FN31X102K500PXG
FN31X102K500PXG
    PSA(信昌电陶)
    贴片电容(MLCC) 1206 1nF ±10% 50V X7R
FN31X102K500PXG 数据手册
信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. No.566-1, Kaoshi Rd., Yangmei, Taoyuan 32668, Taiwan (R.O.C.) Tel : 886-3-4753355 Fax : 886-3-4854959 Messrs. : Date : 一般共用 2023/03/25 APPROVAL SHEET Product Name : General Purpose Multilayer Ceramic Chip Capacitors Part No. : FN Series Description : Size 01R5~2225, C0G/X7R/X7S/X6S/X5R, UR≤50V PREPARED BY APPROVED BY 信昌電子陶瓷股份有限公司 PROSPERITY DIELECTRICS CO., LTD. 桃園市楊梅區高獅路 566-1 號 Tel : 03-4753355 ext : Contactor : http://www.pdc.com.tw Fax : 03-4854959 Mobile : DCM-003-8.1 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. No.566-1, Kaoshi Rd., Yangmei, Taoyuan 32668, Taiwan (R.O.C.) Tel : 886-3-4753355 Fax : 886-3-4854959 SPECIFICATION FOR Product Name : General Purpose Multilayer Ceramic Chip Capacitors Part No. : FN Series Description : Size 01R5~2225, C0G/X7R/X7S/X6S/X5R, UR≤50V SPEC. No. : FN-000-001-20 DATE : 2023/03/25 DRAWN BY CHECEKED BY APPROVED BY Jane Hsiao Yvens Chou Jason Lin DCM-003-8.2 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 1. INTRODUCTION POSPERITY Multilayer Ceramic Chip Capacitors supplied in bulk or tape & reel package are ideally suitable for thick-film hybrid circuits and automatic surface mounting on any printed circuit boards. The nickel-barrier terminations are consisted of a nickel barrier layer over the silver metallization and then finished by electroplated solder layer to ensure the terminations have good solderability. The nickel barrier layer in terminations prevents the dissolution of termination when extended immersion in molten solder at elevated solder temperature. 2. FEATURES 3. APPLICATIONS a. A wide selection of sizes is available (0201 to 2225). b. High capacitance in given case size. c. Capacitor with lead-free termination (pure Tin). d. RoHS & HALOGEN compliant. a. For general digital circuit. b. For power supply bypass capacitors. c. For consumer electronics. d. For telecommunication. e. DC to DC converter. 4. HOW TO ORDER FN PDC Family Table 1 21 X Size 471 K Dielectric Capacitance Tolerance Table 2 Table 3 Table 4 Table 5 500 Rated Voltage Table 6 P X Packaging Thickness Table 7 Table 6 Table 8 G Control Code Table 9 Table 1 PDC Family Code Description Code Description Code Description Code Description FN General purpose product ≤50Vdc 4R0 4.0Vdc 100 10Vdc 250 25Vdc 6R3 6.3Vdc 160 16Vdc 500 50Vdc Table 2 General Purpose Code Description Code Description Code Description 02 03 15 01R5 (0402) 0201 (0603) 0402 (1005) 31 32 42 1206 (3216) 1210 (3225) 1808 (4520) 52 55 56 2211 (5728) 2220 (5750) 2225 (5763) 18 0603 (1608) 43 1812 (4532) 21 0805 (2012) 46 1825 (4563) Table 3 Rated Voltage Table 7 Dielectric Material Characteristics Packaging Type Code Description Code Description B Bulk T Tray package Code Description Code Description Code Description E Tape and 7” Reel, Embossed Tape P Tape and 7” Reel, Paper Tape N C0G X X7R S X6S K Tape and 10” Reel, Embossed Tape D Tape and 10” Reel, Paper Tape B X5R A X7S L Tape and 13” Reel, Embossed Tape G Tape and 13” Reel, Paper Tape Table 4 Capacitance Rule Code Table 8 Thickness Description Code Description Code Description Code Description Code Description Code Description R47 0.47pF 102 102=10x102=1000pF A 0.60 ± 0.10 mm I 1.25 ± 0.20 mm Q 0.50 +0.02/-0.05 mm 0R5 100 0.5pF 100=10x100=10pF 104 106 104=10x104=100nF 106=10x106=10µF B C 0.8 + 0.15/-0.10 mm J K 1.15 ± 0.15 mm 0.50 ± 0.20 mm R S 3.10 ± 0.30 mm 1.25 ± 0.10 mm D 1.40 ± 0.15 mm L 0.30 ± 0.03 mm T 0.85 ± 0.10 mm E 1.60 ± 0.20 mm M 0.95 ± 0.10 mm U 0.50 ± 0.10 mm Table 5 Tolerance 0.80 ± 0.07 mm Code Description Code Description Code Description F 2.00 ± 0.20 mm N 0.50 ± 0.05 mm V 0.20 ± 0.02 mm A ±0.05 pF I -10% ~ 0% Q ±0.03 pF G 2.50 ± 0.30 mm O 3.50 ± 0.20 mm X 0.80 ± 0.10 mm B ±0.10 pF J ±5 % Z -20% ~ +80% H 2.80 ± 0.30 mm P 1.60 +0.3/-0.10 mm Z 0.25 ± 0.03 mm C ±0.25 pF K ±10 % X +10% ~ +20% D ±0.50 pF L 0% ~ +10% Table 9 F ±1 % M ±20 % Code Description G ±2 % N -5% ~ +10% G RoHS Compliant H ±3 % P ±0.02 pF Special Control Code Specification No. : FN-000-001-20 ~1~ DCM-003-8.3 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 5. EXTERNAL DIMENSIONS Size Inch (mm) 01R5(0402) 0201(0603) 0402(1005) 0603(1608) 0805(2012) 1206(3216) 1210(3225) L (mm) W (mm) Code / T (mm) 0.40±0.02 0.20±0.02 0.60±0.03 0.30±0.03 0.60±0.05 (Cap.≥0.68μF) 0.30±0.05 (Cap.≥0.68μF) 1.00±0.10 0.50±0.10 1.00±0.20#1 0.50±0.20#1 1.60±0.15 0.80±0.15 2.00±0.20 1.25±0.20 3.20±0.20 1.60±0.20 3.20 +0.30/-0.10#2 1.60 +0.30/-0.10#2 3.20±0.30 2.50±0.30 1808(4520) 1812(4532) 1825(4563) 2220(5750) 2225(5763) 4.50±0.40 4.50±0.40 4.50±0.40 5.70±0.40 5.70±0.40 #1 MB (mm) 0.10±0.03 0.15±0.05 0.25 +0.05/-0.10 L See No.4 Reference Table 8 0.40±0.15 0.50±0.20 0.75±0.35 0.75±0.35 0.75±0.35 0.75±0.35 0.85±0.35 0.85±0.35 2.00±0.25 3.20±0.30 6.30±0.40 5.00±0.40 6.30±0.40 T 0.60±0.20 W MB MB Fig. 5.1 The outline of MLCC #2 “ ” For 0402 size K thickness products. “ ” For 1206 size P thickness products. 6. GENERAL ELECTRICAL DATA Dielectric C0G Size 01R5, 0201, 0402, 0603, 0805, 1206, 1210, 1808, 1812, 1825, 2220, 2225 Rated voltage (WVDC) 10V, 16V, 25V, 50V Capacitance range* X7R X5R X6S 01R5, 0201, 0402, 0603, 0805, 01R5, 0201, 0201, 0402 1206, 1210, 1812, 0402, 0603 1825, 2220, 2225 6.3V, 10V, 16V, 4V, 6.3V, 10V, 4V, 6.3V, 10V,16V, 25V 25V, 50V 16V, 25V, 50V 100pF to 820nF 100pF to 820nF 100nF to 470nF X7S 0201 10V 0R1 to 100nF 100nF B(±0.1pF), C(±0.25pF),D(±0.5pF) Capacitance tolerance** J(±5% ), K(±10%), M(±20%) K(±10%), M(±20%) F(±1%),G(±2%) J(±5% ), K(±10%) Cap.1000pF, 25°C at ambient temperature. X7R/X5R/X7S/X6S : Apply 1.0±0.2Vrms, 1.0KHz±10%, at 25°C ambient temperature. ** Preconditioning for Class II MLCC : Perform a heat treatment at 150±10°C for 1 hour, then leave in ambient condition for 24±2 hours before measurement. Note 1 : X7R/X5R/X6S/X7S Rated D.F.≤ 50V ≤2.5% Exception of D.F.≤ ≤3.5% 0201(50V), 0603≥0.047μF, 0805≥0.1μF, 1206≥0.47μF ≤5% 0201≥0.01uF, ≤10% 0402≥0.012μF, 0603>0.1μF ≤5% 0201≥0.01μF ≤7% 0603≥0.33μF ≤10% 0201≥0.1μF, 0402≥0.10μF, 0603≥0.47μF ≤12.5% 0402≥0.47μF ≤5% 0201≥0.01μF, 0402≥0.033μF, 0603≥0.15μF, 0805≥0.68μF, ≤10% 0201≥0.1uF(0201/X7R≥0.022μF), 0402≥0.22uF, 0603≥0.68μF, ≤10% 0201≥0.012μF, 0402≥0.33μF(0402/X7R≥0.22μF), 0603≥0.33μF, ≤15% 0201≥0.1μF 25V ≤3.5% 16V ≤3.5% 10V ≤5% 6.3V ≤10% ≤15% 4V 10V 6.3V,10V ≤15% ≤5% ≤10% ------- 0201≥0.1μF --01R5 01R5 Specification No. : FN-000-001-20 ~2~ DCM-003-8.3 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 7. CAPACITANCE RANGE 7-1. C0G Cap(pF) 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.0 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10 12 15 18 22 27 33 39 47 56 68 82 100 120 150 180 220 270 330 390 470 560 680 820 1000 1200 1500 1800 2200 2700 3300 3900 4700 5600 6800 8200 10000 12000 15000 18000 22000 27000 33000 39000 47000 56000 68000 82000 100000 EIA Size Code 0R1 0R2 0R3 0R4 0R5 0R6 0R7 0R8 0R9 1R0 1R0 1R2 1R5 1R8 2R2 2R7 3R3 3R9 4R7 5R6 6R8 8R2 100 120 150 180 220 270 330 390 470 560 680 820 101 121 151 181 221 271 331 391 471 561 681 821 102 122 152 182 222 272 332 392 472 562 682 822 103 123 153 183 223 273 333 393 473 563 683 823 104 10V L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L 0201 16V 25V L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L 50V L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L L 10V N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N 0402 16V 25V N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N 50V N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N 10V S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S B B B B B B B B B B B B 0603 16V 25V S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S B B B B B B B B B B B B S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S B B B B B B B B B B B B 50V S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S B B B B B B B B B B B B 10V 0805 16V 25V A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A X X X X X X X X X X C C C C C C C C T/C C C C A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A X X X X X X X X X X C C C C C C C C T/C C C C A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A X X X X X X X X X X C C C C C C C C T/C C C C 50V A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A X X X X X X X X X X C C C C C C C C C C C C 10V X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X C C C P P P P P P P P P P P E/P 1206 16V 25V 50V X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X C C C P P P P P P P P P P P E/P X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X C C C P P P P P P P P P P P E/P X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X C C C P P P P P P P P P P P E/P Specification No. : FN-000-001-20 ~3~ DCM-003-8.3 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 7. CAPACITANCE RANGE(Con.) 7-1. C0G Cap(pF) EIA Size Code 1210 10V 16V 1808 25V 50V 1812 25V 50V 1825 2220 2225 10V 16V 25V 50V 25V 50V 25V 50V 25V 50V 2.2 2R2 C C 2.7 2R7 C C 3.3 3R3 C C 3.9 3R9 C C 4.7 4R7 C C 5.6 5R6 C C 6.8 6R8 C C 8.2 8R2 C C 10 100 M M M M C C C C C C F F F F F F 12 120 M M M M C C C C C C F F F F F F 15 150 M M M M C C C C C C F F F F F F 18 180 M M M M C C C C C C F F F F F F 22 220 M M M M C C C C C C F F F F F F 27 270 M M M M C C C C C C F F F F F F 33 330 M M M M C C C C C C F F F F F F 39 390 M M M M C C C C C C F F F F F F 47 470 M M M M C C C C C C F F F F F F 56 560 M M M M C C C C C C F F F F F F 68 680 M M M M C C C C C C F F F F F F 82 820 M M M M C C C C C C F F F F F F 100 101 M M M M C C C C C C F F F F F F 120 121 M M M M C C C C C C F F F F F F 150 151 M M M M C C C C C C F F F F F F 180 181 M M M M C C C C C C F F F F F F 220 221 M M M M C C C C C C F F F F F F 270 271 M M M M C C C C C C F F F F F F 330 331 M M M M C C C C C C F F F F F F 390 391 M M M M C C C C C C F F F F F F 470 471 M M M M C C C C C C F F F F F F 560 561 M M M M C C C C C C F F F F F F 680 681 M M M M C C C C C C F F F F F F 820 821 M M M M C C C C C C F F F F F F 1000 102 M M M M C C C C C C F F F F F F 1200 122 M M M M C C C C C C F F F F F F 1500 152 M M M M C C C C C C F F F F F F 1800 182 M M M M C C C C C C F F F F F F 2200 222 M M M M C C C C C C F F F F F F 2700 272 M M M M C C C C C C F F F F F F 3300 332 M M M M C C C C C C F F F F F F 3900 392 M M M M C C C C C C F F F F F F 4700 472 M M M M C C C C C C F F F F F F 5600 562 M M M M C C C C C C F F F F F F 6800 682 M M M/C M/C C C C C C C F F F F F F 8200 822 M M M/C M/C C C C C C C F F F F F F 10000 103 M M M/C M/C C C C C C C F F F F F F 12000 123 C C C/E C/E E E C C C C F F F F F F 15000 153 C C C/E C/E E E C C C C F F F F F F 18000 183 F F F F F F C C C C F F F F F F 22000 223 F F F F F F C C C C F F F F F F 27000 273 F F F/G F/G C C E E F F F F F F 33000 333 F F F/G F/G C C E E F F F F F F 39000 393 F F F/G F/G G G G G F F F F F F 47000 473 F F F/G F/G G G G G F F F F F F 56000 563 G G G G F F F F F F 68000 683 G G G G F F F F F F 82000 823 G G G G F F F F F F 100000 104 G G G G G G G G F F Specification No. : FN-000-001-20 ~4~ DCM-003-8.3 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 7. CAPACITANCE RANGE(Con.) 7-2. X7R Cap(pF) EIA Size Code 0201 6.3V 10V 0402 25V 50V 16V 25V 50V L L L N N N N S S S S X X X X 120 121 L L L N N N N S S S S X X X X 150 151 L L L N N N N S S S S X X X X 180 181 L L L N N N N S S S S X X X X 220 221 L L L N N N N S S S S X X X X 270 271 L L L N N N N S S S S X X X X 330 331 L L L N N N N S S S S X X X X 390 391 L L L N N N N S S S S X X X X 470 471 L L L N N N N S S S S X X X X 560 561 L L L N N N N S S S S X X X X 680 681 L L L N N N N S S S S X X X X 820 821 L L L N N N N S S S S X X X X 1000 102 L L L L L N N N N S S S S X X X X 1200 122 L L L L N N N N S S S S X X X X 1500 152 L L L L N N N N S S S S X X X X 1800 182 L L L L N N N N S S S S X X X X 2200 222 L L L L N N N N S S S S X X X X 2700 272 L L L L N N N N S S S S X X X X 3300 332 L L L L N N N N S S S S X X X X 3900 392 L L L L N N N N S S S S X X X X 4700 472 L L L L N N N N S S S S X X X X 5600 562 L L L L N N N N S S S S X X X X 6800 682 L L L N N N N S S S S X X X X 8200 822 L L L N N N N S S S S X X X X 10000 103 L L L N N N N S S S S X X X X 12000 123 N N N N/K S S S S X X X X 15000 153 N N N N/K S S S S X X X X 18000 183 N N N N/K S S S S X X X X 22000 223 N N N N/K S S S S X X X X 27000 273 N N N N/K S S S S X X X X 33000 333 N N N N/K S S B B X X X X 39000 393 N N N N/K S S B B X X X X 47000 473 N N N N/K S S B B X X X X 56000 563 N N N K S S B B X X X X 68000 683 N N N K S S B B X X X X 82000 823 N N N K S S B B X X X X/C 100000 104 N N N K S S B B X X X X/C 120000 124 S S B X X X C 150000 154 S S B C C C C 180000 184 S S B C C C C 220000 224 S S B C C C C/I 270000 274 B B B C C C I 330000 334 B B B C C C I 390000 394 B B B C C C I 470000 474 B B B C C C I 560000 564 B B C C C I 680000 684 B B C C C I 820000 824 B B C C C I L N N N N 10V 16V 25V 50V N N 6.3V 0805 101 L 6.3V 0603 100 L 16V N B N N B B 10V 16V 25V 50V 6.3V B B C B B 10V Specification No. : FN-000-001-20 ~5~ DCM-003-8.3 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 7. CAPACITANCE RANGE(Con.) 7-2. X7R Cap(pF) 1206 EIA Size Code 6.3V 10V 16V 1210 25V 50V 6.3V 10V 16V 1812 25V 50V 10V 16V 1825 25V 50V 2220 2225 25V 50V 25V 50V 25V 50V 100 101 X X 120 121 X X 150 151 X X X X 180 181 X X X X 220 221 X X X X M M 270 271 X X X X M M C C 330 331 X X X X M M C C 390 391 X X X X M M C C 470 471 X X X X M M C C 560 561 X X X X M M C C 680 681 X X X X M M C C 820 821 X X X X M M C C 1000 102 X X X X M M M M C C C C F F F F F F 1200 122 X X X X M M M M C C C C F F F F F F 1500 152 X X X X M M M M C C C C F F F F F F 1800 182 X X X X M M M M C C C C F F F F F F 2200 222 X X X X M M M M C C C C F F F F F F 2700 272 X X X X M M M M C C C C F F F F F F 3300 332 X X X X M M M M C C C C F F F F F F 3900 392 X X X X M M M M C C C C F F F F F F 4700 472 X X X X M M M M C C C C F F F F F F 5600 562 X X X X M M M M C C C C F F F F F F 6800 682 X X X X M M M M C C C C F F F F F F 8200 822 X X X X M M M M C C C C F F F F F F 10000 103 X X X X M M M M C C C C F F F F F F 12000 123 X X X X M M M M C C C C F F F F F F 15000 153 X X X X M M M M C C C C F F F F F F 18000 183 X X X X M M M M C C C C F F F F F F 22000 223 X X X X M M M M C C C C F F F F F F 27000 273 X X X X M M M M C C C C F F F F F F 33000 333 X X X X M M M M C C C C F F F F F F 39000 393 X X X X M M M M C C C C F F F F F F 47000 473 X X X X M M M M C C C C F F F F F F 56000 563 X X X X M M M M C C C C F F F F F F 68000 683 X X X X M M M M C C C C F F F F F F 82000 823 X X X X M M M M C C C C F F F F F F 100000 104 X X X X M M M M C C C C F F F F F F 120000 124 X X X X M M M M C C C C F F F F F F 150000 154 M M M M M M M M C C C C F F F F F F 180000 184 M M M M M M M M C C C C F F F F F F 220000 224 M M M M M M M M C C C C F F F F F F 270000 274 M M M C M M M M C C C C F F F F F F 330000 334 M M M C M M M C C C C C F F F F F F 390000 394 M M C P M M M C C C C C F F F F F F 470000 474 J J C/J P M M M C C C C C F F F F F F 560000 564 J J C/J P C C C C C C C C F F F F F F 680000 684 J J C/J P C C C C C C C F F F F F F F 820000 824 J J C/J P C C C C C C C F F F F F F F Specification No. : FN-000-001-20 ~6~ DCM-003-8.3 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 7. CAPACITANCE RANGE(Con.) 7-3. X5R EIA Size 0201 0402 0603 Cap(pF) Code 16V 25V 50V L L L L L L L L L L L L L L L L L L L L L L 152 L L L 2200 222 L L L 2700 272 3300 332 L L L 4700 472 L L L 100 101 120 121 150 151 180 181 220 221 270 271 330 331 390 391 470 471 560 561 680 681 820 821 1000 102 1500 4V 6.3V 10V 6800 682 L L L 10000 103 L L L L 15000 153 L L 22000 223 L L 27000 273 33000 333 L L 39000 393 47000 473 L L 56000 563 L L 68000 683 L L 82000 823 100000 104 L L 150000 154 220000 224 270000 274 330000 334 390000 394 470000 474 680000 684 820000 824 L 4V 6.3V 10V 16V 25V 50V 4V 6.3V 10V 16V 25V 50V 4V 6.3V 10V 16V 25V 50V L N N N N N N N N N N N N K N N N N N N N N N N N N L N N N L N N N/K N N L L K K N K S B B B B B B B B B B B B B B B B B B Specification No. : FN-000-001-20 ~7~ DCM-003-8.3 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 7. CAPACITANCE RANGE(Con.) 7-5. X6S EIA Size 0201 0402 Cap(pF) Code 4V 6.3V 10V 16V 25V 6.3V 100000 104 L L L L L N 150000 154 220000 224 L L* 330000 334 470000 474 680000 684 L 10V 16V 25V 50V N K/N 7. CAPACITANCE RANGE(Con.) 7-6. X7S EIA Size 0201 Cap(pF) Code 10V 100000 104 L 150000 154 220000 224 330000 334 470000 474 680000 684 Specification No. : FN-000-001-20 ~8~ DCM-003-8.3 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 7. CAPACITANCE RANGE(Con.) 7-7. 01R5 50 V V V V V V V V V V V V V V V V V V V V V V V V V V V SIZE DIELECTRIC RATED VOLTAGE (VDC) 100pF (101) 150pF (151) 220pF (221) 330pF (331) 470pF (471) 1,000pF (102) 01R5 X7R 10 V V V V V V SIZE DIELECTRIC RATED VOLTAGE (VDC) 1,000pF (102) 1,500pF (152) 2,200pF (222) 3,300pF (332) 4,700pF (472) 6,800pF (682) 0.010μF (103) 0.015μF (153) 0.022μF (223) 0.033μF (333) 0.047μF (473) 0.068μF (683) 0.10μF (104) 01R5 X5R Capacitance 16 V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V 01R5 NP0 25 V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V V Capacitance Capacitance SIZE DIELECTRIC RATED VOLTAGE (VDC) 0.2pF (0R2) 0.3pF (0R3) 0.4pF (0R4) 0.5pF (0R5) 1.0pF (1R0) 1.5pF (1R5) 2.0pF (2R0) 3.0pF (3R0) 4.0pF (4R0) 5.0pF (5R0) 6.0pF (6R0) 7.0pF (7R0) 8.0pF (8R0) 9.0pF (9R0) 10pF (100) 12pF (120) 15pF (150) 18pF (180) 22pF (220) 27pF (270) 33pF (330) 39pF (390) 47pF (470) 56pF (560) 68pF (680) 82pF (820) 100pF (101) 120pF (121) 150pF (151) 180pF (181) 220pF (221) 6.3 V V 10 V V V V V V V V V V V . Specification No. : FN-000-001-20 ~9~ DCM-003-8.3 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 8. RELIABILITY TEST CONDITIONS AND REQUIREMENTS No. 1. Item Visual and Dimensions Test Condition Requirements * No remarkable defect. --- * Dimensions to confirm to individual specification sheet. 2. Capacitance * Shall not exceed the limits given in the detailed spec. * C0G : Cap.≥30pF, Q≥1000; Cap.1000pF, 1.0±0.2Vrms, 1KHz±10%. 50V 3. (Tangent of loss angle) 0201(50V), 0603≥0.047μF, 0805≥0.1μF, 1206≥0.47μF ≤2.5% ≤5% 0201≥0.01uF Cap.≤10µF, 1.0±0.2Vrms, 1KHz±10%**. ≤10% 0402≥0.012μF, 0603>0.1μF Cap.>10µF, 0.5±0.2Vrms, 120Hz±20%. ≤5% 0201≥0.01μF ≤7% 0603≥0.33μF ≤10% 0201≥0.1μF, 0402≥0.10μF, 0603≥0.47μF, ≤12.5% 0402≥0.47μF 0201≥0.01μF, 0402≥0.033μF, 0603≥0.15μF, 0805≥0.68μF 0201≥0.1uF(0201/X7R≥0.022μF), 0402≥0.22uF, 0603≥0.68μF 0201≥0.012μF, 0402≥0.33μF(0402/X7R≥0.22μF), 0603≥0.33μF 0201≥0.1μF 0201≥0.1μF --- * Class II : (X7R, X5R, X7S,X6S) Q/D.F. ≤3.5% ** Test condition : 0.5±0.2Vrms, 1KHz±10%. X5R : 0201≥224(6.3V,10V,16V)#1, X7R & X5R(≥10V) & 01R5X103≤6.3V & 01R5X104≤10V * 0.5±0.2Vrms, 1kHz±10%: X5R(≤6.3V); 25V ≤3.5% ≤5% 16V ≤3.5% ≤10% Excluding 01R5X103≤6.3V & 01R5X104≤10V 10V ≤5% 6.3V 4V ≤10% ≤15% ≤10% ≤15% ≤15% --- Specification No. : FN-000-001-20 ~ 10 ~ DCM-003-8.3 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 8. RELIABILITY TEST CONDITIONS AND REQUIREMENTS No. Item Temperature Coefficient Test Condition Requirements * With no electrical load. T.C. Operating Temp. C0G -55~125°C at 25°C X7R -55~125°C at 25°C X5R -55~ 85°C at 25°C X7S -55 ~ 125°C at 25°C X6S -55~105°C at 25°C 4. (Temperature * Measurement voltage for Class II : Size Cap. Range of capacitance) Cap.0.1µF 6.3V : 0201≥0.1µF Specification No. : FN-000-001-20 ~ 11 ~ DCM-003-8.3 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 8. RELIABILITY TEST CONDITIONS AND REQUIREMENTS No. 6. Item Dielectric Strength Test Condition * To apply 250% of rated voltage. * Duration : 1 to 5 sec. * No evidence of damage or flash over during test. * Charge and discharge current less than 50mA. * Solder temperature : 235±5°C for (01R5,0201~1210). 7. Solderability Requirements * Solder temperature : 245±5°C for (1808~2225). * Dipping time : 2±0.5 sec. * 75% min. coverage of all metalized area. * 95% min. coverage of all metalized area.(for 01R5) * Solder temperature : 260±5°C. * Dipping time : 10±1 sec. * Preheating : 120 to 150°C for 1 minute before Resistance to immerse the capacitor in a eutectic solder. 8. Soldering Heat * Before initial measurement (Class II only) : To apply de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. * Measurement to be made after keeping at room * No remarkable damage. * Cap. change : C0G : Within ±2.5% or ±0.25pF, whichever is larger. X7R, X5R,X6S,X7S : Within ±7.5%. * D.F.(Q)/I.R. : To meet initial requirements. * 25% max. leaching on each edge. temp. for 24±2 hrs (Class I) or 48±4 hrs (Class II). * Conduct the five cycles according to the temperatures and time. Step Temp.(°C) Time(min.) 1 Min. operating temp. +0/-3 30±3 Temperature 2 Room temp. 2~3 Cycle 3 Max. operating temp. +3/-0 30±3 9. (Rapid change 4 Room temp. 2~3 of * Before initial measurement (Class II only) : To apply temperature) de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. * No remarkable damage. * Cap. change : C0G : Within ±2.5% or ±0.25pF, whichever is larger. X7R, X5R ,X7S, X6S : Within ±7.5%. 01R5 X5R: Within ±15.0% * Q for C0G : To meet initial requirements. * D.F.(Class II) : ≤150% of initial requirement. * I.R. : To meet initial requirements. * 01R5 Q/D.F., I.R. and dielectric strength: To meet initial requirements. * Measurement to be made after keeping at room temp. for 24±2 hrs (Class I) or 48±4 hrs (Class II). Specification No. : FN-000-001-20 ~ 12 ~ DCM-003-8.3 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 8. RELIABILITY TEST CONDITIONS AND REQUIREMENTS No. Item Test Condition Requirements * No remarkable damage. * Cap. change : C0G : Within ±5.0% or ±0.5pF, whichever is larger. X7R, X5R, X6S, X7S : Within ±12.5% for ≥10V**, within ±25% for 6.3V. 01R5 X5R: within ±25.0% **10V : Within ±25% for 0603≥4.7µF, 0402≥1µF, 0201≥0.1µF. * Q/DF for C0G : Cap.>30pF, Q≥350. Humidity 10. * Test temp. : 40±2°C. 10pF≤Cap.≤30pF, Q≥275+2.5C. * Humidity : 90~95% RH. Cap.0.01µF 25V : 0201≥0.1uF, 0402≥0.22µF 16V : 0201≥0.1uF, 0402≥0.22µF 10V : 0201≥47nF, 0402≥0.47µF, 0603≥0.47µF, 6.3V; 4V; Size≥1812 ≥1GΩ or RxC≥10Ω-F, whichever is smaller * No remarkable damage. * Cap. change : C0G : Within ±7.5% or ±0.75pF, whichever is larger. X7R, X5R,X7S, X6S : Within ±12.5% for ≥10V**, within ±25% for 6.3V. **10V : Within ±25% for 0603≥4.7µF, 0402≥1µF, 0201≥0.1µF. * Test temp. : 40±2°C. * Humidity : 90~95%RH. * Test time : 500 +24/-0hrs. Humidity * To apply voltage : Rated voltage. 11. (Damp Heat) * Before initial measurement (Class II only) : To apply Load de-aging at 150°C for 1hr then set for 24±2 hrs at * Q for C0G : Cap.≥30pF, Q≥200; Cap.0.1µF C0G : Within ±3.0% or ±0.3pF, whichever is larger. 6.3V - X7R, X5R,X7S, X6S : Within ±12.5% for ≥10V**, within ±25% for ≤6.3V. (4) 150% of rated voltage for below range : Size Dielectric Rated Voltage Capacitance 01R5 X5R 10V - X5R/X7R/X6S 16V/25V C≥0.1µF X7R 16V C≥0.022µF 50V C≥0.1µF 10~25V C≥0.22µF 0201 High 12. Temperature Load (Endurance) 0402 X5R/X7R/X6S 0603 X7R ≥50V C≥0.082µF 0805 X5R/X7R 50V C≥0.47µF * Test time : 1000 +24/-0 hrs. * Before initial measurement (Class II only) : To apply de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. * Measurement to be made after keeping at room temp. for 24±2 hrs (Class I) or 48±4 hrs (Class II). ** De-rating conditions : (For 100% of rated voltage items) 01R5 :X7R Within ±12.5%,X5R Within ±25.0% **10V : Within ±25% for 0603≥4.7μF, 0402≥1μF, 0201≥0.1μF. * Q for C0G : Cap.>30pF, Q≥350. 10pF≤Cap.≤30pF, Q≥275+2.5C. 01R5 : X7R ≤7.5%, X5R ≤20% Cap.0.01µF 25V : 0201≥0.1uF, 0402≥0.22µF 16V : 0201≥0.1uF, 0402≥0.22µF 10V : 0201≥47nF, 0402≥0.47µF, 0603≥0.47µF, 6.3V; 4V; Size≥1812 ≥1GΩ or RxC≥10ΩF, whichever is smaller Specification No. : FN-000-001-20 ~ 14 ~ DCM-003-8.3 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 8. RELIABILITY TEST CONDITIONS AND REQUIREMENTS No. Item Test Condition Requirements * Capacitors mounted on a substrate. A force of 1N(01R5) or 2N(0201) or 5N(0402~0603) or Adhesive Strength of Termination 13. (Robustness 10N(>0603) applied perpendicular to the place of substrate and parallel the line joining the center of terminations for 10±1 second. * No remarkable damage or removal of the terminations. of termination) * The middle part of substrate shall be pressurized by means of the pressurizing rod at a rate of about 1mm per second until the deflection becomes 1mm. Resistance to Flexure of 14. Substrate (Substrate * No remarkable damage. Dielectric Cap. Change C0G Within ±5.0% or ±0.5pF, whichever is larger X7R, X5R,X7S,X6S Within ±12.5% 01R5 X5R Within ±25.0% (This capacitance change means the change of capacitance under bending test) specified flexure of substrate from the capacitance measured before the test) Unit : mm * Vibration frequency : 10~55 Hz/min. * Total amplitude : 1.5mm. * Test time : 6 hrs. (Two hrs each in three mutually 15. Vibration Resistance perpendicular directions) * Before initial measurement (Class II only) : To apply de-aging at 150°C for 1hr then set for 24±2 hrs at * No remarkable damage. * Cap. change and D.F. : To meet initial spec. room temp. * Measurement to be made after keeping at room temp. for 24±2 hrs (Class I) or 48±4 hrs (Class II). Specification No. : FN-000-001-20 ~ 15 ~ DCM-003-8.3 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 9. PACKAGE DIMENSION AND QUANTITY Size Thickness (mm) 01R5 (0402) 0.20±0.02 0.30±0.03 0.30±0.05 0.30±0.09 0.50±0.05 0.50 +0.02/-0.05 0.50±0.20 0.50±0.10 0.80±0.07 0.80 +0.15/-0.10 0.50±0.10 0.60±0.10 0.80±0.10 0.85±0.10 1.25±0.10 1.25±0.20 0.80±0.10 0.85±0.10 0.95±0.10 1.15±0.15 1.25±0.10 1.60±0.20 1.60 +0.30/-0.10 0.85±0.10 0.95±0.10 1.25±0.10 1.60±0.20 2.00±0.20 2.50±0.30 1.25±0.10 1.60±0.20 2.00±0.20 1.25±0.10 1.60±0.20 2.00±0.20 2.50±0.30 2.80±0.30 1.60±0.20 2.00±0.20 2.50±0.30 2.80±0.30 1.60±0.20 2.00±0.20 2.50±0.30 2.80±0.30 1.60±0.20 2.00±0.20 2.50±0.30 2.80±0.30 0201(0603) 0402(1005) 0603(1608) 0805(2012) 1206(3216) 1210(3225) 1808(4520) 1812(4532) 1825(4563) 2220(5750) 2225(5763) Paper tape 7” reel 20k 15k 15k 15k 10k 10k 10k 4k 4k 4k 4k 4k 4k 4k 4k 4k - Plastic tape 13” reel 70k 50k 50k 15k 15k 15k 15k 15k 15k 15k 15k - 7” reel 3k 3k 3k 3k 3k 2k 2k 3k 3k 3k 2k 1k 1k 2k 2k 1k 1k 1k 1k 0.5k 0.5k 1k 1k 0.5k 0.5k 1k 1k 0.5k 0.5k 1k 1k 0.5k 0.5k 13” reel 10k 10k 10k 10k 10k 10k 9k 10k 10k 10k 6k 6k 10k 8k 6k 5k 3k Unit : pcs Specification No. : FN-000-001-20 ~ 16 ~ DCM-003-8.3 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 9. PACKAGE DIMENSION AND QUANTITY 9.1. EMBOSSED TAPE DIMENSIONS Fig. 9.1 The dimension of paper tape Fig. 9.2 The dimension of plastic tape Size 01R5 0201 0402 0603 Chip Thickness 0.20±0.02 0.50±0.05 0.50±0.10 0.50±0.05 0.50±0.10 0.80±0.07 A0 B0 T K0 W P0 10xP0 P1 P2 D0 D1 E F Unit : 0.25±0.05 0.45±0.07 ≤0.50 8.00±0.30 4.00±0.10 40.00±0.10 2.00±0.05 2.00±0.05 1.50+0.1/-0 1.75±0.10 3.50±0.05 mm 0.40±0.10 0.70±0.10 ≤0.55 8.00±0.30 4.00±0.10 40.00±0.10 2.00±0.05 2.00±0.05 1.50+0.1/-0 1.75±0.10 3.50±0.05 mm 0.70±0.20 1.20±0.20 ≤0.80 8.00±0.30 4.00±0.10 40.00±0.10 2.00±0.05 2.00±0.05 1.50+0.1/-0 1.75±0.10 3.50±0.05 mm Size Chip Thickness A0 B0 T K0 W P0 10xP0 P1 P2 D0 D1 E F Unit : 0805 0.80 +0.15/-0.1 1.05 ±0.30 1.80±0.30 ≤1.20 8.00±0.30 4.00±0.10 40.00±0.20 4.00±0.10 2.00±0.05 1.50+0.1/-0 1.75±0.10 3.50±0.05 mm 1206 0.80±0.10 1.25±0.10 1.25±0.20 0.80±0.10 1.50±0.20 2.30±0.20 0.95±0.05 8.00±0.10 4.00±0.10 40.00±0.20 4.00±0.10 2.00±0.05 1.50 +0.10/-0 1.75±0.05 3.50±0.05 mm
FN31X102K500PXG 价格&库存
很抱歉,暂时无法提供与“FN31X102K500PXG”相匹配的价格&库存,您可以联系我们找货
FN31X102K500PXG
  • 50+0.14187
  • 800+0.14045
  • 1600+0.13764
  • 4000+0.13351
库存:3885
FN31X102K500PXG
    • 20+0.15477
    • 200+0.12561
    • 600+0.10930
    库存:2519
