øC Fr 1) (N) Notes øC Form (mm) per fig. Solder øA Conductor Stranded AWG Section (mm2) øA (mm) Male øA Solid AWG Section max. max. (mm2) 0.7 0.9 1.3 1.6 2.0 min. max. min. max. 0.25 0.34 0.50 1.00 1.50 4.00 6.00 – – – – – – – – – – – – – – – 26 222) 202) 18 16 12 10 8 8 4 0 – – – – – – – – – – – 0.14 0.34 0.50 1.00 1.50 4.00 6.00 10.00 10.00 21.00 50.00 – – – – – – – – – – – – 26 32 24 26 32 20 24 26 18 22 16 18 222) 28 20 222) 28 18 20 222) 142) 18 122) 14 0.140 0.035 0.250 0.140 0.035 0.500 0.250 0.140 1.000 0.340 1.500 1.000 0.34 0.09 0.50 0.34 0.09 1.00 0.50 0.34 1.50 1.00 2.50 1.50 – – – – – – – – – – – 22 30 40 50 65 ● ● ● ● ● ● ● ● ● ● ● ● ● Print L øC øA øA øC L Print (elbow) øA L øC Note: 1) 2) contact retention force in the insulator (according to IEC 60512-8 test 15 a). for a given AWG, the diameter of some stranded conductor designs is larger than the solder cup diameter. Make sure that the maximum conductor diameter is smaller than ø C. ● First choice alternative ● Special order alternative Contacts reference for coupler and plug with socket Ref. A L M F 100 Contact type Male - Female Female - Male Female - Female Female - Female - Male Remarks contact configuration is explained on page 101 contact configuration is explained on page 101 contact configuration is explained on page 101 for the FTA model of the S series www.lemo.com ® ® Contacts reference for fixed and free couplers RMA, RAD and SWH A A A Unipole 2 1 Multipole (odd) 1 2 Reference for plug A Reference for plug Reference for plug Unipole Reference for plug L M Female - Male L A L A Female - Female Reference for plug L Male - Female Reference for plug A Unipole 1 2 Multipole (odd) A 2 1 3 3 3 3 2 2 2 2 3 1 4 6 Multipole (even) 5 1 3 6 4 5 A1) A 1 3 6 4 5 Multipole (even) 3 1 4 6 A1) A1) 5 Use of plugs for mating with RAD, RMA and SWH couplers Unipole type: Reference M for coupling two identical plugs fitted with male contact (contact reference A). Reference L for coupling a plug fitted with male contacts (contact reference A) at the flange end for RAD and SWH and an inverted plug fitted with female contacts (contact reference L) at the other end. Reference A for the inverted version of code L. Multipole type: Reference L for coupling a standard plug (contact reference A) at the flange end for RAD and SWH and an inverted plug (contact reference as indicated in the above table) at the other end. Reference M for coupling two standard plugs (contact type A). Only available for RAD and RMA models. Note: 1) this connector combination does not allow for contact numbering. One of the plugs has to be cable mounted in a way to ensure correct signal continuity. www.lemo.com 101 ® ® Collets (S, E and L series) C, K and L type collets for S series øA øB C type øA øB K type oversize cable collet øA L type Reference Collet ø Cable ø Reference Collet ø Cable ø Notes Type Code 00 0S øA øB max. min. C C C C K K L L 17 22 27 31 37 42 27 31 1.7 2.2 2.7 3.1 3.7 4.2 2.7 3.1 1.5 – – 2.7 – 3.7 – – 1.7 2.2 2.7 3.1 3.6 4.4 2.6 3.0 1.3 > 1.7 > 2.2 > 2.7 3.0 > 3.7 2.2 2.6 C C C C K K K K K L L L L L 22 32 37 44 47 52 62 66 68 22 32 37 44 48 2.2 3.2 3.7 4.4 4.7 5.2 6.2 6.6 6.8 2.2 3.2 3.7 4.4 4.8 – – – 3.7 – – 5.2 5.4 – – – – – – 2.1 3.2 3.6 4.4 4.6 5.2 6.2 6.5 6.7 2.2 3.2 3.7 4.3 4.8 1.7 > 2.2 3.0 > 3.7 3.8 > 4.2 > 5.2 5.9 6.0 1.3 > 2.2 > 3.2 3.5 4.4 Notes Type Code NEW NEW NEW NEW 1S NEW NEW NEW NEW NEW 1) C C C C C C K K K K L L L L L L 22 32 42 52 62 68 72 77 82 87 22 32 42 52 62 66 øA øB max. min. 2.2 3.2 4.2 5.2 6.2 6.8 7.2 7.7 8.2 8.7 2.2 3.2 4.2 5.2 6.2 6.6 – – – – 5.2 – – 6.7 6.7 6.7 – – – – – – 2.1 3.2 4.2 5.2 6.1 6.7 7.2 7.5 8.0 8.5 2.2 3.1 4.2 5.2 6.2 6.5 1.7 > 2.2 > 3.2 > 4.2 5.3 6.0 > 6.2 7.1 7.6 8.1 1.2 2.6 > 3.2 > 4.2 > 5.2 5.9 NEW NEW NEW 1) NEW NEW NEW NEW NEW 1) 1) NEW NEW NEW 1) 1) Note: 1) these collets cannot be used for connectors models with nut for fitting a bend relief. 2) these collets are used for the FLA model. All dimensions are in millimetres. 102 www.lemo.com ® ® C, K and L type collets for S series øA øB C type øA øB K type oversize cable collet øA L type Reference Collet ø Cable ø Reference Collet ø Cable ø Notes Type Code 2S 3S øA øB max. min. C C C C C C C C K K K L L L L L L L 27 32 42 52 62 72 82 87 97 10 11 32 42 52 62 72 82 87 2.7 3.2 4.2 5.2 6.2 7.2 8.2 8.7 9.7 10.2 10.7 3.2 4.2 5.2 6.2 7.2 8.2 8.7 – – – – – 6.7 6.7 6.7 8.7 8.7 9.0 – – – – – – – 2.7 3.2 4.2 5.2 6.2 7.2 8.0 8.5 9.7 10.0 10.5 3.2 4.2 5.2 6.2 7.2 8.2 8.7 1.3 > 2.5 > 3.2 > 4.2 > 5.2 > 6.2 7.6 8.1 > 8.7 9.6 10.1 2.5 > 3.2 > 4.2 > 5.2 > 6.2 > 7.2 > 8.2 C C C C C C K K L L L L L L 42 57 72 87 97 11 12 13 42 57 72 87 97 11 4.2 5.7 7.2 8.7 9.7 10.7 12.2 13.2 4.2 5.7 7.2 8.7 9.7 10.7 – – – – 8.7 9.0 – 12.2 – – – – – – 4.2 5.7 7.2 8.7 9.7 10.5 12.0 13.0 4.2 5.7 7.0 8.7 9.5 10.7 2.7 > 4.2 > 5.7 > 7.2 > 8.7 10.1 11.1 12.1 2.7 > 4.2 6.1 > 7.2 9.1 > 9.7 Notes Type Code NEW NEW NEW NEW NEW NEW 4S NEW NEW NEW NEW NEW NEW NEW NEW1) NEW NEW NEW NEW NEW NEW NEW C C C C C C C C C K K K K K K K K K L L L L L L L L L 52 62 72 82 92 10 11 12 13 14 15 16 17 18 19 20 21 22 52 62 72 82 92 10 11 12 13 øA øB max. min. 5.2 6.2 7.2 8.2 9.2 10.2 11.2 12.2 13.2 14.2 15.2 16.2 17.2 18.2 19.2 20.2 21.2 22.2 5.2 6.2 7.2 8.2 9.2 10.2 11.2 12.2 13.2 – – – – – – – – 12.2 – – – – – – 19.7 19.7 19.7 – – – – – – – – – 5.0 6.0 7.0 8.0 9.0 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 21.0 22.0 5.0 6.0 7.0 8.0 9.0 10.0 11.0 12.0 13.0 4.1 5.1 6.1 7.1 8.1 9.1 10.1 11.1 12.6 13.1 14.1 15.1 16.1 17.1 18.1 19.1 20.1 21.1 4.1 5.1 6.1 7.1 8.1 9.1 10.1 11.1 12.6 1) 1) 1) 1) 1) 1) 1) 1) 1) NEW NEW1) Note: 1) these collets cannot be used for connectors models with nut for fitting a bend relief. All dimensions are in millimetres. www.lemo.com 103 ® ® C, K and L type collets for S series øA øB K type oversize cable collet øA øB C type øA L type Collet ø Reference Type Code 5S C C C C C C C C C C C C C C C C K K K K K K K K L L L L L L L L L L L L L 72 82 92 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 92 10 11 12 13 14 15 16 17 18 19 20 21 Cable ø øA øB max. min. 7.2 8.2 9.2 10.2 11.2 12.2 13.2 14.2 15.2 16.2 17.2 18.2 19.2 20.2 21.2 22.2 23.2 24.2 25.2 26.2 27.2 28.2 29.2 30.2 9.2 10.2 11.2 12.2 13.2 14.2 15.2 16.2 17.2 18.2 19.2 20.2 21.2 – – – – – – – – – – – – – 19.7 19.7 19.7 – – – – – 27.2 27.2 27.2 – – – – – – – – – – – – – 7.0 8.0 9.0 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 21.0 22.0 23.0 24.0 25.0 26.0 27.0 28.0 29.0 30.0 9.0 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 21.0 6.1 7.1 8.1 9.1 10.1 11.1 12.1 13.1 14.1 15.1 16.1 17.1 18.1 19.1 20.1 21.1 22.1 23.1 24.1 25.1 26.1 27.1 28.1 29.1 8.1 9.1 10.1 11.1 12.1 13.1 14.1 15.1 16.1 17.1 18.1 19.1 20.1 Note: the 5S.112 is only available with L type of collet All dimensions are in millimetres. 104 Reference Type Code 6S C C C C C C C C C C C C C C C C C C C L L L L L L L L L L L L L L L L L L L 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 Collet ø Cable ø øA øB max. min. 12.2 13.2 14.2 15.2 16.2 17.2 18.2 19.2 20.2 21.2 22.2 23.2 24.2 25.2 26.2 27.2 28.2 29.2 30.2 12.2 13.2 14.2 15.2 16.2 17.2 18.2 19.2 20.2 21.2 22.2 23.2 24.2 25.2 26.2 27.2 28.2 29.2 30.2 – – – – – – – – – – – – – – – – 27.2 27.2 27.2 – – – – – – – – – – – – – – – – – – – 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 21.0 22.0 23.0 24.0 25.0 26.0 27.0 28.0 29.0 30.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 21.0 22.0 23.0 24.0 25.0 26.0 27.0 28.0 29.0 30.0 11.1 12.1 13.1 14.1 15.1 16.1 17.1 18.1 19.1 20.1 21.1 22.1 23.1 24.1 25.1 26.1 27.1 28.1 29.1 11.1 12.1 13.1 14.1 15.1 16.1 17.1 18.1 19.1 20.1 21.1 22.1 23.1 24.1 25.1 26.1 27.1 28.1 29.1 www.lemo.com ® ® C and K type collets for E series øB K type oversize cable collet Reference Type Code 0E 1E 2E øA øA øB C type Collet ø Cable ø Reference øA øB max. min. C C C C C C C C C 10 15 20 25 30 35 40 45 50 1.6 1.6 2.1 3.1 3.1 4.2 4.2 5.2 5.2 – – – – – 4.2 4.2 5.2 5.2 1.2 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 1.0 1.3 1.6 2.1 2.6 3.1 3.6 4.1 4.6 C C C C C C C C C C C K K K K 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 1.6 2.2 3.2 3.2 4.2 4.2 5.2 5.2 6.2 6.2 7.2 7.2 8.2 8.2 9.2 – – – – – – – – 6.2 6.2 6.7 – 8.2 8.2 8.6 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 1.3 1.6 2.1 2.6 3.1 3.6 4.1 4.6 5.1 5.6 6.1 6.6 7.1 7.6 8.1 C C C C C C C C C C C C C C C K K K K 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 90 95 10 11 2.2 2.2 3.2 3.2 4.2 4.2 5.2 5.2 6.2 6.2 7.2 7.2 8.2 8.2 9.2 9.2 10.2 10.2 11.2 – – – – – – – – – – – – 8.2 8.2 8.6 – 10.2 10.2 10.6 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.0 10.5 1.3 1.6 2.1 2.6 3.1 3.6 4.1 4.6 5.1 5.6 6.1 6.6 7.1 7.6 8.1 8.6 9.1 9.6 10.1 Note: all dimensions are in millimetres. www.lemo.com Type Code 3E 4E Collet ø Cable ø øA øB max. min. C C C C C C C C C C C C C C C C K K K K K 30 35 40 45 50 55 60 65 70 75 80 85 90 95 10 11 11 12 13 14 15 3.2 4.2 4.2 5.2 5.2 6.2 6.2 7.2 7.2 8.2 8.2 9.2 9.2 10.2 10.2 11.2 12.3 13.8 13.8 15.3 15.3 – – – – – – – – – – – – – 10.2 10.2 10.6 – 13.8 13.8 15.3 15.3 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.0 10.5 12.0 12.8 13.5 14.0 15.0 2.6 3.1 3.6 4.1 4.6 5.1 5.6 6.1 6.6 7.1 7.6 8.1 8.6 9.1 9.6 10.1 10.6 12.1 12.9 13.6 14.1 C C C C C C C C C C C C C C C C K K K K K K K K 50 55 60 65 70 75 80 85 90 95 10 11 12 13 14 15 16 17 18 19 20 21 22 23 6.3 6.3 6.3 7.3 7.3 8.3 8.3 9.3 9.3 10.8 10.8 12.3 13.8 13.8 15.3 15.3 17.8 17.8 19.8 19.8 21.8 21.8 23.8 23.8 – – – – – – – – – – – – 13.8 13.8 15.3 15.3 – – – – – – 23.8 23.8 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.5 12.0 12.8 13.5 14.0 15.0 16.5 17.5 18.5 19.5 20.5 21.5 22.5 23.5 4.8 5.1 5.6 6.1 6.6 7.1 7.6 8.1 8.6 9.1 9.6 10.6 12.1 12.9 13.6 14.1 15.6 16.6 17.6 18.6 19.6 20.6 21.6 22.6 105 ® ® C and K type collets for E series øB K type oversize cable collet Reference Type Code 5E C C C C C C C C C C C C C C 10 11 12 13 14 15 16 17 18 19 20 21 22 23 øA øA øB C type Collet ø Cable ø Reference øA øB max. min. 11.8 11.8 13.8 13.8 15.8 15.8 17.8 17.8 19.8 19.8 21.8 21.8 23.8 23.8 – – – – – – – – – – – – 23.8 23.8 10.5 11.5 12.5 13.5 14.5 15.5 16.5 17.5 18.5 19.5 20.5 21.5 22.5 23.5 9.6 10.6 11.6 12.6 13.6 14.6 15.6 16.6 17.6 18.6 19.6 20.6 21.6 22.6 Type Code 6E C C C C C C C C C L 14 15 16 17 18 21 22 23 27 30 Collet ø Cable ø øA øB max. min. 14.2 15.2 15.7 16.7 18.2 23.2 23.2 23.2 27.2 30.2 – – – – – – – – – – 14.0 15.0 15.5 16.5 18.0 21.5 22.0 23.0 27.0 30.0 13.0 14.1 14.6 15.6 17.1 20.6 21.1 22.1 26.1 29.5 Note: all dimensions are in millimetres. C and K type collets for L series øB K type oversize cable collet Reference Type Code 0L 1L 106 øA øA øB C type Collet ø Cable ø Reference øA øB max. min. C C C C C C C C C 10 15 20 25 30 35 40 45 50 1.6 1.6 2.1 3.1 3.1 4.2 4.2 5.2 5.2 – – – – – 4.2 4.2 5.2 5.2 1.2 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 1.0 1.3 1.6 2.1 2.6 3.1 3.6 4.1 4.6 C C C C C C C C C C C K K K K 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 1.6 2.2 3.2 3.2 4.2 4.2 5.2 5.2 6.2 6.2 7.2 7.2 8.2 8.2 9.2 – – – – – – – – 6.2 6.2 6.7 – 8.2 8.2 8.6 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 1.3 1.6 2.1 2.6 3.1 3.6 4.1 4.6 5.1 5.6 6.1 6.6 7.1 7.6 8.1 Type Code 2L C C C C C C C C C C C C C C C K K K K 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 90 95 10 11 Collet ø Cable ø øA øB max. min. 2.2 2.2 3.2 3.2 4.2 4.2 5.2 5.2 6.2 6.2 7.2 7.2 8.2 8.2 9.2 9.2 10.2 10.2 11.2 – – – – – – – – – – – – 8.2 8.2 8.6 – 10.2 10.2 10.6 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.0 10.5 1.3 1.6 2.1 2.6 3.1 3.6 4.1 4.6 5.1 5.6 6.1 6.6 7.1 7.6 8.1 8.6 9.1 9.6 10.1 Note: all dimensions are in millimetres. www.lemo.com ® ® Variant (S, E and L series) Bend relief for S series models with collet Bend relief for E and L series models with collet Need to be ordered Need to be ordered separately (see pages 141 and 142) Collet Ref. Ref. Collet Need to be ordered Type Code 00 Z C K L 15 to 31 37 to 42 17 to 31 GMA.00.0●●.D● GMA.0B.0●●.D● GMA.00.0●●.D● 0E 0L 0S Z C K L 27 to 42 47 to 62 27 to 42 GMA.0B.0●●.D● GMA.1B.0●●.D● GMA.0B.0●●.D● 1S Z C K L 27 to 62 72 to 82 27 to 62 2S Z C K L 3S 4S Need to be ordered separately (see pages 141 and 142) Type Code Z C 10 to 50 GMA.0B.●●●.●● 1E 1L Z C K 15 to 65 70 to 85 GMA.1B.●●●.●● GMA.2B.●●●.●● GMA.1B.0●●.D● GMA.2B.0●●.D● GMA.1B.0●●.D● 2E 2L Z C K 15 to 85 90 to 10 GMA.2B.●●●.●● GMA.3B.●●●.●● 42 to 82 92 to 10 42 to 82 GMA.2B.0●●.D● GMA.3B.0●●.D● GMA.2B.0●●.D● 3E Z C K 30 to 10 11 to 15 GMA.3B.●●●.●● GMA.4B.●●●.●● 52 to 10 12 to 13 52 to 10 GMA.3B.0●●.D● GMA.4B.0●●.D● GMA.3B.0●●.D● 4E Z C 50 to 15 GMA.4B.●●●.●● Z C K L Z C L 82 to 13 82 to 13 GMA.4B.0●●.D● GMA.4B.0●●.D● Note: All dimensions are in millimetres. Colour of connectors shell made of plastic material and aluminium alloys Plastic shell Reference Colour A B G J M N R S T V L X F blue white grey yellow brown black red orange natural green black natural cream PSU PPSU ● ● Aluminium alloys PA.6 Anodized colour ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Reference Watertight Vacuumtight S EWB, HCP, HGP, HGW, SWH P PV E EBR, HGP, SWH P PV L HGG P www.lemo.com ● ● ● Watertight and vacumtight socket and coupler models (S, E and L series) Model Anodized colour for bend relief collet nut PV Note: other anodizing colours are available for connectors with collet nut for bend relief. Please consult us. O-ring and gasket material (E and L series) Standard connectors are delivered with silicone o-ring and gaskets. The vacuumtight models, identified with the letter «PV», are delivered with Viton® gaskets. Other gaskets material can be delivered upon special request. O-ring material Reference FPM (Viton®) EPDM FPM (Viton®) and collet nut for bend relief H E D 107 ® 108 ® www.lemo.com 2C SERIES 2G SERIES ® ® 2G Series The 2G series with key (G) provides the same advantages of space saving due to its small dimensions as the 2C series and is available in multipole type with 18 contacts. Metal housing models (page 111) Straight plugs Fixed sockets FGG PHG ECG EGG FGG Free sockets EYG ECG PHG Part Numbering System FGG . 2G . 318 . C Plug L A D 52 Variant: (page 113) Cable ø: (page 113) Collet type: (page 113) EGG . 2G . 318 . C Fixed socket L L Variant: (page 113) Model: (page 111) Contact: (page 113) Series: 2G Insulator: L = PEEK Insert configuration: (page 112) Housing: (page 112) Part Number Example Straight plug with cable collet: FGG.2G.318.CLAD52 = straight plug with cable collet, 2G series, multipole type with 18 contacts, outer shell in chrome-plated brass, PEEK insulator, male solder contacts, D type collet for 5.2 mm diameter cable. Fixed socket: EGG.2G.318.CLL = fixed socket, 2G series, multipole type with 18 contacts, outer shell in chrome-plated brass, PEEK insulator, female solder contacts. Part Section Showing Internal Components Straight plug Fixed socket 5 4 2 3 1 6 5 2 4 1 7 3 1 outer shell 2 hexagonal nut 3 locking washer 4 insulator 5 female contact 1 2 3 4 5 6 7 110 outer shell latch sleeve collet nut split centre-piece insulator male contact collet www.lemo.com ® ® Metal housing models Technical Characteristics Mechanical and Climatical Characteristics Endurance Humidity Temperature range Salt spray corrosion test Protection index Climatical category Value Standard > 500 cycles IEC 60512-5 test 9a up to 95% at 60° C - 55° C + 250° C > 144 h IEC 60512-6 test 11f IP50 IEC 60529 55/175/21 IEC 60068-1 FGG.2G Straight plug, key (G), cable collet Note: The various tests have been carried out with FGG and EGG connector pairs, with chrome-plated brass shell and PEEK insulator. Detailed electrical characteristics, as well as materials and treatment are presented in the chapter Technical Characteristics on page 171. FGG.2G Straight plug, key (G), cable collet and nut for fitting a bend relief 1) ~30 28.4 ~22 ø 14 ø 14 20.4 S 12 S 10.5 Cable assembly (page 115) Cable assembly (page 115) Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see page 141). EGG.2G Fixed socket, nut fixing, key (G) ECG.2G Fixed socket with two nuts, key (G) (back panel mounting) 15.6 maxi 15.6 maxi 4.3 maxi M15 x 1 3.5 M15 x 1 ø 19.2 ø 18 ø 19.2 M15 x 1 S 13.8 S 17 S 13.8 4.2 maxi Panel cut-out (page 115) Panel cut-out (page 115) ECG.2G Fixed socket with two nuts, key (G), straight contact for printed circuit (back panel mounting) EYG.2G Fixed socket, key (G), protruding shell (screw fixing on the panel) 3 12.5 8.5 4.2 maxi Panel cut-out (page 115) Panel cut-out (page 115) PCB drilling pattern (page 115) Note: all dimensions are in millimetres. www.lemo.com 15.6 maxi ø 14 ø 20 M13 x 0.75 3.5 M15 x 1 M15 x 1 ø 19.2 S 17 S 13.8 ø 20 1.8 S 17 111 ® ® PHG.2G Free socket, key (G), cable collet and nut for fitting a bend relief 1) PHG.2G Free socket, key (G), cable collet ~28 ø 14 ø 14 26.4 S 12 S 10.5 Cable assembly (page 115) Cable assembly (page 115) Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see page 141). ø A (mm) Solder Print Test voltage (kV rms) 2) Test voltage (kV dc) 2) Male solder contacts Female solder contacts 18 0.7 ● ● 0.85 1.2 2G Note: 1) 2) Rated current Number of contacts 318 øA Reference Contact type (A)1) Insert configuration (2G series) 5.5 see calculation method, caution and suggested standard on page 178. lowest measured value; contact to contact or contact to shell. Housings (2G series) Ref. C N K Outer shell and collet nut Latch sleeve Other metallic components Material Surf. treatment Material Surf. treatment Material Surf. treatment Brass Brass Brass chrome nickel black chrome brass/bronze brass/bronze brass/bronze nickel nickel nickel brass brass brass nickel nickel nickel Note ● ● ● ● First choice alternative ● Special order alternative Note: detailed characteristics of these materials and treatments are presented on page 171. 112 www.lemo.com ® ® Contacts (2G series) Contact type Ref. A L N Male solder Female solder Female print Collets (2G series) D type collets for 2G series øA øB D type Reference Collet ø Type Code 2G D D D D 52 62 72 80 Cable ø øA øB max. min. 5.2 6.2 7.2 8.0 – – 6.2 6.2 5.1 6.1 7.1 7.9 4.5 5.5 6.5 7.5 Note: all dimensions are in millimetres. Variant (2G series) Bend relief for 2G series models with collet Ref. Need to be ordered 2G Z www.lemo.com Collet Type Code D 52 to 80 Need to be ordered separately (see pages 141 and 142) GMA.2B.●●●.●● 113 ® ® Accessories (2G series) BRE Blanking caps for fixed and free sockets L B M øA Part number N BRE.2G.200.NAS ø 3.5 ● Body material: Nickel-plated brass (Ni 3 µm) ● Lanyard material: Stainless steel ● O-ring material: Silicone rubber or FPM A 18 Dimensions (mm) B L M 12 10.6 6.0 N 85 Note: these caps are suitable for use with any alignment key configuration. The last letter «S» of the part number stands for the material of the O ring (silicone rubber). O-ring’s made from FPM are also available; if required, replace the letter «S» by «V». ● Maximum operating temperature: 200°C ● Watertightness: IP61 according to IEC 60529 BRF Blanking caps for fixed sockets L B M øA Part number N BRF.2G.200.NAS sliding loop ● Body material: Nickel-plated brass (Ni 3 µm) ● Lanyard material: Stainless steel ● O-ring material: Silicone rubber or FPM A 18 Dimensions (mm) B L M 12 14.0 6.0 N 85 Note: this caps are suitable for use with any alignment key configuration. The last letter «S» of the part number stands for the material of the O ring (silicone rubber). O-ring’s made from FPM are also available; if required, replace the letter «S» by «V». ● Maximum operating temperature: 200°C ● Watertightness: IP61 according to IEC 60529 FFM Nut for bend relief øA øC L Part number FFM.2C.130.LC S2 Dimensions (mm) A C L S2 14 8 12.2 12 Note: for bend reliefs to be used with this nut see section «Accessories» page 141. ● Material: Chrome-plated brass (0.3 µm) Note: other accessories are also available. See section «Accessories» on page 135. 114 www.lemo.com ® ® Tooling (2G series) Please consult the «Tooling» section (page 146). Panel cut-outs (2G series) Panel cut-outs PCB drilling pattern EGG - ECG EYG 22 mini ° 60 17 mini ø 15.1 +0.1 0 15° 13.9 +0.1 0 M13 x 0.75 ø 0.6 ø 3.5 ø 6.7 30° Note: mounting nut torque: 6 Nm (1N = 0.102 kg) Cable assembly (2G series) L Connector T Series S 2G Type 318 ø contact A (mm) Cable stripping lengths (2G series) 0.7 Cable stripping lengths (mm) L S T 9 7 3 Note: the tolerances on these dimensions are: L: ± 0.5 mm; S: ± 0.5 mm; T: ± 0.2 mm. www.lemo.com 115 ® ® 2C Series In many applications, it is necessary to use multipole connectors which have shortened dimensions but require high contact density. LEMO short series connectors, which are shorter than 30 mm, perfectly meet these needs. The 2C series, featuring a hermaphroditic insert, is available in multipole type up to 14 contacts. Metal housing models (page 117) Fixed plug Straight plugs Fixed sockets Free sockets Fixed socket Watertight or vacuumtight models (page 119) Fixed sockets FFA FAA PCA ERA PSA ECP ERY HGP FFA ECP HEP PCA EEP Part Numbering System FFA . 2C . 306 . C Plug L A C 27 Variant: (page 121) Cable ø: (page 121) Collet type: (page 121) ERA . 2C . 306 . C Fixed socket L L Variant: (page 121) Model: (page 117) Contact: (page 120) Series: 2C Insulator: L = PEEK Insert configuration: (page 120) Housing: (page 120) Part Number Example Straight plug with cable collet: FFA.2C.306.CLAC27 = straight plug with cable collet, 2C series, multipole type with 6 contacts, outer shell in chromeplated brass, PEEK insulator, male solder contacts, C type collet for 2.7 mm diameter cable. Fixed socket: ERA.2C.306.CLL = fixed socket, nut fixing, 2C series, multipole type with 6 contacts, outer shell in chrome-plated brass, PEEK insulator, female solder contacts. Part Section Showing Internal Components Straight plug Fixed socket 6 4 2 3 1 5 7 6 2 5 4 1 8 3 1 1 2 3 4 5 6 outer shell hexagonal nut locking washer insulator male contact female contact 2 3 4 5 6 7 8 116 outer shell latch sleeve collet nut split centre-piece insulator male contact female contact collet www.lemo.com ® ® Metal housing models Technical Characteristics Mechanical and Climatical Characteristics Endurance Humidity Temperature range Salt spray corrosion test Protection index Climatical category Value Standard > 500 cycles IEC 60512-5 test 9a up to 95% at 60° C - 55° C + 250° C > 144 h IEC 60512-6 test 11f IP50 IEC 60529 55/175/21 IEC 60068-1 FFA.2C Straight plug, cable collet Note: The various tests have been carried out with FFA and ERA connector pairs, with chrome-plated brass shell and PEEK insulator. Detailed electrical characteristics, as well as materials and treatment are presented in the chapter Technical Characteristics on page 171. FFA.2C Straight plug, cable collet and nut for fitting a bend relief 1) ~30 28.4 ~22 ø 14 ø 14 20.4 S 12 S 10.5 Cable assembly (page 122) Cable assembly (page 122) Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see page 141). FAA.2C Fixed plug, nut fixing, non-latching ERA.2C Fixed socket, nut fixing 15.6 maxi 17 maxi S 17 1.3 maxi 1.8 ø 18 M15 x 1 ø 18 ø 19.2 9.5 M15 x 1 ø 19.2 S 17 S 13.8 S 13.8 4.3 maxi Panel cut-out (page 122) Panel cut-out (page 122) ECP.2C Fixed socket with two nuts (back panel mounting) ECP.2C Fixed socket with two nuts, straight contact for printed circuit (back panel mounting) Panel cut-out (page 122) 12.5 4.2 maxi S 13.5 Panel cut-out (page 122) 3.5 M15 x 1 M15 x 1 ø 19.2 S 17 ø 20 M15 x 1 M15 x 1 ø 19.2 S 13.5 3.5 ø 20 3 15.6 maxi S 17 4.2 maxi PCB drilling pattern (page 122) Note: all dimensions are in millimetres. www.lemo.com 117 ® ® EEP.2C Fixed socket, nut fixing (back panel mounting) ERY.2C Fixed socket, protruding shell, (screw fixing on the panel) 15.6 maxi S 13.5 15.6 maxi M13 x 0.75 8.5 ø 14 ø 20 ø 19.5 M15 x 1 3.5 4.2 maxi 9.5 Panel cut-out (page 122) Panel cut-out (page 122) PCA.2C Free socket, cable collet PCA.2C Free socket, cable collet and nut for fitting a bend relief 1) ~28 ø 14 ø 14 26.4 S 12 S 10.5 Cable assembly (page 122) Cable assembly (page 122) Note: 1) to order, add a «Z» at the end of the reference. The bend relief must be ordered separately (see page 141). PSA.2C Fixed socket nut fixing, cable collet ~28 S 10.5 S 13.8 2 ø 18 M15 x 1 ø 19.2 S 17 5 maxi Panel cut-out (page 122) Note: all dimensions are in millimetres. 118 www.lemo.com ® ® Watertight or vacuumtight models These socket allow the device on which they are fitted to reach a protection index of IP68 as per IEC 60529. They are fully compatible with plugs of the same series and are widely used for portable radios, military, laboratory equipment, aviation, etc. These models are identified by a letter «P» at the end of the reference. These models are also available in a vacuumtight version. Such models are identified by an additional letter «V» at the end of the part number (certificate on request). Epoxy resin is used to seal these models. Technical Characteristics Mechanical and Climatical Endurance Humidity Temperature range Salt spray corrosion test Value Standard > 500 cycles > 144h IEC 60512-5 test 9a up to 95% at 60° C - 20° C, +80° C IEC 60512-6 test 11f HGP.2C Fixed socket, nut fixing, watertight or vacuumtight Characteristics Climatical category Leakage rate (He)1) Maximum operating pressure Value Standard 20/80/21 IEC 60068-1 < 10-7 mbar.l.s-1 IEC 60512-7 test 14b 5 bars IEC 60512-7 test 14d Note: 1) only for vacuumtight models. HEP.2C Fixed socket, nut fixing, watertight or vacuumtight (back panel mounting) 20 maxi 20 maxi S 13.8 10.6 4 S 17 Panel cut-out (page 122) www.lemo.com 5 maxi 3.5 M15 x 1 ø 20 ø 20 ø 19.2 M15 x 1 5.7 5.2 maxi ø 20 Characteristics S 13.8 Panel cut-out (page 122) 119 ® ® Insert configuration (2C series) Number of contacts ø A (mm) Solder Print Test voltage (kV rms)1) 2) Test voltage (kV dc)1) 2) Rated current (A)1) 302 2 1.6 ● – 1.80 2.40 20 303 3 1.3 ● – 1.50 2.10 15 304 4 1.3 ● – 1.80 2.40 15 306 6 1.3 ● – 1.50 2.10 12 308 8 0.7 ● ● 0.95 1.35 7 310 10 0.7 ● ● 0.95 1.35 7 312 12 0.7 ● ● 0.60 0.90 5 314 14 0.7 ● ● 0.60 0.90 5 øA øA Reference Contact type Male solder contacts 2C 2 Female solder contacts 1 1 2 2 1 1 2 3 3 1 4 2 3 2 2 3 1 3 1 4 4 6 6 5 3 4 3 4 3 2 1 9 1 8 8 7 2 7 3 1 2 3 3 7 6 10 7 11 12 1 1 3 7 4 4 8 11 8 12 14 14 12 1) 2) 7 4 12 11 7 6 10 5 6 1 6 10 11 5 8 2 9 4 1 8 7 3 2 1 6 5 10 6 5 2 5 Note: 2 3 1 4 see calculation method, caution and suggested standard on page 178. lowest measured value; contact to contact or contact to shell. Housings (2C series) Ref. C N K Outer shell and collet nut Latch sleeve Other metallic components Material Surf. treatment Material Surf. treatment Material Surf. treatment Brass Brass Brass chrome nickel black chrome brass/bronze brass/bronze brass/bronze nickel nickel nickel brass brass brass nickel nickel nickel Note ● ● ● ● First choice alternative ● Special order alternative Note: detailed characteristics of these materials and treatments are presented on page 171. Contacts (2C series) Ref. A L N 120 Contact type Male solder Female solder Female print Multipole connectors are fitted with hermaphroditic inserts including male and female contacts. However, by convention, the letter indicating the contact type in the part number composition will be the male contact (reference A) for plugs and female contact (reference L) for sockets. www.lemo.com ® ® Collets (2C series) C and L type collets for 2C series L type Reference Collet ø Type Code 2C C C C C C C C C C C C C øA øA øB C type 27 32 37 42 47 52 57 62 67 72 75 80 Cable ø Reference øA øB max. min. 2.7 3.2 3.7 4.2 4.7 5.2 5.7 6.2 6.7 7.2 7.5 8.0 – – – – – – – – 6.2 6.2 6.2 6.2 2.6 3.1 3.6 4.1 4.6 5.1 5.6 6.1 6.6 7.1 7.4 7.9 2.2 2.7 3.2 3.7 4.2 4.7 5.2 5.7 6.2 6.7 7.2 7.5 Note: all dimensions are in millimetres. Type Code 2C L L L L L L L L L L L L L 14 27 32 37 42 47 52 57 62 67 72 77 82 Collet ø Cable ø øA øB max. min. 1.4 2.7 3.2 3.7 4.2 4.7 5.2 5.7 6.2 6.7 7.2 7.7 8.2 – – – – – – – – – – – – – 1.3 2.6 3.1 3.6 4.1 4.6 5.1 5.6 6.1 6.6 7.1 7.6 8.1 0.8 2.2 2.7 3.2 3.7 4.2 4.7 5.2 5.7 6.2 6.7 7.2 7.7 Variant (2C series) Bend relief for 2C series models with collet Need to be ordered Ref. Collet 2C Z Type Code C L 42 to 80 42 to 82 Need to be ordered separately (see pages 141 and 142) GMA.2B.0●●.D● GMA.2B.0●●.D● Watertight and vacumtight socket models (2C series) Model 2C www.lemo.com HEP HGP Reference Watertight Vacuumtight P PV 121 ® ® Accessories (2C series) Accessories for the 2C series are identical with the 2G series. Please refer to corresponding pages (page 114). Tooling (2C series) Please consult the «Tooling» section (page 146). Panel cut-outs (2C series) PCB drilling patterns 2.8 (4x) 1.5 (4x) 1.5 312 ERY 2.8 1.1 13.9 13.9 ø 0.6 1.1 HGP PSA 310 ø 0.6 2.8 13.6 13.6 13.9 13.9 13.9 308 B (mm) 1.1 ECP EEP ERA FAA HEP Model 1.1 314 ø 0.6 ø 0.6 M13 x 0.75 (6x) 1 Note: mounting nut torque: 6 Nm (1N = 0.102 kg) 2.4 2.4 1 1 1 1 2.4 17 mini 2.4 ø 15.1 +0.1 0 B +0.1 0 B (mm) Model 22 mini 2.8 Panel cut-outs (6x) 1 Cable assembly (2C series) L Connector T Series S 2C Type 302 303/304/306 308/310/312/314 ø contact A (mm) Cable stripping lengths (2C series) Cable stripping lengths (mm) L S T 1.6 1.3 0.7 11 11 11 8 8 8 3 3 3 Note: the tolerances on these dimensions are: L: ± 0.5 mm; S: ± 0.5 mm; T: ± 0.2 mm. 122 www.lemo.com 1D SERIES (quadrax) ® ® 1D Series 1D series QUADRAX connectors have four concentric contacts insulated from the connector shell. Specially developed for major radio and television channels, this new connector type provides the possibility of blind mating with the full security of the LEMO Push-Pull self-latching system. Metal housing models (page 125) Fixed plug Straight plugs FAA FFA Fixed socket Free sockets ERN PCA Bridge plug CFF, CRF PCA FFA Part Numbering System FFA . 1D . 694 . C N Plug L D 42 Variant: (page 128) Cable ø: (page 127) Collet type: (page 127) ERN . 1D . 694 . C N A Fixed socket Variant: (page 128) Model: (page 125) Contact: (page 127) Series: 1D Insulator: N = PA6.6 Insert configuration: (page 127) 694 = quadrax Housing: (page 127) Part Number Example Straight plug with cable collet: FFA.1D.694.CNLD42 = straight plug with cable collet, 1D series, quadrax type, outer shell in chrome-plated brass, PA6.6 insulator, female solder contacts, D type collet for 4.2 mm diameter cable. Fixed socket: ERN.1D.694.CNA = fixed socket, 1D series, quadrax type, outer shell in chrome-plated brass, PA6.6 insulator, male solder contacts. Part Section Showing Internal Components Straight plug Fixed socket outer shell 6 7 2 earthing crown 3 retaining ring 4 hexagonal nut 5 locking washer 6 insulator 7 printed circuit 8 male contact 9 male intermediate contact 10 female intermediate contact 1 2 124 3 4 5 1 10 9 10 8 2 8 9 8 7 6 5 1 4 10 3 1 2 3 4 5 6 7 8 9 10 outer shell latch sleeve collet nut split centre-piece insulator printed circuit female contact male intermediate contact female intermediate contact collet www.lemo.com ® ® Metal housing models Technical Characteristics Mechanical and Climatical Characteristics Electrical Value Endurance Temperature range1) Salt spray corrosion test Protection index Characteristics Standard > 1000 cycles IEC 60512-5 test 9a -40° C, +120° C > 144h IEC 60512-6 test 11f IP50 IEC 60529 Note: 1) for bridge plug: -40° C, +80° C Detailed electrical characteristics, as well as materials and treatment are presented in the chapter Technical Characteristics on page 171. Insulation resistance Insul. res. after 48h 95%RH at 10 MHz Screening efficiency at 1 GHz Contact resistance Value > 1011Ω > 1010Ω > 70 dB > 35 dB < 20mΩ Standard IEC 60512-2 test 3a IEC 60512-2 test 3a IEC 60169-1-3 IEC 60169-1-3 IEC 60512-2 test 2a FFA Straight plug, cable collet Part number FFA.1D.694.CNLD42 FFA.1D.694.CNLD52 FFA.1D.694.CNLD62 FFA.1D.694.CNLD72 FFA.1D.694.CNLD76 ~43 ø 12 ~32 Cable assembly (page 128) S9 S 10 FFA Straight plug, cable collet and nut for fitting a bend relief Part number FFA.1D.694.CNLD42Z FFA.1D.694.CNLD52Z FFA.1D.694.CNLD62Z FFA.1D.694.CNLD72Z 42 ø 12 33 S9 Cable assembly (page 128) Note: The bend relief must be ordered separately (see page 141). S 10 FAA Fixed plug, nut fixing, non-latching 26.5 22.5 S 14 12.5 ø 14 M 12 x 1 ø 15.8 Part number Panel cut-out (page 128) 7 maxi www.lemo.com FAA.1D.694.CNL S 10.5 125 ® ® ERN Fixed socket nut fixing, with earthing tag 21.7 maxi 19.5 S 14 1.5 ø 14 M 12 x 1 ø 15.8 Part number ERN.1D.694.CNA Panel cut-out (page 128) 7.5 maxi S 10.5 CFF Bridge plug with two non-latching plugs CRF Bridge plug with two non-latching plugs with monitoring output Part number 31 CFF.1D.694.PNMG CRF.1D.694.PNFG 22 20 35 15 Note: the last letter (G) of the part number indicates the grey colour of the housing. For other colours, replace this letter (G) by the one corresponding to the required colour. 42.5 PCA Free socket, cable collet Part number ø 12.5 ~40 S9 PCA.1D.694.CNAD42 PCA.1D.694.CNAD52 PCA.1D.694.CNAD62 PCA.1D.694.CNAD72 PCA.1D.694.CNAD76 Cable assembly (page 128) S 10 PCA Free socket, cable collet and nut for fitting a bend relief Part number ø 12.5 39.5 PCA.1D.694.CNAD42Z PCA.1D.694.CNAD52Z PCA.1D.694.CNAD62Z PCA.1D.694.CNAD72Z Cable assembly (page 128) S9 126 S 10 Note: The bend relief must be ordered separately (see page 141). www.lemo.com ® ® Reference Number of contacts Solder Test voltage (kV rms)1) 2) Test voltage (kV dc)1) 2) Rated current (A)1) Insert configuration (1D series) 694 4 ● 0.42 0.6 0.5 Contact type Male solder contacts Note: Female solder contacts 1) see calculation method, 2) lowest measured value; caution and suggested standard on page 178. contact to contact or contact to shell. Housings (1D series) Ref. Outer shell and collet nut Latch sleeve + earthing crown Other metallic components Material Surf. treatment Material Surf. treatment Material Surf. treatment Brass PA.6 chrome – brass/bronze brass/bronze nickel nickel brass brass nickel nickel C P Remarks Note Only for CFF and CRF bridge plug 1) ● ● Note: detailed characteristics of these materials and treatments are presented on page 171. 1) see «variant» for the colour. ● First choice alternative ● Special order alternative Contacts (1D series) Contact type Ref. A L Remarks Male solder center contact Female solder center contact For sockets For plugs Collets (1D series) D type collets for 1D series D type collets for 1D series øB øB Reference øA D type øA D type Collet ø Cable ø Reference Collet ø Cable ø Notes Type Code 1D D D D 42 52 62 øA øB max. min. 4.2 5.2 6.2 – – – 4.0 5.0 6.0 3.1 4.1 5.1 Notes Type Code 1D D D 72 76 øA øB max. min. 7.2 7.6 6.7 6.7 7.0 7.5 6.1 7.1 1) Note: 1) these collets cannot be used for connector models with nut for fitting a bend relief. All dimensions are in millimetres. www.lemo.com 127 ® ® Variant (1D series) Bend relief for 1D series models with collet Colour of the bridge plug shells Need to be ordered Ref. Collet 1D Z Type Code Need to be ordered separately (see pages 141 and 142) D 42 to 72 GMA.1B.●●●.●● Reference Colour A B G J M N R V blue white grey yellow brown black red green Accessories and Tooling (1D series) Accessories and tooling for the 1D series are identical with the 1B series. Please refer to corresponding pages (page 135 and 146). Panel cut-outs (1D series) Panel cut-out ø 12.1 +0.1 0 20 Note: mounting nut torque: 4.5 Nm (1N = 0.102 kg) When connectors are assembled with double panel washers or insulating washers the mounting nut torque is 4 Nm. 10.6 +0.1 0 Cable assembly (1D series) L Connector T Series S 1D Type 694 ø contact A (mm) Cable stripping lengths (1D series) – Cable stripping lengths (mm) L S T 14 8 3 Note: the tolerances on these dimensions are: L: ± 0.5 mm; S: ± 0.5 mm; T: ± 0.2 mm. 128 www.lemo.com SPARE PARTS ® ® Spare parts FGG-EGG Insulators for crimp contacts male Type female Insulator part number Male contact Female contact 302 303 304 FGG.00.302.YL FGG.00.303.YL FGG.00.304.YL EGG.00.402.YL EGG.00.403.YL EGG.00.404.YL 0B 0K 302 303 304 305 306 307 309 FGG.0B.302.YL FGG.0B.303.YL FGG.0B.304.YL FGG.0B.305.YL FGG.0B.306.YL FGG.0B.307.YL FGG.0B.309.YL EGG.0B.402.YL EGG.0B.403.YL EGG.0B.404.YL EGG.0B.405.YL – – – 1B 1K 302 303 304 305 306 307 308 310 314 316 FGG.1B.302.YL FGG.1B.303.YL FGG.1B.304.YL FGG.1B.305.YL FGG.1B.306.YL FGG.1B.307.YL FGG.1B.308.YL FGG.1B.310.YL FGG.1B.314.YL FGG.1B.316.YL EGG.1B.402.YL EGG.1B.403.YL EGG.1B.404.YL EGG.1B.405.YL EGG.1B.406.YL EGG.1B.407.YL EGG.1B.408.YL – – – 2B 2K 302 303 304 305 306 307 308 310 312 314 316 318 319 FGG.2B.302.YL FGG.2B.303.YL FGG.2B.304.YL FGG.2B.305.YL FGG.2B.306.YL FGG.2B.307.YL FGG.2B.308.YL FGG.2B.310.YL FGG.2B.312.YL FGG.2B.314.YL FGG.2B.316.YL FGG.2B.318.YL FGG.2B.319.YL EGG.2B.402.YL EGG.2B.403.YL EGG.2B.404.YL EGG.2B.405.YL EGG.2B.406.YL EGG.2B.407.YL EGG.2B.408.YL EGG.2B.410.YL EGG.2B.412.YL EGG.2B.414.YL EGG.2B.416.YL EGG.2B.418.YL EGG.2B.419.YL 302 303 304 305 306 307 FGG.3B.302.YL FGG.3B.303.YL FGG.3B.304.YL FGG.3B.305.YL FGG.3B.306.YL FGG.3B.307.YL EGG.3B.402.YL EGG.3B.403.YL EGG.3B.404.YL EGG.3B.405.YL EGG.3B.406.YL EGG.3B.407.YL 00 3B 3K 130 Type Insulator part number Male contact Female contact 3B 3K 308 309 310 312 314 316 318 320 322 324 326 330 FGG.3B.308.YL FGG.3B.309.ML FGG.3B.310.YL FGG.3B.312.YL FGG.3B.314.YL FGG.3B.316.YL FGG.3B.318.YL FGG.3B.320.YL FGG.3B.322.YL FGG.3B.324.YL FGG.3B.326.YL FGG.3B.330.YL EGG.3B.408.YL EGG.3B.409.ML EGG.3B.410.YL EGG.3B.412.YL EGG.3B.414.YL EGG.3B.416.YL EGG.3B.418.YL EGG.3B.420.YL EGG.3B.422.YL EGG.3B.424.YL EGG.3B.426.YL EGG.3B.430.YL 4B 4K 304 306 307 310 312 316 320 324 330 340 348 FGG.4B.304.YL FGG.4B.306.YL FGG.4B.307.YL FGG.4B.310.YL FGG.4B.312.YL FGG.4B.316.YL FGG.4B.320.YL FGG.4B.324.YL FGG.4B.330.YL FGG.4B.340.YL FGG.4B.348.YL EGG.4B.404.YL EGG.4B.406.YL EGG.4B.407.YL EGG.4B.410.YL EGG.4B.412.YL EGG.4B.416.YL EGG.4B.420.YL EGG.4B.424.YL EGG.4B.430.YL EGG.4B.440.YL EGG.4B.448.YL 5B 5K 304 310 314 316 320 330 340 348 350 354 364 FGG.5B.304.ML FGG.5B.310.YL FGG.5B.314.YL FGG.5B.316.YL FGG.5B.320.YL FGG.5B.330.YL FGG.5B.340.YL FGG.5B.348.YL FGG.5B.350.ML FGG.5B.354.YL FGG.5B.364.YL EGG.5B.404.ML EGG.5B.410.YL EGG.5B.414.YL EGG.5B.416.YL EGG.5B.420.YL EGG.5B.430.YL EGG.5B.440.YL EGG.5B.448.YL EGG.5B.450.ML EGG.5B.454.YL EGG.5B.464.YL Note: each insulator can be used both for crimp contacts of normal shape (fig. 1) or with reduced solder cups (fig. 2) as shown on page 131. www.lemo.com ® ® FGG-EGG Crimp contacts øC Types øA øC øA øC Contact part number Types Male Female ø C (mm) øA Fig. 2 ø A (mm) øC ø C (mm) øA ø A (mm) Fig. 1 Contact part number Male Female 00 302 303 304 0.5 0.45 FGG.00.554.ZZC EGG.00.654.ZZM 0.5 0.45 FGG.00.554.ZZC EGG.00.654.ZZM 0.5 0.45 FGG.00.554.ZZC EGG.00.654.ZZM 0B 0K 302/303 302/303 304/305 0.9 0.80 FGG.0B.561.ZZC EGG.0B.661.ZZM 0.9 0.45 FGG.0B.562.ZZC EGG.0B.662.ZZM 0.7 0.45 FGG.0B.556.ZZC EGG.0B.656.ZZM 0B 0K 302/303 0.9 1.10 FGG.0B.560.ZZC EGG.0B.660.ZZM 304/305 0.7 0.80 FGG.0B.555.ZZC EGG.0B.655.ZZM 306/307/309 0.5 0.45 FGG.0B.554.ZZC – 0S 302 302 304 0.9 0.80 FGG.0B.561.ZZC EGG.0B.661.ZZM 0.9 0.45 FGG.0B.562.ZZC EGG.0B.662.ZZM 0.7 0.45 FGG.0B.556.ZZC EGG.0B.656.ZZM 0S 302 304 0.9 1.10 FGG.0B.560.ZZC EGG.0B.660.ZZM 0.7 0.80 FGG.0B.555.ZZC EGG.0B.655.ZZM 1B 1K 302/303 304/305 306/307/308 310/314/316 1.3 0.9 0.7 0.5 1B 1K 302/303 1.3 1.10 FGG.1B.566.ZZC EGG.1B.666.ZZM 304/305 0.9 0.80 FGG.1B.561.ZZC EGG.1B.661.ZZM 306/307/308 0.7 0.45 FGG.1B.556.ZZC EGG.1B.656.ZZM 1S 302 304 1.3 1.10 FGG.1B.566.ZZC EGG.1B.666.ZZM 0.9 0.80 FGG.1B.561.ZZC EGG.1B.661.ZZM 1S 302 304 1.3 1.40 FGG.1B.565.ZZC EGG.1B.665.ZZM 0.9 1.10 FGG.1B.560.ZZC EGG.1B.660.ZZM 2B 2K 2B 2K 302 303 304/305 306/307 308/310 312/314/316 318/319 2.0 1.6 1.3 1.3 0.9 0.7 0.7 302 303 304/305 306/307 304/305 306/307 308/310 308/310 312/314/316 318/319 2.0 1.6 1.3 1.3 1.3 1.3 0.9 0.9 0.7 0.7 2S 306 1.3 1.40 FGG.2B.565.ZZC EGG.2B.665.ZZM 2S 306 306 1.3 1.10 FGG.2B.566.ZZC EGG.2B.666.ZZM 1.3 0.80 FGG.2B.567.ZZC EGG.2B.667.ZZM 3B 3K 302 303/304/309 305/306/307 308/309/310 312/314 316/318 320/322/324 326/330 3.0 2.0 1.6 1.3 0.9 0.9 0.7 0.7 2.90 2.40 1.90 1.40 1.10 1.10 0.80 0.80 FGG.3B.580.ZZC FGG.3B.575.ZZC FGG.3B.570.ZZC FGG.3B.565.ZZC FGG.3B.560.ZZC FGG.3B.560.ZZC FGG.3B.555.ZZC FGG.3B.555.ZZC EGG.3B.680.ZZM EGG.3B.675.ZZM EGG.3B.670.ZZM EGG.3B.665.ZZM EGG.3B.660.ZZM EGG.3B.660.ZZM EGG.3B.655.ZZM EGG.3B.655.ZZM 3B 3K 4B 4K 304 306/307 310 312 316/320 324/330 340/348 3.0 2.0 1.6 1.3 0.9 0.9 0.7 2.90 2.40 1.90 1.40 1.10 1.10 0.80 FGG.4B.580.ZZC FGG.4B.575.ZZC FGG.4B.570.ZZC FGG.4B.565.ZZC FGG.4B.560.ZZC FGG.4B.560.ZZC FGG.4B.555.ZZC EGG.4B.680.ZZM EGG.4B.675.ZZM EGG.4B.670.ZZM EGG.4B.665.ZZM EGG.4B.660.ZZM EGG.4B.660.ZZM EGG.4B.655.ZZM 303/304/309 305/306/307 308/309/310 312/314 316/318 312/314 316/318 316/318 320/322/324 326/330 320/322/324 326/330 2.0 1.6 1.3 0.9 0.9 0.9 0.9 0.9 0.7 0.7 0.7 0.7 1.90 1.40 1.10 1.10 1.10 0.80 0.80 0.45 0.80 0.80 0.45 0.45 FGG.3B.576.ZZC FGG.3B.571.ZZC FGG.3B.566.ZZC FGG.3B.560.ZZC FGG.3B.560.ZZC FGG.3B.561.ZZC FGG.3B.561.ZZC FGG.3B.562.ZZC FGG.3B.555.ZZC FGG.3B.555.ZZC FGG.3B.556.ZZC FGG.3B.556.ZZC EGG.3B.676.ZZM EGG.3B.671.ZZM EGG.3B.666.ZZM EGG.3B.660.ZZM EGG.3B.660.ZZM EGG.3B.661.ZZM EGG.3B.661.ZZM EGG.3B.662.ZZM EGG.3B.655.ZZM EGG.3B.655.ZZM EGG.3B.656.ZZM EGG.3B.656.ZZM 4B 4K 304 310 314/316 320 330/340/348 350/354/364 4.0 3.0 2.0 1.6 1.3 0.9 4.00 2.90 2.40 1.90 1.40 1.10 FGG.5B.582.ZZC FGG.5B.580.ZZC FGG.5B.575.ZZC FGG.5B.570.ZZC FGG.5B.565.ZZC FGG.5B.560.ZZC EGG.5B.682.ZZM EGG.5B.680.ZZM EGG.5B.675.ZZM EGG.5B.670.ZZM EGG.5B.665.ZZM EGG.5B.660.ZZM 306/307 310 312 316/320 324/330 340/348 2.0 1.6 1.3 0.9 0.9 0.7 1.90 1.40 1.10 0.80 0.80 0.45 FGG.4B.576.ZZC FGG.4B.571.ZZC FGG.4B.566.ZZC FGG.4B.561.ZZC FGG.4B.561.ZZC FGG.4B.556.ZZC EGG.4B.676.ZZM EGG.4B.671.ZZM EGG.4B.666.ZZM EGG.4B.661.ZZM EGG.4B.661.ZZM EGG.4B.656.ZZM 5B 5K 314/316 320 320 330/340/348 330/340/348 350/354/364 2.0 1.6 1.6 1.3 1.3 0.9 1.90 1.90 1.40 1.40 1.10 0.80 FGG.5B.576.ZZC FGG.5B.570.ZZC FGG.5B.571.ZZC FGG.5B.565.ZZC FGG.5B.566.ZZC FGG.5B.561.ZZC EGG.5B.676.ZZM EGG.5B.670.ZZM EGG.5B.671.ZZM EGG.5B.665.ZZM EGG.5B.666.ZZM EGG.5B.661.ZZM 5B 5K www.lemo.com 1.40 1.10 0.80 0.45 2.40 1.90 1.40 1.40 1.10 0.80 0.80 FGG.1B.565.ZZC EGG.1B.665.ZZM FGG.1B.560.ZZC EGG.1B.660.ZZM FGG.1B.555.ZZC EGG.1B.655.ZZM FGG.1B.554.ZZC – FGG.2B.575.ZZC FGG.2B.570.ZZC FGG.2B.565.ZZC FGG.2B.565.ZZC FGG.2B.560.ZZC FGG.2B.555.ZZC FGG.2B.555.ZZC EGG.2B.675.ZZM EGG.2B.670.ZZM EGG.2B.665.ZZM EGG.2B.665.ZZM EGG.2B.660.ZZM EGG.2B.655.ZZM EGG.2B.655.ZZM 1.90 1.40 1.10 1.10 0.80 0.80 0.80 0.45 0.45 0.45 FGG.2B.576.ZZC FGG.2B.571.ZZC FGG.2B.566.ZZC FGG.2B.566.ZZC FGG.2B.567.ZZC FGG.2B.567.ZZC FGG.2B.561.ZZC FGG.2B.562.ZZC FGG.2B.556.ZZC FGG.2B.556.ZZC EGG.2B.676.ZZM EGG.2B.671.ZZM EGG.2B.666.ZZM EGG.2B.666.ZZM EGG.2B.667.ZZM EGG.2B.667.ZZM EGG.2B.661.ZZM EGG.2B.662.ZZM EGG.2B.656.ZZM EGG.2B.656.ZZM 131 ® ® GBA Locking washers Part number Series øA L øC ● Material: Nickel-plated bronze (3 µm) Dimensions (mm) A C L GBA.00.250.FN GBA.0S.250.FN 00 9.5 0S-0B 12.5 7.1 9.1 1.0 1.0 GBA.1S.250.FN 1S-1B 16.0 12.1 1D 1.0 GBA.1E.250.FN 1E-1K 21.8 16.1 1.2 GBA.2S.250.FN 2S-2B 19.5 15.1 2C-2G 1.2 GBA.3S.250.FN GBA.4S.250.FN 3S-3B 25.0 18.1 4S-4B 32.0 25.1 1.4 1.4 Note: to order this accessory separately, use the above part numbers. GBB Tapered washers øA L øC ● Material: Nickel-plated brass (3 µm) Dimensions (mm) A C L Part number Series GBB.00.250.LN GBB.0S.250.LN GBB.1S.250.LN 00 0S-0B 1S-1B 9 11 15 7.1 9.1 12.1 2.0 2.5 3.5 GBB.2S.250.LN 2S-2B 2C-2G 18 15.1 4.0 GBB.3S.250.LN GBB.4S.250.LN GBB.5S.250.LN 3S-3B 4S-4B 5S-5B 22 28 40 18.1 25.2 35.2 4.5 5.0 7.5 Note: sockets of series 5B and 5S are always supplied with a tapered washer. To order this accessory separately, use the above part numbers. GEA Hexagonal nuts Part number A L B e ● Material: – Nickel-plated brass (3 µm) – Natural anodized aluminium alloy – Stainless steel 132 Series A Dimensions (mm) B e L GEA.00.240.LN GEA.0S.240.LN GEA.0S.241.LN 00 0S-0B 0S-0B 9 11 12 10.2 M7 x 0.50 2.0 12.4 M 9 x 0.60 2.0 13.8 M10 x 0.75 2.5 GEA.0E.240.LN 0E-0K-0L 1S-1B 17 19.2 M14 x 1.00 2.5 GEA.1S.240.LN 1S-1B-1D 14 15.8 M12 x 1.00 2.5 GEA.1E.240.LN 1E-1K-1L 2S-2B 19 21.5 M16 x 1.00 3.0 GEA.2S.240.LN GEA.2E.240.LN GEA.3S.240.LN GEA.3E.240.LN GEA.4S.240.LN GEA.4E.240.LN 2S-2B 2E-2K-2L 3S-3B 3E-3K 4S-4B 4E-4K 17 24 22 30 30 36 19.2 27.0 25.0 34.0 34.0 40.5 M15 x 1.00 M20 x 1.00 M18 x 1.00 M24 x 1.00 M25 x 1.00 M30 x 1.00 2.7 4.0 3.0 5.0 5.0 7.0 Note: to order this part separately, use the above part numbers. The last letters «LN» of the part number refer to the nut material and treatment. If a nut in aluminium alloy or stainless steel is desired, replace the last letters of the part number by «PT» or «AZ» respectively. www.lemo.com ® ® GEG Notched nut øA L e Model øB Part number Model 1 øA L øB e 1 1 1 1 2 1 2 2 2 GEG.00.240.LC GEG.0S.240.LC GEG.0E.240.LC GEG.1S.240.LC GEG.1E.240.LC GEG.1S.242.LC GEG.2S.240.LC GEG.2S.241.LC GEG.2E.240.LC A 8.6 10.5 15.8 14.0 17.5 12.1 17.5 20.5 22.5 Dimensions (mm) B e L 10 12 18 16 20 14 20 24 25 M7 x 0.5 M9 x 0.6 M14 x 1.0 M12 x 1.0 M16 x 1.0 M11 x 0.5 M15 x 1.0 M19 x 1.0 M20 x 1.0 2.5 2.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5 ● Material: Chrome-plated brass (Ni 3 µm + Cr 0.3 µm) Note: 00, 0B, 0S, 1B, 1S, 2B and 2S series fixed and free sockets for back panel mounting are always delivered with this notched nut. To order this accessory separately, use the above part numbers. Model 2 GEC Conical nuts Part number A L øB e ● Material: Chrome-plated brass (Ni 3 µm + Cr 0.3 µm) Note: 3B, 3K, 3S, 3E, 4B, 4K, 4S, 4E, 5B, 5K, 5S, 5E, 6S and 6E series fixed and free sockets for back panel mounting are always delivered with a conical nut. To order this accessory separately, use the part numbers in the adjacent table. GEC.00.240.LC GEC.0S.240.LC GEC.0E.240.LC GEC.1S.240.LC GEC.1S.241.LC GEC.1S.242.LC GEC.2S.240.LC GEC.2S.241.LC GEC.2E.240.LC GEC.3S.240.LC GEC.3E.240.LC GEC.4S.240.LC GEC.4K.241.LC GEC.5S.240.LC A 8 10 16 13 17 12 17 20 22 20 27 27 32 37 Dimensions (mm) B e L 10.0 12.0 18.0 16.0 20.0 14.0 20.0 24.0 25.0 24.0 30.0 30.0 35.5 41.0 M7 x 0.5 M9 x 0.6 M14 x 1.0 M12 x 1.0 M16 x 1.0 M11 x 0.5 M15 x 1.0 M19 x 1.0 M20 x 1.0 M18 x 1.0 M24 x 1.0 M25 x 1.0 M30 x 1.0 M35 x 1.0 2.5 2.5 3.0 3.2 4.0 3.2 3.8 5.8 5.0 4.5 4.5 4.5 5.0 5.0 GEB Round nuts øA L e Part number Model 1 øA e Model 2 ● Material: Nickel-plated brass (3 µm) www.lemo.com L GEB.00.240.LN GEB.0S.240.LN GEB.0E.240.LN GEB.1S.240.LN GEB.1E.240.LN GEB.2S.240.LN GEB.2B.240.LN GEB.3S.240.LN GEB.4S.240.LN GEB.5S.240.LN GEB.5E.240.LN GEB.6S.241.LN GEB.6E.240.LN Model 1 1 1 1 1 1 1 1 1 2 2 2 2 Dimensions (mm) A e L 9.0 11.0 18.0 14.0 20.0 18.0 17.5 22.0 28.0 40.0 54.0 54.0 65.0 M7 x 0.50 M9 x 0.60 M14 x 1.00 M12 x 1.00 M16 x 1.00 M15 x 1.00 M15 x 0.75 M18 x 1.00 M25 x 1.00 M35 x 1.00 M45 x 1.50 M48 x 1.50 M55 x 2.00 4.0 4.0 5.0 5.0 5.0 5.5 2.5 5.5 6.0 8.0 8.0 8.0 9.0 Note: 5B, 5K, 5S, 5E, 6S and 6E series sockets are always supplied with model 2 round nuts. To order this accessory separately, use the part numbers in the adjacent table. 133 ® 134 ® www.lemo.com TOOLING ACCESSORIES ® ® Accessories BFG Plug caps B øA L Part number Series Dimensions (mm) A B L N BFG.00.100 PCSG BFG.0B.100.PCSG 00 0S-0B 7.5 9.8 10.0 9.5 12.0 12.2 60 85 BFG.1B.100.PCSG 1S-1B 12.0 15.0 13.8 1D 85 BFG.2B.100.PCSG BFG.3B.100.PCSG 2S-2B 15.0 18.0 15.0 3S-3B 18.5 22.0 18.5 85 95 N ● ● ● ● ● Body material: Polyoxymethylene (POM) grey (or black) Cord material: Polyamide 6, grey (or black) Gasket material: Silicone rubber Maximum operating temperature: 100°C Watertightness: IP61 according to IEC 60529 Note: this cap is available only with an alignment key (G). Upon request this cap can be supplied in black and the last letter «G» of the part number should be replaced with «N». Fitting the cord Slide the plug into the loop of the cord. Place the loop into the groove in front of the collet nut and tighten the loop. BFA Plug caps B L N øA Part number sliding loop ● ● ● ● ● ● Body material: Nickel-plated brass (Ni 3µm) Lanyard material: Stainless steel Crimp ferrule material: Nickel-plated brass + polyolefin O-ring material: Silicone rubber or FPM Maximum operating temperature: 135°C Watertightness: IP68 according to IEC 60529 for E series BFA.0E.100.NAS BFA.1E.100.NAS BFA.2E.100.NAS BFA.3E.100.NAS BFA.4E.100.NAS BFA.4S.100.NAS BFA.5E.100.NAS BFA.5S.100.NAS BFA.6S.100.NAS Series 0E 1E 2E 3E 4E 4S 5E 5S 6S Dimensions (mm) A B L N 14.0 16.0 19.5 23.0 29.0 25.0 44.0 36.0 46.0 6 6 6 6 10 10 10 10 10 12.5 15.5 17.5 22.0 22.5 22.2 27.0 30.2 33.0 85 85 85 120 120 120 150 150 150 Note: the last letter «S» of the part number stands for the material of the Oring (silicone rubber). O-ring’s made from FPM are also available; if required, replace the letter «S» by «V». BFG Plug caps with key (G) B L N øA Part number sliding loop ● ● ● ● ● ● Body material: Nickel-plated brass (Ni 3µm) Lanyard material: Stainless steel Crimp ferrule material: Nickel-plated brass + polyolefin O-ring material: Silicone rubber or FPM Maximum operating temperature: 135°C Watertightness: IP68 according to IEC 60529 for E and K series 136 BFG.0K.100.NAS BFG.1K.100.NAS BFG.2K.100.NAS BFG.3K.100.NAS BFG.4B.100.NAS BFG.4K.100.NAS BFG.5B.100.NAS BFG.5K.100.NAS BFG.6E.100.NAS Series 0K-0L 1K-1L 2K-2L 3K 4B 4K 5B 5K 6E Dimensions (mm) A B L N 14.0 16.0 19.5 23.0 25.0 29.0 36.0 44.0 54.0 6 6 6 6 10 10 10 10 10 12.5 15.5 17.5 22.0 20.2 22.5 27.2 27.0 31.0 85 85 85 120 120 120 150 150 150 Note: this cap is available only with an alignment key (G). The last letter «S» of the part number stands for the material of the O-ring (silicone rubber). O-ring’s made from FPM are also available; if required, replace the letter «S» by «V». www.lemo.com ® ® BHG Plug caps, nut fixing or flange B L ø 3.5 N øA Part number ● ● ● ● ● ● Body material: Nickel-plated brass (Ni 3µm) Lanyard material: Stainless steel Crimp ferrule material: Nickel-plated brass + polyolefin O-ring material: Silicone rubber or FPM Maximum operating temperature: 135°C Watertightness: IP68 according to IEC 60529 for E and K series BHG.0K.100.NAS BHG.1K.100.NAS BHG.2K.100.NAS BHG.3K.100.NAS BHG.4B.100.NAS BHG.4K.100.NAS BHG.5B.100.NAS BHG.5K.100.NAS BHG.6E.100.NAS Series 0K-0L 1K-1L 2K-2L 3K 4B 4K 5B 5K 6E Dimensions (mm) A B L N 14.0 16.0 19.5 23.0 25.0 29.0 36.0 44.0 54.0 6 6 6 6 10 10 10 10 10 12.5 15.5 17.5 22.0 20.2 22.5 27.2 27.0 31.0 85 85 85 120 120 120 150 150 150 Note: this cap is available only with an alignment key (G). The last letter «S» of the part number stands for the material of the O-ring (silicone rubber). O-ring’s made from FPM are also available; if required, replace the letter «S» by «V». BFG Plug cap øA L Part number BFG.3K.100.EAN Series 3K Dimensions (mm) A L N 24 30 155 ● Material: black EPDM ● Lanyard material: Stainless steel ● Crimp ferrule material: Nickel-plated brass + polyolefin N Note: These caps are suitable for use with any alignment key configuration. BHA Plug cap øA L Part number BHA.3K.100.EAN 3K Dimensions (mm) A L N 24 30 120 ● Material: black EPDM ● Lanyard material: Stainless steel ● Crimp ferrule material: Nickel-plated brass + polyolefin ø 3.5 N Series Note: These caps are suitable for use with any alignment key configuration. BRA Blanking caps for fixed sockets and free straight sockets L M ø 3.5 N ● ● ● ● ● Body material: Polyoxymethylene (POM) grey (or black) Cord material: Polyamide 6, grey (or black) Gasket material: Silicone rubber Maximum operating temperature: 100°C Watertightness: IP61 according to IEC 60529 www.lemo.com B øA Part number Series A Dimensions (mm) B L M N BRA.00.200.PCSG BRA.0B.200.PCSG 00 7.5 9.8 9.0 0S-0B 10.0 12.5 11.0 3.5 4.8 60 60 BRA.1B.200.PCSG 1S-1B 14.0 17.0 13.5 1D 5.6 60 BRA.2B.200.PCSG 2S-2B 18.0 21.0 14.5 2C-2G 6.0 60 BRA.3B.200.PCSG 3S-3B 22.0 25.5 17.0 7.0 60 Note: these caps are suitable for use with any alignment key configuration. On request this cap can be supplied in black. If so, replace the last letter «G» of the part number by «N». 137 ® ® BRE Blanking caps for fixed sockets L B Part number Series N øA M ø 3.5 ● ● ● ● ● ● Body material: Nickel-plated brass (Ni 3 µm) Lanyard material: Stainless steel Crimp ferrule material: Nickel-plated brass + polyolefin O-ring material: Silicone rubber or FPM Maximum operating temperature: 135°C Watertightness: IP61 according to IEC 60529 for S series Dimensions (mm) B L M A N BRE.00.200.NAS BRE.0S.200.NAS 00 0S-0B 8 10 7.5 8.8 9.5 10.5 3.5 4.5 60 85 BRE.1S.200.NAS 1S-1B 1D 14 11.0 12.5 5.0 85 BRE.2S.200.NAS BRE.3S.200.NAS BRE.4S.200.NAS BRE.5S.200.NAS BRE.6S.200.NAS BRE.6E.200.NAS 2S-2B 3S-3B 4S-4B 5S-5B 6S 6E 18 22 28 40 54 57 12.0 14.0 20.0 22.0 22.0 24.0 6.0 8.0 10.0 12.0 12.0 14.0 85 120 120 150 150 150 14.0 18.0 23.0 30.0 30.0 31.5 Note: these caps are suitable for use with any alignment key configuration. The last letter «S» of the part number stands for the O-ring material (silicone rubber). O-ring’s made from FPM are also available; if required, replace the letter «S» by «V». BRE Blanking caps for fixed sockets L B M ø 3.5 N øA Part number ● ● ● ● ● ● Body material: Nickel-plated brass (Ni 3 µm) Lanyard material: Stainless steel Crimp ferrule material: Nickel-plated brass + polyolefin O-ring material: Silicone rubber or FPM Maximum operating temperature: 135°C Watertightness: IP68 according to IEC 60529 BRE.0K.200.NAS BRE.1K.200.NAS BRE.2K.200.NAS BRE.3K.200.NAS BRE.4K.200.NAS BRE.5K.200.NAS Series A 0K-0E-0L 1K-1E-1L 2K-2E-2L 3K-3E 4K-4E 5K-5E Dimensions (mm) B L M 15.0 17.0 20.5 24.0 30.0 44.0 10 12 14 14 20 22 15.0 20.0 24.0 28.0 30.5 37.0 4 6 8 8 10 12 N 85 85 85 120 120 150 Note: these caps are suitable for use with any alignment key configuration. The last letter «S» of the part number stands for the O-ring material (silicone rubber). O-ring’s made from FPM are also available; if required, replace the letter «S» by «V». BRA Blanking caps for fixed sockets L M øA Part number ø 3.3 BRA.3K.200.EAN BRA.4K.200.EAN Series 3K 4K Dimensions (mm) A L M N 24 31 27 31 14.5 17.0 120 120 ● Material: black EPDM ● Lanyard material: Stainless steel ● Crimp ferrule material: Nickel-plated brass + polyolefin N Note: These caps are suitable for use with any alignment key configuration. BRF Blanking caps for free sockets L øA M Part number BRF.3K.200.EAN N Series 3K Dimensions (mm) A L M N 24 27 14.5 155 ● Material: black EPDM ● Lanyard material: Stainless steel ● Crimp ferrule material: Nickel-plated brass + polyolefin Note: These caps are suitable for use with any alignment key configuration. 138 www.lemo.com ® ® BRD Blanking caps for free sockets L M A Dimensions (mm) B L M N BRD.00.200.PCSG BRD.0B.200.PCSG 00 7.5 0S-0B 10.0 9.8 9.0 12.5 11.0 3.5 4.8 85 85 BRD.1B.200.PCSG 1S-1B 14.0 1D 17.0 13.5 5.6 85 BRD.2B.200.PCSG BRD.3B.200.PCSG 2S-2B 18.0 3S-3B 22.0 21.0 14.5 25.5 17.0 6.0 7.0 85 95 N ● ● ● ● ● Series B øA Part number Body material: Polyoxymethylene (POM) grey (or black) Cord material: Polyamide 6, grey (or black) Gasket material: Silicone rubber Maximum operating temperature: 100°C Watertightness: IP61 according to IEC 60529 Note: on request this cap is available in black. If required, replace the last letter «G» of the part number by «N». Fitting the cord Slide the socket into the loop of the cord. Place the loop into the groove in front of the collet nut. Tighten the loop. BRF Blanking caps for free sockets L B Part number N øA M sliding loop ● ● ● ● ● ● Body material: Nickel-plated brass (Ni 3 µm) Lanyard material: Stainless steel Crimp ferrule material: Nickel-plated brass + polyolefin O-ring material: Silicone rubber or FPM Maximum operating temperature: 135°C Watertightness: IP61 according to IEC 60529 for S series Series Dimensions (mm) B L M A N BRF.00.200.NAS BRF.0S.200.NAS 00 0S-0B 8 10 7.5 8.8 9.5 10.5 3.5 4.5 85 85 BRF.1S.200.NAS 1S-1B 1D 14 11.0 12.5 5.0 85 BRF.2S.200.NAS BRF.3S.200.NAS BRF.4S.200.NAS BRF.5S.200.NAS BRF.6S.200.NAS 2S-2B 3S-3B 4S-4B 5S-5B 6S 18 22 28 40 54 12.0 14.0 20.0 22.0 22.0 14.0 6.0 85 18.0 8.0 120 23.0 10.0 120 30.0 12.0 150 30.0 12.0 150 Note: these caps are suitable for use with any alignment key configuration. The last letter «S» of the part number stands for the O-ring material (silicone rubber). O-ring’s made from FPM are also available; if required, replace the letter «S» by «V». BRF Blanking caps for free sockets L Part number B N øA M sliding loop ● Body material: Nickel-plated brass (Ni 3 µm) ● Lanyard material: Stainless steel ● Crimp ferrule material: Nickel-plated brass + polyolefin www.lemo.com BRF.0K.200.NAS BRF.1K.200.NAS BRF.2K.200.NAS BRF.3K.200.NAS BRF.4K.200.NAS BRF.5K.200.NAS Series 0K-0E-0L 1K-1E-1L 2K-2E-2L 3K-3E 4K-4E 5K-5E A 15.0 17.0 20.5 24.0 30.0 44.0 Dimensions (mm) B L M 10 12 14 14 20 22 15.0 20.0 24.0 28.0 30.5 37.0 4 6 8 8 10 12 N 85 85 85 120 120 150 Note: these caps are suitable for use with any alignment key configuration. The last letter «S» of the part number stands for the O-ring material (silicone rubber). O-ring’s made from FPM are also available; if required, replace the letter «S» by «V». ● O-ring material: Silicone rubber or FPM ● Maximum operating temperature: 135°C ● Watertightness: IP68 according to IEC 60529 139 ® ® BRR Spring loaded dust caps for ERA, ERN and EG● sockets or PSA and PK● fixed sockets Part number Series A B Dimensions (mm) C E L M N BRR.0S.200.PZSG 0S-0B 11.0 13.3 9.0 5.8 5.0 1.2 15.3 BRR.1S.200.PZSG 1S-1B 14.2 17.1 12.0 6.0 6.3 1.5 20.3 1D BRR.2S.200.PZSG 2S-2B 18.6 22.4 15.2 6.5 8.2 2.0 26.2 2C-2G BRR.3S.200.PZSG 3S-3B 22.5 26.5 18.2 9.0 8.8 2.5 30.8 N L Note: On request, this cap is available in black. If so replace the last letter «G» of the part number by «N». øC B øA M E maxi ● ● ● ● ● ● Body material: Polyoxymethylene (POM) grey (or black) Gasket material: Silicone rubber Spring material: Stainless steel Axes material: Nickel-plated brass Maximum operating temperature: 100°C Watertightness: IP61 according to IEC 60529 BRR Spring loaded dust cap for ED● and EB● fixed sockets Part number Series BRR.3K.200.PZSG 3K L øA N A Dimensions (mm) B C L M 29 29 23 8.1 3 N 33.2 øC B Note: Use Allen key (0.9 mm flat) to secure cap on connector. M 140 ● ● ● ● ● ● ● Cap material: Polyoxymethylene (POM) grey Body material: Nickel-plated brass Gasket material: Silicone rubber Spring material: Stainless steel Axes material: Nickel-plated brass Maximum operating temperature: 100°C Watertightness: IP61 according to IEC 60529 www.lemo.com ® ® GM● Bend relief (Polyurethane) A bend relief made from thermoplastic polyurethane elastomer (Desmopan 786) can be fitted over LEMO plugs and sockets that are supplied with nut for fitting such bend relief. They are available in nine different colours that match with the GRA insulating washers (see page 144). Use the part numbers shown below to order this accessory separately. øA L Main characteristics ● Material: Polyurethane elastomer ● Temperature range in dry atmosphere: Part number Dimensions (mm) Bend relief Cable ø A L max. min. -40°C +80°C Series Part number of nut for fitting the bend relief FFM.00.130.LC 1) FFM.00.131.LC 2) GMA.00.012.DG GMA.00.018.DG GMB.00.025.DG GMB.00.028.DG GMB.00.032.DG GMD.00.025.DG GMD.00.028.DG GMD.00.032.DG 1.2 1.8 2.5 2.8 3.2 2.5 2.8 3.2 22 22 22 22 22 22 22 22 1.4 2.1 2.8 3.1 3.5 2.8 3.1 3.5 1.1 1.8 2.5 2.8 3.2 2.5 2.8 3.2 00 GMA.0B.025.DG GMA.0B.030.DG GMA.0B.035.DG GMA.0B.040.DG GMA.0B.045.DG 2.5 3.0 24 24 2.9 3.4 2.5 3.0 0B FFM.0B.130.LC FFM.2B.132.LC 1) 3.5 4.0 4.5 24 24 24 3.9 4.4 5.2 3.5 4.0 4.5 0S FFM.0S.130.LC GMA.1B.025.DG GMA.1B.030.DG GMA.1B.035.DG GMA.1B.040.DG GMA.1B.045.DG GMA.1B.054.DG GMA.1B.065.DG 2.5 3.0 3.5 4.0 4.5 5.4 6.5 30 30 30 30 30 30 30 2.9 3.4 3.9 4.4 4.9 6.0 7.0 2.5 3.0 3.5 4.0 4.5 5.4 6.5 GMA.2B.040.DG GMA.2B.045.DG GMA.2B.050.DG GMA.2B.060.DG GMA.2B.070.DG GMA.2B.080.DG 4.0 4.5 5.0 6.0 7.0 7.8 36 36 36 36 36 36 4.5 5.0 5.5 6.5 7.7 8.8 4.0 4.5 5.0 6.0 7.0 7.8 GMA.3B.050.DG GMA.3B.060.DG GMA.3B.070.DG GMA.3B.080.DG GMA.3B.090.DG 4.5 6.0 7.0 8.0 9.0 42 42 42 42 42 5.2 6.9 7.9 8.9 10.0 4.5 6.0 7.0 8.0 9.0 GMA.4B.080.DG GMA.4B.010.DG GMA.4B.011.DG GMA.4B.012.DG GMA.4B.013.DG 8.0 10.0 11.0 12.0 13.5 60 60 60 60 60 9.0 10.9 11.9 13.0 14.5 8.0 10.0 11.0 12.0 13.5 Note 1) 2) For unipole connectors For multipole connectors The «GMD» are thin bend reliefs (for very flexible cables) 1) For use only with connectors from series 2B equipped with cable fixing type M and where a bend relief from series 0B is used. 1) For use only with connectors from series 3B equipped with cable fixing type M and where a bend relief from series 1B is used. 1) For use only with connectors from series 4B equipped with cable fixing type M and where a bend relief from series 2B is used. 0E-0K-0L FFM.0E.130.LC 1B-1D 1S FFM.1B.130.LC FFM.3B.131.LC 1) FFM.1S.130.LC 1E-1K-1L FFM.1E.130.LC 2B FFM.2B.130.LC FFM.4K.132.LC 1) 2S FFM.2S.130.LC 2E-2K-2L FFM.2E.130.LC 2C-2G FFM.2C.130.LC 3S FFM.3S.130.LC 3B FFM.3B.130.LC 3E-3K FFM.3E.130.LC 4S FFM.4S.130.LC 4S FFM.4S.130.LC 4B FFM.4B.130.LC 4E-4K FFM.4E.130.LC Note: the last letter «G» of the part number indicates the grey colour of the bend relief. For ordering a bend relief with another colour, see table on page 142 and replace the letter «G» by the letter of the required colour. See also detailed information for each series: B series on page 54: K series on page 54; S series on page 107; E series on page 107. www.lemo.com 141 ® ® GMA Bend relief (Silicone) øA L A bend relief has been designed for connectors used in applications at high temperature or requiring vapour sterilization. These bend reliefs are different from previous ones as for their material, a silicone elastomer which is noted for its retention of flexibility over a wide temperature range. They are available in nine colours. Use the part numbers shown below to order this accessory separately. Main characteristics ● Material: Silicone elastomer VMQ ● Temperature range in dry atmosphere: -60°C ● Temperature range in water steam: +140°C Part number Dimensions (mm) Bend relief Cable ø A L max. min. +200°C Series Part number of nut for fitting the bend relief GMA.0B.025.RG GMA.0B.030.RG GMA.0B.035.RG GMA.0B.040.RG GMA.0B.045.RG 2.5 3.0 27 27 2.9 3.4 2.5 3.0 0B FFM.0B.130.LC FFM.2B.132.LC 1) 3.5 4.0 4.5 27 27 27 3.9 4.4 5.2 3.5 4.0 4.5 0S FFM.0S.130.LC GMA.1B.025.RG GMA.1B.030.RG GMA.1B.035.RG GMA.1B.040.RG GMA.1B.045.RG GMA.1B.051.RG GMA.1B.057.RG GMA.1B.063.RG 2.5 3.0 3.5 4.0 4.5 5.1 5.7 6.3 34 34 34 34 34 34 34 34 2.9 3.4 3.9 4.4 5.0 5.6 6.2 7.0 2.5 3.0 3.5 4.0 4.5 5.1 5.7 6.3 GMA.2B.040.RG GMA.2B.045.RG GMA.2B.051.RG GMA.2B.057.RG GMA.2B.063.RG GMA.2B.071.RG GMA.2B.080.RG 4.0 4.5 5.1 5.7 6.3 7.1 8.0 41 41 41 41 41 41 41 4.4 5.0 5.6 6.2 7.0 7.9 9.0 4.0 4.5 5.1 5.7 6.3 7.1 8.0 Note 1) For use only with connectors from series 2B equipped with cable fixing type M and where a bend relief from series 0B is used. 1) For use only with connectors from series 3B equipped with cable fixing type M and where a bend relief from series 1B is used. 1) For use only with connectors from series 4B equipped with cable fixing type M and where a bend relief from series 2B is used. 0E-0K-0L FFM.0E.130.LC 1B-1D 1S FFM.1B.130.LC FFM.3B.131.LC 1) FFM.1S.130.LC 1E-1K-1L FFM.1E.130.LC 2B FFM.2B.130.LC FFM.4K.132.LC 1) 2S FFM.2S.130.LC 2E-2K-2L FFM.2E.130.LC 2C-2G FFM.2C.130.LC Note: the last letter «G» of the part number indicates the grey colour of the bend relief. For ordering a bend relief with another colour, see table on page 142 and replace the letter «G» by the letter of the required colour. See also detailed information for each series: B series on page 54: K series on page 54; S series on page 107; E series on page 107. Note: the selection of pigments, which should remain stable at high temperature, is limited by the new regulations. For this reason, some colours will be a shade different from those used for Desmopan bend reliefs. The selected solutions represent the best possible compromise. 142 Ref. A B G J M Colour blue white grey yellow brown Ref. N R S V Colour black red orange green www.lemo.com ® ® GM● Overall bend relief for plugs and sockets Overall bend reliefs, type GMF for plugs and GMP for sockets offer optimum protection against mechanical damage and give a protection index of IP65 according to IEC 60529 (mated position). These bend reliefs slide easily over the connector shell and are positioned by slightly pressing the bend relief backnut. The special design of the bend relief for plug provides for easy use of the push-pull self-latching system. GMF Bend relief for straight plug øA L Part number Series Dimensions (mm) Bend relief Cable ø A L max. min. GMF.0B.035.060EN GMF.1B.062.072EN GMF.2B.082.095EN 0S-0B 1S-1B 2S-2B 11.0 60.5 16.0 72.0 22.0 95.0 3.5 6.2 8.2 1.0 2.5 5.0 ● Material: Elastomer rubber black colour ● Operating temperature: -30°C to +120°C GMP Bend relief for free socket øA L Part number Series Dimensions (mm) Bend relief Cable ø A L max. min. GMP.0B.035.069EN GMP.1B.062.079EN GMP.2B.082.102EN 0S-0B 1S-1B 2S-2B 11.0 69.0 3.5 16.0 80.0 6.2 21.0 102.5 8.2 1.0 2.5 5.0 ● Material: Elastomer rubber black colour ● Operating temperature: -30°C to +120°C – The overall bend relief shall be installed over plug or free socket fitted with a nut for bend relief. – The typical applications are shown below. – The overall bend relief can be cut at different length depending on cable diameter. Plug-free socket Plug-fixed socket Optimum protection is offered only when using front panel mounting fixed sockets www.lemo.com PCA FFA S series PHG FGG B series ERA FFA S series EGG FGG B series 143 ® ® GMF Bend relief with cap for plug Part number 131 Series For models 4E FFA 4K FGG Cut – A B C D E 35 GMF.4K.080.EANZ ø 31 ø 31 ø admissible ø (mm) min. max. 8.0 9.0 10.0 11.5 13.0 15.0 8.9 9.9 11.4 12.9 14.9 16.5 ● Material: Black EPDM AB C D E 160 GMP Bend relief with cap for free socket Part number 156 Series For models 4E PCA 4K PHG 17 Cut – A B C D E ø 35 ø 31 ø GMP.4K.080.EANZ AB C D E admissible ø (mm) min. max. 8.0 9.0 10.0 11.5 13.0 15.0 8.9 9.9 11.4 12.9 14.9 16.5 ● Material: Black EPDM 160 GRA Insulating washers Sockets or plugs mounted on panels can be fitted with insulating washers. The nine colours available combined with those for the bend reliefs makes colour coding possible. Part number Series GRA.00.269.GG GRA.0S.269.GG GRA.1S.269.GG GRA.2S.269.GG GRA.3S.269.GG GRA.4S.269.GG 00 0S-0B 1S-1B 2S-2B 3S-3B 4S-4B Dimensions (mm) E L M S A B 10.0 12.0 16.0 21.1 25.0 31.9 8.8 10.8 13.8 17.9 21.8 28.7 4.5 6.0 6.5 7.3 10.3 10.5 1.8 1.8 1.8 2.3 2.2 2.5 1.0 1.0 1.0 1.3 1.2 1.5 6.4 8.3 10.6 13.6 16.7 23.6 T 8.0 9.9 12.2 16.2 20.2 27.1 Note: insulating washers for series 5B are available on request. L M øA Caution: these insulating washers can be used with fixed and free sockets with across flat dimension S1 equivalent to the S dimension of the washer. S øB Ref. E maxi ● Material: Polyamide ● Maximum operating temperature: 90° C 144 T A B G J M Colour blue white grey yellow brown Ref. N R S V Colour black red orange green Note: the last letter «G» of the part number indicates the colour grey for the insulating washer. To obtain an insulating washer of another colour, refer to the table above and change the letter «G» of the part number to the corresponding letter of the colour required. For the panel cut-out, please consult chapter «Panel cut-out» on page 153. www.lemo.com ® ® GRC Double panel washers Double panel washers have been designed to make the drilling of panel holes easier for mounting fixed and free sockets. The combination of the nine different colours of the double panel washers and of the bend reliefs makes colour coding possible. Part number GRC.0S.260.HG GRC.1B.260.HG Series Dimensions (mm) E H L M N R B S 0S-0B 10.9 5 14 2.5 1.5 26.5 12.5 8.3 1S-1B 13.9 5 20 3.3 1.8 34.5 14.5 10.6 Caution: these double panel washers can be used with fixed or free sockets with across flat dimension S1 equivalent to the S dimension of the washer. L R M S øB H N Ref. A B G J M Ref. Colour blue white grey yellow brown N R S V Colour black red orange green Note: the last letter «G» of the washer’s part number indicates the colour grey. For other colours, refer to the above table and replace letter «G» by the one corresponding to the colour required. For the panel cut-out, please consult chapter «Panel cut-out» on page 153. E maxi ● Material: Polyamide ● Maximum operating temperature: 90° C GCA Earthing washer Part number Series GCA.00.255.LT GCA.0S.255.LT GCA.0E.255.LT GCA.1S.255.LT GCA.1E.255.LT GCA.2S.255.LT GCA.2E.255.LT GCA.3S.255.LT GCA.4S.255.LT GCA.4E.255.LT GCA.5S.255.LT 00 0S-0B 0E-0K 1S-1B 1E-1K 2S-2B 2E-2K 3S-3B 4S-4B 4E-4K 5S-5B Dimensions (mm) A B L N øA L N øB 9.5 13.0 17.0 17.0 20.0 20.0 25.0 25.0 35.0 35.0 42.0 7.1 9.1 14.1 12.2 16.2 15.2 20.2 18.2 25.6 30.6 35.1 0.4 0.4 0.5 0.5 0.5 0.5 0.5 0.5 0.6 0.6 0.3 18.2 22.0 27.5 27.5 32.0 32.0 39.0 39.0 50.0 50.0 57.5 ● Material: CuSnZn plated brass (2 µm) GSC Lead-through with cable collet Part number ~L øA M e øB S3 GSC.00.290.CD●● GSC.1S.290.ND●● GSC.3S.290.ND●● E maxi www.lemo.com S1 S2 A B Dimensions (mm) e E L M S1 S2 S3 6.5 8.1 M5x0.5 1.5 16 4.0 5 12.0 12.5 M9x0.6 5.0 26 7.5 11 17.0 19.5 M15x1.0 8.1 30 12.0 – 6 7 9 11 14 17 Note: ●● = collet cable diameter of the B series. For cable diameter refer to page 52. The cable collet system stands for both screened and unscreened cables. It can be delivered with a nut for fitting a bend relief it you add a «Z» at the end of the part number. 145 ® ® Tooling DCG Spanners for hexagonal nuts N L Part number øB DCG.91.149.0TN DCG.91.161.1TN DCG.91.201.4TN DCG.91.231.7TN DCG.91.282.2TN Dimensions (mm) B L N 14 16 20 23 28 40 45 52 62 76 50 52 65 68 73 Part number of the nut GEA.00.240.LN GEA.0S.240.LN GEA.1S.240.LN GEA.2S.240.LN GEA.3S.240.LN ● Material: blackened steel DCA Spanners for hexagonal nuts with locator for flats on socket thread N L max Part number DCA.91.149.0TN DCA.91.161.1TN DCA.91.201.4TN DCA.91.231.7TN DCA.91.282.2TN Dimensions (mm) B L N 14 16 20 23 28 65 73 85 100 120 50 52 65 68 73 Part number of the nut GEA.00.240.LN GEA.0S.240.LN GEA.1S.240.LN GEA.2S.240.LN GEA.3S.240.LN ● Material: blackened steel øB DCB Spanners for round nuts N L Part number øB DCB.91.119.0TN DCB.91.131.1TN DCB.91.161.4TN DCB.91.201.8TN DCB.91.242.2TN Dimensions (mm) B L N 11 13 16 20 24 40 45 52 62 76 50 50 65 65 70 Part number of the nut GEB.00.240.LN GEB.0S.240.LN GEB.1S.240.LN GEB.2S.240.LN GEB.3S.240.LN ● Material: blackened steel øA DCH Spanners for conical nut øB Part number L DCH.91.101.PN DCH.91.121.PN DCH.91.161.PN DCH.91.201.PN Dimensions (mm) A B L N 10.1 12.1 16.1 20.1 12.8 14.8 21.0 22.8 124 124 124 129 48.3 49.3 51.9 53.5 Part number of the nut GEC.00.240.LC GEC.0S.240.LC GEC.1S.240.LC GEC.2S.240.LC ● Material: dark grey polyurethane N 146 www.lemo.com ® ® DCP Flat spanners for collet nut M N S1 Part number L DCP.99.040.TC DCP.99.045.TC DCP.99.050.TC DCP.99.055.TC DCP.99.060.TC Dimensions (mm) L M N S1 70 70 78 78 78 0.95 2.00 2.00 2.00 2.00 10.5 10.5 12.6 12.6 12.6 4.0 4.5 5.0 5.5 6.0 ● Material: chrome-plated steel S1 DCH Spanners for notched nuts øA øB Part number L DCH.91.101.PA DCH.91.121.PA DCH.91.181.PA DCH.91.161.PA DCH.91.201.PA DCH.91.141.PA DCH.91.201.PA DCH.91.241.PA DCH.91.251.PA N Dimensions (mm) A B L N 10.1 12.1 18.1 16.1 20.1 14.1 20.1 24.1 25.1 12.8 14.8 22.8 21.0 22.8 18.6 22.8 30.8 32.8 124 124 129 124 129 124 129 134 134 Part number of the nut 48.3 49.3 53.1 51.2 53.5 51.2 53.5 52.6 55.5 GEG.00.240.LC GEG.0S.240.LC GEG.0E.240.LC GEG.1S.240.LC GEG.1E.240.LC GEG.1S.242.LC GEG.2S.240.LC GEG.2S.241.LC GEG.2E.240.LC ● Material: blue polyurethane DCP Set of flat spanners for collet nuts N S1 S2 Part number M DCP.91.001.TN L DCP.91.023.TN DCP.91.045.TN Series 0B 1B 2B-2K 3B-3K 4B 5B L 95 95 115 115 130 130 Dimensions (mm) M N S1 2.5 2.5 3.0 3.0 3.5 3.5 21 25 30 35 40 45 8.1 10.1 13.1 15.1 21.2 31.2 S2 7.1 9.1 12.1 14.1 20.2 30.2 ● Material: blackened steel DCL Spanners for assembling plugs with 2 latches øB N L Part number DCL.91.105.0TK DCL.91.127.0TK DCL.91.149.0TK Series 00 0S 1S Dimensions (mm) B L N 10 12 14 45 47 52 13.5 17.0 19.0 ● Material: blackened steel www.lemo.com 147 ® ® DCN Spanners for assembling plugs with 3 latches øB N Part number L DCN.91.905.0TK DCN.91.125.0TK DCN.91.149.0TK DCN.91.171.2TK DCN.91.201.5TK Series 00 0S 1S 2S-2C 3S Dimensions (mm) B L N 9 12 14 17 20 42 47 53 63 74 12 17 19 20 22 ● Material: blackened steel DCL Assembly tool for FVB.00.303.NLA plugs Part number 00 Dim. (mm) A L 5 165 øA DCL.91.516.5TK Series L DPF Pliers for assembling plugs (series K, E and L) Part number øA DPF.91.001.TA DPF.91.023.TA Series 0E-0K-0L 1E-1K-1L 2E-2K-2L 3E-3K Dimensions (mm) A B 10 – 15 – – 12 – 18 øB 220 Example for use The plug end must be held in the pliers whilst the nut is tightened with the flat spanner. Spanner Pliers DPF DTA Taps Part number DTA.99.700.5Z DTA.99.900.6Z 148 Series 00 0S-0B Thread M7 x 0.5 M9 x 0.6 www.lemo.com ® ® Crimping tools for electrical contacts Manual crimping tools Fig. A Part number Supplier contact ø 0.5-0.7 0.9-1.3 (Fig. A) DPC.91.701.V1) MH8601) 6163361) LEMO DANIELS ASTRO Fig. B 1) 2) contact ø 1.6-2.0 (Fig. B) DPC.91.101.A2) AF82) 6157082) contact ø 3.0-4.0 (Fig. B) DPC.91.102.V M300BT – According to specification MIL-C-22520/7-01. According to specification MIL-C-22520/1-01. Pneumatic crimping tools Part number Supplier DPC.91.701.C 85230 621101 LEMO BALMAR BUCHANAN According to specification MIL-C-22520/7-01. For LEMO contacts ø 0.5-0.7-0.9-1.3 mm DCE Positioners for crimp contacts ø 0.5-0.7-0.9 and 1.3 mm For female contact female These positioners are suitable for use with both manual and pneumatic crimping tools according to the MIL-C-22520/7-01 standard. Fig. 1 øA øA Fig. 2 øA øA øC øC 00 0.5 0.45 1 28-30-32 DCE.91.050.0VC DCE.91.050.0VM 0B 0K 0S 0.9 0.9 0.9 0.7 0.7 1 2 2 1 2 20-22-24 22-24-26 28-30-32 22-24-26 28-30-32 DCE.91.090.BVC DCE.91.090.BVM DCE.91.090.AVC DCE.91.090.AVM DCE.91.070.BVC DCE.91.070.BVM 306/307 0.5 0.45 1 309 28-30-32 DCE.91.050.BVC DCE.91.050.BVM 1B 1K 1S 1.3 1.3 0.9 3041) 305 0.9 306/307 0.7 308 0.7 1 2 1 2 1 2 18-20 20-22-24 20-22-24 22-24-26 22-24-26 28-30-32 DCE.91.131.BVC DCE.91.131.BVM DCE.91.091.BVC DCE.91.091.BVM øC DCE.91.071.BVC DCE.91.071.BVM 310/314 0.5 0.45 1 316 øC 28-30-32 DCE.91.051.BVC DCE.91.051.BVM 2B 2K 2S 304/305 1.3 1.40 1 1.3 1.10 2 3061) 307 1.3 0.80 2 0.9 1.10 1 308/310 0.9 0.80 2 0.9 0.45 2 18-20 20-22-24 22-24-26 20-22-24 22-24-26 28-30-32 DCE.91.132.BVC DCE.91.132.BVM DCE.91.132.CVC DCE.91.132.CVM Note: a wide variation of strand number and diameter combinations are quoted as being AWG, some of which do not have a large enough cross section to guarantee a crimp as per either MIL-C-22520/1-01 or /7-01. Our technical department is at your disposal to study and propose a solution to all your applications. DCE.91.092.BVC DCE.91.092.BVM DCE.91.092.AVC DCE.91.092.AVM 312/314 0.7 0.80 1 316/318 0.7 0.45 2 319 22-24-26 DCE.91.072.BVC DCE.91.072.BVM Note: see table on page 51 for connector selection and the table on page 131 for contact selection. www.lemo.com 302 303 304 3021) 303 304 305 1) 3021) 303 øC For male contact øA Conductor AWG Type male Positioners part number Fig. Connector + Contact 1.10 0.80 0.45 0.80 0.45 1.40 1.10 1.10 0.80 0.80 0.45 28-30-32 Note: 1) only these types are available in S series. 149 ® ® DCE Positioners for crimp contacts 0.5-0.7-0.9 and 1.3 mm diameter 1 2 1 2 18-20 20-22-24 20-22-24 22-24-26 320/322 0.7 0.80 1 324/326 330 0.7 0.45 2 22-24-26 1.3 1.3 316/320 0.9 324/330 0.9 0.7 340/348 0.7 18-20 20-22-24 20-22-24 22-24-26 22-24-26 28-30-32 Type male female 3B 3K These positioners are suitable for use with both manual and pneumatic crimping tools according to the MIL-C-22520/7-01 standard. 4B 4K 5B 5K øC Conductor AWG øA Fig. Connector + Contact 308/309 1.3 1.40 310 1.3 1.10 312/314 0.9 1.10 316/318 0.9 0.80 312 1.40 1.10 1.10 0.80 0.80 0.45 1 2 1 2 1 2 Positioners part number For male contact For female contact DCE.91.133.BVC DCE.91.133.BVM DCE.91.093.BVC DCE.91.093.BVM DCE.91.073.BVC DCE.91.073.BVM DCE.91.134.BVC DCE.91.134.BVM DCE.91.094.BVC DCE.91.094.BVM DCE.91.074.BVC DCE.91.074.BVM 28-30-32 330/340 1.3 1.40 1 348 18-20 DCE.91.135.BVC DCE.91.135.BVM 350/354 0.9 1.10 1 364 0.9 0.80 2 20-22-24 22-24-26 DCE.91.095.BVC DCE.91.095.BVM DCE Turret for crimp contacts 1.6-2.0-3.0 and 4.0 mm diameter øC Fig. Conductor AWG 2B 2K 302 2.0 2.0 1.6 1.6 2.4 1.9 1.9 1.4 1 2 1 2 12-14-16 14-16-18 14-16-18 18-20-22 3B 3K 302 3.0 2.9 303/304 2.0 2.4 309 2.0 1.9 305/306 1.6 1.9 307 1.6 1.4 1 1 2 1 2 10-12-14 12-14-16 14-16-18 14-16-18 18-20-22 DCE.91.303.BVCM 304 Type Note: these turrets can be used with manual crimping tool according to MIL-C-22520/1-01 standard. Positioners øA Connector + Contact 4B 4K 5B 5K 303 Part number DCE.91.202.BVCM DCE.91.162.BVCM DCE.91.203.BVCM DCE.91.163.BVCM 3.0 2.0 306/307 2.0 1.6 310 1.6 2.9 2.4 1.9 1.9 1.4 1 1 2 1 2 10-12-14 12-14-16 14-16-18 14-16-18 18-20-22 DCE.91.304.BVCM 304 310 4.0 2.9 2.4 1.9 1.9 1.4 1 1 1 2 1 2 10-12 10-12-14 12-14-16 14-16-18 14-16-18 18-20-22 DCE.91.405.BVCM DCE.91.305.BVCM 4.0 3.0 2.0 314/316 2.0 1.6 320 1.6 DCE.91.204.BVCM DCE.91.164.BVCM DCE.91.205.BVCM DCE.91.165.BVCM DCK Retention testing tools for crimp contacts 0.5-0.7-0.9 and 1.3 mm diameter F 150 Contact øA Test force (N) 0.5 0.7 0.9 1.3 8 10 14 25 Testing tool part number For male contact DCK.91.050.8LRC DCK.91.071.0LRC DCK.91.091.4LRC DCK.91.132.5LRC For female contact DCK.91.050.8LRM DCK.91.071.0LRM DCK.91.091.4LRM DCK.91.132.5LRM www.lemo.com ® ® DCF Automatic extraction tools for crimp contacts (not valid for FA● and FW● models) Connector Type Extractors part number Contact øA For male and female contacts 00 302/303/304 0.5 DCF.91.050.2LT 0B 0K 302/303 304/305 306/307/309 0.9 0.7 0.5 DCF.91.090.2LT DCF.92.070.3LT DCF.91.050.2LT 1B 1K 302/303 304/305 306/307/308 310/314/316 1.3 0.9 0.7 0.5 DCF.91.131.2LT DCF.91.090.2LT DCF.91.070.2LT DCF.91.050.2LT 2B 2K 302 303 304/305/306/307 308/310 312/314/316/318/319 2.0 1.6 1.3 0.9 0.7 DCC.91.202.5LA 1) DCF.91.162.2LT DCF.91.131.2LT DCF.91.090.2LT DCF.91.070.2LT 3B 3K 302 303/304/309 305/306/307 308/309/310 312/314/316/318 320/322/324/326/330 3.0 2.0 1.6 1.3 0.9 0.7 DCF.91.303.5LT DCC.91.202.5LA 1) DCF.91.163.5LT DCF.91.133.5LT DCF.91.093.5LT DCF.91.073.5LT 4B 4K 304 306/307 310 312 316/320/324/330 340/348 3.0 2.0 1.6 1.3 0.9 0.7 DCF.91.303.5LT DCC.91.202.5LA 1) DCF.91.163.5LT DCF.91.133.5LT DCF.91.093.5LT DCF.91.073.5LT 5B 5K 304 310 314/316 320 330/340/348 350/354/364 4.0 3.0 2.0 1.6 1.3 0.9 DCF.91.405.5LT DCF.91.303.5LT DCC.91.202.5LA 1) DCF.91.163.5LT DCF.91.133.5LT DCF.91.093.5LT Note: 1) this model is thumb-operated. S Series available on request. DCF Automatic extraction tools for crimp contacts (for FA● and FW● models) Contact øA (mm) 0B/0K to 3B/3K www.lemo.com 1.6 1.3 0.9 0.7 Extractors part number For male and female contacts DCF.92.162.3LT DCF.92.131.3LT DCF.92.090.3LT DCF.92.070.3LT Note: extractor for FA● of the 4B/4K and 5B/5K still need to be determinated. 151 ® ® Panel cut-outs P2-P5-P10-P11 L mini P6-P7 P8 B + 0.1 0 øC 120° x 3 B + 0.1 0 øA ø A+ 0.1 0 L mini H P1-P3-P4-P9 ø A + 0.1 0 B + 0.1 0 ø A + 0.1 0 B series øA P1 B 7.1 9.1 12.1 15.1 18.2 25.2 35.21) 6.4 8.3 10.6 13.6 16.6 23.6 33.6 Series 00 0B 1B 2B 3B 4B 5B L P2 øA L øA P3 B L øA P4 B P5 ø A2) L L øA P6 B 12.5 7.1 11.5 – – – – – – – – – – 14.5 9.1 13.5 14.1 12.6 20.1 10.1 9.1 15.0 8.30 10.5 – – 18.5 – – 16.1 14.6 22.0 14.1 12.6 21.0 11.17 14.0 – – 22.5 – – 19.2 17.1 28.0 16.1 15.1 23.0 13.95 18.0 – – 27.0 – – – – – 20.2 18.6 29.5 – – – – 36.0 – – – – – 25.2 23.6 36.1 – – – – 44.0 – – – – – 35.2 33.6 47.1 – – 3.3 35.2 P8 B H øA – – – – – – 34 – – – – – – – – – – – – 2.8 35.2 C øA P9 B L P10 øA L – – – – – – 47 7.1 9.1 12.1 15.1 18.2 25.2 35.2 – 8.3 10.6 13.6 16.6 23.6 33.6 12 15 19 23 27 36 47 – – 11.1 – – – – – – 17 – – – – Note: 1) for using the tapered washer a round hole ø 36 mm apply. 2) tolerance: + 0.02 0 Cut-out types Model Mounting nut torque Type ECG EEG EGG EFG EHG EJG EKG Model P1 P1 P1 P2 P1 P5 P1 Type ENG ENY ESG EXG EYG FAG FWG P1 P1 P1/P2 P2/P10 P1/P10 P1 P9 Model Type HCG HEG HGG HHG HMG HNG PEG P3 P9 P9 P9 P9 P9 P1 Model PFG PKG R●● S●● XBG XPF XRB Note: 3) in series 1B use P9. Type P1 P1 P4 P4/P93) P2 P2 P2 Model YHG Type Series P9 00 0B 1B 2B 3B 4B 5B Torque (Nm) Metal shell Plastic shell4) 1.0 2.5 4.5 6.0 9.0 12.0 17.0 0.4 0.4 0.7 0.8 1.0 5.0 – Note: 4) these values apply when metal shell are mounted with insulating washer. S series Series 00 0S 1S 2S 3S 4S 5S 6S øA P1 B L 7.1 9.1 12.1 15.1 18.2 25.2 35.21) 48.3 6.4 8.3 10.6 13.6 16.6 23.6 33.6 45.6 12.5 14.5 18.5 22.5 27.0 36.0 44.0 58.0 P2 øA L øA P3 B L øA P4 B L P5 ø A2) L 7.1 9.1 12.1 15.1 18.2 25.2 35.2 48.3 – 12.1 14.1 16.1 20.2 25.2 35.2 48.3 – 10.6 12.6 14.6 18.6 23.6 33.6 45.6 – 20.0 21.0 22.0 30.0 36.0 47.0 60.0 – 10.1 12.1 16.1 20.2 25.2 35.2 48.3 – 9.1 10.6 15.1 18.6 23.6 33.6 45.6 – 15 18 23 29 36 47 60 – – – – – – – – – – 11.92 15.5 3.3 12.1 12.7 – – 3.3 15.1 15.5 – – 3.3 18.2 18.0 – – – – – – – 4.4 35.2 36.8 – – – – – 11.5 13.5 19.0 21.5 27.0 34.0 44.0 58.0 øA P6 B H øA P7 B H P10 øA L – – – – – – – – 2.7 11.1 12.4 11.1 – – – – – – – – – – – – – – – – – – – – P11 øA L – – – – 9.1 16 17 12.1 19 – – – – – – – – – – – – – – – Note: using the tapered washer a round hole ø 36 mm apply. 2) tolerance: + 0.02 0 1) for Cut-out types Model EBC EBD EBS ECP EEP EHP Note: 152 Type P6 P6 P7 P1 P1 P2/P1 3) 5) Mounting nut torque Model Type ERA ERC ERD ERN ERS EXP P1 P1 P1 P1 P2 P2/P10 4) Model EWB FAA HCP HGP HGW PSA Type P3 P1/P23) P34) P3 P11 P1 in series 6S use P2. use only ø A in 1S series. in series 4S and 5S use P2. Model PSP PSS RAD SWH Type Series P1 P1 P1/P25) P4 0S 1S 2S 3S 4S 5S 6S 1 N = 0.102 kg Torque (Nm) Metal shell Plastic shell6) 2.5 4.5 6.0 9.0 12.0 17.0 22.0 0.4 0.7 0.8 1.0 5.0 – – Note: 6) these values apply when metal shell are mounted with insulating washer. www.lemo.com ® ® K series Series 0K 1K 2K 3K 4K 5K øA P1 B L øA 14.1 16.1 20.2 24.2 30.2 45.2 12.6 14.6 18.6 22.6 28.6 42.6 20.5 22.5 29.0 35.5 43.0 57.0 – – – 3.5 3.5 4.5 P6 B H P7 B øA – – – – – – 22.6 20.6 28.6 27.0 42.6 38.0 – – – 3.5 3.5 4.5 H – – – – – – 23.1 23.0 30.1 29.0 45.1 44.0 Cut-out types Model EBG EDG EEG EGG EHG ENG Mounting nut torque Type Model P7 P72) P1 P1 P1 P1 EVG FAG FXG HEG HGG PBG Type Model P1 P1 P6 P1 P1 P73) PEG PKG S●● Type Series Torque (Nm) P1 P1 P1 0K 1K 2K 3K 4K 5K 5 7 9 12 17 22 1 N = 0.102 kg Note: 2) for this model dimension B = 18.1. 3) for this model dimension B = 19.1. E and L series 0E-0L 1E-1L 2E-2L 3E 4E 5E 6E øA P1 B L øA P6 14.1 16.1 20.2 24.2 30.2 45.2 55.3 12.6 14.6 18.6 22.6 28.6 42.6 52.1 20.5 22.5 29.0 35.5 43.0 57.0 68.0 – – 2.9 – – – – B Cut-out types E series Model EBR EEP EHP ERA ERB ERC FAA Type P6 P1 P1 P1 P1 P1 P1 H – – – – 15.1 11.8x20.4 – – – – – – – – Cut-out types L series Model HGP PSA PSP SWH Type P1 P1 P1 P1 Model EEG EGG FAG HGG PKG Mounting nut torque Type Series Torque (Nm) P1 P1 P1 P1 P1 0E-0L 1E-1L 2E-2L 3E 4E 5E 6E 5 7 9 12 17 22 27 Panel cut-out for mounting with insulating washer (S-B series) GRA Panel cut-out for mounting with double panel washer (S-B series) 0.1 ø A+ 0 GRC 0.1 B +0 Series Dim. (mm) øA B 00 0S-0B 1S-1B 2S-2B 3S-3B 4S-4B 8.9 10.9 13.9 18.0 21.9 29.1 8.1 10.0 12.3 16.3 20.3 27.4 1 N = 0.102 kg øA H Series Series L mini 0S-0B 1S-1B Dimensions (mm) øA H L 11 14 14 20 13.5 17.0 Note: for nut tightening torques please refer to the corresponding series in the table on page 152. www.lemo.com 153 ® ® PCB drilling pattern Fixed socket with straight print contact (B-K series) 00 0B-0K 1B-1K 2B-2K 0.6 0.8 0.8 0.8 1.2 2.2 2.8 4.4 A Dimensions B C 0.6 0.6 0.8 0.8 0.8 1.6 2.5 3.1 5.0 6.2 45° 45° 45° 45° 45° A Dimensions B C 0.6 0.8 3.0 3.7 60° 60° 00 0B-0K 1B-1K 2B-2K 3B-3K øB 306 øA Series øB 0B-0K 1B-1K 00 0B-0K 1B-1K 2B-2K 3B-3K øA øB 305 Dimensions B C 0.6 0.8 0.8 0.8 0.8 1.35 2.30 3.00 4.60 5.60 120° 120° 120° 120° 120° A Dimensions B C 0.6 0.8 0.8 0.8 2.8 3.4 5.2 6.7 72° 72° 72° 72° A Dimensions B C 0.8 0.8 5.6 7.1 72° 72° A Dimensions B C 0.8 3.8 51°26’ A Dimensions B C 0.6 0.8 3.2 7.5 45° 45° Series C° 0B-0K 1B-1K 2B-2K 3B-3K øB øA C° A Series 306 Series 2B-2K 3B-3K øB Series 303 øA 304 Dimensions A B øA øB øA Series C° 302 P15 C° C° A Dimensions B C 0.6 0.8 0.8 0.8 3.00 3.70 5.80 7.08 60° 60° 60° 60° A Dimensions B C 0.8 0.8 6.4 7.5 45° 45° øB C° øA 0B-0K 1B-1K 2B-2K 3B-3K 308 Series 2B-2K 3B-3K Series C° 1B-1K 309 Series C° 0B-0K 3B-3K øB øB øA C° 308 øB Series øA 307 øA 0.6 0.8 0.8 Dimensions B C D 312 C° 3.95 45° 22°30' 1.40 6.30 45° 22°30' 2.15 7.90 45° 22°30' 2.80 6° øB 36° H 3 øA I 1B-1K 2B-2K 3B-3K A 0.6 0.8 0.8 Dimensions B C H 4.4 6.5 8.2 316 Series I 90° 1.90 1.80 90° 2.65 2.65 90° 3.40 3.40 D° 1B-1K øH Series øA 314 154 2B-2K 3B-3K D° øA øA C° Series H A Dimensions B C D H 0.8 6.50 45° 22°30’ 2.80 0.8 8.20 45° 22°30’ 3.40 øB øB H C° 1B-1K 2B-2K 3B-3K A A 0.6 Dimensions B D H 4.4 32°44’ 2.00 øB Series D° øH 310 72 ° www.lemo.com ® Series ° 72 2B-2K 3B-3K 4B-4K E° 318 Series H C° 0.8 6.6 32°44' 16°22’ 3.10 0.8 8.4 32°44' 16°22’ 3.86 0.6 10.5 32°44' 16°22’ 5.00 D° A 2B-2K 3B-3K E° øH øB øH D° Dimensions B D E A B Dimensions C D E H 0.8 6.7 60° 30° 15° 3.50 0.8 8.4 60° 30° 15° 4.34 øB 316 ® øA øA Series C° A 2B-2K E° B Dimensions C D E 320 Series H 3B-3K 4B-4K øA øB B Dimensions C D H 0.6 8.62 51°26’ 27°42’ 4.78 0.6 11.00 51°26’ 27°42’ 6.00 øB D° øH A D° 0.8 6.7 60° 30° 15° 3.5 øH 319 324 Series C° 0.6 8.8 45° 25°43’ 22°30’ 5 øH D° 3B-3K 4B-4K øA 36° 90 36° 11°15' ø 0.6 ø 0.6 ø9 4B-4K.340 ° ø9 2.2 22° 30 ' ø 2.1 40° ø 0.6 ø 0.6 2.6 4B-4K.348 ø 7.2 5B-5K.350 ' 0° ø 3.1 ' 40° 24° 40° 5B-5K.364 11° 18 °5 ø 0.6 60 ° ø 19.84 ø 14.96 ø 19.4 ø9 36° ø 14.2 ø 3.8 22°30' ø 5.05 ° ø 10.08 ø 0.6 15' 13°5 1' 0' 7°3 15 12 15°40 17°8'34'' 5B-5K.354 ø 12 ø 8.65 ø 7.94 21°11' ø 5.3 ø2 12 0° ø 11.64 ° 24 ø 0.6 ø7 ø 0.6 2' 27°4 ° 8 1 ø 0.6 ø 0.6 4.6 ø 2.2 36° ø 4.24 °26 51 ° 72 ø 19.2 2B-2K.332 ° 11°15' ø 5.6 0° 12 ø7 40° ø 1.6 ø 4.2 0° 12 90 4B-4K.330 ø 11.4 25°43' H 0.6 8.8 45° 25°43' 1.8 5.30 0.6 11.1 45° 25°43' 2.2 6.65 øE 3B-3K.330 25°43' Dimensions C D E 22° 30 ' 3B-3K.326 B 7.4 øA 2B-2K.326 A ø 7.0 H øB øH D° 3B-3K Dimensions C D E ø 5.7 E° B ø 13.73 A ø 8.36 Series C° øB 322 ø 3.1 øA C° 27°41'32'' 7' Note: all views are from the side of the socket. www.lemo.com 155 ® ® Length of straight print contacts (for socket E●●) Length of straight print contacts (for socket EZG/EYG/XPF) Dimensions Type Models EZG/EYG XPF øC L øC L Type øC L 00 302 303 304 0.5 0.5 0.5 3.0 3.0 3.0 0B 302/303 304/305 306/307/309 0.7 0.5 0.5 4.5 4.5 3.0 – 0.7 – – 3.0 – 0B 0K 302/303 304/305 306/307/309 0.7 0.5 0.5 3.2 3.2 3.2 1B 302/303/304/305 306/307/308 310/314/316 0.7 0.7 0.5 3.8 3.8 3.8 – – – – – – 1B 1K 302/303/304/305 306/307/308 310/314/316 0.7 0.7 0.5 3.0 3.0 4.0 2B 302/303/304/305 306/307/308/310 312/314/316/318/319 0.7 0.7 0.7 5.5 5.5 5.5 – – – – – – 2B 2K 302/303/304/305/306/307 308/310/312/314/316/318/319 326/332 0.7 0.7 0.5 3.0 3.0 3.0 3B 3K 303/304/305/306/307 308/309/310/312/314/316/318 320/322/324/326/330 0.7 0.7 0.5 3.0 3.0 5.0 4B 4K 316/320 324/330 340/348 0.5 0.5 0.5 5.0 5.0 5.0 5B 5K 348 350 354 364 0.7 0.5 0.5 0.5 5.0 5.0 5.0 5.0 EZG/EYG/XPF øC øC E●● L L Note: This table does not apply for socket H●●; socket EH● and plugs FA●/FW●. Fixed socket for printed circuit (B series) P16 Holes for fixing the housing EYG-EZG B Series øA 00 0B 1B 2B Dimensions A B 0.81) 1.72) 1.72) 1.72) 5.08 7.62 7.62 10.16 XPF.0B B Series øA 0B Dimensions A B 1.7 5.08 Note: Mounting torque for screws: 0.1 Nm. 1) to solder. 2) to screw. 156 www.lemo.com ® Fixed socket with elbow print contact (B-K series) P17 302 Series Dim. A 00 0B-0K 1B-1K 2B-2K 0.6 0.7 0.9 0.9 øA 1 A 2 A 2.54 Dim. Series L øA 00 0B-0K 1B-1K 2B-2K 3 1 L 2 2.54 0B-0K.305 304 L 0.6 0.7 0.9 0.9 1.27 1.27 1.27 2.54 4 3 1 2 00 0B-0K 1B-1K 2B-2K 2.54 1B-1K.305 Dim. Series øA A L 303 ® A L 0.6 0.7 0.7 0.9 2.54 2.54 2.54 3.50 0B-0K / 1B-1K.306 2B-2K.305 ø 0.7 1.27 1.27 2 2.54 2.54 1 2 2.54 2.54 5 6 3 4 1 2.54 2.54 2.54 2.54 3 3 2 1.27 1 4 ø 0.9 3 5 2.54 2.54 2 1 4 ø 0.7 4 ø 0.7 5 5 2.54 2.54 3 7 1 6 5 8 5 9 10 1 4 4 2 1.27 3 6 2.54 2.54 7 3 8 8 12 11 5 1 9 10 4 2 3 6 11 13 1 12 11 1 2 13 14 3 4 12 5 1 4 2B-2K.319 5 4 2.54 2.54 2.54 2.54 9 12 18 17 14 15 3 4 2 5 7 16 13 1 9 18 17 13 16 14 15 3 4 8 12 7 6 6 1 5 2 1.27 2.54 2.54 2.54 2.54 3B-3K.320 10 11 8 1.27 1.27 1.27 2.54 2.54 2.54 2.54 10 6 2 3 12 3 11 7 15 6 13 3B-3K.318 8 16 14 11 1.27 14 ø 0.7 10 7 10 2B-2K.318 10 2.54 2.54 9 ø 0.7 9 7 3 2 ø 0.7 8 2 6 2.54 2.54 2.54 2B-2K / 3B-3K.316 9 8 1B-1K / 2B-2K.314 2.54 2.54 2.54 3B-3K.314 1 1.27 1 7 2B-2K / 3B-3K.312 2.54 2.54 2.54 1B-1K / 2B-2K.310 ø 0.9 7 2.54 2.54 ø 0.7 2B-2K.308 / 3B-3K.308 6 4 1.27 2.54 2.54 7 5 2 1.27 1.27 2.54 2.54 2.54 3 2 2 2 4 3B-3K.324 ø 0.7 7 1 6 0.92 3 4 ø 0.7 ø 0.9 6 1 5 6 ø 0.7 5 5 8 1B-1K.308 ø 0.9 4 2B-2K.307 ø 0.7 0B-0K / 1B-1K.307 ø 0.7 2B-2K.306 5 2.54 5.08 2.54 3B-3K.330 ø 0.7 11 14 16 15 2 www.lemo.com 7 16 17 3 1.27 19 7 24 16 2 18 2.54 2.54 2.54 2.54 12 11 25 24 23 29 22 10 30 9 17 27 18 19 20 21 3 4 5 6 28 1 5 8 2 4 2.54 2.54 2.54 2.54 13 26 16 6 17 3 5 8 23 1 6 4 1.27 1.27 2 4 14 14 15 20 15 18 15 9 21 22 8 1 6 13 9 14 5 3 19 1.27 1 10 20 10 ø 0.7 19 13 7 13 1.27 17 18 ø 0.7 12 11 12 8 ø 0.7 9 10 11 12 7 2.54 2.54 2.54 2.54 2.54 2.54 157 ® Elbow socket (90°) for printed circuit (B series) P18 P18 - EPG.00.302 - XBG.00.302 XRB.00.3021) 5.08 P19 P20 P18 - EPG.00.3032) - XBG.00.3032) P18 - EPG.00.304 - XBG.00.304 XRB.00.3041) XRB.00.3031) ø 0.8 ø 0.8 5.08 5.08 ø 0.8 ø 0.6 1.9 7.62 7.62 1.27 7.62 1.27 2.54 7.62 7.62 ø 0.8 1.27 1.27 ø 1.7 ø 0.7 7.62 12.7 1.27 2.54 7.62 1.27 2.54 ø 1.7 7.62 ø 1.7 7.62 P20 - EPG.1B.314 12.7 ø 0.8 1.27 2.54 7.62 1.27 1.27 7.62 P19 - EPG-EXG (1B.310) Screw mount P19 - EPG-EXG (0B.309) Screw mount ø 0.8 7.62 ø 0.8 1.27 ø 0.8 1.27 ø 0.8 7.62 2.54 2.54 7.62 2.54 2.54 1.27 2.54 7.62 1.27 ø 0.8 1.27 P19 - EPG-EXG (1B.310) Solder mount 2.54 P19 - EPG-EXG (0B.309) Solder mount ø 1.7 7.62 ø 1.7 7.62 ø 0.8 1.27 2.54 P19 - EPG-EXG (1B.308) Screw mount ø 0.8 ø 0.8 7.62 P19 - EPG-EXG (0B/1B.307) Screw mount ø 0.8 1.27 ø 0.8 2.54 P19 - EPG-EXG (1B.308) Solder mount 2.54 P19 - EPG-EXG (0B/1B.307) Solder mount 2.54 ø 1.7 ø 1.7 7.62 ø 0.8 2.54 7.62 ø 0.8 2.54 7.62 ø 0.8 7.62 7.62 2.54 P19 - EPG-EXG (0B/1B.306) Screw mount 7.62 P19 - EPG-EXG (0B/1B.305) Screw mount ø 0.8 2.54 7.62 2.54 ø 0.8 ø 0.8 2.54 P19 - EPG-EXG (0B/1B.305) Solder mount ø 0.8 2.54 P19 - EPG-EXG (0B/1B.306) Solder mount ø 1.7 7.62 7.62 7.62 2.54 7.62 2.54 ø 1.7 7.62 P19 - EPG-EXG (0B/1B.303) Screw mount ø 0.8 2.54 P19 - EPG-EXG (0B/1B.304) Screw mount ø 0.8 2.54 7.62 ø 0.8 7.62 ø 0.8 2.54 ø 0.8 7.62 1.27 P19 - EPG-EXG (0B/1B.303) Solder mount 2.54 2.54 ø 1.7 7.62 7.62 2.54 ø 0.8 P19 - EPG-EXG (0B/1B.304) Solder mount 5.08 1.27 P19 - EPG-EXG (0B/1B.302) Screw mount ø 0.8 2.54 1.9 ø 0.6 1.27 7.62 1.27 1.9 1.9 P19 - EPG-EXG (0B/1B.302) Solder mount 0.63 A = A = = = ø 0.6 1.27 ® ø 0.8 1.27 2.54 1.27 Note: 1) for the XRB.00 series the holes for shell fixing are different (see p. 30). 2) the dimensions for the EPG.00.303.HLN and XBG.00.303.HLN models are given on page 23. For other models please contact factory. 158 www.lemo.com ® Fixed socket with straight print contact (S-E series) øB øA Series Dimensions A B 0S-0E 1S-1E 0.6 0.8 P21 303 C° 2.2 3.0 0S-0E 1S-1E 2S-2E øB C 0.6 0.8 0.8 2.8 3.5 5.0 45° 45° 45° A Dimensions B C 0.8 0.8 0.8 3.5 5.5 6.5 60° 60° 60° øA øB 1S-1E 2S-2E 3S-3E 308 Series 2S-2E 3S-3E øB Dimensions B C 0.8 0.8 6.5 7.8 45° 45° 45° 45° 60° øB A Dimensions B C 0.8 0.8 3.5 5.5 C Dimensions D E F 45° 45° 22°30’ 2.75 22°30’ 3.25 3.25 3.90 A Dimensions B C D 0.8 0.8 6.5 7.8 60° 60° Series 60° 2S-2E 3S-3E D° Series C° 22°30’ 22°30’ 2S-2E 3S-3E D 45° 60° E 45° 22°30’ 1.25 45° 22°30’ 1.50 3S-3E.314 2.9 3.2 8x1 1.3 1.3 ø 0.8 3S-3E.316 6 x 1.2 1.2 6 x 1.2 ø 0.8 3S-3E.313 6 x 1.2 1.3 ø 0.8 D° C° 310 D 2.8 3.5 5.5 øA 3.2 3S-3E.312 A 307 3.2 øA C° D° 1S-1E 2S-2E øB Series C° Series F 306 C 0.6 0.8 0.8 D° ø 0.8 øB C° E 0S-0E 1S-1E 2S-2E 305 Dimensions B E Dimensions B øA A Series øA C° ø 0.8 304 A Series øA 302 ® 3S-3E.318 ø 0.8 1.2 2.9 8x1 Note: all views are from the side of the socket. øC Length of straight print contacts (for socket E●●) L Type 0S 0E 302 303 304 1S 1E 302 303/304/305 305/306 Dimensions øC L 0.7 0.5 0.5 3.0 3.0 3.0 0.7/1.5 3.0/5.0 0.7 3.0 0.5 3.0 Type Dimensions øC L 2S 2E 303/304/305 306/307 308/310 0.7 0.7 0.7 3.0 3.0 3.0 3S 3E 305/306/307/308/310 312/313/314 316/318 0.7 0.7 0.7 3.0 3.0 3.0 Note: This table does not apply for HGP and EHP sockets and for FAA plugs. www.lemo.com 159 ® Elbow socket (90°) for printed circuit (S series) P22 - EPL - EXP Solder mount P23 P22 - EPL - EXP Screw mount P23 - EPL.00.113 P23 - EPL.0S.116 5.08 5.08 ø 1.7 7.62 ø 0.8 2.54 ø 1.1 = = 7.62 2.54 7.62 2.54 2.54 2.54 2.54 = 2.54 ø 0.8 7.62 2.54 P22 = ® 2.54 2.54 2.54 2.54 Note: all dimensions are in millimetres. Fixed socket with elbow print contact (S-E series) P24 302 øA 1 A 2 Series Dim. A 0S-0E 1S-1E 0.7 0.9 Series Dimensions A B 0S-0E 1S-1E 2S-2E 0.7 0.7 0.9 Series Dim. A 1S-1E 2S-2E 0.7 0.9 A 2.54 Series C B 0.7 0.7 0S-0E 1S-1E 1 3 Dimensions B C A øA 2.00 2.48 304 øA 1.00 1.24 2 4 2 3 2.00 3.50 3.50 2.54 2.54 Dim. A 5 3 0.7 0.9 1S-1E 2S-2E øA 2 306 4 1 6 2 5 3 4 øA Series 1 2.4 2.4 305 2.54 2.54 1 B 303 2.54 2.54 2.54 2S-2E.308 2S-2E / 3S-3E.310 3S-3E.312 4 5 2.54 2.54 2.54 6 2.54 2.54 2.54 8 5 9 6 10 11 ø 0.7 10 7 4 2.4 9 3 1 2 12 1.2 2.54 2.54 5 1.25 4 7 3 6 5 1.75 4 1.75 3 3 8 2 ø 0.7 1 7 6 6 1.27 8 ø 0.7 1 2 6 7 2.5 1 2 ø 0.7 1.2 2S-2E.307 2.54 2.54 2.54 3S-3E.316 1.2 3S-3E.314 8 5 9 12 6 10 7 11 3 9 6 10 13 2 14 2.4 13 ø 0.7 2 5 1 14 3 15 7 11 8 12 2.54 2.54 2.54 16 1.2 1.2 4 ø 0.7 4 1 2.54 2.54 2.54 160 www.lemo.com ® ® Cable assembly (B, K, S and E series) Cable stripping lengths (B series) straight plugs and sockets with cable collet, clamping type D or M (solder or crimp contacts) M3 elbow plugs (90°) with cable collet, clamping type D or M (solder or crimp contacts) Connector Series Type 00 302/303/304 302/303 304/305 306/307/3092) 302/303 304/305 306/307/308 310/314/316 302 303 304/305/306/307 308/310 312/314/316/318/319 326/332 302 303/304 305/306/307 308/310 0B1) 1B1) 2B L T S 3B 309 4B 5B1) 0.5 0.9 0.7 0.5 1.3 0.9 0.7 0.5 2.0 1.6 1.3 0.9 0.7 0.5 3.0 2.0 1.6 1.3 1.3 2.0 0.9 0.7 3.0 2.0 1.6 1.3 0.9 0.7 6.0 4.0 3.0 2.0 1.6 1.3 0.9 Cable stripping lengths (mm) M1 L Solder S 7.0 13.0 13.0 14.0 14.0 14.0 14.0 16.5 19.0 19.0 18.0 17.0 17.0 17.0 24.0 23.0 23.0 22.0 4 7 7 7 8 8 8 8 9 9 9 9 9 9 10 10 10 10 22.0 10 21.0 21.0 33.0 32.0 32.0 32.0 32.0 32.0 42.0 47.0 47.0 46.0 46.0 45.0 45.0 10 10 12 12 12 12 12 12 18 18 18 18 18 18 18 M3 T L Crimp S 2.5 3.0 3.0 2.5 3.5 3.0 3.0 2.5 4.0 3.5 3.5 3.0 3.0 2.5 4.5 4.0 3.5 3.5 3.5 4.0 3.0 3.0 4.5 4.0 3.5 3.5 3.0 3.0 7.5 5.5 4.5 4.0 3.5 3.5 3.0 10.0 17.0 17.0 18.0 18.0 18.0 18.0 – 22.0 22.0 20.0 20.0 20.0 – 28.0 27.0 27.0 25.0 4 7 7 7 8 8 8 – 9 9 9 9 9 – 10 10 10 10 25.0 10 25.0 25.0 36.0 36.0 36.0 36.0 34.0 34.0 – 50.0 50.0 49.0 49.0 48.0 48.0 10 10 12 12 12 12 12 12 – 18 18 18 18 18 18 T L Solder S 3.0 4.0 4.0 3.0 4.0 4.0 4.0 – 5.5 5.5 4.0 4.0 4.0 – 5.5 5.5 5.5 4.0 4.0 5.5 4.0 4.0 5.5 5.5 5.5 4.0 4.0 4.0 – 7.0 7.0 5.5 5.5 4.0 4.0 9.5 18.0 18.0 19.0 25.0 25.0 25.0 27.5 30.0 30.0 29.0 28.0 28.0 28.0 35.0 34.0 34.0 33.0 4 7 7 7 8 8 8 8 9 9 9 9 9 9 10 10 10 10 33.0 10 32.0 32.0 41.0 41.0 39.0 39.0 39.0 39.0 70.0 75.0 75.0 74.0 74.0 74.0 74.0 10 10 12 12 12 12 12 12 18 18 18 18 18 18 18 T L Crimp S 2.5 3.0 3.0 2.5 3.5 3.0 3.0 2.5 4.0 3.5 3.5 3.0 3.0 2.5 4.5 4.0 3.5 3.5 3.5 4.0 3.0 3.0 4.5 4.0 3.5 3.5 3.0 3.0 7.5 5.5 4.5 4.0 3.5 3.5 3.0 12.5 22.0 22.0 23.0 28.0 28.0 28.0 – 33.0 33.0 31.0 31.0 31.0 – 39.0 38.0 38.0 36.0 4 7 7 7 8 8 8 – 9 9 9 9 9 – 10 10 10 10 36.0 10 36.0 36.0 45.0 45.0 43.0 43.0 43.0 43.0 – 78.0 78.0 77.0 77.0 77.0 77.0 10 10 12 12 12 12 12 12 – 18 18 18 18 18 18 T 3.0 4.0 4.0 3.0 4.0 4.0 4.0 – 5.5 5.5 4.0 4.0 4.0 – 5.5 5.5 5.5 4.0 4.0 5.5 4.0 4.0 5.5 5.5 5.5 4.0 4.0 4.0 – 7.0 7.0 5.5 5.5 4.0 4.0 straight plug, short version, clamping type D or M (solder or crimp contacts) L Connector T Series S 0B Type 302/303 304/305 306/307/3092) ø contact A (mm) M4 312/314/316/318 320/322/324/326/330 304 306/307 310 312 316/320/324/330 340/348 302 304 310 314/316 320 330/340/348 350/354/364 ø contact A (mm) M1 0.9 0.7 0.5 Cable stripping lengths (mm) M4 Solder Crimp L S T L S T 9.5 9.5 10.0 8 8 8 3.0 3.0 2.5 13.0 13.0 13.5 8 8 8 4.0 4.0 3.0 Note: the tolerances on these dimensions are: L: ± 0.5 mm; S: ± 0.5 mm; T: ± 0.2 mm. 1) In 0B and 1B series, «L» and «S» dimensions shall be increased by 2 mm for the largest collet (D56 in 0B series; D76 in 1B series). In 5B series, «L» and «S» dimensions shall be increased by 13 mm for the largest collet (D25). 2) Crimp contacts are available only for connectors fitted with male contacts. www.lemo.com 161 ® straight plug, long version, clamping type D or M (solder or crimp contacts) Connector Series L T 1B1) S 2B Type 302/303 304/305 306/307/308 310/314/316 302 303 304/305/306/307 308/310 312/314/316/318/319 326/332 ø contact A (mm) M2 ® 1.3 0.9 0.7 0.5 2.0 1.6 1.3 0.9 0.7 0.5 Cable stripping lengths (mm) M2 Solder Crimp L S T L S T 39.0 39.0 39.0 42.0 49.0 49.0 48.0 47.0 47.0 47.0 8 8 8 8 9 9 9 9 9 9 3.5 3.0 3.0 2.5 4.0 3.5 3.5 3.0 3.0 2.5 43.0 43.0 43.0 – 53.0 53.0 50.0 49.0 49.0 – 8 8 8 – 9 9 9 9 9 – 4.0 4.0 4.0 – 5.5 5.5 4.0 4.0 4.0 – Note: 1) In 0B and 1B series, «L» and «S» dimensions shall be increased by 2 mm for the largest collet (D56 in 0B series; D76 in 1B series). In 5B series, «L» and «S» dimensions shall be increased by 13 mm for the largest collet (D25). The tolerances on these dimensions are: L: ± 0.5 mm; S: ± 0.5 mm; T: ± 0.2 mm Cable stripping lengths (K series) straight plugs and sockets with cable collet, clamping type C (solder or crimp contacts) M3 elbow plug (90°) with cable collet, clamping type C (solder or crimp contacts) Connector Series 0K 1K 2K L T S 3K Type 302/303 304/305 306/307/3091) 302/303 304/305 306/307/308 310/314/316 302 303 304/305/306/307 308/310 312/314/316/318/319 326/332 302 303/304 305/306/307 308/310 309 4K 5K 312/314/316/318 320/322/324/326/330 304 306/307 310 312 316/320/324/330 340/348 302 304 310 314/316 320 330/340/348 350/354/364 ø contact A (mm) M1 0.9 0.7 0.5 1.3 0.9 0.7 0.5 2.0 1.6 1.3 0.9 0.7 0.5 3.0 2.0 1.6 1.3 1.3 2.0 0.9 0.7 3.0 2.0 1.6 1.3 0.9 0.7 6.0 4.0 3.0 2.0 1.6 1.3 0.9 Cable stripping lengths (mm) M1 L Solder S 8.0 8.0 9.0 10.5 10.5 10.5 13.0 16.5 16.5 15.5 14.5 14.5 14.5 19.0 18.0 18.0 17.0 6 6 6 7 7 7 7 8 8 8 8 8 8 10 10 10 10 17.0 10 16.0 16.0 22.0 21.0 21.0 21.0 21.0 21.0 24.0 29.0 29.0 28.0 28.0 27.0 27.0 10 10 11 11 11 11 11 11 14 14 14 14 14 14 14 M3 T L Crimp S 3.0 3.0 2.5 3.5 3.0 3.0 2.5 4.0 3.5 3.5 3.0 3.0 2.5 4.5 4.0 3.5 3.5 3.5 4.0 3.0 3.0 4.5 4.0 3.5 3.5 3.0 3.0 7.5 5.5 4.5 4.0 3.5 3.5 3.0 12.0 12.0 13.0 14.5 14.5 14.5 – 19.5 19.5 17.5 17.5 17.5 – 23.0 22.0 22.0 20.0 6 6 6 7 7 7 – 8 8 8 8 8 – 10 10 10 10 20.0 10 20.0 20.0 25.0 25.0 25.0 25.0 23.0 23.0 – 32.0 32.0 31.0 31.0 30.0 30.0 10 10 11 11 11 11 11 11 – 14 14 14 14 14 14 T L Solder S 4.0 4.0 4.0 4.0 4.0 4.0 – 5.5 5.5 4.0 4.0 4.0 – 5.5 5.5 5.5 4.0 4.0 5.5 4.0 4.0 5.5 5.5 5.5 4.0 4.0 4.0 – 7.0 7.0 5.5 5.5 4.0 4.0 21.0 21.0 22.0 27.0 27.0 27.0 29.5 36.0 36.0 35.0 34.0 34.0 34.0 48.0 48.0 48.0 47.0 6 6 6 7 7 7 7 8 8 8 8 8 8 10 10 10 10 47.0 10 46.0 46.0 52.0 51.0 51.0 51.0 51.0 51.0 – – – – – – – 10 10 11 11 11 11 11 11 – – – – – – – T L Crimp S 3.0 3.0 2.5 3.5 3.0 3.0 2.5 4.0 3.5 3.5 3.0 3.0 2.5 4.5 4.0 3.5 3.5 3.5 4.0 3.0 3.0 4.5 4.0 3.5 3.5 3.0 3.0 – – – – – – – 25.0 25.0 26.0 31.0 31.0 31.0 – 39.0 39.0 37.0 37.0 37.0 – 53.0 52.0 52.0 50.0 6 6 6 7 7 7 – 8 8 8 8 8 – 10 10 10 10 50.0 10 50.0 50.0 55.0 55.0 55.0 55.0 53.0 53.0 – – – – – – – 10 10 11 11 11 11 11 11 – – – – – – – T 4.0 4.0 4.0 4.0 4.0 4.0 – 5.5 5.5 4.0 4.0 4.0 – 5.5 5.5 5.5 4.0 4.0 5.5 4.0 4.0 5.5 5.5 5.5 4.0 4.0 4.0 – – – – – – – Note: 1) crimp contacts are available only for connectors fitted with male contacts. The tolerances on these dimensions are: L: ± 0.5 mm; S: ± 0.5 mm; T: ± 0.2 mm. 162 www.lemo.com ® ® Cable stripping lengths (K series) straight plug and socket with oversize cable collet, clamping type K (solder or crimp contacts) Connector Series 1K 2K L T S 3K Type 302/303 304/305 306/307/308 310/314/316 302 303 304/305/306/307 308/310 312/314/316/318/319 326/332 302 303/304 305/306/307 308/310 309 4K 312/314/316/318 320/322/324/326/330 304 306/307 310 312 316/320/324/330 340/348 Cable stripping lengths (mm) M2 Solder Crimp L S T L S T ø contact A (mm) M2 1.3 0.9 0.7 0.5 2.0 1.6 1.3 0.9 0.7 0.5 3.0 2.0 1.6 1.3 1.3 2.0 0.9 0.7 3.0 2.0 1.6 1.3 0.9 0.7 24.5 24.5 24.5 27.0 29.5 29.5 28.5 27.5 27.5 27.5 37.0 36.0 36.0 35.0 8 8 8 8 10 10 10 10 10 10 11 11 11 11 35.0 11 34.0 34.0 45.0 44.0 44.0 44.0 44.0 44.0 11 11 14 14 14 14 14 14 3.5 3.0 3.0 2.5 4.0 3.5 3.5 3.0 3.0 2.5 4.5 4.0 3.5 3.5 3.5 4.0 3.0 3.0 4.5 4.0 3.5 3.5 3.0 3.0 28.5 28.5 28.5 – 32.5 32.5 30.5 30.5 30.5 – 41.0 40.0 40.0 38.0 8 8 8 – 10 10 10 10 10 – 11 11 11 11 38.0 11 38.0 38.0 48.0 48.0 48.0 48.0 46.0 46.0 11 11 14 14 14 14 14 14 4.0 4.0 4.0 – 5.5 5.5 4.0 4.0 4.0 – 5.5 5.5 5.5 4.0 4.0 5.5 4.0 4.0 5.5 5.5 5.5 4.0 4.0 4.0 Note: the tolerances on these dimensions are: L: ± 0.5 mm S: ± 0.5 mm T: ± 0.2 mm Cable stripping lengths for unipole connectors (S series) straight plugs and sockets with cable collet, clamping type C (solder contacts) M3 elbow plugs (90°) with cable collet, clamping type C (solder contacts) M5 straight plugs and sockets with cable crimping type E (crimp contacts) M6 elbow plugs (90°) with cable crimping type E (crimp contacts) Connector Series 00 0S L T 1S 2S S 3S 4S 5S www.lemo.com Type 113 116 120 130 130 140 140 160 140 160 112 ø contact A (mm) M1 L M1 Solder S 1.3 1.6 2.0 3.0 3.0 4.0 4.0 6.0 4.0 6.0 12.0 9 11 13 13 18 18 21 21 25 25 12 4 5 8 8 9 9 9 9 9 9 15 T Cable stripping lengths (mm) M5 M3 Crimp Solder L S T L S T 4 4 5 5 6 6 7 9 7 9 12 19 – – – – – – – – – – 5 – – – – – – – – – – 7 – – – – – – – – – – 7 8 13 13 15 15 19 19 23 23 – 4 5 8 8 9 9 9 9 9 9 – 2 2 2 2 2 2 2 2 2 2 – L M6 Crimp S T 17 – – – – – – – – – – 5 – – – – – – – – – – 7 – – – – – – – – – – 163 ® ® Cable stripping lengths for unipole connectors (S series) straight plugs and sockets with oversize cable collet, clamping type K (solder contacts) Connector Series Type L 00 0S T 1S S 2S 3S 4S 113 116 120 130 130 140 140 160 140 160 ø contact A (mm) M2 1.3 1.6 2.0 3.0 3.0 4.0 4.0 6.0 4.0 6.0 Cable stripping lengths (mm) L M2 Solder S T 16 19 25 25 34 34 39 39 50 50 4 5 8 8 9 9 9 9 9 9 4 4 5 5 6 6 7 9 7 9 Cable stripping lengths for multipole connectors (S series) M1 straight plugs and sockets with cable collet, clamping type C (solder or crimp contacts) M3 elbow plugs (90°) with cable collet, clamping type C (solder or crimp contacts) Series 0S 1S Type 302 303/304 302 303/304 305 306 302 303/304/305/306 L 2S T 307 308/310 302/303/304 S 3S 305 306/307/308/310 312/313/314/316/318 302 303/304 305 4S 306 307 308/309/310 312/313/314 316/318/320/322/324 164 Cable stripping lengths (mm) ø contact A (mm) Connector L Solder S T 0.9 0.7 1.3 0.9 0.9 0.7 0.7 1.6 1.3 1.3 0.9 0.9 2.0 2.0 1.3 1.3 0.9 4.0 3.0 3.0 2.0 2.0 2.0 1.3 1.3 1.3 0.9 11 11 13 13 13 13 13 18 18 18 18 18 21 21 21 21 21 25 25 25 25 25 25 25 25 25 25 5 5 8 8 8 8 8 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 3.0 2.5 3.0 3.0 3.0 2.5 2.5 4.5 4.0 4.0 4.0 4.0 5.0 5.0 4.0 4.0 4.0 7.0 6.0 6.0 5.0 5.0 5.0 4.0 4.0 4.0 4.0 M1 M3 L Crimp S T 15 15 17 17 17 17 17 22 22 22 22 22 – – – – – – – – – – – – – – – 5 5 8 8 8 8 8 9 9 9 9 9 – – – – – – – – – – – – – – – 4.0 4.0 4.0 4.0 4.0 4.0 4.0 5.5 4.0 4.0 4.0 4.0 – – – – – – – – – – – – – – – L Solder S T L Crimp S T 11 11 13 13 13 13 13 18 18 18 18 18 – – – – – – – – – – – – – – – 5 5 8 8 8 8 8 9 9 9 9 9 – – – – – – – – – – – – – – – 3.0 2.5 3.0 3.0 3.0 2.5 2.5 4.5 4.0 4.0 4.0 4.0 – – – – – – – – – – – – – – – 15 15 17 17 17 17 17 22 22 22 22 22 – – – – – – – – – – – – – – – 5 5 8 8 8 8 8 9 9 9 9 9 – – – – – – – – – – – – – – – 4.0 4.0 4.0 4.0 4.0 4.0 4.0 5.5 4.0 4.0 4.0 4.0 – – – – – – – – – – – – – – – www.lemo.com ® ® Cable stripping lengths for multipole connectors (S series) straight plugs and sockets with cable collet, clamping type C (solder contacts) M3 elbow plugs (90°) with cable collet, clamping type C (solder contacts) Connector Series Type 302 303 304 305 306/308 310/312 L 5S T 314 316 318 S 320 322 6S 324 330/336/340/344/348 304 312/318 320/324 330/336/348 360 364/372 106 ø contact A (mm) M1 Cable stripping lengths (mm) M1 M3 Solder Solder L S T L S T 6.0 6.0 4.0 4.0 4.0 3.0 3.0 2.0 3.0 2.0 2.0 3.0 1.6 1.6 3.0 1.6 1.6 1.3 8.0 4.0 3.0 2.0 1.6 1.3 0.9 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 37 37 37 37 37 37 37 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 15 15 15 15 15 15 15 9.0 9.0 7.0 7.0 7.0 6.0 6.0 7.0 6.0 7.0 7.0 6.0 4.5 4.5 6.0 4.5 4.5 4.0 10.0 7.0 6.0 7.0 4.5 4.0 4.0 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 35 37 37 37 37 37 37 37 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 15 15 15 15 15 15 15 9.0 9.0 7.0 7.0 7.0 6.0 6.0 7.0 6.0 7.0 7.0 6.0 4.5 4.5 6.0 4.5 4.5 4.0 10.0 7.0 6.0 7.0 4.5 4.0 4.0 Cable stripping lengths for multipole connectors (S series) straight plug with cable collet, clamping type D or M (solder or crimp contacts) Connector L Series T Type 302 303/304/305/306 S 2S 307 308/310 www.lemo.com ø contact A (mm) M4 Cable stripping lengths (mm) M4 Solder Crimp L S T L S T 1.6 1.3 1.3 0.9 0.9 48 48 48 48 48 9 9 9 9 9 4.5 4.0 4.0 4.0 4.0 52 52 52 52 52 9 9 9 9 9 5.5 4.0 4.0 4.0 4.0 165 ® ® Cable stripping lengths for multipole connectors (S series) straight plugs and sockets with oversize cable collet, clamping type K (solder or crimp contacts) Connector Series 0S 1S Type 302 303/304 302 303/304 305 306 302 303/304/305/306 2S 307 308/310 302/303/304 3S 305 306/307/308/310 312/313/314/316/318 302 303/304 L T 305 4S 306 307 S 308/309/310 312/313/314 316/318/320/322/324 302 303 304 305 306/308 310/312 5S 314 316 318 320 322 324 330/336/340/344/348 166 Cable stripping lengths (mm) ø contact A (mm) M2 L Solder S T L Crimp S T 0.9 0.7 1.3 0.9 0.9 0.7 0.7 1.6 1.3 1.3 0.9 0.9 2.0 2.0 1.3 1.3 0.9 4.0 3.0 3.0 2.0 2.0 2.0 1.3 1.3 1.3 0.9 6.0 6.0 4.0 4.0 4.0 3.0 3.0 2.0 3.0 2.0 2.0 3.0 1.6 1.6 3.0 1.6 1.6 1.3 19 19 25 25 25 25 25 34 34 34 34 34 39 39 39 39 39 50 50 50 50 50 50 50 50 50 50 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 70 5 5 8 8 8 8 8 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 22 3.0 2.5 3.0 3.0 3.0 2.5 2.5 4.5 4.0 4.0 4.0 4.0 5.0 5.0 4.0 4.0 4.0 7.0 6.0 6.0 5.0 5.0 5.0 4.0 4.0 4.0 4.0 9.0 9.0 7.0 7.0 7.0 6.0 6.0 7.0 6.0 7.0 7.0 6.0 4.5 4.5 6.0 4.5 4.5 4.0 23 23 28 28 28 28 28 38 38 38 38 38 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 5 5 8 8 8 8 8 9 9 9 9 9 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 4.0 4.0 4.0 4.0 4.0 4.0 4.0 5.5 4.0 4.0 4.0 4.0 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – M2 www.lemo.com ® ® Cable stripping lengths for unipole connectors (E series) straight plugs and sockets with cable collet, clamping type C (solder contacts) M3 elbow plugs (90°) with cable collet, clamping type C (solder contacts) Connector Series Type L 0E T 1E 2E S 3E 4E 5E 116 120 130 130 140 140 160 160 112 ø contact A (mm) M1 Cable stripping lengths (mm) M1 M3 Solder Solder L S T L S T 1.6 2.0 3.0 3.0 4.0 4.0 6.0 6.0 12.0 9 12 13 16 15 19 20 23 12 5 8 8 9 9 9 9 9 15 4 5 5 6 6 7 9 9 12 20 25 25 33 33 40 40 50 – 5 8 8 9 9 9 9 9 – 4 5 5 6 6 7 9 9 – Cable stripping lengths for unipole connectors (E series) straight plugs and sockets with oversize cable collet, clamping type K (solder contacts) Connector L Series Type T 1E S 2E 3E 4E 120 130 130 140 140 160 160 ø contact A (mm) M2 2.0 3.0 3.0 4.0 4.0 6.0 6.0 Cable stripping lengths (mm) L M2 Solder S T 25 26 28 27 36 37 50 8 8 9 9 9 9 9 5 5 6 6 7 9 9 Cable stripping lengths for multipole connectors (E series) M1 straight plugs and sockets with cable collet, clamping type C (solder or crimp contacts) M3 elbow plugs (90°) with cable collet, clamping type C (solder or crimp contacts) Series 0E L T 1E Type 302 303/304 302 303/304 305 306 302 303/304/305/306 S 2E 307 308/310 www.lemo.com Cable stripping lengths (mm) ø contact A (mm) Connector L Solder S T 0.9 0.7 1.3 0.9 0.9 0.7 0.7 1.6 1.3 1.3 0.9 0.9 8 8 11 11 11 11 11 15 15 15 15 15 5 5 8 8 8 8 8 9 9 9 9 9 3.0 2.5 3.0 3.0 3.0 2.5 2.5 4.5 4.0 4.0 4.0 4.0 M1 M3 L Crimp S T 12 12 15 15 15 15 15 19 19 19 19 19 5 5 8 8 8 8 8 9 9 9 9 9 4.0 4.0 4.0 4.0 4.0 4.0 4.0 5.5 4.0 4.0 4.0 4.0 L Solder S T L Crimp S T 19 19 24 24 24 24 24 33 33 33 33 33 5 5 8 8 8 8 8 9 9 9 9 9 3.0 2.5 3.0 3.0 3.0 2.5 2.5 4.5 4.0 4.0 4.0 4.0 23 23 28 28 28 28 28 37 37 37 37 37 5 5 8 8 8 8 8 9 9 9 9 9 4.0 4.0 4.0 4.0 4.0 4.0 4.0 5.5 4.0 4.0 4.0 4.0 167 ® ® Cable stripping lengths for multipole connectors (E series) straight plugs and sockets with cable collet, clamping type C (solder contacts) M3 elbow plugs (90°) with cable collet, clamping type C (solder contacts) Connector Series Type 302/303/304 3E 305 306/307/308/310 312/313/314/316/318 302 303/304 305 4E 306 307 308/309/310/312/314 316/318/320/322/324 302 303 L 304 T 305 306/308 310/312 S 5E 314 316 318 320 322 324 330/336/340/344/348 303 304 312 316/320/324 330/332 6E 336 340/348 360/362 364/372 106 168 ø contact A (mm) M1 Cable stripping lengths (mm) M1 M3 Solder Solder L S T L S T 2.0 2.0 1.3 1.3 0.9 4.0 3.0 3.0 2.0 2.0 2.0 1.3 1.3 0.9 6.0 6.0 4.0 4.0 4.0 3.0 3.0 2.0 3.0 2.0 2.0 3.0 1.6 1.6 3.0 1.6 1.6 1.3 6.0 8.0 5.0 3.0 2.0 1.3 5.0 2.0 1.6 1.3 0.9 18 18 18 18 18 23 23 23 23 23 23 23 23 23 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 70 70 70 70 70 70 70 70 70 70 70 9 9 9 9 9 9 9 9 9 9 9 9 9 9 15 15 15 15 15 15 15 15 15 15 15 15 15 15 15 15 15 15 30 30 30 30 30 30 30 30 30 30 30 5.0 5.0 4.0 4.0 4.0 7.0 6.0 6.0 5.0 5.0 5.0 4.0 4.0 4.0 9.0 9.0 7.0 7.0 7.0 6.0 6.0 7.0 6.0 7.0 7.0 6.0 4.5 4.5 6.0 4.5 4.5 4.0 9.0 10.0 8.0 6.0 7.0 4.0 8.0 7.0 4.5 4.0 4.0 39 39 39 39 39 50 50 50 50 50 50 50 50 50 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 9 9 9 9 9 9 9 9 9 9 9 9 9 9 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 5.0 5.0 4.0 4.0 4.0 7.0 6.0 6.0 5.0 5.0 5.0 4.0 4.0 4.0 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – www.lemo.com ® ® Cable stripping lengths for multipole connectors (E series) straight plugs and sockets with oversize cable collet, clamping type K (solder or crimp contacts) Connector Series Type 302 303/304 1E 305 306 302 303/304/305/306 L 2E T 307 308/310 302/303/304 S 3E 305 306/307/308/310 312/313/314/316/318 302 303/304 305 4E 306 307 308/309/310/312/314 316/318/320/322/324 www.lemo.com Cable stripping lengths (mm) ø contact A (mm) M2 L Solder S T L Crimp S T 1.3 0.9 0.9 0.7 0.7 1.6 1.3 1.3 0.9 0.9 2.0 2.0 1.3 1.3 0.9 4.0 3.0 3.0 2.0 2.0 2.0 1.3 1.3 0.9 24 24 24 24 24 27 27 27 27 27 35 35 35 35 35 50 50 50 50 50 50 50 50 50 8 8 8 8 8 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 3.0 3.0 3.0 2.5 2.5 4.5 4.0 4.0 4.0 4.0 5.0 5.0 4.0 4.0 4.0 7.0 6.0 6.0 5.0 5.0 5.0 4.0 4.0 4.0 28 28 28 28 28 31 31 31 31 31 – – – – – – – – – – – – – – 8 8 8 8 8 9 9 9 9 9 – – – – – – – – – – – – – – 4.0 4.0 4.0 4.0 4.0 5.5 4.0 4.0 4.0 4.0 – – – – – – – – – – – – – – M2 169 ® ® Cable stripping lengths for multipole connectors (L series) M1 straight plugs and sockets with cable collet, clamping type C (solder or crimp contacts) M3 elbow plugs (90°) with cable collet, clamping type C (solder or crimp contacts) Series 0L L T 1L Type 302 303/304 302 303/304 305 306 302 303/304/305/306 S 2L 307 308/310 Cable stripping lengths (mm) ø contact A (mm) Connector L Solder S T 0.9 0.7 1.3 0.9 0.9 0.7 0.7 1.6 1.3 1.3 0.9 0.9 10.5 10.5 12.5 12.5 12.5 12.5 12.5 18.0 17.0 17.0 16.0 16.0 6 6 7 7 7 7 7 8 8 8 8 8 3.0 2.5 3.0 3.0 3.0 2.5 2.5 4.5 4.0 4.0 4.0 4.0 M1 M3 L Crimp S T 12.0 12.0 14.5 14.5 14.5 14.5 14.5 19.5 17.5 17.5 17.5 17.5 6 6 7 7 7 7 7 8 8 8 8 8 4.0 4.0 4.0 4.0 4.0 4.0 4.0 5.5 4.0 4.0 4.0 4.0 L Solder S T L Crimp S T 23.5 23.5 29.0 29.0 29.0 29.0 29.0 37.5 36.5 36.5 35.5 35.5 6 6 7 7 7 7 7 8 8 8 8 8 3.0 2.5 3.0 3.0 3.0 2.5 2.5 4.5 4.0 4.0 4.0 4.0 25.0 25.0 31.0 31.0 31.0 31.0 31.0 39.0 37.0 37.0 37.0 37.0 6 6 7 7 7 7 7 8 8 8 8 8 4.0 4.0 4.0 4.0 4.0 4.0 4.0 5.5 4.0 4.0 4.0 4.0 Cable stripping lengths for multipole connectors (L series) straight plugs and sockets with oversize cable collet, clamping type K (solder or crimp contacts) Connector Series L Type 302 303/304 T 1L 305 306 302 303/304/305/306 S 2L 307 308/310 170 ø contact A (mm) M2 1.3 0.9 0.9 0.7 0.7 1.6 1.3 1.3 0.9 0.9 Cable stripping lengths (mm) M2 Solder Crimp L S T L S T 26.5 26.5 26.5 26.5 26.5 31.0 30.0 30.0 29.0 29.0 8 8 8 8 8 10 10 10 10 10 3.0 3.0 3.0 2.5 2.5 4.5 4.0 4.0 4.0 4.0 28.5 28.5 28.5 28.5 28.5 32.5 30.5 30.5 30.5 30.5 8 8 8 8 8 10 10 10 10 10 4.0 4.0 4.0 4.0 4.0 5.5 4.0 4.0 4.0 4.0 www.lemo.com ® ® Technical characteristics Outer shell Brass Plastic materials In most cases, LEMO connectors have a brass outer shell which is suitable for most general purpose applications, including civilian and military. The brass outer shells have a chrome nickel-plated surface which ensures very good protection against industrial atmosphere, salt air and most corrosive agents. Some connector model shells can be made of plastic. This solution offers optimum electrical insulating properties particularly suitable for medical applications. Black Polyoxymethylene (POM) is particularly adapted to products of the 00 or S series. Grey or white polysulfone (PSU) and beige PEEK offers excellent mechanical properties and is suitable for gas or vapour sterilization. Some models of the 2B and 3B series are available with an outer shell of cream-coloured polyphenylsulfone (PPSU). We recommend this material particularly for applications where products are to withstand hundreds of vapour sterilization cycles. Alternative protective coatings are available to satisfy other specific environmental conditions: – electrolytic nickel – nickel-gold – nickel-black chrome. After the black chrome treatment, the part is coated with a protective organic film. Stainless steel For applications where there are severe environmental conditions that may rapidly damage the surface finish, we recommend using stainless steel. The AISI 303 stainless steel is a material for general use adapted to most applications requiring a product made entirely of stainless metal. For the nuclear industry where elements are subject to radiation and to vaporous nitric acid, we offer AISI 304 stainless steel. Grade AISI 316L is recommended for medical applications, highly demanding with regard to non-corrosiveness. This material is also used for connector shells soldered by electronic beam onto a device made of the same stainless steel. These parts have no surface treatment. Aluminium alloy The aluminium alloy outer shells find numerous applications where light weight is a predominant factor; such as in the aeronautics and space industries, and for portable and mobile equipment. These materials have high mechanical strength and excellent resistance to corrosion. The shell surface is protected by anodizing which is available in six colours: blue, yellow, black, red, green, and natural. www.lemo.com Bridge plug or plugs with parallel sockets are made of polyamide (PA.6) available in 9 colours: blue, white, grey, yellow, brown, black, red, orange and green. Some elbow socket shells for printed circuits are overmoulded in polyphenilene sulfide (PPS). Other metallic components In general, most metallic components are manufactured in brass. However, bronze or beryllium copper are used where good elasticity is required (for example: earthing crown). Depending on the application, these parts have electrolytic nickel or nickel-gold plating. These parts can also be manufactured in stainless steel. Sealing gasket In general, sealing gaskets are made of silicone rubber MQ/MVQ. However, for vacuumtight sockets and couplers, gaskets are made of fluorosilicone rubber (FPM). Sealing resin An epoxy resin is used to seal both watertight and vacuumtight socket and coupler models. 171 ® ® Materials and Treatments Material (Standard) Component Outer shell, collet nut, conical nut or notched nut and oversized collet Earthing crown Latch sleeve Locking washer Hexagonal or round nut Other metallic components O-ring and gaskets Sealing resin chrome Cu Ni Cr Brass (UNS C 38500) 0.5 Stainless steel (AISI 303, 304 or 316L) Aluminium alloy (AA 6262A or AA 6023) – Aluminium alloy (AA 6262A or AA 6023) POM (Delrin® or Ertacetal®), Polyoxymethylene, black PEEK, Polyether ethercetone, beige PSU (Udel®), Polysulfone, grey or white PPSU (Radel®), Polyphenylsulfone, cream PA.6 (Grilon®), Polyamid PPS (Ryton®), Polyphenilene sulfide, brown – Bronze (UNS C 54400) or special brass – Beryllium Copper (UNS C 17300) Stainless steel (AISI 416 or 316L) 0.5 Special brass Stainless steel (AISI 416 or 316L) Bronze (UNS C 52100) – Brass (UNS C 38500) Stainless steel (AISI 303, 304 or 316L) Aluminium alloy (AA 6262A or AA 6023) Brass (UNS C 38500) – Stainless steel (AISI 303, 304 or 316L) Silicone MQ/MVQ or FPM/FKM (Viton®) Epoxy (Araldite® or Stycast®) Notes: standards for surface treatment are as follows: – chrome-plated: FS QQ-C-320B – nickel-plated: FS QQ-N-290A, or MIL-C-26074C – gold-plated: ISO 4523 – black chrome: MIL-C-14538C with a minimum of 10 µm of lacquer protection 1) anthracite colour (other colours upon request) 2) for FFP, PCP and ERN models of the 0S to 3S series 3) for FFP, PCP and ERN models of the 0S to 3S series and FGG and ENG models of the 1B, 3B and 4B series 3 – – – 3 – – Surface treatment (µm) nickel gold black chr. Notes Cu Ni Cu Ni Au Ni Cr 0.3 0.5 3 0.5 3 without treatment – – 5 – – anodized – – – – – – – 0.5 3 0.5 3 – 0.5 3 0.5 3 without treatment 0.3 0.5 3 0.5 3 without treatment – – 0.5 3 0.5 3 without treatment anodized natural 0.5 3 0.5 3 without treatment – – 0.5 1 2 – – – 1) 2) 3) 4) 4) 5) 6) 1.0 1.0 – – – – 0.5 – – 7) 8) 9) 9) 0.5 – – 10) 10) 0.5 – – 11) 4) 5) 6) 7) 8) 9) 10) for the FGY and ENY models of the 2B and 3B series for bridge plugs of the B series for S and B series elbow sockets for printed circuits gold-plating for unipole types used in 00 series free and fixed sockets and couplers AISI 416 steel is used with shells made of AISI 303 or 304 delivered with free and fixed sockets with aluminium alloy or stainless steel shell 11) FPM/FKM (Viton®) o-ring and gaskets are installed upon special request. However standard for vacuumtight models. Technical characteristics of plastic materials Type Density Tensile strength (at 23°C) Flexurale strength (at 23°C) Dielectric strength Volume resis. at 50% HR and 23°C Surface resistivity Thermal conductivity Comparative tracking index Maxi. continuous service temperature Min. continuous service temperature Max. short-time service temperature Water absorption in 24h at 23°C Radiation resistance Flammability rating Resistance to steam sterilization Standard Units POM ASTM D 792 – 1.4 ASTM D 638/ ISO R527 MPa 70-80 ASTM D 790/ ISO R178 MPA – ASTM D 149/IEC 60243 kV/mm 60 ASTM D 257/IEC 60093 Ω ● cm 1015 ASTM D 257 Ω 1013 ASTM C 177 W/K ● m 0.31 IEC 60112 V CTI 600 UL 746 °C 90 UL 746 °C -50 – °C 140 ASTM D 570/ISO R62A % 0.85 – Gy1) 8x103 ASTM D 635/UL 94 – HB – – bad PEEK 1.3-1.4 92-142 170 19-25 1016 1015 0.25 CTI 150 250 -55 300 0.12 107 V-0/3.2 excel. PSU PPSU PPS PA.6 Silicone 1.24 1.3 1.67 1.14 ~1.2 70 70 121 55 >9 106 91 179 75 – 17-20 15 17 35 18-30 5x1016 – 1016 1015 1014 – – – – – 0.26 – 0.3 – – CTI 150 – CTI 200 CTI 600 – 140 180 220 80 200 -60 -50 -60 -40 -50 160 200 250 150 > 250 0.3 0.37 < 0.05 >3 – 105 – > 107 5x103 105 V-0/4.4 V-0/1.6 V-0/5V V-2 – good excel. excel. bad good FPM Epoxy ~1.9 1.58 > 12 16 – 24 – 15 – 1014 – – – 0.8 – CTI>600 200 80 -20 -20 300 120 – 0.25 8x104 2x106 – V-0/4 good bad Notes: 1) 1 Gy (Gray) = 100 rad ASTM = American Society for Testing Material ISO = International Standards Organisation 172 UL IEC = Underwriters Laboratories = International Electrotechnical Commission www.lemo.com ® ® Mechanical latching characteristics Standard series Fv Force (N) Fv Fd Fa Series 2C 2S 3S 4S 5S 6S 00 0S 1D 1S 9 14 14 15 12 17 20 40 60 70 7 9 11 10 12 11 14 25 40 55 120 140 300 250 400 350 500 650 750 900 Watertight series Fd Force (N) Fv Fd Fa Series 2E 2L 3E 4E 5E 6E 0E 0L 1E 1L 14 14 16 16 20 20 32 65 85 100 9 9 10 10 13 13 25 40 60 75 250 250 300 300 400 400 550 700 800 900 Keyed series Fa Fv: average latching force. Fd: average unmating force with axial pull on the outer shell. Fa: average pull force with axial pull on the collet nut Force (N) Series 00 0B 1B 2B 2G 3B 4B 5B Fv Fd Fa 9 10 14 15 12 17 39 48 7 8 11 12 12 14 38 38 120 250 300 400 400 550 700 800 Keyed watertight series Force (N) Fv Fd Fa Series 0K 1K 2K 3K 4K 5K 14 16 20 32 65 85 9 10 13 25 40 60 250 300 400 550 700 800 Notes: 1N = 0.102 kg. Notes: forces were measured on outer shells not fitted with contacts. Mechanical endurance: 5000 cycles. Mechanical endurance represents the number of cycles after which the latching system is still effective (1 cycle = 1 latching/unlatching at 300 cycles per hour). The values were measured according to the standard IEC 60512-7 test 13a. -30 100 -35 110 500 M 90 200 M -25 50 M 100 M 80 20 M -20 5M 70 10 M -15 2M 60 500 K 1M -10 200 K 50 50 K -5 100 K When selecting a connector, screen or shielding efficiency and low resistance to electric continuity between the cable and the connector should be considered. The design of LEMO connectors with metal shell and earthing crown guarantee optimum shielding efficiency in all applications where electromagnetic compatibility (EMC) is critical. The performance of a connector is measured through shielding efficiency, a value that represents the ratio between the electromagnetic field on the outside and the inside of the shell. Our measurements are carried out according to the IEC 60169-1-3 standard. 40 20 K a) reduce the emission of generated electromagnetic disturbance to a level where radios and telecommunication and other devices can properly function; b) electromagnetic immunity against electromagnetic disturbance so that they can properly function. 0 10 K Electrical and electronic devices are to be designed to ensure the following: Transfer impedance The electromagnetic compatibility of a device can only be ensured by meeting a number of basic rules with the design of the device and by carefully selecting components, cables and connectors. (dB) 30 Shielding efficiency (dBOhm) 5 1G Electromagnetic compatibility (EMC) and shielding efficiency (Hz) Frequency FGG + PHG.1B FGG + PHG.1K The performance of S and B series connectors is comparable to the results of measurements carried out on a pair of FGG + PHG.1B connectors. The performance of E and K series connectors is comparable to the results of measurements carried out on a pair of FGG + PHG.1K connectors. www.lemo.com 173 ® ® Shell electrical continuity: (measured according to IEC 60512-2 test 2f) R1 Values with earthing crown and latch sleeve or inner-sleeve nickelplated. R2 Values with gold-plated earthing crown and nickel-plated latch sleeve or inner sleeve. Test current: 1A A = Ammeter mV = Millivoltmeter G = Generator Standard series A mV G Series R1 (mΩ) R2 (mΩ) Series R1 (mΩ) R2 (mΩ) 00 0S 1D 1S 2C 3.5 2.8 2.5 2.2 – 2.8 1.6 1.1 1.5 – 2S 3S 4S 5S 6S 1.8 1.6 1.4 1.4 1.0 1.2 1.2 1.0 1.0 0.5 Series R1 (mΩ) R2 (mΩ) Series R1 (mΩ) R2 (mΩ) 00 0B 1B 2B 3.5 3.5 2.5 2.2 2.8 1.3 1.1 0.9 2G 3B 4B 5B – 2.2 1.5 1.5 – 0.7 0.5 0.3 Series R1 (mΩ) R2 (mΩ) 0E-0K-0L 1E-1K-1L 2E-2K-2L 3E-3K 4E-4K 5E-5K 6E 2.8 2.2 1.8 1.6 1.4 1.4 1.0 1.6 1.5 1.2 1.2 1.0 1.0 0.5 Keyed series A mV G Watertight series Keyed watertight series A 174 mV G www.lemo.com ® ® Insulator Plastic material used by LEMO for manufacturing insulators is selected according to the electric and thermal properties required for the various connector types. Characteristics examined for the two connector types are: – Dielectric strength; – Comparative tracking index; – Surface and volume resistivity; – Continuous service temperature; – Water absorption; – Radiation resistance; – Flammability rating – Resistance to hydrocarbon. Radiation resistance PA 6.6 PEEK PTFE FEP PI 103 rads Gray (Gy) 101 104 102 105 103 106 104 107 105 108 106 Mechanical and Electrical Properties Mechanical characteristics of thermoplastics, such as PA 6.6, and PEEK, are improved by the addition of glass fibres. By adding glass fibres in the resin the performance of this material (mechanical strength and radiation resistance) is enhanced and water absorption rate is reduced. From an electric point of view, the addition of glass fibres improves dielectric strength. Selection of the insulator A number of thermoplastics have common characteristics, some of them are identical with other insulating materials. In this case, the insulator material is selected according to the specific difference in features to provide all the required parameters for the given type. Damage 109 1010 7 10 108 Radiation dose γ Minimum to slight (almost available usable) Slight to medium (often satisfactory) Medium to serious (not usable) Note: technical data in this chapter provide general information on plastics used by LEMO as electrical insulators. LEMO reserves the right to propose new materials with better technical characteristics, and to withdraw, without notice, any material mentioned in the present catalogue or any other publications edited by LEMO S.A. and/or its subsidiaries. LEMO SA and its subsidiaries use only plastic granules, powder or bars supplied by specialized companies, and thus cannot in any case take responsibility with regard to this material. Technical characteristics Type Standard Dielectric strength Volume resistivity at 50% RH and 23°C Surface resistivity Thermal conductivity Comparative tracking index Dielectric constant (106 Hz) Dissipation factor (106 Hz) Maximum continuous service temperature Maximum short-time service temperature Minimum continuous service temperature Water absorption in 24h at 23°C Radiation resistance Flammability rating ASTM D 149 / IEC 60243 ASTM D 257 / IEC 60093 ASTM D 257 / IEC 60093 ASTM C 177 IEC 60112 ASTM D 150 / IEC 60250 ASTM D 150 / IEC 60250 UL 746 – – ASTM D 570 / ISO R624 – ASTM D 635 / UL 94 Units PA6.6 PEEK PTFE FEP PI kV/mm Ω ● cm Ω W/K ● m V – – °C °C °C % Gy – 15-17 5.8x1015 1012 0.21 CTI 600 4 – 120 150 – < 0.7 5x103 – 19-25 1016 1015 0.25 CTI 150 3.2-3.5 < 0.005 250 300 -55 < 0.3 107 V-0/3.2 17.2-24 1018 1017 0.23 CTI 500 2-2.1 < 0.0003 260 300 -200 < 0.01 2x102 V-0 20 > 1016 > 1016 0.24 – 2.1 < 0.001 200 260 -200 < 0.01 2x104 V-0 22 > 1016 > 1015 0.35 – 3.6 < 0.0034 350 480 – 0.24 106 – Note: values of insulation resistance between contacts are given on page 177. Designation chemical Polyamide (glass fitted) Polyether Ethercetone Polytetrafluorethylene Tetrafluorethylene Polyimide commercial Nylatron® Peek® – – Vespel® Symbol PA 6.6 PEEK PTFE FEP PI Standard – – ASTM D 1457-83 ASTM D 2116-81 – 00 ● ● Unipole S E ● ● ● ● 00 S E Multipole B K 2C 2G 1D ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● First choice alternative ● Special order alternative www.lemo.com 175 ® ® Electrical contact Technical description The secure reliable electromechanical connection achieved with LEMO female cylindrical contacts is mainly due to two important design features : 1. Prod proof entry on the mating side which ensures perfect concentric mating even with carelessly handled connectors. 2. The pressure spring, with good elasticity, maintains a constant even force on the male contact when mated. The leading edge of the pressure spring preserves the surface treatment (gold-plated) and prevents undue wear. Contact material and treatment LEMO female contacts are made of bronze beryllium (QQC-530) or bronze (UNS C 54400). These materials are chosen because of their high modulus of elasticity, their excellent electrical conductivity and a high mechanical strength. LEMO male solder and print contacts are made of brass (UNS C 38500). Male crimp contacts are made of brass (UNS C 34500) or annealed brass (UNS C 38500) with optimum hardness (HV) for crimping onto the wire. Type Au Ni Cu Male crimp Bronze or brass Material (standard) Surf. treatment (µm) Cu Ni Au1) 0.5 3 1.0 Male print Brass (UNS C 34500) Brass (UNS C 38500) Brass (UNS C 38500) Female crimp Female print Bronze (UNS C 54400) Cu-Be (FS QQ-C-530) 0.5 3 1.5 Clips Cu-Be (FS QQ-C-530) Stainless steel – – – Wire2) Brass – 33) – Notes: the standard surface treatment are as follows: – nickel: FS QQ-N-290A or MIL-C-26074C – gold: ISO 4523. 1) minimum value 2) for elbow print contacts 3) treatment completed by 6 µm Sn (lead free) tin-plating Thickness comparison between the outside and the inside of female contacts P 2.5 P 2.5 Note: P = inspection point Gold thickness female Contact øA (mm) male (µm) 0.5 0.7 0.9 1.3 1.6 2.0 3.0 4.0 5.0 6.0 8.0 12.01) 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 – outside (µm) inside (%) 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 – 65 70 75 75 75 75 75 75 75 75 75 – Notes: 1) contacts are silver plated 176 www.lemo.com ® Contact resistance with relation to the number of mating cyles (measured according to IEC 60512-2 test 2a) ® Insulation resistance between the contacts and contact/shell (measured according to IEC 60512-2 test 3a) Average values measured after the mating cycles and the salt spray test according to IEC 60512-6 test 11f. Aø (mm) 0.5 0.7 0.9 1.3 1.6 2.0 Contact resistance (mΩ) 1000 3000 5000 cycles cycles cycles 7.5 5.6 4.1 2.8 2.6 2.9 8.3 5.7 4.2 2.9 2.7 3.1 8.7 6.1 4.8 3.6 3.5 3.3 Aø (mm) 3.0 4.0 5.0 6.0 8.0 12.0 Contact resistance (mΩ) 1000 3000 5000 cycles cycles cycles 2.0 1.6 1.4 1.2 0.8 0.7 2.2 2.0 – – – – 3.1 2.8 – – – – Insulating material new after humidity test1) Multipole PEEK Unipole PTFE > 1012 Ω > 1010 Ω > 1012 Ω > 1010 Ω Note: 1) 21 days at 95% RH according to IEC 60068-2-3. Solder contacts The conductor bucket of these contacts is machined at an angle to form a cup into which the solder can flow. See page 7 for the range of cable dimensions that can be soldered. Crimp contacts Advantages of crimping The square form crimp method is used (MIL-C-22520F, class I, type 2) photo 1 for unipole contacts. – practical, quick contact fixing outside the insulator – possible use at high temperature – no risk of heating the insulator during the conductorcontact fixing – high tensile strength For multipole contacts the standard four identer crimp method is used, MIL-C-22520F, class I, type 1), photo 2. The crimp method requires a controlled compression to obtain a symmetrical deformation of the conductor strand and of the contact material. The radial hole in the side of the contact makes it possible to check whether the conductor is correctly positioned within the contact. A good crimping is characterized by only slightly reduced conductor section and practically no gap. For optimum crimping of bronze or brass contacts they are annealed to relieve internal stress and reduce material hardening during the crimping process. Only the crimping zone is annealed with the help of an induction heating machine designed by the LEMO Research and Development Department (see photo 3). Crimp contacts are available in standard version (form 1) for mounting maximum size conductors. For some dimensions, these crimp contacts can be produced with reduced crimp barrels (form 2) for mounting reduced size conductors. 1 2 3 Crimp contacts The crimp contacts can be with two forms: a standard crimp barrel for large conductors (see fig. 1) or with a reduced crimp barrel for smaller conductors (see fig. 2). Fig. 1 www.lemo.com The range of cable dimensions that can be crimped into our contacts are indicated on the table on page 7. Fig. 2 177 ® ® Print contacts Print contacts are available in straight or elbow versions for certain connector types, mostly for straight and elbow socket models. Connection is made on flexible or rigid printed circuits by soldering. Straight print contacts are gold-plated which guarantees optimum soldering, even after long-term storage. However straight for wave soldering, we recommend removal the gold-plating from the contact end on the printed circuit side before soldering according to the assembly procedures. Print elbow contacts include a tinned lead free brass wire crimped into a crimp contact. elbow Test voltage Test voltage (Ue) : (measured according to the IEC 60512-2 test 4a standard) It corresponds to 75% of the mean breakdown voltage. Test voltage is applied at 500 V/s and the test duration is 1 minute. This test has been carried out with a mated plug and socket, with power supply only on the plug end. Operating voltage (Us) : It is proposed according to the following ratio : Us = Ue 3 Caution: For a number of applications, safety requirements for electrical appliances are more severe with regard to operating voltage. In such cases operating voltage is defined according to creepage distance and air clearance) between live parts. Please consult us for the choice of a connector by indicating the safety standard to be met by the product. Voltage values are given in the table on insulator types for each series. They correspond with values measured at sea level. They are adapted to all applications up to an altitude of 2000 m. In case a device is used at a higher altitude, air clearance between live parts has to be multiplied by the following coefficients. It means also that test voltage has to be divided by this coefficient. altitude (m) coefficient 2000 3000 4000 5000 1.00 1.14 1.29 1.48 Rated current The current values are indicated in the table of insulator types in each series. For use at higher temperatures acceptable rated current will be lower. It tends towards zero as the material is used at the maximum operating temperature accepted for the insulator. In most case the current depend on the conductor dimension (see table on page 183) or on the printed circuit dimension. Rated current (A) 100% 75% 50% 25% for the insulator The specified rated current can be applied simultaneously to all the contacts. It corresponds with an average temperature rise of 40°C of the connector. For connectors with PEEK insulator, maximum admissible current will follow the curve below depending on the operating temperature T. Maximum operating temperature (measured according to IEC 60512-3 test 5a) T (°C) Caution: In general, connectors should not be unmated while live. 178 0 50 100 150 200 250 www.lemo.com ® ® Cable fixing Cables are fixed into LEMO connectors with cable collet systems. These collets with latches have a design which is very similar to those used for tool machines. This solution guarantees excellent cable retention and ensures perfectly symmetrical deformation of the cable. The 00 multipole series is also available with hexagonal crimping (MIL-C-22520F). Material and treatment Component Material (standard) Center piece Collet Crimp ferrule Reducer Reducing cone Earthing cone Metal washer Brass (UNS C 38500) Brass (UNS C 38500) Copper (UNS C 18700) Brass (UNS C 38500) Brass (UNS C 38500) Brass (UNS C 38500) Brass (UNS C 38500) Gasket Silicone MQ/MVQ FPM (Viton®)2) Surface treatment (µm) Gold Nickel1) Cu Ni Cu Ni Au 0.5 0.5 0.5 0.5 0.5 0.5 0.5 3 3 3 3 3 3 3 – – 0.5 – – – – – – 3 – – – – – – 0.5 – – – – Notes: 1) standards for surface treatment are as follows: – nickel-plated: FS QQ-N-290A. 2) available upon special request. – Cable clamping system B series (D and M cable clamping) See assembly instructions under www.lemo.com. 6 7 5 Type D 1 3 7 6 5 4 3 Type M 9 7 6 5 2 1 Plug and socket ➀ collet nut ➁ reducing cone ➂ collet ➃ reducer ➄ split insert carriers ➅ insulator + contacts ➆ housing subassy. Elbow plug ➀ collet nut ➁ reducing cone ➂ collet ➃ reducer ➄ elbow outlet ➅ insert carrier ➆ insulator + contacts ➇ housing subassy. ➈ hex cap 8 www.lemo.com 179 ® ® K series (C and K cable clamping) See assembly instructions under www.lemo.com. 8 7 6 1 8 7 Type C 5 4 3 2 1 6 10 8 9 7 1 Type K 8 6 7 5 4 3 Plug and socket ➀ collet nut ➁ collet ➂ metal washer ➃ flexible gasket ➄ earthing cone ➅ split insert carriers ➆ insulator + contacts ➇ housing subassy. 2 1 Elbow plug ➀ collet nut ➁ collet ➂ metal washer ➃ flexible gasket ➄ earthing cone ➅ split insert carrier ➆ elbow inner shell ➇ insulator + contacts ➈ hex cap ➉ housing subassy. Plug and socket ➀ collet nut ➁ collet ➂ metal washer ➃ flexible gasket ➄ earthing cone ➅ split centre-pieces ➆ insulator + contacts ➇ housing subassy. w. oversized back S series (C, L and K cable clamping) See assembly instructions under www.lemo.com. 1 2 3 4 5 Type K 1 6 5 F ●● 2 Type L 1 5 6 3 1 2 5 Type C 4 P ●● 6 7 5 6 Plug and socket ➀ collet nut ➁ collet ➂ oversize collet housing (type K) ➂ earthing centre-piece (type C) ➃ split centre-pieces (type K and C) ➄ insulator + contacts ➅ housing subassy. 4 Elbow plug ➀ collet nut ➁ collet ➃ threaded sleeve ➄ bracket ➅ insulator + contacts ➆ insulating sleeve ➇ housing subassy. 8 FLA 180 www.lemo.com ® ® E series (C and K cable clamping) See assembly instructions under www.lemo.com. 8 1 Type K 9 4 5 6 7 Plug and socket ➀ collet nut ➁ collet ➂ metal washer ➃ flexible gasket ➄ earthing cone ➅ split centre-pieces (type K) ➅ earthing centre-piece (type C) ➆ oversize collet housing (type K) ➆ earthing centre-piece (type C) ➇ insulator + contacts ➈ housing subassy. 2 3 8 1 6 8 9 7 8 1 Type C 5 4 3 2 Elbow plug ➀ collet nut ➁ collet ➂ metal washer ➃ flexible gasket ➄ earthing cone ➅ split insert carrier ➆ elbow inner shell ➇ insulator + contacts ➈ hex cap ➉ housing subassy. 6 10 8 9 7 1 FLA Maximum metal collet nut tightening torque Standard series 0S 1D 1S Series 2C 2S 0.25 0.5 1.5 1.5 2.5 00 Torque (Nm) Watertight series 2.5 3S 4S 5S 6S 6 8 10 12 Keyed series 0L 1E 1L 0.7 0.7 0.8 0.8 2 2 4K 5K 5 8 3E 4E 5E 6E 3 5 8 12 Watertight keyed series 00 Torque (Nm) Torque (Nm) Series 2E 2L 0E 0B 0.25 0.5 1B 1.5 Series 2B 2G 2.5 2.5 3B 4 4B 7 5B Torque (Nm) 10 0K 1K Series 2K 3K 0.7 0.8 2 3 0E 0L 1E 1L 0.8 0.8 1 1 1.2 1.2 Series 2K 3K 4K 5K 3 5 1N = 0.102 kg Maximum elbow plug hex cap tightening torque Watertight series Keyed series 00 Torque (Nm) 0.3 0B 0.6 1B 1 Series 2B 3B 1 1.5 4B 3 5B Torque (Nm) 5 Series 2E 2L 3E 4E 5E 1.5 3 5 Watertight keyed series Torque (Nm) 0K 1K 0.8 1 1.2 1.5 1N = 0.102 kg Maximum plastic collet nut tightening torque 1) 00 Torque (Nm) www.lemo.com 0S 1S 2S Series 3S 1B 2B 3B 4B 0.15 0.45 0.50 0.50 1.00 0.50 0.50 1.00 1.50 Note: For applications subject to strong vibration, we recommend fixing the collet nut with epoxy resin. We recommend to tight to the maximum value. Optimal torque may depend on cable jacket design. 1) 181 ® ® Technical tables Table of American Wire Gauge Construction AWG 0 1 2 4 6 8 8 10 10 10 12 12 12 1) 12 14 14 14 1) 14 16 1) 16 16 16 1) 16 18 1) 18 1) 18 18 18 18 20 1) 20 20 20 20 22 22 22 24 1) 24 24 24 26 26 26 28 1) 28 28 30 30 32 32 34 36 38 40 182 Table of wire gauges according to IEC-60228 standard ø wire max Wire section Strand nb AWG/ strand (mm) (in) (mm2) (sq in) 259 817 259 133 133 168 133 105 37 1 37 19 7 1 41 19 7 1 65 26 19 7 1 65 42 19 16 7 1 42 19 10 7 1 19 7 1 42 19 7 1 19 7 1 19 7 1 7 1 7 1 1 1 1 1 24 30 26 25 27 30 29 30 26 10 28 25 20 12 30 27 22 14 34 30 29 24 16 36 34 30 30 26 18 36 32 30 28 20 34 30 22 40 36 32 24 38 34 26 40 36 28 38 30 40 32 34 36 38 40 11.277 9.702 8.89 6.9596 5.5118 4.4450 4.3942 3.3020 2.9210 2.6162 2.3114 2.3622 2.5400 2.0828 2.0574 1.8542 2.0828 1.6510 1.5748 1.5748 1.4986 1.5494 1.3208 1.2700 1.2700 1.3208 1.2954 1.2700 1.0414 1.0160 1.0414 1.0160 0.9906 0.8382 0.8382 0.7874 0.6604 0.6604 0.6858 0.6350 0.5588 0.5588 0.5080 0.4318 0.4318 0.4064 0.3302 0.3302 0.2794 0.2794 0.2286 0.1693 0.127 0.1016 0.078 0.444 0.382 0.35 0.274 0.217 0.175 0.173 0.13 0.115 0.103 0.091 0.093 0.10 0.082 0.081 0.073 0.082 0.065 0.062 0.062 0.059 0.061 0.052 0.05 0.05 0.052 0.051 0.05 0.041 0.04 0.041 0.04 0.039 0.033 0.033 0.031 0.026 0.026 0.027 0.025 0.022 0.022 0.02 0.017 0.017 0.016 0.013 0.013 0.011 0.011 0.009 0.007 0.005 0.004 0.003 52.90 41.40 33.20 21.5925 13.5885 8.5127 8.6053 5.3204 4.7397 5.2614 2.9765 3.0847 3.6321 3.3081 2.0775 1.9413 2.2704 2.0820 1.3072 1.3174 1.2293 1.4330 1.3076 0.8234 0.8447 0.9627 0.8107 0.8967 0.8229 0.5320 0.6162 0.5067 0.5631 0.5189 0.3821 0.3547 0.3243 0.2045 0.2407 0.2270 0.2047 0.1540 0.1408 0.1281 0.0925 0.0887 0.0804 0.0568 0.0507 0.0341 0.0324 0.0201 0.0127 0.0081 0.0049 0.0820 0.0641 0.0514 0.0335 0.0211 0.0132 0.0133 0.0082 0.0073 0.0082 0.0046 0.0048 0.0056 0.0051 0.0032 0.0030 0.0035 0.0032 0.0020 0.0020 0.0019 0.0022 0.0020 0.0013 0.0013 0.0015 0.0013 0.0014 0.0013 8.2x10-4 0.0010 7.9x10-4 8.7x10-4 8.0x10-4 5.9x10-4 5.5x10-4 5.0x10-4 3.2x10-4 3.7x10-4 3.5x10-4 3.2x10-4 2.4x10-4 2.2x10-4 2.0x10-4 1.4x10-4 1.4x10-4 1.2x10-4 8.8x10-5 7.9x10-5 5.3x10-5 5.0x10-5 3.1x10-5 2.0x10-5 1.3x10-5 7.5x10-6 Conductor no x Ø (mm) 196x0.40 7x2.14 125x0.40 7x1.72 1x4.50 80x0.40 7x1.38 1x3.60 84x0.30 7x1.50 1x2.76 56x0.30 7x0.86 1x2.25 50x0.25 7x0.68 1x1.78 30x0.25 7x0.52 1x1.4 32x0.20 7x0.43 1x1.15 42x0.15 28x0.20 1x1.0 28x0.15 16x0.20 1x0.80 7x0.25 1x0.60 14x0.15 7x0.20 18x0.10 14x0.10 21x0.07 14x0.10 Max Ø (mm) Max Ø (in) Section (mm2) Section (sq in) 7.50 6.10 6.00 4.90 4.50 4.70 3.95 3.60 3.70 3.15 2.76 2.80 2.58 2.25 2.15 2.04 1.78 1.60 1.56 1.40 1.35 1.29 1.15 1.20 1.15 1.00 0.95 0.90 0.80 0.75 0.60 0.75 0.65 0.50 0.40 0.40 0.40 0.295 0.240 0.236 0.192 0.177 0.155 0.155 0.141 0.145 0.124 0.108 0.110 0.098 0.082 0.084 0.080 0.070 0.062 0.061 0.055 0.053 0.050 0.045 0.047 0.045 0.039 0.037 0.035 0.031 0.029 0.023 0.029 0.023 0.019 0.015 0.015 0.015 25.00 25.00 16.00 16.00 16.00 10.00 10.00 10.00 6.00 6.00 6.00 4.00 4.00 4.00 2.50 2.50 2.50 1.50 1.50 1.50 1.00 1.00 1.00 0.75 0.75 0.75 0.50 0.50 0.50 0.34 0.28 0.25 0.22 0.14 0.11 0.09 0.09 0.0387 0.0387 0.0248 0.0248 0.0248 0.0155 0.0155 0.0155 0.0093 0.0093 0.0093 0.0062 0.0062 0.0062 0.0038 0.0038 0.0038 0.0023 0.0023 0.0023 0.0015 0.0015 0.0015 0.0011 0.0011 0.0011 7.7x10-4 7.7x10-4 7.7x10-4 5.2x10-4 4.3x10-4 3.8x10-4 3.4x10-4 2.1x10-4 1.7x10-4 1.3x10-4 1.3x10-4 Note: 1) not included in the standard www.lemo.com ® ® Maximum current rating for conductor Maximum current on insulated conductors up to an ambiant temperature of 30° C (from VDE 0100, parts 430 and 532 as well as other VDE regulations). Nominal section mm2 Group 2 Intens. max. A Group 3 Intens. max. A 0.08 0.14 0.25 0.34 0.50 0.75 1.00 1.50 2.50 1.0 2.0 4.0 6.0 9.0 12.0 15.0 18.0 26.0 1.5 3.0 5.0 8.0 12.0 15.0 19.0 24.0 32.0 Group 2 Multi-conductor, e. g. solid cable under sheath, shielded cable, lead-sheath cables, … Group 3 Single conductor and single conductor cable laid on open air in a way to leave at least a space between them equal to their diameter Some formulae Resistance R of a conductor: R = ρ Impedance of coaxial line: Z = ● l [Ω] A Where: ρ = conductor resistivity l = conductor length A = conductor cross-section D 138 log [Ω] √εr d εr = dielectric constant D = dielectric outer diameter d = center conductor outer diameter ● Signal attenuation: Attenuation = 20 log ● U1 [dB] U2 U1 = input signal voltage U2 = output signal voltage Conversion of some units: millimeters into inches: 1 mm = 0.0394 in inches into millimeters: 1 in = 25.4 mm centimeters into feet: 1 cm = 0.0328 ft feet (12 in) into centimeters: 1 ft = 30.48 cm square centimeters into square inches: 1 cm2 = 0.155 sq in square inches into square centimeters: 1 sq in = 6.4516 cm2 bar into pounds per square inch: 1 bar = 14.51 psi bar into Pascal: 1 bar = 105 Pa °C into °F: °F = °C 1.8 + 32 ● newtonmeter (Nm) into inch pound (in lb) ● mbar l s-1 into Torr l s-1 ● ● www.lemo.com ● ● 1 Nm = 8.85 in lb ● 1 mbar l s-1 = 1.33 Torr l s-1 ● ● ● ● 183 ® ® Product safety notice PLEASE READ AND FOLLOW ALL INSTUCTIONS CAREFULLY AND CONSULT ALL RELEVENT NATIONAL AND INTERNATIONAL SAFETY REGULATIONS FOR YOUR APPLICATION. IMPROPER HANDLING, CABLE ASSEMBLY, OR WRONG USE OF CONNECTORS CAN RESULT IN HAZARDOUS SITUATIONS. 1. SHOCK AND FIRE HAZARD Incorrect wiring, the use of damaged components, presence of foreign objects (such as metal debris), and / or residue (such as cleaning fluids), can result in short circuits, overheating, and / or risk of electric shock. Mated components should never be disconnected while live as this may result in an exposed electric arc and local overheating, resulting in possible damage to components. 2. HANDLING Connectors and their components should be visually inspected for damage prior to installation and assembly. Suspect components should be rejected or returned to the factory for verification. Connector assembly and installation should only be carried out by properly trained personnel. Proper tools must be used during installation and / or assembly in order to obtain safe and reliable performance. 3. USE Connectors with exposed contacts should never be live (or on the current supply side of a circuit). Under general conditions voltages above 30 VAC and 42 VDC are considered hazardous and proper measures should be taken to eliminate all risk of transmission of such voltages to any exposed metal part of the connector. 4. TEST AND OPERATING VOLTAGES The maximum admissible operating voltage depends upon the national or international standards in force for the application in question. Air and creepage distances impact the operating voltage; reference values are indicated in the catalog however these may be influenced by PC board design and / or wiring harnesses. The test voltage indicated in the catalog is 75% of the mean breakdown voltage; the test is applied at 500 V/s and the test duration is 1 minute. 5. CE MARKING CE Marking is applied to a complete product or device, and implies that the device complies with one or several European safety directives. CE Marking can not be applied to electromechanical components such as connectors. 6. PRODUCT IMPROVEMENTS The LEMO Group reserves the right to modify and improve to our products or specifications without providing prior notification. 184 www.lemo.com
FH*.0B.304.CLAD42 价格&库存
很抱歉,暂时无法提供与“FH*.0B.304.CLAD42”相匹配的价格&库存,您可以联系我们找货
