2SC3356
2SC3356
    JSMSEMI(杰盛微)
    SOT-23
    集射极击穿电压(Vceo):12V 集电极电流(Ic):100mA 功率(Pd):200mW 集电极截止电流(Icbo):1uA
2SC3356 数据手册
2SC3356-R25 Silicon Epitaxial Planar Transistor Silicon Epitaxial Planar Transistor 2SC3356-R25 FEATURES z Low noise and high gain. NF=1.1dB TYP.,Ga=11dB TYP. @VCE=10V,IC=7mA, f=1.0GHz z High power gain. MAG=13dB TYP. @VCE=10V,IC=20mA,f=1.0GHz. MI JS APPLICATIONS z SOT-23 Designed for low noise amplifier at VHF,UHF and CATV band. Type No. O CR ORDERING INFORMATION Marking 2SC3356-R25 Package Code R25 SOT-23 mi Se MAXIMUM RATING @ Ta=25℃ unless otherwise specified Parameter Value Units VCBO Collector-Base Voltage 20 V VCEO Collector-Emitter Voltage 12 V VEBO Emitter-Base Voltage 3 V IC Collector Current -Continuous 100 PC Collector Dissipation 200 Tj,Tstg Junction and Storage Temperature -65 to +150 mA r to www.jsmsemi.com uc nd co Symbol mW ℃ 第1/4页 2SC3356-R25 Silicon Epitaxial Planar Transistor ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified Symbol Test conditions Collector-base breakdown voltage V(BR)CBO IC=10μA,IE=0 20 V Collector-emitter breakdown voltage V(BR)CEO IC=1mA,IB=0 12 V Emitter-base breakdown voltage V(BR)EBO IE=10μA,IC=0 3 V Collector cut-off current ICBO VCB=10V,IE=0 1 μA Emitter cut-off current IEBO VEB=1V,IC=0 1 μA hFE VCE=10V,IC=20mA Transition frequency fT VCE=10V,IC= 20mA Insertion power gain |S21e|2 VCE=10V, IC= 20mA , f=1GHz 11.5 Feed-back capacitance Cre VCB=10V, IE=0,f=1MHz 0.55 1.0 pF Noise Figure NF VCE=10V,IC=7mA, f=1GHz 1.1 2.0 dB DC current gain O CR MI JS Parameter 50 hFE 125-250 Marking R25 www.jsmsemi.com UNIT 300 GHz dB r to Range 120 MAX uc nd co OF TYP 7 mi Se CLASSIFICATION MIN 第2/4页 2SC3356-R25 Silicon Epitaxial Planar Transistor TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified O CR MI JS r to uc nd co mi Se www.jsmsemi.com 第3/4页 2SC3356-R25 Silicon Epitaxial Planar Transistor PACKAGE OUTLINE Plastic surface mounted package SOT-23 SOT-23 A E K B MI JS J D O CR G Min Max A 2.70 3.10 B 1.10 1.50 C 1.0 Typical D 0.4 Typical E 0.35 0.48 G 1.80 2.00 H 0.02 0.1 J H C Dim K 0.1 Typical 2.20 2.60 All Dimensions in mm 0.95 0.95 2.00 0.90 Unit : mm 0.80 PACKAGE Device 2SC3356-R25 r to uc nd co mi Se SOLDERING FOOTPRINT INFORMATION Package SOT-23 Shipping 3000/Tape&Reel www.jsmsemi.com 第4/4页
2SC3356 价格&库存
很抱歉,暂时无法提供与“2SC3356”相匹配的价格&库存,您可以联系我们找货
