SMFJ3.3CA
ESD Protection Diode
»Features
400Watts peak pulse power (tp = 8/20μs)
Tiny SOD123 package
Bidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
IEC 61000-4-2 ±25kV contact ±25kV air
IEC 61000-4-4 (EFT) 40A(5/50ns)
IEC 61000-4-5 (Lightning) 40A (8/20μs)
»Applications
»Mechanical Data
Cell Phone Handsets and Accessories
SOD123 package
Microprocessor based equipment
Molding compound flammability rating: UL 94V-0
Personal Digital Assistants (PDA’s)
Packaging: Tape and Reel
Notebooks, Desktops, and Servers
RoHS/WEEE Compliant
Portable Instrumentation
»Schematic & PIN Configuration
SOD-123
Revision 2018
www.born-tw.com
1/4
SMFJ3.3CA
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs )
PPP
400
Watts
Peak Pulse Current ( tp =8/20μs ) (note1)
Ipp
40
A
VESD
30
30
kV
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 125
Storage Temperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Conditions
Min
Typical
VRWM
3.5
Max
Units
3.3
V
4.2
VBR
IT=1mA
V
Reverse Leakage Current
IR
VRWM=3.3V,T=25℃
Clamping Voltage
VC
IPP=40A,tp=8/20μs
11
V
Junction Capacitance
Cj
VR = 0V, f = 1MHz
70
pF
1
uA
»Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
I PP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ I PP
V RWM
IR
V BR
IT
I
Parameter
Working Peak Reverse Voltage
V
Maximum Reverse Leakage Current @ V RWM
Breakdown Voltage @ IT
Test Current
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
SMFJ3.3CA
»Typical Characteristics
Figure 2: Power Derating Curve
10k
110
400w 8/20μs waveform
1000
100
10
0.1
1
10
100
100
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(W)
Figure 1: Peak Pulse Power vs. Pulse Time
90
80
70
60
50
40
30
td – Pulse Duration - µs
100
125
150
18
Waveform
Paramters
tr=8µs
td=20µs
90
Test
Waveform
Paramters
tr=8µs
td=20µs
16
Clamping Voltage–VC (V)
100
80
Ipp
75
Figure 4: Clamping Voltage vs.Ipp
110
Percent
50
Ambient Temperature - TA (℃)
Figure3: Pulse Waveform
70
e-1
60
25
50
40
30
td=Ipp/2
12
10
8
6
4
2
10
10
15
30
Time (µs)
Revision 2018
10
40
50
Peak Pulse Current–IPP (A)
www.born-tw.com
3/4
SMFJ3.3CA
»Outline Drawing – SOD123
C
D
DIMENSIONS
SYMBOL
B
A
1
2
F
G
H
E
b
I
MILLIMETER
A
MIN
0.520
MAX
0.550
MIN
0.570
B
1.400
1.550
1.700
C
3.350
3.650
3.850
D
2.550
2.650
2.850
E
0.000
0.050
0.100
F
1.050
1.100
1.150
G
0.620
0.650
0.670
H
0.100
0.110
0.120
I
0.250
0.350
0.450
»Marking
1
»Ordering information
Order code
SMFJ3.3CA
Revision 2018
Package
SOD123
3BE
2
Base qty
3k
www.born-tw.com
Delivery mode
Tape and reel
4/4
很抱歉,暂时无法提供与“SMFJ3.3CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.39636
- 100+0.32379
- 300+0.28750
- 3000+0.21557
- 6000+0.19376
- 9000+0.18285
- 国内价格
- 10+0.24150
- 50+0.22434
- 200+0.21004
- 600+0.19574
- 1500+0.18430
- 3000+0.17715
- 国内价格
- 1+0.33770
- 200+0.21890
- 1500+0.19030
- 3000+0.16830
- 国内价格
- 10+0.39550
- 100+0.32090
- 300+0.28480
- 3000+0.21360
- 6000+0.19200
- 9000+0.18120
