RT0603P-101-M
RT0603P-101-M
    SUSUMU
    贴片电阻 0201 100Ω ±20% 1/20W ±25ppm/℃
RT0603P-101-M 数据手册
Metal thin film trimmable chip resistors ■RT series AEC-Q200 Compliant Features ・ Patented trimming method (Patent# 1921853)guarantees precision trimming, post trimming stability and short trimming time. Thin film surface mount resistors ・ Available as small as 0.3mm x 0.6mm Applications ・ Sensor circuits that require accuracy (e.g. automotive electronics) ・ PA module of mobile phone ・ Devices that requires anti-vibration stability (e.g. microphone) RT series ◆Part numbering system RT 0816 P - 102 - M Series code Resistance tolerance Size: RT0603, RT0510, RT0816, RT1220 Nominal resistance value Temperature coefficient of resistance ◆Electrical Specification Type Temperature coefficient of resistance Power ratings (ppm/°C) Targetted resistance value (Ω) ±25(P) RT0603 1/20W ±100(R) ±25(P) RT0510 1/16W ±100(R) ±25(P) RT0816 1/16W ±25(P) 1/10W ±50(Q) ±100(R) Maximum voltage Operating temperature Packaging quantity (%) 150 330 - - 1.0k 1.9k - - 1.5k - - - 10k - - - 100 270 - - 820 2.1k - - 1.5k - - - 10k - - - 100 330 1.0k - 2.7k 8.0k 8.8k - - 3.3k 10k -- - 37k 40k - ±100(R) RT1220 Initial resisstance value tolerance Initial resistance value (Ω) 100 330 1.0k - 8.2k 15k 15k - 33 - - - 4.7k - - - 3.3k 10k 33k 100k 100k 120k 120k 220k 15V 15,000pcs 25V 10,000pcs ±20(M) -55℃ ~ 125℃ 75V 5,000pcs 100V 5,000pcs ◆Dimensions L W a t b Type Size (inch) L W a b t RT0603 0201 0.60±0.05 0.30±0.03 0.12±0.05 0.15±0.05 0.25±0.03 RT0510 0402 1.00±0.07 0.50±0.07 0.20±0.10 0.25±0.20 0.35±0.05 RT0816 0603 1.60±0.20 0.80±0.20 0.30±0.20 0.30±0.20 0.40±0.10 RT1220 0805 2.00±0.20 1.25±0.20 0.40±0.20 0.40±0.20 0.40±0.10 (unit:mm) 34
RT0603P-101-M 价格&库存
很抱歉,暂时无法提供与“RT0603P-101-M”相匹配的价格&库存,您可以联系我们找货
