ICMEF062P250MFR
ICMEF062P250MFR
    ICT
    CHOKE_0.87X0.67MM_SM
    共模电感 100mA ±25% 5Ω 25Ω CHOKE_0.87X0.67MM_SM
ICMEF062P250MFR 数据手册
ITEM P/N Page COMMON MODE ESD FILTER ICMEF062P250MFR 1 Data Sheet - ITEM : COMMON MODE ESD FILTER - PART NO : ICMEF062P250MFR - CONDITION : 1. 2. 3. 4. ITEM P/N Page COMMON MODE ESD FILTER ICMEF062P250MFR 2 1. Generals • This specification covers the engineering requirements for the ICMEF062P250MFR (Common Mode ESD Filter) 2. Features • Effective for suppressing common mode noise and almost no effect for high speed differential data line • One common mode filters and two ESD suppression devices integrated • Ultra low profile (0.87ⅹ0.67ⅹ0.50mm) • Ceramic multilayer type SMD component • Non-polarized product • It is a product conforming to RoHS directive. 3. Applications • HDMI lines in PDP, LCD TV, DVD Player, PC, Audio player, DSC • MDDI, MIPI, MHL in mobile phone 4. Product specifications 4. 1 PART NUMBER CODE ICMEF ① 06 ② 2P ③ 250 ④ M ⑤ F ⑥ R ⑦ ① Series name of ICT’s Common Mode ESD Filter ② Dimensions, 0.87mm (L) ⅹ 0.67mm (W) ③ Number of lines, 2P= 2 lines ④ Common Mode Impedance (at 100MHz), 250= 25Ω ⑤ Tolerance of common mode impedance, M= ±25% ⑥ Type of electrode plating: F= Lead Free ⑦ Packing Type, R= Reel ITEM P/N Page COMMON MODE ESD FILTER ICMEF062P250MFR 3 Rated Voltage Rated Current 4. 2 Specification of electrical characteristics Resistance Leakage Current Capacitance Insulation Resistance (Max) ZCM RDC IL C IRCR VR IR Units Ω Ω ㎂ pF MΩ Volt mA Test Condition @100MHz 25℃±2℃ 5V 0.5Vrms @1MHz 5V Value 25(±25%) Max 5.0 Max 1.0 Max 1.7 Min 10 Characteristics Common Mode Impedance symbol 25℃±2℃ 25℃±2℃ 5 Max100 -Transmission characteristics (S-parameter) - Impedance Curves 0 10k -3 Differential Mode S21 -6 Insertion Loss(dB) Impedance () 1k 100 10 -9 -12 -15 -18 -21 -24 -27 1 1M 10M 100M Frequency (Hz) 1G 10G -30 1M 10M 100M Frequency(Hz) 1G 10G ITEM P/N Page COMMON MODE ESD FILTER ICMEF062P250MFR 4 4. 3 Operating Temperature DESCRIPTION REQUIREMENTS Operating Temperature -40℃ ∼ + 85℃ 5. Equivalent Circuit & Recommended Foot print & Stencil mask PIN NUMBER DESCRIPTION ①~④ DATA LINE ⑤, ⑥ GROUND Land pattern 0.05 Stencil 0.21 0.2 ⑤ ③ ④ 0.05 0.18 0.4 0.61 ⑥ 15 0.05 ② 0.05 ① 0. 0.05 0.2 0.05 0.2 0.6 [ Equivalent circuit ] [ Foot print & Stencil mask ] 6. Mechanical Property 6. 1 Appearance and Dimension Unit : mm ITEM P/N Page COMMON MODE ESD FILTER ICMEF062P250MFR 5 7. TEST METHOD OF ELECTRICAL PROPERTY - PIN INDEX Pin1 Pin2 Pin5 Pin6 Pin3 Pin4 ITEM DESCRIPTION SOURCE EQUIPMENT Rdc Pin 1-3, 2-4 10mA DC Source Source Meter CM Impedance Pin 1-2(Short) to Pin 3-4(Short) 500mV LCR Meter (3GHz) IL Pin 5 or 6 to Pin 1, 2, 3, 4 5V DC Source Source Meter IRCR Pin1 -2 or Pin3-4 5V DC Source Source Meter ITEM P/N Page COMMON MODE ESD FILTER ICMEF062P250MFR 6 8. REFLOW CONDITION 8. 1 RECOMMENDED SOLDERING PROFILE (Lead-free condition) (℃ ) Dwell: max 260℃-10sec ℃ 185℃ ℃ 160℃ Δ T≤ 220℃ 130 ℃ 250℃ ΔT ≤130℃ 30~50 sec 30~50 sec Soldering Soldering Pre-heating 110 ±10 sec Gradual Cooling 25℃ 60 sec Time (sec) 8. 2 RECOMMENDED LEAD-FREE SOLDER PASTE - Supplier : Tamura Donghwa - Main composition : Sn-Ag-Cu - Ratio of composition : 96.5%-3.0%-0.5% 8. 3 RECOMMENDED HAND SOLDER - Max Temperature: Max 380 ℃(Max 5sec) ITEM P/N Page COMMON MODE ESD FILTER ICMEF062P250MFR 7 9. PACKING SPECIFICATION 9. 1 TAPING FIGURE 9. 2 CARRIER TAPE DIMENSIONS Unit : mm SYMBOL A B E F D0 P1 P2 P0 10P0 W T T’ DIMENSION 0.80 1.02 1.75 3.50 1.55 2.00 2.00 4.00 40.00 8.00 0.60 0.63 TOLERANCE 0.03 0.03 0.05 0.05 0.03 0.05 0.05 0.05 0.10 0.10 0.04 0.03 ITEM P/N Page COMMON MODE ESD FILTER ICMEF062P250MFR 8 9. 3 REEL DIMENSIONS (1) Reel Materials: Polystyrene (2) Label (3) Taping - Standard Packing Quantity per Reel (178) - PE Tape: 10,000pcs Unit : mm CODE A DIMENSION 1782 B C Min. 50 130.5 D E W t R 210.8 2.00.5 101.5 0.80.2 1.0 9. 4 LABEL CODE ICMEF062P250MFR J01218LA B 001 QTY 10,000 PCS - P/N : Part Number - L/N : Lot Number - C/N : Customer Number - SPEC : Size, Line numbers & CM Impedance - DATE : Date code - Q’TY : Quantity ITEM P/N Page COMMON MODE ESD FILTER ICMEF062P250MFR 9 9. 5 REEL PACKING Part Number / Company Name MADE IN KOREA (Country of region ) (1) (2) Product box material : Card board 5 Reels in each SPQ Box (3) PQ Box contains 10 SPQ Boxes (50 Reels) Packing box + Product weight Product CMF CMEF Size S-box + 5reel M-box + 5S-box L-box + 10S-box L x W x H(mm) 185 x 70 x 185 370 x 190 x 200 380 x 370 x 200 Size weight(g) /1 unit Total(g) Chip(g) Total(g) Chip(g) Total(g) Chip(g) 0806 0.00124 643 62 3215 310 6147 620 1210 0.00480 750 96 3758 480 7503 960 2012 0.00750 804 150 4028 750 8043 1500 0806 0.00128 646 65 3230 325 6177 650 1210 0.00490 752 98 3768 490 7523 980 2012 0.00760 806 152 4038 760 8063 1520
