A1015
A1015
    JSMSEMI(杰盛微)
    SOT-23
    SOT23-3 150mA 80MHz
A1015 数据手册
A1015 Silicon Epitaxial Planar Transistor FEATURES z Complementary To 2SC1815. z Excellent HFE Linearity. z High voltage and high current. z Low noise. z Collector-Emitter voltage BVCEO=-50V. to r SOT-23 APPLICATIONS uc Low frequency , low noise amplifier. nd z Type No. co ORDERING INFORMATION Marking BA SOT-23 mi A1015 Package Code Parameter VCBO Units Collector-Base Voltage -50 V Collector-Emitter Voltage -50 V JS MI VCEO Value CR O Symbol Se MAXIMUM RATING @ Ta=25℃ unless otherwise specified VEBO Emitter-Base Voltage -5 V IC Collector Current -Continuous -150 mA PC Collector Dissipation 400 mW Tj,Tstg Junction and Storage Temperature -55 to +150 ℃ www.jsmsemi.com 第1页,共4页 A1015 Silicon Epitaxial Planar Transistor ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified Parameter Symbol Test conditions Collector-base breakdown voltage V(BR)CBO IC=-100μA,IE=0 -50 V Collector-emitter breakdown voltage V(BR)CEO IC=-0.1mA,IB=0 -50 V Emitter-base breakdown voltage V(BR)EBO IE=-10μA,IC=0 Collector cut-off current ICBO VCB=-50V,IE=0 Collector cut-off current ICEO VCE=-50V,IB=0 Emitter cut-off current IEBO VEB=-5V,IC=0 VCE=-6V,IC=-150mA 25 mi IC=-100 mA, IB=- 10mA VBE(sat) IC=-100 mA, IB= -10mA VCE=-10V, IC= -1mA f=30MHz OF JS MI CLASSIFICATION fT UNIT V -0.1 μA -0.1 μA -0.1 μA 400 80 -0.1 Se Transition frequency MAX to r 70 VCE(sat) CR O Base-emitter saturation voltage uc nd VCE=-6V,IC=-2mA hFE Collector-emitter saturation voltage TYP -5 co DC current gain MIN 80 -0.3 V -1.1 V MHz hFE(1) Rank L H Range 130-200 200-400 www.jsmsemi.com 第2页,共4页 A1015 Silicon Epitaxial Planar Transistor JS MI CR O Se mi co nd uc to r TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified www.jsmsemi.com 第3页,共4页 A1015 Silicon Epitaxial Planar Transistor PACKAGE OUTLINE Plastic surface mounted package SOT-23 SOT-23 A Min Max A 2.70 3.10 E K B B C D G 1.80 2.00 H 0.02 0.1 2.20 2.60 All Dimensions in mm mi co K 0.1 Typical CR O 0.95 0.4 Typical Se SOLDERING FOOTPRINT 0.95 1.0 Typical 0.48 J H 1.50 0.35 nd G C 1.10 uc E J D to r Dim JS MI 2.00 0.90 Unit : mm 0.80 PACKAGE INFORMATION Device Package Shipping A1015 SOT-23 3000/Tape&Reel www.jsmsemi.com 第4页,共4页
A1015 价格&库存
很抱歉,暂时无法提供与“A1015”相匹配的价格&库存,您可以联系我们找货
