B5817W THRU B5819W
SCHOTTKY DIODE
SOD-123
FEATURES
1.80(.071)
1.40(.055)
For use in low voltage, high frequency inverters
Free wheeling, and polarity protection applications
3.86(0.152)
2.84(0.112)
3.56(0.145)
2.54(0.100)
MECHANICAL DATA
.71(0.028)
.50(0.020)
.15(.006)
Case: Molded plastic body
Terminals: Plated leads solderable per MIL-STD-750,
Method 2026
Polarity: Polarity symbols marked on case
Marking: B5817W:SJ, B5818W:SK, B5819W:SL
1.35(.053)
MAX
.94(.037)
.25(.010)
MIN
Dimensions in millimeters and (inches)
Maximum ratings and electrical characteristics, Single diode @TA=25C
PARAMETER
Peak repetitive peak reverse voltage
Working peak reverse voltage
DC Blocking voltage
RMS Reverse voltage
Average rectified output current
Peak forward surge current @=8.3ms
Power dissipation
Thermal resistance junction to ambient
Storage temperature
Non-Repetitive peak reverse voltage
SYMBOLS
B5817W
B5818W
B5819W
UNITS
VRRM
VRWM
VR
40
V
14
21
1
9
250
500
-55 to +150
30
28
V
A
A
mW
K/W
C
V
VR(RMS)
IO
IFSM
Pd
RΘJA
TSTG
VRM
Electrical ratings @TA=25C
PARAMETER
Reverse breakdown voltage
SYMBOLS
V(BR)
Min.
Max.
40
Unit
IR=1mA
B5817W
B5818W
B5819W
mA
VR=20V
VR=30V
VR=40V
B5817W
B5818W
B5819W
Reverse voltage leakage current
IR
1
0.45
Forward voltage
0.75
VF
0.55
0.875
0.6
0.9
Diode capacitance
DN:S11G04A0
Test conditions
V
V
V
CD
120
B5817W
V
V
V
pF
IF=1A
IF=3A
B5818W
B5819W
VR=4V,f=1.0MHz
STAR SEA
RATINGS AND CHARACTERISTIC CURVES B5817W THRU B5819W
PEAK FORWARD SURGE CURRENT(A)
AVERAGE FORWARD CURRENT(A)
FIG. 1- FORWARD CURRENT DERATING CURVE
1.25
1.0
0.75
Resistive or inductive
load0.375''(9.5mm)
lead length
0.5
0.25
60
80
100
120
FIG. 2-MAXIMUM NON-REPETITIVE PEAK
10.8
9.0
7.2
5.4
3.6
1.8
10
INSTANTANEOUS REVERSE CURRENT (mA)
INSTANTANEOUS FORWARD CURRENT(A)
FIG. 3- TYPICAL INSTANTANEOUS
FORWARD CHARACTERISTICS
50
10
TA=25 C
TA=125 C
1.0
Pulse width=300us
1% duty cycle
0.1
0.4
0.8
1.2
FIG. 4- TYPICAL REVERSE CHARACTERISTICS
100
10
TJ=125 C
1.0
TJ=75 C
0.1
0.01
TJ=25 C
0.001
TRANSIENT THERMAL IMPEDANCE ( C/W)
FIG. 5- TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE (pF)
400
100
40
60
80
100
FIG. 6-TYPICAL TRANSIENT
THERMAL IMPEDANCE
100
10
1
0.1
1
10
REVERSE VOLTAGE (V)
DN:S11G04A0
PERCENT OF RATED PEAK PEVERSE VOLTAGE (%)
INSTANTANEOUS FORWARD VOLTAGE(V)
10
0.1
100
NUMBER OF CYCLES AT 60Hz
CASE TEMPERATURE( C)
100
0.01
1
10
100
t--PULSE DURATION (sec.)
STAR SEA
很抱歉,暂时无法提供与“B5819W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.60610
- 200+0.20240
- 1500+0.12650
- 3000+0.10043
- 国内价格
- 20+0.21330
- 200+0.16838
- 600+0.14332
