S1A-S1M
1.0AMP.Surface Mount Rectifiers
SMA/DO-214AC
Features
For surface mounted application
Glass passivated junction chip.
Low forward voltage drop
High current capability
Easy pick and place
High surge current capability
Plastic material used carries Underwriters
Laboratory Classification 94V-0
High temperature soldering:
o
260 C / 10 seconds at terminals
Mechanical Data
Case: Molded plastic
Polarity: Indicated by cathode band
Packaging: 12mm tape
W eight: 0.064 gram
Dimensions in inches and (millimeters)
Maximum Ratings and Electrical Characteristics
Rating at 25 oC ambient temperature unless otherwise specified.
Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%
Symbol S1A S1B S1D
Type Number
Maximum Recurrent Peak Reverse Voltage
50
100 200
V RRM
Maximum RMS Voltage
35
70
140
V RMS
Maximum DC Blocking Voltage
50
100 200
V DC
Maximum Average Forward Rectified
Current @T L =110 oC
Peak Forward Surge Current, 8.3 ms Single
Half Sine-wave Superimposed on Rated
Load (JEDEC method )
Maximum Instantaneous Forward Voltage
@ 1.0A
Maximum DC Reverse Current @ T A =25 oC
at Rated DC Blocking Voltage @ T A =125 oC
S1G
400
280
400
S1K S1M Units
800 1000
V
560 700
V
800 1000
V
1.0
I(AV)
IFSM
S1J
600
420
600
A
40
30
A
VF
1.1
V
IR
1.0
50
1.5
12
uA
uA
uS
pF
Typical Reverse Recovery Time (Note 1)
Trr
Typical Junction Capacitance ( Note 2 )
Non-Repetitive Peak Reverse Avalanche
Engergy at 25 oC, IAS =1A, L=10mH
Typical Thermal Resistance (Note 3)
Cj
E AS
R θJL
R θJA
5
27
75
-55 to +150
-55 to +150
Operating Temperature Range
TJ
Storage Temperature Range
T STG
Notes:
1. Reverse Recovery Test Conditions: I F=0.5A, IR =1.0A, I RR =0.25A
2. Measured at 1 MHz and Applied V R =4.0 Volts
3. Measured on P.C. Board with 0.2” x 0.2” (5.0mm x 5.0mm) Copper Pad Areas.
mJ
30
85
o
C/W
o
o
C
C
S1A-S1M
RATINGS AND CHARACTERISTIC CURVES (S1A THRU S1M)
FIG.2- TYPICAL REVERSE CHARACTERISTICS
1.2
100
1.0
0.8
INSTANTANEOUS REVERSE CURRENT. ( A)
AVERAGE FORWARD CURRENT. (A)
FIG.1- MAXIMUM FORWARD CURRENT DERATING
CURVE
0.6
0.4
0.2
60
80
100
120
140
160
o
LEAD TEMPERATURE. ( C)
FIG.3- MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
10
Tj=125 0C
1
Tj=75 0C
0.1
Tj=25 0C
0.01
PEAK FORWARD SURGE CURRENT. (A)
100
50
0.001
S 1 A -S
10
S1M
5
FIG.5- TYPICAL FORWARD CHARACTERISTICS
8.3ms Single
Half Sine Wave
Tj=Tj max
2
100
1
1
2
5
10
50
100
FIG.4- TYPICAL JUNCTION CAPACITANCE
100
Tj=25 0C
f=1.0MHz
Vsig=50mVp-p
50
INSTANTANEOUS FORWARD CURRENT. (A)
NUMBER OF CYCLES AT 60Hz
JUNCTION CAPACITANCE.(pF)
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE. (%)
1K
5
10
5
2
1
0.5
0.2
0.1
0.05
2
1
0.01
0.02
1
0.1
10
0.01
0.4
100
0.6
0.8
1.0
1.2
1.4
1.6
1.8
2.0
FORWARD VOLTAGE. (V)
REVERSE VOLTAGE. (V)
FIG.6- REVERSE RECOVERY TIME CHARACTERISTIC AND TEST CIRCUIT DIAGRAM
50W
NONINDUCTIVE
10W
NONINDUCTIVE
trr
+0.5A
DUT
50Vdc
(approx)
PULSE
GENERATOR
(NOTE 2)
1W
NON
INDUCTIVE
OSCILLOSCOPE
(NOTE 1)
NOTES: 1. Rise Time=7ns max. Input Impedance=
1 megohm 22pf
2. Rise Time=10ns max. Sourse Impedance=
50 ohms
-0.25A
-1.0A
1cm
SET TIME BASE FOR
5/ 10ns/ cm
Version: E08
很抱歉,暂时无法提供与“S1A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.16870
- 200+0.13490
- 600+0.11610
- 5000+0.08921
- 10000+0.07938
- 20000+0.07409
