KRL3216T4A-M-R001-G-T1
    SUSUMU
    贴片电阻 1206 1MΩ ±2% 1W ±150ppm/℃
KRL3216T4A-M-R001-G-T1 数据手册
Metal foil low resistance chip resistors (4 terminal type) ■KRL series AEC-Q200 Compliant Features ・ Separated voltage terminal for precise measurement of voltage ・ TCR stable at very low resistance: 4mΩ:±50ppm/°C ・ Power ratings: 1W ~ 5W Applications ・ Smartphones, mobile telephones, PCs, HDD, audio visual equipment, power devices, inverters. ・ automotive electronics, industrial measurement instrumentation/equipment. ◆Part numbering system KRL 3216T4 - M - R010 - F - T1 (KRL 3216T4A - M - R010 - F - T1) Series code Packaging quantity: T1(1,000pcs), T5(5,000pcs) KRL series Current sensing surface mount resistors Size: KRL3216T4, KRL6432T4, KRL7638T4 KRL9045T4, KRL11050T4, Resistance tolerance Temperature characteristics type: M (low EMF) Nominal resistance value ◆Electrical Specification Type Power ratings Temperature coefficient of resistance (ppm/°C) *1 Resistance range(Ω) Resistance tolerance ±1% (F) ±2% (G) ±5% (J) ー ー R=2m R=1m ー ー R=2m R=1m Resistance Operating value series temperature Packaging quantity 4m≦R≦9m KRL3216T4 (KRL3216T4A) 1W ±50 (1m step) (±35) 10m≦R≦100m R=200m, 500m ±100(±75) R=3m 4m≦R≦9m KRL6432T4 2W ±50 (1m step) 10m≦R≦100m R=200m, 500m ±100 R=3m T1 4m≦R≦9m KRL7638T4 3W ±50 (1m step) 10m≦R≦100m T5 ー ー R=200m, 500m ±100 R=3m R=2m R=1m ー ー R=2m R=1m ー ー R=2m R=1m *2 E6 -55℃ ~ 155℃ (Code M) 4m≦R≦9m KRL9045T4 4W ±50 (1m step) 10m≦R≦100m R=200m, 500m ±100 R=3m 4m≦R≦9m KRL11050T4 5W ±50 (1m step) 10m≦R≦100m R=200m, 500m ±100 *1 *2 R=3m We can meet your requirement of less than 1mΩ. Please contact our sales office. We can meet your requirement of resistance value outside of E-6 series. Please contact our sales office. 57 T1 ◆Dimensions L t b c W d a Size Type (inch) L W a b c d t KRL3216T4 1206 1.60±0.20 3.20±0.20 0.35±0.20 0.35±0.15 0.20±0.10 2.65±0.15 0.50±0.20 KRL3216T4A 1206 1.60±0.20 3.20±0.20 0.45±0.20 0.50±0.20 0.50±0.20 2.20±0.20 0.50±0.20 KRL6432T4 2512 3.20±0.20 6.40±0.20 0.50±0.20 0.70±0.15 0.50±0.10 5.20±0.15 0.50±0.20 KRL7638T4 3015 3.80±0.20 7.60±0.20 0.55±0.20 0.80±0.20 0.60±0.20 6.20±0.10 0.50±0.20 KRL9045T4 3518 4.50±0.20 9.00±0.20 0.50±0.20 0.70±0.20 0.50±0.20 5.20±0.10 0.50±0.20 KRL11050T4 4320 5.00±0.20 11.0±0.20 0.70±0.20 1.40±0.20 1.10±0.20 8.50±0.10 0.50±0.20 (unit:mm) ◆Circuit diagram V V I I V Voltage terminal I Current terminal Current sensing surface mount resistors Ratio to rated power (%) ◆Derating Curve 100 50 0 -55    0    50 100 155 Ambient temperature (℃) KRL series 58
物料型号:KRL系列,包括KRL3216T4、KRL6432T4、KRL7638T4、KRL9045T4和KRL11050T4。
器件简介:这些是金属箔低电阻芯片电阻器,符合AEC-Q200标准,适用于电流检测。
引脚分配:文档中没有明确提供引脚分配图,但提到了电流端子I和电压端子V。
参数特性: - 分离的电压端子,用于精确测量电压。 - 在极低电阻下TCR稳定:4mΩ ±50ppm/°C。 - 功率等级:1W至5W。
功能详解:这些电阻器适用于智能手机、移动电话、个人电脑、硬盘驱动器、音视频设备、功率器件、逆变器、汽车电子、工业测量仪器/设备。
应用信息:适用于多种电子设备,包括消费电子和工业应用。
封装信息:提供了不同尺寸的封装信息,包括尺寸、长度、宽度、公差等详细数据。
KRL3216T4A-M-R001-G-T1 价格&库存
很抱歉,暂时无法提供与“KRL3216T4A-M-R001-G-T1”相匹配的价格&库存,您可以联系我们找货
  • 1000+3.149551000+0.37964
  • 2000+3.078542000+0.37108
  • 5000+3.019345000+0.36394
  • 10000+2.9482810000+0.35538
  • 25000+2.8739225000+0.34641
库存:4772
