1.25mm Pitch Miniature Crimping Connector (UL Listed)
DF13 Series
Right Angle Type
Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Straight Type
Type
■ Features
1. Miniature Size
Designed in the low profile at mounting height 5.8mm.
(SMT mounting straight type)
(For DIP type, the mounting height is to 5.3mm to the straight
and 3.6mm at the right angle)
Mounting Type
Mounting Height(h)
DIP
5.3mm
SMT
5.8mm
DIP
3.6mm
SMT
Correspond to Automatic Mounting
Secure the automatic plain area for the absorption
type automatic mounting machine.
Straight Type
Absorption area
2. Multi-contact
The double row type achieves the multi-contact up to 40
contacts, and secures 30% higher density in the mounting
area, compared with the single row type.
3. Correspond to Automatic Mounting
The header provides the grade with the vacuum absorption
area, and secures automatic mounting by the embossed
tape packaging.
In addition, the tube packaging can be selected. (Fig.1)
Metal fitting
4. Integral Basic Function Despite Miniature Size
The header is designed in a scoop-proof box structure, and
completely prevents mis-insertion.
In addition, the surface mounting (SMT) header is equipped
with the metal fitting to prevent solder peeling. (Fig.1)
Right Angle Type
Absorption area
5. UL Certifled
■ Applications
Note PC, mobile terminal, miniature type business equipment,
and other various consumer equipment, including video
camera
Fig.1
2021.2②
1
DF13 Series●1.25mm Pitch Miniature Crimping Connector (UL Listed)
■ Product Specifications
Specification
1A/pin
UL
Operating Temperature Range : -35 to +85ç (Note 1) Storage Temperature Range : -10 to +60ç (Note 2)
Specification 150V AC/DC Operating Moisture Range : 20 to 80% (Note 3) Storage Moisture Range : 40 to 70% (Note 2)
Voltage rating
UL
29.9V AC/DC
Current rating
Rating
Item
Specification
Condition
1.Insulation Resistance
500Mø min.
100V DC
2.Withstanding voltage
No flashover or insulation breakdown.
500V AC/1 minute
3.Contact Resistance
30mø max.
100mA
4.Vibration
No electrical discontinuity of 1μs or more
Frequency : 10to55 Hz,single amplitudeof 0.75 mm, 2hours ineach of the3directions.
5.Humidity (Steady state) Contact resistance : 30m ø max. Insulation resistance : 500Mø min. 96 hoursat temperature of 40çand humidity of 90%to95%
6.Temperature Cycle
Contact resistance : 30m ø max. Insulation resistance : 500Mø min. (-55ç : 30 minutes➝5 to 35ç : 10 minutes➝ 85ç :30 minutes➝ 5 to 35ç :10 minutes) 5 cycles
7.Durability (Mating/un-mating) Contact resistance : 30mø max.
Tin plating : 30 cycles
Gold plating : 50 cycles
8.Resistance to Soldering heat No deformation of components affecting performance.
Flow : 250ç for 10 seconds
Manual soldering : 300ç for 3 seconds
Reflow : At the recommended temperature profile
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use.
Operating Temperature Range and Humidity range covers non conducting condition of
installed connectors in storage, shipment or during transportation.
Note 3 : Use without condensation on parts.
Note 4 : Information contained in ths catalog represents general requirements for this Series.
Contact us for the drawings and specifications for a specific part number shown.
UL File No. and Recognition
No. UL : E52653
■ Materials/Finish
Product
Crimping Socket
Crimping Contact for Socket
Pin Header (Through hole)
Pin Header (SMT Single row)
Pin Header (SMT Double row)
Part
Insulator
Contact
Insulator
Contact
Insulator
Contact
Metal Fitting
Insulator
Contact
Metal Fitting
Material
Polyamide
Phosphor copper
Polyamide
Brass
Polyamide
Brass
Phosphor copper
Polyamide
Brass
Phosphor copper
Finish
Beige
Tin plated or gold plated
Beige
Tin plated
Beige
Tin plated
Beige
Tin plated
Remarks
UL94V-0
---UL94V-0
---UL94V-0
------UL94V-0
RoHS2
Yes
■ Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
DF13 # - * S - 1.25 C
● Connector
q
q Series Name
: DF13
w Style Symbol
: Blank : With boss
A : Without boss
w
e
r
t
y
e Number of Contacts
Single row : 2 to 12, 14, 15
Double row : 10, 20, 30, 40
C : Without boss
r Connector Type
t Contact Pitch : 1.25mm
y Connection Form / Contact Style.
C :Crimping socket/DSA :Straight through hole
DS : Right angle through hole / V : Straight SMT
S : Single row socket / P : Single row pin header
H : Right angle SMT
DS : Double row socket / DP : Double row pin header
● Contact
DF13 # - 2630 SCF A
q
w
e
r
q Style Symbol Blank : Standard
wApplicableCable Size 2630 :26 to30AWG
3032:30 to32AWG
2
e PackagingType SCF:SocketContact/Reel
G : Low insertion / extraction r Plating Type
Blank : Tin plated
A : Gold plated
■ Single Row Socket
Photo: Contact insertion
Part No.
HRS No. No. of Contacts
A
B
Part No.
DF13-2S-1.25C
536-0001-4
2
1.25 4.15
DF13- 9S-1.25C 536-0008-3
9
DF13-3S-1.25C
536-0002-7
3
2.50 5.40
DF13-10S-1.25C 536-0009-6
10
DF13-4S-1.25C
536-0003-0
4
3.75 6.65
DF13-11S-1.25C 536-0010-5
11
DF13-5S-1.25C
536-0004-2
5
5.00 7.90
DF13-12S-1.25C 536-0011-8
12
DF13-6S-1.25C
536-0005-5
6
6.25 9.15
DF13-13S-1.25C 536-0012-0
13
DF13-7S-1.25C
536-0006-8
7
7.50 10.40
DF13-14S-1.25C 536-0013-3
14
DF13-8S-1.25C
536-0007-0
8
8.75 11.65
DF13-15S-1.25C 536-0014-6
15
Note 1 : The quantity is delivered per bag (100pcs.). If needed, please select and order the products per bag.
Unit : mm
A
B
10.00 12.90
11.25 14.15
12.50 15.40
13.75 16.65
15.00 17.90
16.25 19.15
17.50 20.40
■ Double Row Socket
Photo: Contact insertion state
Unit : mm
Part No.
A
B
DF13-10DS-1.25C 536-0550-2
10
10.40
5.00
DF13-20DS-1.25C 536-0555-6
11.25
DF13-30DS-1.25C 536-0560-6
30
22.90
17.50
DF13-40DS-1.25C 536-0565-0
40
29.15
23.75
Note : The quantity is delivered per bag (100pcs). If needed, please select and order the products per bag.
3
■ Single Row Straight Pin Header (Through hole)
[Specific No.] (**), **
Blank : Tin plated
(75) : Tin plated, tube packaging
BTube Dimensions
10
5
● Board Through-hole Diameter : Ø0.6±0.03
Unit: mm
Part No.
HRS No. No. of Contacts A
B Tube Packaging Quantity
Part No.
115
37
DF13-2P-1.25DSA(**) 536-0101-9 **
2
1.25 4.15
DF13- 9P-1.25DSA(**) 536-0108-8 **
9
10.00 12.90
89
34
DF13-3P-1.25DSA(**) 536-0102-1 **
3
2.50 5.40
DF13-10P-1.25DSA(**) 536-0109-0 **
10
11.25 14.15
72
31
DF13-4P-1.25DSA(**) 536-0103-4 **
4
3.75 6.65
DF13-11P-1.25DSA(**) 536-0110-0 **
11
12.50 15.40
61
29
DF13-5P-1.25DSA(**) 536-0104-7 **
5
5.00 7.90
DF13-12P-1.25DSA(**) 536-0111-2 **
12
13.75 16.65
52
27
DF13-6P-1.25DSA(**) 536-0105-0 **
6
6.25 9.15
DF13-13P-1.25DSA(**) 536-0112-5 **
13
15.00 17.90
46
25
DF13-7P-1.25DSA(**) 536-0106-2 **
7
7.50 10.40
DF13-14P-1.25DSA(**) 536-0113-8 **
14
16.25 19.15
41
23
DF13-8P-1.25DSA(**) 536-0107-5 **
8
8.75 11.65
DF13-15P-1.25DSA(**) 536-0114-0 **
15
17.50 20.40
Note 1 : The quantity at the specific No."None" is delivered per bag (100pcs.). If needed, please select and order the products per bag.
Note 2 : Order the tube packaging product, multiplying the tube packaging quantity.
■ Single Row Right Angle Pin Header (Through hole)
(20) : Tin plated tube packaging
BTube Dimensions
Part No.
Part No.
DF13-2P-1.25DS(20) 536-0151-7 20
2
1.25 4.15
115
DF13- 9P-1.25DS(20)
DF13-3P-1.25DS(20) 536-0152-0 20
3
2.50 5.40
89
DF13-10P-1.25DS(20)
4
3.75 6.65
72
DF13-4P-1.25DS(20) 536-0153-2 20
DF13-11P-1.25DS(20)
DF13-5P-1.25DS(20) 536-0154-5 20
5
5.00 7.90
61
DF13-12P-1.25DS(20)
DF13-6P-1.25DS(20) 536-0155-8 20
6
6.25 9.15
52
DF13-14P-1.25DS(20)
DF13-15P-1.25DS(20)
7
7.50 10.40
46
DF13-7P-1.25DS(20) 536-0156-0 20
DF13-8P-1.25DS(20) 536-0157-3 20
8
8.75 11.65
41
Note 1 : Order the tube packaging product, multiplying the tube packaging quantity.
4
Unit : mm
536-0158-6 20
9
10.00 12.90
37
536-0159-9 20
10
11.25 14.15
34
11
12.50 15.40
31
536-0160-8 20
536-0161-0 20
12
13.75 16.65
29
536-0163-6 20
14
16.25 19.15
25
536-0164-9 20
15
17.50 20.40
23
■ Single Row Straight Pin Header (SMT)
(Three-Wall/Correspond to Vacuum Absorption)
1.8
BPCB mounting pattern
Note 1.Shaded area must be free of any
electrically conductive traces to
avoid contact with soldered pin
header terminations.
This pin header is a three-wall type, header has sufficiently large flat areas to allow
pick-up with vacuum nozzles of automatic placement equipment.
(21) : Tin plated embossed tape packaging
(51) : Gold plated embossed tape packaging
Unit : mm
Part No.
DF13C- 2P-1.25V(**)
DF13C- 3P-1.25V(**)
DF13C- 4P-1.25V(**)
DF13C- 5P-1.25V(**)
DF13C- 6P-1.25V(**)
DF13C- 7P-1.25V(**)
DF13C- 8P-1.25V(**)
DF13C- 9P-1.25V(**)
DF13C-10P-1.25V(**)
DF13C-11P-1.25V(**)
DF13C-12P-1.25V(**)
DF13C-14P-1.25V(**)
DF13C-15P-1.25V(**)
HRS No.
536-0401-2
536-0402-5
536-0403-8
536-0404-0
536-0405-3
536-0406-6
536-0407-9
536-0408-1
536-0409-4
536-0410-3
536-0411-6
536-0413-1
536-0414-4
No. of Contacts
A
B
C
D
E
F
2
3
4
5
6
7
8
9
10
11
12
14
15
1.25
2.50
3.75
5.00
6.25
7.50
8.75
10.00
11.25
12.50
13.75
16.25
17.50
4.15
5.40
6.65
7.90
9.15
10.40
11.65
12.90
14.15
15.40
16.65
19.15
20.40
7.15
8.40
9.65
10.90
12.15
13.40
14.65
15.90
17.15
18.40
19.65
22.15
23.40
5.65
6.90
8.15
9.40
10.65
11.90
13.15
14.40
15.65
16.90
18.15
20.65
21.90
1.95
3.20
4.45
5.70
6.95
8.20
9.45
10.70
11.95
13.20
14.45
16.95
18.20
2.20
3.45
3.10
4.35
5.60
6.85
8.10
9.35
10.60
11.85
13.10
15.60
16.85
Emboss
Width
16
16
24
24
24
24
24
24
24
32
32
32
44
Note 1 : Please order the embossed tape packaging product according to reel number. (1000pcs/reel)
5
DF13-7P-1.25DSA(76) 价格&库存
很抱歉,暂时无法提供与“DF13-7P-1.25DSA(76)”相匹配的价格&库存,您可以联系我们找货
