DBX1M40P001
DBX1M40P001
    JIJINDA(吉金达)
    线材/电缆 彩色排线 1m 40Pin
DBX1M40P001 数据手册
REV. Q`TY REVISED DATE DESCRIPTION CHECKED W TP 1.27±0.12 (0.05±0.005) 0.635±0.2 (0.025±0.008) 0.95±0.05 (0.037±0.002) PIN NO. 1 2 3 4 5 6 7 8 9 10 11 12 13 COLOR brown red orange yellow green blue purple gray white black brown red orange 颜色 棕色 红色 橙色 黄色 绿色 蓝色 紫色 灰色 白色 黑色 棕色 红色 橙色 …… …… …… CONDUCTOR(28AWG,7/0.127) 东莞市鸿彩电子科技有限公司 SYMBOL Q'TY X MAJOR DIMENSION 1. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN UNITS TOLERANCE ARE AS FOLLOWS: 2. ALL DIMENSIONS ARE "mm". METRIC .XXX±.003 .XX±.05 .X±.1 FILE NO. DESCRIPTION ANGLES ±1/2 DEG. REVISION HC P/N: CUSTOMER: CUSTOMER P/N: DESCRIPTION APPROVED HC(28AWG,7/0.127)PH1.27 RAINBOW CABLE CHECKED ENGINEER UNIT SCALE PAGE NO A1 mm NONE 1/3 11.11.13 DATE DRAWN SPECIFICATIONS: ELECTRONIC CHARACTERISTICS: Spark test.. .. ..2500V Dielectric strength test.. .. ..Min 2KV in 1 minute UL & CSA GRADE: UL Style......2651 Rate Temperature......-20°c To 105°c Rate Voltage......MAX.300V Flame Test......VW-1 Conductor resistance.. .. ..MAX 237Ω/km Insulation resistance.. .. ..Min 100MΩ-km Capacity.. .. ..44PF/m(G-S-G) Inductance.. .. ..1.45μH/m Impedance.. .. ..105Ω(G-S-G) Propagation delay time.. .. ..4.2 ns/m CSA Standard......C22.2 NO.210.2 Rate Temperature......-20°c To 105°c Rate VOltage......MAX 300v Flame Test......FT1.FT2 PHYSICAL PROPERTY: Stranded conductor AWG size.. .. ..28 AWG Material of insulation.. .. ..Polyvinyl chloride(PVC) Insulation thickness average.. .. ..9 mil Min insulation thickness.. .. ..7 mil 东莞市鸿彩电子科技有限公司 SYMBOL Q'TY X MAJOR DIMENSION 1. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN UNITS TOLERANCE ARE AS FOLLOWS: 2. ALL DIMENSIONS ARE "mm". METRIC .XXX±.003 .XX±.05 .X±.1 FILE NO. DESCRIPTION ANGLES ±1/2 DEG. REVISION HC P/N: CUSTOMER: CUSTOMER P/N: DESCRIPTION APPROVED HC(28AWG,7/0.127)PH1.27 RAINBOW CABLE CHECKED ENGINEER UNIT SCALE PAGE NO A1 mm NONE 2/3 11.11.13 DATE DRAWN CODE NO. NUMBER WIDTH(mm) TP(mm) OF CORES ALLOWABLE ERROR(mm) CODE NO. NUMBER OF CORES WIDTH(mm) TP(mm) ALLOWABLE ERROR(mm) HC-4 4 5.08 3.81 ± 0.15 HC-20 20 25.40 24.13 ± 0.15 HC-5 5 6.35 5.08 ± 0.15 HC-25 25 31.75 30.48 ± 0.20 HC-6 6 7.62 6.35 ± 0.15 HC-26 26 33.02 31.75 ± 0.20 HC-7 7 8.89 7.62 ± 0.15 HC-28 28 35.56 34.29 ± 0.20 HC-8 8 10.16 8.89 ± 0.15 HC-30 30 38.10 36.83 ± 0.20 HC-9 9 11.43 10.16 ± 0.15 HC-34 34 43.18 41.91 ± 0.20 HC-10 10 12.70 11.43 ± 0.15 HC-36 36 45.72 44.45 ± 0.20 HC-12 12 15.24 13.97 ± 0.15 HC-37 37 46.99 45.72 ± 0.20 HC-14 14 17.78 16.51 ± 0.15 HC-40 40 50.80 49.53 ± 0.20 HC-15 15 19.05 17.78 ± 0.15 HC-50 50 63.50 62.23 ± 0.20 HC-16 16 20.32 19.05 ± 0.15 HC-60 60 76.20 74.93 ± 0.20 HC-18 18 22.86 21.59 ± 0.15 HC-64 64 81.28 80.01 ± 0.20 东莞市鸿彩电子科技有限公司 SYMBOL Q'TY X MAJOR DIMENSION 1. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN UNITS TOLERANCE ARE AS FOLLOWS: 2. ALL DIMENSIONS ARE "mm". METRIC .XXX±.003 .XX±.05 .X±.1 FILE NO. DESCRIPTION ANGLES ±1/2 DEG. REVISION HC P/N: CUSTOMER: CUSTOMER P/N: DESCRIPTION APPROVED HC(28AWG,7/0.127)PH1.27 RAINBOW CABLE ENGINEER CHECKED UNIT SCALE PAGE NO A1 mm NONE 3/3 11.11.13 DATE DRAWN
DBX1M40P001 价格&库存
很抱歉,暂时无法提供与“DBX1M40P001”相匹配的价格&库存,您可以联系我们找货
DBX1M40P001
    • 1+5.25299
    库存:98
