KRL1220E-M-R180-F-T5
    SUSUMU
    贴片电阻 0805 180mΩ ±1% 1/2W ±50ppm/℃
KRL1220E-M-R180-F-T5 数据手册
Metal foil low resistance chip resistors (short-side terminal) ■KRL series AEC-Q200 Compliant Features ・ High current sensing short side terminal low resistance chip resistor ・ Two types available: high temperature (operating temperature up to 175°C), low emf type ( operating temperature up to 155°C). ・ High current handling capability and wide range of power ratings ・ Size: 0510 ~ 50110, power ratings: 0.2W ~ 5W, resistance value range: 5m ~ 1000mΩ ・ Face down construction. Choice between bottom only or wrap around terminal Applications ・ Automotive electronics ・ Power source devises, ACDC converters, DCDC converters ・ Motors, inverters, office automation equipment ◆Part numbering system KRL 1220E - C - R010 - F - T1 Series code Resistance tolerance Current sensing surface mount resistors Size: KRL0510, KRL0816, KRL1220, KRL1632 KRL2550, KRL3264, KRL50110 KRL series Packaging quantity: T1(1,000pcs), T5(5,000pcs) Nominal resistance value Temperature characteristics type: C (high operating temperature ), M (low EMF) Terminal type: D (bottom terminal), E (wrap around terminal) ◆Electrical Specification Type Power ratings Temperature coefficient of resistance (ppm/°C) *1 Resistance range(Ω) Resistance tolerance ±1% (F) Resistance value series Operating temperature C ±2% (G) Packaging quantity M ±50 KRL0510 0.2W KRL0816 0.3W KRL1220 0.5W KRL1632 0.75W KRL2550 1.5W KRL3264 3W KRL50110 5W *1 *2 10,000pcs 50m≦R≦100m ±100 ±50 10m≦R≦500m ー ±100 ー 5m≦R≦9m(1m step) ±50 10m≦R≦500m ー ±100 ー 5m≦R≦9m(1m step) ±50 10m≦R≦500m ー ±100 ー 5m≦R≦9m(1m step) ±50 10m≦R≦500m ー ±100 ー 5m≦R≦9m(1m step) ±50 10m≦R≦1000m ー ±100 ー 5m≦R≦9m(1m step) ±50 10m≦R≦1000m ー ±100 ー 5m≦R≦9m(1m step) We can meet your requirement for resistance value not specified in above table. Please contact our sales office. We can meet your requirement outside of E-6/E-12 series resistance. Please contact our sales office. 55 *2 E-6 / E-12 -55℃ ~ 175℃ -55℃ ~ 155℃ T1 T5 T1 ◆Dimensions L Size Type W (inch) L W t a KRL0510 0402 1.00±0.20 0.50±0.20 0.40±0.20 0.30±0.20 KRL0816 0603 1.60±0.20 0.80±0.20 0.50±0.20 0.30±0.15(48mΩ~)/0.55±0.15(20~39mΩ) 0.70±0.15(10~18mΩ) KRL1220 0805 2.00±0.20 1.25±0.20 0.50±0.20 0.40±0.20 KRL1632 1206 3.20±0.20 1.60±0.20 0.50±0.20 0.50±0.20(9mΩ∼)/1.10±0.20(5 ∼ 8mΩ) D Type KRL2550 2010 5.00±0.20 2.50±0.20 0.50±0.20 0.60±0.20(9mΩ∼ /1.40±0.20(5 ∼ 8mΩ) L KRL3264 2512 6.30±0.20 3.10±0.20 0.50±0.20 1.00±0.20(9mΩ∼)/1.90±0.20(5 ∼ 8mΩ) KRL50110 4320 11.00±0.20 5.00±0.20 0.65±0.20 2.36±0.30(8mΩ∼)/3.60±0.30(5 ∼ 7mΩ) t a a W (unit:mm) t a a E Type C(high operating temperature) M(low EMF) 100 50 0 -55     0     50  100 120 KRL series Ratio to rated power (%) Current sensing surface mount resistors ◆Derating Curve 155 175 Ambient temperature (℃) Ratio to rated power (%) KRL1632E-3A series (1W) is also in our line-up. 100 50 0 -55    0    50 70 100 150 175 Terminal temperature(℃) 56
KRL1220E-M-R180-F-T5 价格&库存
很抱歉,暂时无法提供与“KRL1220E-M-R180-F-T5”相匹配的价格&库存,您可以联系我们找货
    • 1+0.44086
    • 200+0.17064
    • 500+0.16460
    • 1000+0.16168
      • 1+3.533161+0.45727
      • 10+2.2415910+0.29011
      • 25+1.8961725+0.24541
      • 50+1.6807650+0.21753
      • 100+1.49706100+0.19376
      • 250+1.29547250+0.16767
      • 500+1.16926500+0.15133
      • 1000+1.061911000+0.13744
      库存:5336
      • 5000+0.870755000+0.11270
      • 10000+0.8082410000+0.10461
      • 15000+0.7761415000+0.10045
      • 25000+0.7398225000+0.09575
      • 35000+0.7181935000+0.09295
      • 50000+0.6970450000+0.09022
      库存:5336
