2SC4793
2SC4793
    JSMSEMI(杰盛微)
    TO-220F
    通用三极管 TO-220F NPN 230V
2SC4793 数据手册
2SC4793 NPN Silicon NPN Triple Diffused Transistor APPLICATIONS   Power Amplifier Applications FEATURES  High collector voltage VCEO=230V (min)  Complementary to 2SA1937  High transition frequency :fT=100MHz(Typ.)  RoHS product VCEO=230V (min) 2SA1837 fT=100MHz(Typ.) r RoHS Package nd uc TO-220F to     Order codes Marking Halogen Free 2SC4793 NO mi 2SC4793-O co 不ORDER MESSAGE不不 Package Packaging TO-220F Tube Se ABSOLUTE RATINGS (Tc=25℃ unless otherwise noted) Parameter Value Unit VCBO 230 V VCEO 230 V Emitter-Base Voltage VEBO 5 V Collector Current DC IC 1 A Base Current IB 0.1 A 2.0 W 20 W Collector- Emitter Voltage RO   — Symbol — Collector- Emitter Voltage JS MI C — IB=0 Collector Dissipation(Ta=25 ) Collector Dissipation(Tc=25 ) PC Junction Temperature Tj Storage Temperature Tstg 150 -55~+150 THERMAL CHARACTERISTIC Symbo Parameter min max Unit Thermal Resistance Junction Ambient TO-220F Rth(j-a) - 62.5 /W Thermal Resistance Junction Case Rth(j-c) - 6.25 /W TO-220F 1/3 2SC4793 NPN Silicon NPN Triple Diffused Transistor ELECTRICAL CHARACTERISTIC Tests conditions Parameter Value(min) VCE=230V,IE=0 - - 1.0 μA IEBO VEB=5V,IC=0 - - 1.0 μA V(BR)CEO Ic=10mA,IB=0 230 - - V hFE VCE=5V,IC=0.1A 100 160 270 - VCE(sat) IC=0.5A,IB=0.05A - - 1.5 V VBE VCE=5V,IC=0.5A - - 1.0 V fT VCE=10V, Ic=0.1A, - 100 - MHz Cob VCB=10V,IE=0,f=1MHz - 20 - uc VCE(sat)- IC hFE – IC nd IC/IB = 10 Single pulse test mi RO   市小式市 COLLECTOR CURRENT 式小市市 Tc=25 VOLTAGE Se Vce=5V 市小市式 市小市式 IC A 市小式 PC-TC PC (percent) MI C JS IC A COLLECTOR CURRENT 市小换 Tc=25 Tc=125 式 COLLECTOR CURRENT IC- VBE 市小明 Tc=125 市小式 Tc=25 式市 市小市式 Common emitter co Tc=125 COLLECTOR-BMITTER SATURATION DC CURRENT GAIN hFE 式市市市 VCE(sat) V 式 式市市 pF to ON r ICBO ELECTRICAL CHARACTERISTICS (curves) 式 市小4 Common emitter Vce=-5V 市小性 Infinite heat sink 市 市 Unit Value(typ) Value(max) 市小性 市小4 市小换 市小明 BASE-EMITTER VOLTAGE 式 VBE V 式小性 式小4 CASE TEMPERATURE TC 2/3 IC A 2SC4793 NPN Silicon NPN Triple Diffused Transistor Tc = 25°C to Single nonrepetitive pulse r COLLECTOR CURRENT IC A SAFE OPERATION AREA Curves must be derated linear VCE V co COLLECTOR-EMITTER VOLTAGE nd uc with increase in temperature. PACKAGE MECHANICAL DATA Se RO   MI C JS Unit mi TO-220F mm mm A 4.50-4.90 B
2SC4793 价格&库存
很抱歉,暂时无法提供与“2SC4793”相匹配的价格&库存,您可以联系我们找货
