ZMM5221B THRU ZM5267B
0.5W SILICON PLANAR ZENER DIODES
FEATURES
MINI-MELF
Silicon planar power zener diodes.
Standard zener voltage tolerance is ±5% with a
"B" suffix, and ±10% with a "A" suffix.Other
tolerances are available upon request.
0.063(1.6)
0.055(1.4)
MECHANICAL DATA
0.142(3.6)
0.134(3.4)
0.019(0.48)
0.011(0.28)
SM
IC
RO
S
em
ic
on
du
ct
or
Case:JEDEC MINI-MELF,glass case.
Terminals: Solderable per MIL-STD-202,Method 208
Dimensions in inches and (millimeters)
Polarity: Color band denotes cathods end
Weight: approx.0.031 gram
Mounting position: any
Maximum Ratings and Thermal Characteristics
(TA=25ć unless otherwise noted)
Symbol
Value
Unit
Power dissipation at Tamb=75ć (Note 1)
Ptot
500.0
mW
Maximum thermal resistance
junction to ambient (Note 1)
RJA
300
K/W
TJ
175
ć
Storage temperature range
TSTG
-55 to +175
ć
Forward voltage at IF=200mA
VF
1.1
V
Parameter
Zener current (see Table "Characteristics")
Junction temperature
NOTE:1˅ Valid provided that electrodes are kept at ambient temperature.
www.jsmsemi.com
第1/3页
ELECTRICAL CHARACTERISTICS(Ratings at 25ć ambient temperature unless otherwise specified)
TYPE
Maximum zener
impedance
Nominal zener
voltage
Typical
temperature
coefficient
Maximum reverse
leakage current
Maximum DC
zener current
IR @ VR
IZM
IZT
ZZT @ IZT
ZZK @ IZK
ĮV Z
ZMM5221B
ZMM5222B
ZMM5223B
ZMM5224B
(V)
2.4
2.5
2.7
2.8
(m A)
(ȍ)
30
30
30
30
(ȍ)
1200
1250
1300
1400
%/ć
-0.085
-0.085
-0.080
-0.080
( A)
100
100
75
75
(V)
1.0
1.0
1.0
1.0
(m A)
185
180
165
160
ZMM5225B
ZMM5226B
ZMM5227B
ZMM5228B
ZMM5229B
ZMM5230B
ZMM5231B
ZMM5232B
ZMM5233B
ZMM5234B
ZMM5235B
ZMM5236B
ZMM5237B
ZMM5238B
ZMM5239B
ZMM5240B
ZMM5241B
ZMM5242B
ZMM5243B
ZMM5244B
ZMM5245B
ZMM5246B
ZMM5247B
ZMM5248B
ZMM5249B
ZMM5250B
ZMM5251B
ZMM5252B
ZMM5253B
ZMM5254B
ZMM5255B
ZMM5256B
ZMM5257B
ZMM5258B
ZMM5259B
ZMM5260B
ZMM5261B
ZMM5262B
ZMM5263B
ZMM5264B
ZMM5265B
ZMM5266B
ZMM5267B
3.0
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.0
6.2
6.8
7.5
8.2
8.7
9.1
10
11
12
13
14
15
16
17
18
19
24
25
27
28
30
33
36
39
43
47
51
56
60
62
68
75
9.0
8.5
7.8
7.4
7.0
6.6
6.2
5.6
5.2
5.0
4.6
4.5
4.2
3.8
3.4
3.2
3.0
2.7
2.5
2.2
2.1
2.0
1.8
1.7
29
28
24
23
22
19
17
11
7
7
5
6
8
8
10
17
22
30
13
15
16
17
19
21
23
25
29
33
35
41
44
49
58
70
80
93
105
125
150
170
185
230
270
1600
1600
1700
1900
2000
1900
1600
1600
1600
1000
750
500
500
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
600
700
700
800
900
1000
1100
1300
1400
1400
1600
1700
-0.075
-0.070
-0.065
-0.060
-0.055
50
25
15
10
5.0
5.0
5.0
5.0
5.0
5.0
3.0
3.0
3.0
3.0
3.0
3.0
2.0
1.0
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
0.1
1.0
1.0
1.0
1.0
1.0
2.0
2.0
3.0
3.5
4.0
5.0
6.0
6.5
6.5
7.0
8.0
8.4
9.1
9.9
10
11
12
13
14
14
15
17
18
19
21
21
23
25
27
30
33
36
39
43
46
47
52
56
151
138
126
115
106
97
89
81
76
73
67
61
55
52
50
45
41
38
35
32
30
28
27
25
24
23
21.2
19.1
18.2
16.8
16.2
15.1
13.8
12.6
11.5
10.6
9.7
8.9
ct
du
on
ic
em
S
MI
CR
O
JS
±0.030
±0.030
+0.038
+0.038
+0.045
+0.050
+0.058
+0.062
+0.065
+0.068
+0.075
+0.076
+0.077
+0.079
+0.082
+0.082
+0.083
+0.084
+0.085
+0.086
+0.086
+0.087
+0.087
+0.089
+0.090
+0.091
+0.091
+0.092
+0.093
+0.094
+0.095
+0.095
+0.096
+0.096
+0.097
+0.097
+0.097
+0.098
www.jsmsemi.com
or
VZ @ IZT
第2/3页
FIG.1 -- BREAKDOWN CHARACTERISTICS
mA
5
50
15
30 V
40
Test current
Iz=20mA
to
30
r
IZ
10
uc
co
mi
VZ
ZMM5252
ZMM 5250
ZMM 5245
ZMM 5242
ZMM 5241
ZMM5239
ZMM5235
ZMM5234
ZMM5232
ZMM5231
ZMM5230
ZMM5229
ZMM5224
ZMM5228
nd
10
Se
FIG.2 -- ADMISSIBLE POWER DISSIPATION VERSUS AMBIENT TEMPERATURE
mW
RO
500
JS
MI
C
400
Ptot
300
200
100
Tamb
www.jsmsemi.com
200ć
第3/3页
很抱歉,暂时无法提供与“ZMM5237B”相匹配的价格&库存,您可以联系我们找货
