SurgeArresters
陶瓷气体放电管
SE90 Series
http://www.szshaoxin.com/
绍 鑫 实 业
Gas Discharge Tube - SE 9 0 Series
Gas discharge tubes (GDT) use noble gasses enclosed in ceramic tubes to
provide an alternate circuit path for voltage spikes.The ceramic envelope
and with nickel connectors allow for high loads and Surging offers products
that function at 20KA,40KA,50KA,60KA,100KA&150KA.The breakdown
voltages of the devices have a wide range (up to 20% tolerance).Major
applications are high frequency telecommunication lines,stations, security
systems,HID and high quality Surge Protection Devices (SPD).
Features
• RoHS & HF compliant
• High insulation resistance.
• High holdover voltage.
• Size:7.2mm*5.0mm
• Large absorbing transient current capability.
• DC Spark-over voltage: 75~1100V
• Low Capacitance
• Stable breakdown voltage.
• Micro-Gap Design
Recommended Applications
• Cable Modem
• Power supplier
• xDSL
• Consumer electronics
• Set-Top Box
• General telecom equipment
• Satellite and CATV equipment
Product Name
SE 90 - 230X
Series:
Lead Type:
DC Line Voltage:
SE 90系列:ф5 * 7.6
0=SMD
3=Thrust
90X=90V
230X=230V
102X=1000V
绍 鑫 实 业
Electriacl Characteristics
Part Number
Max.
Impulse
Breakdown
Voltage
DC
Spark-over
Voltage
Max. Impulse
Impulse Life Normal Alternating
Discharge
(10/1000μs) Discharge Current
Current (8/20μs)
1
time
10
times
100A
50Hz,
1Sec
100V/S
100V/μs
1KV/μs
(V)
(V)
(V)
SE90-75X
75±20%
600
700
10
5
300
5
SE90-90X
90±20%
500
600
10
5
300
SE90-120X
120±20%
500
600
10
5
SE90-150X
150±20%
500
600
10
SE90-200X
200±20%
600
700
SE90-230X
230±20%
600
SE90-250X
250±20%
SE90-350X
(KA)
(Times)
DC Holdover
Voltage
Minimum
Maximum
Insulation Capacitance
Resistance
(1MHz)
Single
9 Cycles
(V)
(GΩ)
(pF)
30
52
1
2
5
30
52
1
2
300
5
30
80
1
2
5
300
5
30
80
1
2
15
10
300
10
60
135
1
2
700
15
10
300
10
60
135
1
2
600
700
15
10
300
10
60
135
1
2
350±20%
650
750
15
10
300
10
60
135
1
2
SE90-400X
400±20%
700
800
15
10
300
10
60
135
1
2
SE90-420X
420±20%
700
800
15
10
300
10
60
135
1
2
SE90-470X
470±20%
800
900
15
10
300
10
60
135
1
2
SE90-600X
600±20%
900
1000
10
5
300
5
30
135
1
2
SE90-800X
800±20%
1150
1400
10
5
300
5
30
135
1
2
SE90-112X
1100±20%
1450
1750
10
5
300
5
30
135
1
2
DC Spark-over Voltage
DC Measuring Voltage
75-90V
50V
120-400V
100V
420-1100V
250V
(A)
绍 鑫 实 业
Product size (Unit:mm)
Recommended Pad Size
Dimension
7.2±0.3
8.2
7. 6 ± 0.3
0.4
0.4
1.5
1.5
0.4
3.3
5.0±0.1
5.0±0.1
5.0±0.1
5.0±0.1
5.6
1.6
0.4
Packaging Taping
Unit:mm
P0
D
330 ± 4.0
E
F
>1.5
W
100typ
t
P
K
18. typ
Quantity:1000pcs per reel (13”)
Item
P
PO
W
F
E
D
K
t
Spec.
12.0
4.0
16.0
7.5
1.75
Φ1.55
6.7
0.5
Tolerance
±0.1
±0.1
±0.3
±0.1
±0.1
±0.05
±0.1
±0.05
很抱歉,暂时无法提供与“SE90-75X”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+4.19350
- 100+2.50150
- 500+1.75100
- 1000+1.25070
- 2000+1.18820
- 10000+1.10070
- 国内价格
- 5+2.27114
- 50+1.79766
- 150+1.59462
- 国内价格
- 1+3.16500
- 10+2.37370
- 50+1.89900
- 100+1.58250
- 500+1.35640
- 1000+1.26600
