SMF5V0A - SMF220A
Transient Voltage Suppressor
Features
to
r
Low profile package with built-in strain relief for SMT applications
Low incremental surge resistance, excellent clamping capability
200W peak pulse power capability with very fast response time
High temperature soldering guaranteed: 260°C / 10s at terminals
RoHS compliant with Halogen-free
Mechanical Data
nd
uc
Case: SOD-123FL
Terminals: Solder plated; solderable per MIL- STD-750, Method 2026
Weight: 15mg/0.00048oz
Parameter
mi
Peak power dissipation with a 10/1000μs waveform
co
Maximum Ratings (at TA = 25°C unless otherwise specified)
Forward Voltage @ IF = 1A
Se
Peak pulse current with a 10/1000μs waveform *1
Typical thermal resistance, junction to ambient
Value
Unit
PPPM
Minimum 200
W
IPPM
see E. Characteristics
A
VF
1.6
V
RθJA
180
°C/W
TJ, TSTG
-55 ~ +150
°C
JS
MI
CR
O
Operating junction and storage temperature range
Symbol
www.jsmsemi.com
第1/5页
SMF5V0A - SMF220A
Electrical Characteristics (at TA = 25°C unless otherwise specified)
Type
Marking
Max. Reverse
Max. Peak
Standoff
Leakage@
Pulse
Voltage
VRWM
Current
IT
VRWM
IR
IPP
VC
A
V
21.7
9.2
19.4
10.3
Breakdown
Test
Voltage VBR@IT
Current
V
Max.
Reverse
Max
mA
V
uA
Voltage
@IPP
AE
6.4
7
10
5
400
SMF6V0A
AG
6.7
7.4
10
6
400
SMF6V5A
AK
7.2
8
10
6.5
250
17.9
11.2
SMF7V0A
AM
7.8
8.6
10
7
100
16.7
12.0
SMF7V5A
AP
8.3
9.2
1
7.5
50
15.5
12.9
SMF8V0A
AR
8.9
9.8
1
8
25
14.7
13.6
SMF8V5A
AT
9.4
10.4
1
8.5
10
13.9
14.4
SMF9V0A
AV
10
11.1
1
9
5
13.0
15.4
SMF10A
AX
11.1
12.3
1
10
2.5
11.8
17.0
SMF11A
AZ
12.2
13.5
1
11
2.5
11
18.2
SMF12A
BE
13.3
14.7
1
12
2.5
10.1
19.9
SMF13A
BG
14.4
15.9
1
13
1
9.3
21.5
SMF14A
BK
15.6
17.2
1
14
1
8.6
23.2
SMF15A
BM
16.7
18.5
1
15
1
8.2
24.4
SMF16A
BP
17.8
19.7
1
16
1
7.7
26.0
SMF17A
BR
18.9
20.9
1
17
1
7.2
27.6
SMF18A
BT
1
18
1
6.8
29.2
SMF20A
BV
22.2
24.5
1
6.2
32.4
SMF22A
BX
24.4
26.9
1
22
1
5.6
35.5
SMF24A
BZ
26.7
29.5
1
24
1
5.1
38.9
SMF26A
CE
28.9
31.9
1
26
1
4.8
42.1
SMF28A
CG
31.1
34.4
1
28
1
4.4
45.4
SMF30A
CK
33.3
36.8
1
30
1
4.1
48.4
SMF33A
CM
36.7
40.6
1
33
1
3.8
53.3
SMF36A
CP
40
44.2
1
36
1
3.4
58.1
SMF40A
CR
44.4
49.1
1
40
1
3.1
64.5
SMF43A
CT
47.8
52.8
1
43
1
2.9
69.4
SMF45A
CV
50
55.3
1
45
1
2.8
72.7
SMF48A
CX
53.3
58.9
1
48
1
2.6
77.4
nd
co
mi
Se
CR
O
JS
MI
uc
SMF5V0A
to
r
Min
Clamping
www.jsmsemi.com
第2/5页
SMF5V0A - SMF220A
Marking
Max. Reverse
Max. Peak
Standoff
Leakage@
Pulse
Voltage
VRWM
Current
IT
VRWM
IR
IPP
VC
Breakdown
Test
Voltage VBR@IT
Current
V
Clamping
Voltage
@IPP
Min
Max
mA
V
uA
A
V
2.4
82.4
2.3
87.1
2.1
93.6
2.1
96.8
1.9
103
1
1.8
113
1
1.7
121
1
1.6
126
1
1.5
137
90
1
1.4
146
100
1
1.2
162
CZ
56.7
62.7
1
51
1
SMF54A
DE
60
66.3
1
54
1
SMF58A
DG
64
71.2
1
58
1
SMF60A
DK
66.7
73.7
1
60
1
SMF64A
DM
71.1
78.6
1
64
1
SMF70A
DP
78.8
86
1
70
SMF75A
DR
83.3
92.1
1
75
SMF78A
DT
86.7
95.8
1
78
SMF85A
DV
94.4
104
1
85
SMF90A
DX
100
111
1
SMF100A
DZ
111
123
1
SMF110A
EE
122
135
SMF120A
EG
133
147
SMF130A
EK
144
159
SMF150A
EM
167
SMF160A
EP
SMF170A
mi
co
nd
uc
SMF51A
to
r
Type
Max.
Reverse
110
1
1.1
177
1
120
1
1.0
193
1
130
1
1.0
209
185
1
150
1
0.8
243
178
197
1
160
1
0.8
259
ER
189
209
1
170
1
0.7
275
SMF200A
EX
224
247
1
200
1
0.6
324
SMF220A
E22
245
270
1
220
1
0.6
356
JS
MI
CR
O
Se
1
www.jsmsemi.com
第3/5页
SMF5V0A - SMF220A
Ratings and Characteristic Curves (at TA=25°C unless otherwise noted)
to
r
JSM
mi
co
nd
uc
JSM
JS
MI
CR
O
Se
JSM
www.jsmsemi.com
第4/5页
SMF5V0A - SMF220A
Se
Mounting Pad Layout (Unit: mm)
CR
O
1.16
3.16
JS
MI
1.17
mi
co
nd
uc
to
r
Package Outline Dimensions (Unit: mm)
Ordering Information
Part Number
Package
Shipping Quantity
SMF5V0A - SMF220A
SOD-123FL
3000 / Tape & Reel
www.jsmsemi.com
第5/5页
很抱歉,暂时无法提供与“SMF54A”相匹配的价格&库存,您可以联系我们找货
