SMF33A
SMF33A
    JSMSEMI(杰盛微)
    SOD-123FL
    SOD123FL SMT 33V 53.3V
SMF33A 数据手册
SMF5V0A - SMF220A Transient Voltage Suppressor Features to r Low profile package with built-in strain relief for SMT applications Low incremental surge resistance, excellent clamping capability 200W peak pulse power capability with very fast response time High temperature soldering guaranteed: 260°C / 10s at terminals RoHS compliant with Halogen-free Mechanical Data nd uc Case: SOD-123FL Terminals: Solder plated; solderable per MIL- STD-750, Method 2026 Weight: 15mg/0.00048oz Parameter mi Peak power dissipation with a 10/1000μs waveform co Maximum Ratings (at TA = 25°C unless otherwise specified) Forward Voltage @ IF = 1A Se Peak pulse current with a 10/1000μs waveform *1 Typical thermal resistance, junction to ambient Value Unit PPPM Minimum 200 W IPPM see E. Characteristics A VF 1.6 V RθJA 180 °C/W TJ, TSTG -55 ~ +150 °C JS MI CR O Operating junction and storage temperature range Symbol www.jsmsemi.com 第1/5页 SMF5V0A - SMF220A Transient Voltage Suppressor Electrical Characteristics (at TA = 25°C unless otherwise specified) Type Marking Max. Reverse Max. Peak Standoff Leakage@ Pulse Voltage VRWM Current IT VRWM IR IPP VC A V 21.7 9.2 19.4 10.3 Breakdown Test Voltage VBR@IT Current V Max. Reverse Max mA V uA Voltage @IPP AE 6.4 7 10 5 400 SMF6V0A AG 6.7 7.4 10 6 400 SMF6V5A AK 7.2 8 10 6.5 250 17.9 11.2 SMF7V0A AM 7.8 8.6 10 7 100 16.7 12.0 SMF7V5A AP 8.3 9.2 1 7.5 50 15.5 12.9 SMF8V0A AR 8.9 9.8 1 8 25 14.7 13.6 SMF8V5A AT 9.4 10.4 1 8.5 10 13.9 14.4 SMF9V0A AV 10 11.1 1 9 5 13.0 15.4 SMF10A AX 11.1 12.3 1 10 2.5 11.8 17.0 SMF11A AZ 12.2 13.5 1 11 2.5 11 18.2 SMF12A BE 13.3 14.7 1 12 2.5 10.1 19.9 SMF13A BG 14.4 15.9 1 13 1 9.3 21.5 SMF14A BK 15.6 17.2 1 14 1 8.6 23.2 SMF15A BM 16.7 18.5 1 15 1 8.2 24.4 SMF16A BP 17.8 19.7 1 16 1 7.7 26.0 SMF17A BR 18.9 20.9 1 17 1 7.2 27.6 SMF18A BT 20 22.1 1 18 1 6.8 29.2 SMF20A BV 22.2 24.5 1 20 1 6.2 32.4 SMF22A BX 24.4 26.9 1 22 1 5.6 35.5 SMF24A BZ 26.7 29.5 1 24 1 5.1 38.9 SMF26A CE 28.9 31.9 1 26 1 4.8 42.1 SMF28A CG 31.1 34.4 1 28 1 4.4 45.4 SMF30A CK 33.3 36.8 1 30 1 4.1 48.4 SMF33A CM 36.7 40.6 1 33 1 3.8 53.3 SMF36A CP 40 44.2 1 36 1 3.4 58.1 SMF40A CR 44.4 49.1 1 40 1 3.1 64.5 SMF43A CT 47.8 52.8 1 43 1 2.9 69.4 SMF45A CV 50 55.3 1 45 1 2.8 72.7 SMF48A CX 53.3 58.9 1 48 1 2.6 77.4 nd co mi Se CR O JS MI uc SMF5V0A to r Min Clamping www.jsmsemi.com 第2/5页 SMF5V0A - SMF220A Transient Voltage Suppressor Marking Max. Reverse Max. Peak Standoff Leakage@ Pulse Voltage VRWM Current IT VRWM IR IPP VC Breakdown Test Voltage VBR@IT Current V Clamping Voltage @IPP Min Max mA V uA A V 2.4 82.4 2.3 87.1 2.1 93.6 2.1 96.8 1.9 103 1 1.8 113 1 1.7 121 1 1.6 126 1 1.5 137 90 1 1.4 146 100 1 1.2 162 CZ 56.7 62.7 1 51 1 SMF54A DE 60 66.3 1 54 1 SMF58A DG 64 71.2 1 58 1 SMF60A DK 66.7 73.7 1 60 1 SMF64A DM 71.1 78.6 1 64 1 SMF70A DP 78.8 86 1 70 SMF75A DR 83.3 92.1 1 75 SMF78A DT 86.7 95.8 1 78 SMF85A DV 94.4 104 1 85 SMF90A DX 100 111 1 SMF100A DZ 111 123 1 SMF110A EE 122 135 SMF120A EG 133 147 SMF130A EK 144 159 SMF150A EM 167 SMF160A EP SMF170A mi co nd uc SMF51A to r Type Max. Reverse 110 1 1.1 177 1 120 1 1.0 193 1 130 1 1.0 209 185 1 150 1 0.8 243 178 197 1 160 1 0.8 259 ER 189 209 1 170 1 0.7 275 SMF200A EX 224 247 1 200 1 0.6 324 SMF220A E22 245 270 1 220 1 0.6 356 JS MI CR O Se 1 www.jsmsemi.com 第3/5页 SMF5V0A - SMF220A Transient Voltage Suppressor Ratings and Characteristic Curves (at TA=25°C unless otherwise noted) to r JSM mi co nd uc JSM JS MI CR O Se JSM www.jsmsemi.com 第4/5页 SMF5V0A - SMF220A Transient Voltage Suppressor Se Mounting Pad Layout (Unit: mm) CR O 1.16 3.16 JS MI 1.17 mi co nd uc to r Package Outline Dimensions (Unit: mm) Ordering Information Part Number Package Shipping Quantity SMF5V0A - SMF220A SOD-123FL 3000 / Tape & Reel www.jsmsemi.com 第5/5页
SMF33A 价格&库存
很抱歉,暂时无法提供与“SMF33A”相匹配的价格&库存,您可以联系我们找货
