DATA SHEET
CURRENT SENSOR - LOW TCR
AUTOMOTIVE GRADE
PE_L series
5%, 1%, 0.5%, 0.1%
sizes
0201/0402/ 0603/ 0805/ 1206/ 2010/ 2512
Product specification – July 8, 2020 V.8
RoHS compliant & Halogen free
Chip Resistor Surface Mount
SERIES
PE_L
0201 /0402/ 0603/ 0805/ 1206/ 2010/ 2512
2
12
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER
This specification describes PE
series current sensor - low TCR
with lead-free terminations made by
metal film with ceramic substrate.
Global part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
APPLICATIONS
Consumer goods
Computer
Telecom / Datacom
Industrial / Power supply
Automotive
Alternative Energy
FEATURES
AEC-Q200 qualified
Halogen-free Epoxy
RoHS compliant
Reduce environmentally
hazardous wastes
High component and equipment
reliability
None forbidden-materials used
in products/production
Low resistances applied to
current sensing
GLOBAL PART NUMBER
PE XXXX X X X XX XXXX L
(1)
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
0201/ 0402/ 0603/ 0805/ 1206/ 2010/ 2512
(2) TOLERANCE
B = ± 0.1% (only for 0805, > 50mΩ)
D = ± 0.5% ( ≥10mΩ)
F = ± 1%
J = ± 5%
(3) PACKAGING TYPE
R = Paper/ PE taping reel
K = Embossed taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
E = ± 50 ppm/°C
M = ± 75 ppm/°C
F = ± 100 ppm/°C
J = ± 350 ppm/°C
(5) TAPING REEL
07 / 7W / 7T / 47 / 57= 7 inch dia. Reel and specific rated power.
Detailed power rating are shown in the Table 2.
(6) RESISTANCE VALUE
5 mΩ to 910 mΩ
There are 3~5 digits indicated the resistance value. Letter R is decimal point.
Detailed coding rules of resistance are shown in the table of “Resistance rule of
global part number”.
(7) DEFAULT CODE
Letter L is the system default code for ordering only. (Note)
Resistance rule of global part
number
Resistance code rule
Example
0R001 = 1 mΩ
0RXXX
(1 to 910 mΩ)
0R1 = 100 mΩ
ORDERING EXAMPLE
The ordering code of a PE2512
1W chip resistor, value 0.1 Ω with
± 1% tolerance, supplied in 7-inch
tape reel is: PE2512FKM070R1L
0R91 = 910 mΩ
NOTE
1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions
"Lead-Free Process"
www.yageo.com
Jul. 08, 2020 V.8
SERIES
PE_L
3
12
MARKING
PE0201 / PE0402
No marking
YNSC123_1
Fig. 1
PE0603
5mΩ ≤ R ≤ 50mΩ
51mΩ ≤ R ≤ 99mΩ
100mΩ ≤ R ≤ 910mΩ
10
51
100
YNSC140
YNSC145
YNSC144
Fig. 2 Value = 10 mΩ
Value = 51 mΩ
Value = 100 mΩ
2 digits
resistance range: 5mΩ ≤ R ≤ 99mΩ
3 digits
resistance range: 100mΩ ≤ R ≤ 910mΩ
PE0805
5mΩ ≤ R ≤ 50mΩ
51mΩ ≤ R ≤ 910mΩ
3 digits
051
010
YNSC138
YNSC145
Fig. 3 Value = 10 mΩ
Value = 51 mΩ
PE1206
5mΩ ≤ R ≤ 50mΩ
51mΩ ≤ R ≤ 910mΩ
R010
R051
YNSC146
YNSC139
Fig. 4 Value = 10 mΩ
Value = 51 mΩ
4 digits
The “R” is used as a decimal point; the other 3 digits are
significant.
PE2010 / PE2512
5mΩ ≤ R ≤ 100mΩ
100mΩ < R ≤ 910mΩ
R510
R010
YNSC158
YNSC139
Fig. 5 Value = 10 mΩ
Value = 510 mΩ
4 digits
significant.
Outlines
For dimensions, please refer to Table 1
5mΩ ≤ R ≤ 50mΩ
R010
51mΩ ≤ R ≤ 910mΩ
R051
YNSC143
Fig. 5 Chip resistor outlines
www.yageo.com
Jul. 08, 2020 V.8
PE_L
SERIES
4
12
DIMENSION
Table 1 For outlines, please refer to Fig. 4
TYPE
RESISTANCE RANGE
PE0201
PE0402
PE0603
PE0805
PE1206
PE2010
PE2512
L (mm)
W (mm)
H (mm)
I1 (mm)
50 mΩ ≤ R ≤ 910 mΩ
0.60± 0.03
0.31± 0.04
0.27± 0.04
0.14± 0.06
10 mΩ ≤ R ≤ 910 mΩ
1.00+0.10/-0.15
0.50+0.10/-0.15
0.35± 0.15
0.25± 0.10
5 mΩ ≤ R ≤ 50 mΩ
1.60± 0.20
0.76± 0.25
0.35± 0.25
0.38± 0.25
51 mΩ ≤ R ≤ 910 mΩ
1.52± 0.25
0.76± 0.25
0.45± 0.10
0.38± 0.25
5 mΩ ≤ R ≤ 6 mΩ
2.03± 0.25
1.27± 0.25
0.35± 0.25
0.73± 0.25
7 mΩ ≤ R ≤ 50 mΩ
2.03± 0.25
1.27± 0.25
0.35± 0.25
0.38± 0.25
51 mΩ ≤ R ≤ 910 mΩ
2.03± 0.25
1.27± 0.25
0.55± 0.10
0.35± 0.20
5 mΩ
3.20± 0.25
1.60± 0.25
0.64± 0.25
0.64± 0.25
6 mΩ ≤ R ≤ 910 mΩ
3.20± 0.25
1.60± 0.25
0.64± 0.25
0.51± 0.25
5 mΩ ≤ R ≤ 6 mΩ
5.08± 0.25
2.54± 0.25
0.64± 0.25
1.47± 0.25
7 mΩ ≤ R ≤ 910 mΩ
5.08± 0.25
2.54± 0.25
0.64± 0.25
0.51± 0.25
6 mΩ ≤ R ≤ 910 mΩ
6.35± 0.25
3.18± 0.25
0.64± 0.25
0.76± 0.25
Note:
1. For relevant physical dimensions, please refer to construction outlines.
2. Please contact with sales offices, distributors and representatives in your region before ordering.
www.yageo.com
Jul. 08, 2020 V.8
SERIES
PE_L
5
12
ELECTRICAL CHARACTERISTICS
Table 2
POWER RATING (1)
SERIES SIZE
07
7W
0201 1/20W 1/10W
Fig. 4
Chip
outlines
0402resistor
1/16W
1/8W
0603
PE
0805
RESISTANCE
RANGE
TOLERANCE
OF RESISTANCE
7T
47
57
50 mΩ ≤ R ≤ 910 mΩ
50 mΩ ≤ R ≤ 70 mΩ ± 350 ppm/°C
70 mΩ < R ≤ 910 mΩ ± 100 ppm/°C
10 mΩ ≤ R ≤ 910 mΩ
± 100 ppm/°C
5 mΩ ≤ R ≤ 910 mΩ
± 75 ppm/°C
± 100 ppm/°C
1/6W 1/4W
1/10W 1/5W 1/3W 2/5W 1/2W ± 0.1% (only for
0805, >50mΩ)
1/8W 1/4W 1/3W 1/2W --- ± 0.5%(≥10 mΩ)
5 mΩ ≤ R ≤ 19 mΩ
± 75 ppm/°C, ± 100 ppm/°C
20 mΩ ≤ R ≤ 910 mΩ
± 50 ppm/°C, ± 75 ppm/°C, ± 100 ppm/°C
5 mΩ ≤ R ≤ 910 mΩ
6 mΩ ≤ R ≤ 910 mΩ
± 50 ppm/°C
± 75 ppm/°C
± 100 ppm/°C
1206
1/4W
1/2W
1W
2010
1/2W
1W
2512
1W
2W
± 1%
± 5%
Note: 1. Global part number (code 10 - 11)
FUNCTIONAL DESCRIPTION
OPERATING TEMPERATURE RANGE
PE0201 to PE0402 Range: -55°C to +125°C (Fig. 6-1)
PE0603 to PE2512 Range: -55°C to +170°C (Fig. 6-2)
handbook,
P halfpage
MLB206
max
(%Prated)
100
POWER RATING
Standard rated power at 70°C:
PE0201 = 1/20W
PE0402 = 1/16W
PE0603 = 1/10W
PE0805 = 1/8W
PE1206 = 1/4W
PE2010 = 1/2W
PE2512 = 1W
For detail power value, please refer to Table 2.
50
Fig. 6-1
70
100 125
o
Tamb ( C)
Maximum dissipation (P max ) in percentage of rated
power as a function of the operating ambient
temperature (T amb )
RATED VOLTAGE
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
V=
MRA633
P
(%Prated)
100
(PxR )
Where
50
V = Continuous rated DC or
AC (rms) working voltage (V)
P = Rated power (W)
R = Resistance value (Ω)
Fig. 6-2
100
170
Tamb ( C)
www.yageo.com
Jul. 08, 2020 V.8
SERIES
PE_L
6
12
PULSE LOAD BEHAVIOR
PACKING STYLE AND PACKAGING QUANTITY
Table 3 Packing style and packaging quantity
PACKING STYLE
REEL DIMENSION
PE0201
PE0402
PE0603
PE0805
PE1206
PE2010
PE2512
Paper taping reel (R)
7" (178 mm)
10,000
10,000
5,000
5,000
4,000
Embossed taping reel (K)
7" (178 mm)
4,000
4,000
PAPER TAPE
P0
T
D0
P2
E
F
cover tape
W
B0
A0
P1
MBG251
Fig. 7 Paper Tape
www.yageo.com
Jul. 08, 2020 V.8
SERIES
PE_L
7
12
Table 4 Dimensions of paper tape for relevant chip resistors size
Unit: mm
SYMBOL
SIZE
A0
B0
W
E
F
P0
P1
P2
Ø D0
T
PE0201
0.35± 0.10
1.65± 0.10
8.00± 0.30
1.75± 0.10
3.50± 0.10
4.00± 0.10
2.00± 0.05
2.00± 0.05
1.50± 0.10
0.53± 0.10
PE0402
0.65± 0.10
1.15± 0.10
8.00± 0.30
1.75± 0.10
3.50± 0.10
4.00± 0.10
2.00± 0.05
2.00± 0.05
1.50± 0.10
0.53± 0.10
PE0603
1.20± 0.15
1.90± 0.15
8.00± 0.30
1.75± 0.10
3.50± 0.10
4.00± 0.10
4.00± 0.10
2.00± 0.10
1.50± 0.10
0.55± 0.15
PE0805
1.60± 0.15
2.30± 0.15
8.00± 0.30
1.75± 0.10
3.50± 0.10
4.00± 0.10
4.00± 0.10
2.00± 0.10
1.50± 0.10
0.85± 0.15
PE1206
1.90± 0.10
3.50± 0.10
8.00± 0.30
1.75± 0.10
3.50± 0.10
4.00± 0.10
4.00± 0.10
2.00± 0.10
1.50± 0.10
1.50± 0.10
EMBOSSED TAPE
P0
D0
P2
E
F
cover tape
W
B0
MBG516_b
A0
T
D1
P1
direction of unreeling
Fig. 8 Embossed Tape
Table 5 Dimensions of embossed tape for relevant chip resistors size
SIZE
SYMBOL
A0
Unit: mm
B0
W
E
F
P0
P1
P2
Ø D0
Ø D1
T
PE2010 3.00± 0.15 5.60± 0.15 12.10± 0.30 1.75± 0.10
5.50± 0.10 4.00± 0.10 4.00± 0.10 2.00± 0.10 1.50± 0.10 1.50± 0.10 0.80± 0.15
PE2512 3.40± 0.15 6.70± 0.15 12.10± 0.30 1.75± 0.10
www.yageo.com
Jul. 08, 2020 V.8
SERIES
PE_L
8
12
REEL SPECIFICATION
W2
D
C
N
A
Fig. 9 Reel
HBK039_a
W1
Table 6 Dimensions of reel specification for relevant chip resistors size
QUANTITY
PER REEL
SIZE
REEL SIZE
8 mm
TAPE WIDE
7"
PE0201
10,000
PE0402
10,000
PE0603
5000
PE0805
5000
PE1206
4000
PE2010
4000
PE2512
4000
(Ø 178 mm)
7"
(Ø 178 mm)
7"
(Ø 178 mm)
7"
(Ø 178 mm)
7"
(Ø 178 mm)
SYMBOL
Unit: mm
12 mm
TAPE WIDE
24 mm
TAPE WIDE
180.0+0/-3
60.0+1/-0
13.0± 0.2
21.0± 0.8
9.0± 0.30
12.4
180.0+0/-3
60.0+1/-0
13.0± 0.2
21.0± 0.8
9.0± 0.30
12.4
180.0+0/-3
60.0+1/-0
13.0± 0.2
21.0± 0.8
8.4 +1/-0
12.4
180.0+0/-3
60.0+1/-0
13.0± 0.2
21.0± 0.8
8.4 +1/-0
12.4
180.0+0/-3
60.0+1/-0
13.0± 0.2
21.0± 0.8
8.4 +1/-0
12.4
180.0+0/-3
60.0+1/-0
13.0± 0.2
21.0± 0.8
12.3 +1/-0
18.4
180.0+0/-3
60.0+1/-0
13.0± 0.2
21.0± 0.8
12.3 +1/-0
18.4
7"
(Ø 178 mm)
7"
(Ø 178 mm)
A
N
C
D
W1
W2 MAX.
LEADER/TRAILER TAPE SPECIFICATION
leader end
handbook, full pagewidth
empty compartments
with cover tape
(min. 240 mm)
trailer end
trailer (max. 260 mm)
cover tape only
leader 400 mm
CCB325
Fig.10 Leader/Trailer Tape
www.yageo.com
Jul. 08, 2020 V.8
PE_L
SERIES
9
12
FOOTPRINT AND SOLDERING PROFILES
For recommended soldering profiles, please refer to data sheet “Chip resistors mounting”.
FOOTPRINT
Fig. 11 Single resistor chips recommended dimensions of footprints
Table 7 Footprint dimensions
SIZE
RESISTANCE RANGE
PE0201
Unit: mm
A
B
C
D
50 mΩ ≤ R ≤ 910 mΩ
1.00
0.30
0.35
0.40
PE0402
10 mΩ ≤ R ≤ 910 mΩ
1.45
0.35
0.55
0.55
PE0603
5 mΩ ≤ R ≤ 910 mΩ
2.52
0.50
1.01
1.01
PE0805
5 mΩ ≤ R ≤ 910 mΩ
2.54
0.50
1.02
1.27
PE1206
5 mΩ ≤ R ≤ 910 mΩ
3.90
0.76
1.57
1.78
5 mΩ ≤ R ≤ 6 mΩ
6.12
1.40
2.36
3.05
7 mΩ ≤ R ≤ 910 mΩ
6.10
3.30
1.40
3.05
6 mΩ
7.40
3.18
2.11
3.68
7 mΩ ≤ R ≤ 910 mΩ
7.36
4.06
1.65
3.68
PE2010
PE2512
www.yageo.com
Jul. 08, 2020 V.8
PE_L
SERIES
10
12
TESTS AND REQUIREMENTS
Table 8 Test condition, procedure and requirements
TEST
TEST METHOD
PROCEDURE
Life/
Operational Life/
Endurance
MIL-STD-202G-method 108
1,000 hours at 70± 2 °C applied RCWV
1.5 hours on, 0.5 hour off, still air required
High
Temperature
Exposure/
Endurance at
Upper Category
Temperature
IEC 60115-1 4.25.1
IEC 60115-1 4.25.3
1,000 hours at maximum operating temperature
depending on specification, unpowered
REQUIREMENTS
± (1%+0.0005 Ω)
± (1%+0.0005 Ω)
No direct impingement of forced air to the parts
Tolerances:
0201/0402 125± 3℃
0603 and above 170± 3℃
Moisture
Resistance
MIL-STD-202G-method 106
Each temperature / humidity cycle is defined at 8
hours (method 106F), 3 cycles / 24 hours for 10d
with 25 °C / 65 °C 95% R.H, without steps 7a &
7b, unpowered
0201: ± (5%+0.0005 Ω)
Others: ± (0.5%+0.0005 Ω)
Parts mounted on test-boards, without
condensation on parts
Measurement at 24± 2 hours after
test conclusion
Thermal Shock
MIL-STD-202G-method 107
-55/+125 °C
± (1%+0.0005 Ω)
Note: Number of cycles required is 300.
Devices mounted
Maximum transfer time is 20 seconds.
Dwell time is 15 minutes. Air – Air
Short Time
Overload
IEC60115-1 4.13
Board Flex/
Bending
IEC60115-1 4.33
5 times of rated power for 5 seconds at room
temperature
± (1%+0.0005 Ω)
Device mounted on PCB test board as described,
only 1 board bending required
± (1%+0.0005 Ω)
No visible damage
No visible damage
Bending for
0201: 3mm
0402 and above: 2mm
Holding time: minimum 60 seconds
Biased Humidity
MIL-STD-202
Method 103
1,000 hours at 85ºC/85%R.H. 10% of operating
power, no condensation on the devices, circulating
air.
Others : ± (1.0%+0.0005 Ω)
www.yageo.com
Jul. 08, 2020 V.8
PE_L
SERIES
11
12
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Solderability
- Wetting
IPC/JEDEC
Electrical Test not required
Well tinned (≥95% covered)
J-STD-002B test B
Magnification 50X
No visible damage
SMD conditions:
1st step: method B, aging 4 hours at 155 °C
dry heat
2nd step: leadfree solder bath at 245± 3 °C
Dipping time: 3± 0.5 seconds
- Leaching
- Resistance to
Soldering Heat
IPC/JEDEC
Leadfree solder, 260 °C,
30 seconds immersion time
No visible damage
J-STD-002B test D
MIL-STD-202G-method 210F
Condition B, no pre-heat of samples
± (0.5%+0.0005 Ω)
IEC 60115-1 4.18
10 seconds immersion time
No visible damage
Procedure 2 for SMD: devices fluxed and
cleaned with isopropanol
www.yageo.com
Jul. 08, 2020 V.8
PE_L
SERIES
12
12
REVISION HISTORY
REVISION
DATE
TYPE
Version 8
Jun. 11, 2020
CHANGE
NOTIFICATION
POWER
0603 1/10W, 1/5W, 3/10W, 2/5W, 1/2W
1/8W, 1/4W, 1/3W, 1/2W
0805
Version 7
Jan. 21, 2019
1/4W, 1/2W
1206
Version 6
1/2W, 1W
- are constructed
Oct.The
22, 2018
resistors
DESCRIPTION
OF RESISTANCE
- Update the dimension for PE0805 5mohm & 6mohm
TOLERANCE
RESISTANCE RANGE
- Update the marking 5for
PE0603
mΩ
≦ R < 100 mΩ
- Extend resistance range for PE0201
4 mΩ ≦ R < 100 mΩ
- Extended resistor value for PE2010 and 2512
3 mΩ ≦ R < 100 mΩ
- Extend resistor value for PE0603 and 0805, and 0.1% tol for 0805 > 50mΩ
using outstanding TCR level
material, which makes Yageo PF
Version 5
Novresistors
23, 2016 excellent
for current
sensing application in battery
charger circuit & DC-DC
Version 4
Dec.converter.
21, 2015 The composition of the resistive
material is adjusted to give the
PF
Version 32010
Aug. 06, 2015 approximate required resistance
and is covered with a protective
coating, which printed with the
Version 2
Apr. 20, 2015 resistance value.
Finally, the three external
terminations (Ni / matte Tin) are
Version 1
Mar. 04, 2015 added, as shown in Fig. 4.
- Add in pulse load behavior
Version 0
- New datasheet for current sensor - low TCR PE series sizes of
0201/0402/0603/0805/1206/2010/2512,
1 mΩ ≦ R < 100 mΩ0.5%, 1%, and 5%
Feb. 10, 2015
2512
4527
1W, 2W
- Extend resistor value for 0.5%
- Update resistance value
± 1%
5 mΩ ≦ R < 100 mΩ
± 2%
- Update 0603 to 1206 TCR
± 5%
±75 ppm/°C
- Update TCR and operating temperature
3W
1 mΩ ≦ R ≦ 50 mΩ
2W, 3W, 5W
6 mΩ ≦ R < 1Ω
NOTE: 1. PLEASE CONTACT WITH SALES OFFICES, DISTRIBUTORS AND REPRESENTATIVES IN YOUR REGION BEFORE ORDERING
“ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itself are unchanged. Any
product change will be announced by PCN.”
www.yageo.com
Jul. 08, 2020 V.8
