Dimension
C±0.3
D
24.99
30.80
16.33
15
26.50
33.32
39.14
24.66
25
40.00
47.04
53.04
38.38
37
56.50
63.50
69.32
54.84
67.04
61.00
52.34
2Ø3
NOTES:
2.77
.0
5
7.9
12.5
15.3
B±0.2
17.90
5.68
2. Environment characteristics:
2.1.Temperature range: -40°C~+105°C.
3. Materials:
3.1 Insulator:PBT+Glass fiber
3.2 Shell:Steel
3.3 Contact:Copper alloy
1.385
2.77
50pin Female Figure
67.04
61.00
54.30
4.6
4. Product number code:
2.77
2.84
2-Ø
CC type
[Male]
C
B
A
A
1.385
9.2
12.5
44.32
Ø1
6.0
BR type
41.55
61.00
Recommend PCB layout(50P)
(Tolerance:±0.05)
4.2
11
1.0
Mating face
2.84
5.68
2.84
2.77
4.6
Ø1
.0
2.84
Ø
2.77
BRJ type
1.385
2.84
C
B
A
10.7
Screw type
S: Standard(W/O nut)
1: CC type 2: CS type
3: BR type 4: BRJ type DIM. B:6.00 C: 4.2mm
5: BRJ type DIM. B:6.00 C: 5~6mm
6: BRJ type DIM. B:6.00 C: 4.2mm
(Inside thread M2.6*0.45P,outside thread unc#4-40)
7: BRJ type DIM. B:6.00 C: 4.2mm
(Inside thread M3.0*0.50P,outside thread unc#4-40)
Contact plating
Si: Full gold flash
0: Selective gold flash
Shell plating
N: Front Nickel,Back Tin
B
Ø0.6
50pin Male Figure
CS type
2.77
0.9
Screw DIM. A
1: 5.00 2: 3.00 3: 5.20
4: 4.80 5: 5.80 6: 4.00
7: 4.80mm(Inside thread M2.6*0.45p,
8: 4.80mm(Inside thread M3.0*0.5p,
5
5.68
12.2
10.7
3 .0
15.3
0.9
A
1.0
10.7
Standard
Ø0.6
1. Electrical characteristics:
1.1 Contact resistance: 20mΩ Max. Initial.
1.2 Dielectric withstanding voltage: 500V AC(rms) for 1 minute.
1.3 Insulation resistance: 1000MΩ Min.
Ø3
2.84
C
B
D
A±0.2
9
10.8
[Female]
Position
(Tolerance:±0.05)
Housing color
B: Black W: White
U: Blue
Connector type
M: Male F: Female
No.of contacts
09,15,25,37,50
晨翔电子有限公司
(Series Image-Reference Only)
CONNFLY ELECTRONIC CO. LTD
很抱歉,暂时无法提供与“DS1034-09MUNSI44”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.99880
- 10+2.33240
- 30+2.04820
- 80+1.71500
- 国内价格
- 1+3.30480
- 10+2.57040
- 30+2.25720
- 80+1.89000
- 480+1.71720
- 960+1.60920
