DATASHEET
Single-Phase Filters FN2060
Multi-stage general purpose AC/DC EMI Filter
Rated currents from 1 to 30 A
Approvals & Compliances
High differential and common-mode
attenuation
Optional medical versions (B type)
Optional safety versions (A type)
Features and benefits
Performance indicators
FN 2060 two-stage filters are designed for easy and
fast chassis mounting
FN 2060 B versions without capacitors to earth
comply to 1MOP for ME (medical equipment) acc.
IEC 60601-1
FN 2060 A version with low capacitance to earth for
safety critical applications with necessity for low
leakage currents
All filters provide a high conducted attenuation
performance, based on chokes with high saturation
resistance and excellent thermal behavior
FN 2060 two-stage filters are designed for noisy
applications requiering good differential and
common-mode attenuation
Technical specifications
FN 2060 filters are also available as single-stage
filters (FN 2010 series)
Rated voltage*
Operating frequency
Rated currents
High potential test voltage
250 VAC, 50/60 Hz; 250 VDC
Temperature range (operation and storage)
Certified to
-25°C to +100°C (25/100/21)**
UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 (applies to
AC and DC applications)
Electrical and electronic equipment
Flammability corresponding to
Terminal plastic for -06/-08 version: UL 94 V-0
Laces for -07 version: UL 94 VW-1
Grommet for -07 version: UL 94 V-0
Household equipment
Design corresponding to
Overvoltage category
Pollution degree
Altitude
MTBF @ 40°C/230 V (Mil-HB-217F)
Industrial applications
II acc. IEC 60664-1
Machinery
2 acc. IEC 60664-1
Medical equipment
2000m (above derating applies)**
Electronic data processing equipment
1,650,000 hours (B types)
950,000 hours
Office automation and datacom equipment
DC to 400 Hz
1 to 30 A @ 40°C max.
P –> PE 2000 VAC for 2 sec
P –> PE 2500 VAC for 2 sec (B types)
P –> N 1100 VDC for 2 sec
* maximum RMS operating voltage at rated frequency or the maximum DC operating voltage
** for dedicated requests exceeding this specification (e.g. -40 °C or higher altitude) please contact your local
Schaffner Sales office
Various terminal options allow you to select the
desired connection style
Typical applications
Consumer goods
Building automation
Various noisy applications requiering good filter
performance
Typical electrical schematic
2
Schaffner Group
EMC/EMI Products
Datasheets
09 Dec 2021
Filter selection table
Filter*
Buy
Rated current
Leakage current**
Power Loss
Inductance***
@ 40°C (25°C)
@ 250 VAC/50 Hz
@25°C/DC
L
Capacitance***
Cx
Cy
Resistance***
Input/Output
R
connections
Weight
(@ 120 VAC/60 Hz)
[A]
[mA]
[W]
[mH]
[μF]
[nF]
[kΩ]
FN2060-1-..
1 (1.2)
0.66 (0.38)
1.6
12
0.22
4.7
1000
-06
-07
120
FN2060-3-..
3 (3.5)
0.66 (0.38)
2.2
2.5
0.22
4.7
1000
-06
-07
120
FN2060-6-..
6 (6.9)
0.66 (0.38)
3.2
0.97
0.22
4.7
1000
-06
-07
FN2060-10-..
10 (11.5)
0.66 (0.38)
4.3
0.8
0.47
4.7
470
-06
-07
-08
190
FN2060-12-..
12 (13.8)
0.66 (0.38)
6.2
0.58
0.47
4.7
470
-06
-07
-08
190
FN2060-16-..
16 (18.4)
0.66 (0.38)
4.4
0.65
0.33
4.7
1000
-06
-07
FN2060-20-..
20 (23)
0.66 (0.38)
5.3
0.6
1
4.7
220
-06
30 (34.5)
0.79 (0.45)
9.1
0.6
1
10
220
FN2060A-1-..
1 (1.2)
0.07 (0.04)
1.6
12
0.22
0.47
1000
-06
-07
120
FN2060A-3-..
3 (3.5)
0.07 (0.04)
2.2
2.5
0.22
0.47
1000
-06
-07
120
FN2060A-6-..
6 (6.9)
0.07 (0.04)
3.2
0.97
0.22
0.47
1000
-06
-07
FN2060A-10-..
10 (11.5)
0.07 (0.04)
4.3
0.8
0.47
0.47
470
-06
-07
-08
190
FN2060A-12-..
12 (13.8)
0.07 (0.04)
6.2
0.58
0.47
0.47
470
-06
-07
-08
190
FN2060A-16-..
16 (18.4)
0.07 (0.04)
4.4
0.65
0.33
0.47
1000
-06
-07
-08
260
-06
FN2060-30-08
FN2060A-20-..
[g]
120
-08
260
-08
480
-08
950
120
20 (23)
0.07 (0.04)
5.3
0.6
1
0.47
220
30 (34.5)
0.07 (0.04)
9.1
0.6
1
0.47
220
FN2060B-1-..
1 (1.2)
0.00
1.6
12
0.22
1000
-06
-07
120
FN2060B-3-..
3 (3.5)
0.00
2.2
2.5
0.22
1000
-06
-07
120
FN2060B-6-..
6 (6.9)
0.00
3.2
0.97
0.22
1000
-06
-07
FN2060B-10-..
10 (11.5)
0.00
4.3
0.8
0.47
470
-06
-07
-08
FN2060B-12-..
12 (13.8)
0.00
6.2
0.58
0.47
470
-06
-07
-08
190
FN2060B-16-..
16 (18.4)
0.00
4.4
0.65
0.33
1000
-06
-07
-08
260
FN2060B-20-..
20 (23)
0.00
5.3
0.6
1
220
-06
-08
480
30 (34.5)
0.00
9.1
0.6
1
220
-08
950
FN2060A-30-08
FN2060B-30-08
* To compile a complete part number, please replace the -.. with the required I/O connection style (e.g. FN 2070-25-08, FN 2070B-10-06).
** Maximum leakage under usual AC operating conditions (acc. IEC60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this level.
*** Tolerances apply: Inductance: -30/+50%, Capacitance: ±20%, Resistance: ±10%
-08
480
-08
950
120
190
3
Schaffner Group
EMC/EMI Products
Typical filter attenuation
Per CISPR 17; CM=50 Ω/50 Ω sym; DM=50 Ω/50 Ω asym;
1 A: Standard type
A type
B type
3 A: Standard type
A type
B type
6 A: Standard type
A type
B type
10 A: Standard type
A type
B type
12 A: Standard type
A type
B type
Datasheets
09 Dec 2021
4
Schaffner Group
EMC/EMI Products
16 A: Standard type
A type
B type
20 A: Standard type
A type
B type
30 A: Standard type
A type
B type
Datasheets
09 Dec 2021
5
Schaffner Group
EMC/EMI Products
Datasheets
09 Dec 2021
Product selector
Mechanical data
Connection style -06, 1 to 12 A types
Connection style -06, 16 A types
B
Connection style -06, 20 A types
Connection style -07, 1 to 16 A types (same dimensions as style -06)
Connection style -08, 10 to 16 A types
Connection style -08, 20 A types
Connection style -08, 30 A types
6
Schaffner Group
EMC/EMI Products
Datasheets
09 Dec 2021
1A
3A
6A
10 A
12 A
16 A
20 A
30 A
Tolerances
A
71
71
71
85
85
85
113.5 ±1
119 ±1
±0.5
B
46.6
46.6
46.6
54
54
54
57.5 ±1
85.5 ±1
±0.5
C
29.3
29.3
29.3
30.3
30.3
40.3
45.4 ±1
57.6 ±1
±0.5
D
50.5
50.5
50.5
64.8
64.8
64.8
94 ±1
98.5 ±1
±0.5
E
44.5
44.5
44.5
49.8
49.8
49.8
56
84.5
±0.5
F
61
61
61
75
75
75
103
109
±0.3
G
21
21
21
27
27
27
25
40
±0.2
H
10.8
10.8
10.8
12.3
12.3
12.3
12.4
15.6
±0.5
I
19.3
19.3
19.3
20.8
20.8
29.8
32.4
J
20.1
20.1
20.1
19.9
19.9
11.4
15.5
42.25
K
5.3
5.3
5.3
5.3
5.3
5.3
4.4
4.4
L
6.3
6.3
6.3
6.3
6.3
6.3
6
7.4
M
0.7
0.7
0.7
0.7
0.7
0.7
1
1.2
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
±0.5
±0.5
±0.3
N
O
8.3
8.3
8.3
8.3
8.3
8.3
P
14
14
14
14.9
14.9
14.9
AWG type wire
AWG 20
AWG 20
AWG 18
AWG 18
AWG 16
AWG 16
Wire length
140
140
140
140
140
140
M4
M4
M4
M4
Recommended torque (Nm)
1.2 - 1.3
1.2 - 1.3
1.2 - 1.3
1.2 - 1.3
Earth terminal
1.5 - 1.7
1.5 - 1.7
1.5 - 1.7
1.5 - 1.7
±0.5
+5
N
Q
All dimensions in mm; 1 inch = 25.4 mm
Tolerances according: ISO 2768-m/EN 22768-m
Please visit www.schaffner.com to find more details on filter connections.
M4
51
1.2 - 1.3
±0.2
7
Schaffner Group
EMC/EMI Products
Datasheets
09 Dec 2021
Headquarters, global
innovation and development
Sales and application centers
Switzerland
Schaffner Group
Industrie Nord
Nordstrasse 11e
4542 Luterbach
T +41 32 681 66 26
info@schaffner.com
China
Schaffner EMC Ltd. Shanghai
T20-3 C, No 565 Chuangye Road,
Pudong district
201201 Shanghai
T +86 21 3813 9500
cschina@schaffner.com
www.schaffner.com.cn
Spain
Schaffner EMC España
Calle Caléndula 93, Miniparc III, Edificio E
El Soto de Moraleja, Alcobendas
28109 Madrid
T +34 917 912 900
F +34 917 912 901
spainsales@schaffner.com
Finland
Schaffner Oy
Sauvonrinne 19 H
08500 Lohja
T +358 50 468 7284
finlandsales@schaffner.com
Sweden
Schaffner EMC AB
Östermalmstorg 1
114 42 Stockholm
T +46 8 5050 2425
swedensales@schaffner.com
www.schaffner.com
France
Schaffner EMC S.A.S.
16-20 Rue Louis Rameau
95875 Bezons
T +33 1 34 34 30 60
F +33 1 39 47 02 28
francesales@schaffner.com
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185 Karlsruhe
T +49 721 56910
germanysales@schaffner.com
India
Schaffner India Pvt. Ltd
REGUS WORLD TRADE CENTRE
WTC, 22nd Floor Unit No 2238, Brigade
Gateway Campus, 26/1, Dr. Rajkumar Road
Malleshwaram (W)
560055 Bangalore
T +91 80 67935355
indiasales@schaffner.com
To find your local partner within Schaffner‘s
global network: www.schaffner.com
© 2021 Schaffner Group
The content of this document has been
carefully checked and understood. However,
neither Schaffner nor its subsidiaries assume
any liability whatsoever for any errors or
inaccuracies of this document and the
consequences thereof. Published specifications are subject to change without notice.
Product suitability for any area of application
must ultimately be determined by the
customer. In all cases, products must never
be operated outside their published
specifications. Schaffner does not guarantee
the availability of all published products. This
disclaimer shall be governed by substantive
Swiss law and resulting disputes shall be
settled by the courts at the place of business
of Schaffner Holding AG. Latest publications
and a complete disclaimer can be downloaded from the Schaffner website. All
trademarks recognized.
Italy
Schaffner EMC S.r.l.
Via Ticino, 30
20900 Monza (MB)
T +39 039 21 41 070
italysales@schaffner.com
Japan
Schaffner EMC K.K.
Taiju-Seimei Sangenjaya Bldg.
1-32-12, Kamiuma, Setagaya-ku
154-0011 Tokyo
T +81 3 5712 3650
F +81 3 5712 3651
japansales@schaffner.com
www.schaffner.jp
Singapore
Schaffner EMC Pte Ltd.
#05-09, Kg Ubi Ind. Estate
408705 Singapore
T +65 6377 3283
F +65 6377 3281
singaporesales@schaffner.com
Switzerland
Schaffner EMV AG
Industrie Nord
Nordstrasse 11e
4542 Luterbach
T +41 32 681 66 88
T +41 32 681 66 26
switzerlandsales@schaffner.com
Taiwan
Schaffner EMV Ltd.
20 Floor-2, No 97, Section 1, XinTai 5th Road
22175 XiZhi District New Taipei City 22175
T +886 2 2697 5500
F +886 2 2697 5533
taiwansales@schaffner.com
www.schaffner.com.tw
Thailand
Schaffner EMC Co. Ltd.
Northern Region Industrial Estate
67 Moo 4 Tambon Ban Klang
Amphur Muangg P.O. Box 14
51000 Lamphun
T +66 53 58 11 04
F +66 53 58 10 19
thailandsales@schaffner.com
United Kingdom
Schaffner Ltd.
1, Oakmede Place
Binfield
RG42 4JF Berkshire
T +44 118 9770070
F +44 118 9792969
uksales@schaffner.com
USA
Schaffner EMC Inc.
52 Mayfield Avenue
Edison, New Jersey
T +1 732 225 9533
F +1 732 225 4789
usasales@schaffner.com
www.schaffnerusa.com
很抱歉,暂时无法提供与“FN2060-12-06”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+201.70978
- 100+197.67546
- 200+193.72132
- 国内价格
- 1+210.50531
- 13+204.18411
- 国内价格 香港价格
- 1+215.528371+27.64585
- 3+180.763303+23.18653
- 4+176.419764+22.62938
- 5+173.808615+22.29445
- 9+169.180529+21.70081
- 10+168.5946910+21.62566
- 20+165.9919120+21.29180
- 国内价格
- 1+143.75004
- 10+137.50004
