RS0101YH6
RS0101YH6
    RUNIC(润石)
    SOT23-6
    1位双向电压电平转换器,用于开漏和推挽应用
RS0101YH6 数据手册
RS0101 1-Bit Bidirectional Voltage-Level Translator for OpenDrain and Push-Pull Application FEATURES • • • • • • • DESCRIPTION No Direction-Control Data Rates 24Mbps (Push-Pull) 2Mbps (Open-Drain) 1.65V to 5.5V on A ports and 2.3V to 5.5V on B Ports (VCCA≤VCCB) VCC Isolation: If Either VCC is at GND, Both Ports are in the High-Impedance State No Power-Supply Sequencing Required: Either VCCA or VCCB can be Ramped First IOFF: Supports Partial-Power-Down Mode Operation Extended Temperature: -40°C to +85°C APPLICATIONS • • • I2C/ SMBus UART GPIO This 1-bit non-inverting translator is a bidirectional voltagelevel translator and can be used to establish digital switching compatibility between mixed-voltage systems. It uses two separate configurable power-supply rails, with the A ports supporting operating voltages from 1.65V to 5.5V while it tracks the VCCA supply, and the B ports supporting operating voltages from 2.3V to 5.5V while it tracks the VCCB supply. This allows the support of both lower and higher logic signal levels while providing bidirectional translation capabilities between any of the 1.8V, 2.5V, 3.3V and 5V voltage nodes. When the output-enable (OE) input is low, all I/Os are placed in the high-impedance state, which significantly reduces the power-supply quiescent current consumption. OE has an internal pull-down current source, as long as VCCA is powered. To ensure the high-impedance state during power up or power down, OE should be tied to GND through a pulldown resistor; the minimum value of the resistor is determined by the current-sourcing capability of the driver. The RS0101 is available in Green SOT23-6 、 SOT363(SC70-6) and DFN1.45x1.0-6L packages. It operates over an ambient temperature range of -40°C to +85°C. Functional Block Diagram VCCB VCCA OE One Shot Accelerator One Shot Accelerator Gate Bias 10KΩ 10KΩ A REV A.4 B 1 / 24 www.run-ic.com RS0101 Revision History Note: Page numbers for previous revisions may different from page numbers in the current version. VERSION Change Date A.1 2020/09/02 A.2 2020/09/10 A.3 2021/01/09 A.4 2021/11/01 Change Item Initial version completed Fix mistake in PACKAGE/ORDERING INFORMATION. Order number value from RS0101YUTDV8 to RS0101YUTDV6 Add Moisture Sensitivity Level information 1.Change Recommended Operating Conditions in Page 6 @ A.3 Version 2.Add TAPE AND REEL INFORMATION 3.Add Typical Characteristics 2 / 24 www.run-ic.com RS0101 PIN CONFIGURATIONS VCCA 1 6 VCCB GND 2 5 OE A 3 4 B VCCB 1 6 VCCA OE 2 5 GND B 3 4 A DFN1.45X1.0-6L SOT23-6/SOT363(SC70-6) PIN DESCRIPTION PIN NAME TYPE (1) 6 VCCA P 2 5 GND ‒ 3 4 A I/O Input/output A. Reference to VCCA. 4 3 B I/O 5 2 OE I 6 1 VCCB P Input/output B. Reference to VCCB. Output Enable (Active High). Pull OE low to place all outputs in 3-state mode. Referenced to VCCA. B Ports Supply Voltage.2.3V ≤ VCCB ≤ 5.5V. SOT23-6/ SOT363(SC70-6) DFN1.45x1.0-6L 1 (1) FUNCTION A Port Supply Voltage.1.65V ≤ VCCA ≤ 5.5V and VCCA ≤ VCCB. Ground. I=input, O=output, I/O=input and output, P=power 3 / 24 www.run-ic.com RS0101 SPECIFICATIONS Absolute Maximum Ratings Over operating free-air temperature range (unless otherwise noted) (1) SYMBOL PARAMETER MIN MAX UNIT VCCA Supply Voltage Range -0.3 6.0 V VCCB Supply Voltage Range -0.3 6.0 V VI(2) Input Voltage Range A port -0.3 6.0 B port -0.3 6.0 VO(2) Voltage range applied to any output in the highimpedance or power-off state A port -0.3 6.0 B port -0.3 6.0 Voltage range applied to any output in the high or low state A port -0.3 VCCA+0.3 B port -0.3 VCCB+0.3 Input clamp current VI
RS0101YH6 价格&库存
很抱歉,暂时无法提供与“RS0101YH6”相匹配的价格&库存,您可以联系我们找货
RS0101YH6
  • 5+0.84500
  • 20+0.77000
  • 100+0.69500
  • 500+0.62000
  • 1000+0.58500
  • 2000+0.56000
库存:2030
RS0101YH6
  • 1+3.063011+0.38312
  • 10+2.1038310+0.26314
  • 25+1.8687525+0.23374
  • 100+1.61004100+0.20138
  • 250+1.48750250+0.18606
  • 500+1.41337500+0.17678
  • 1000+1.352451000+0.16916
库存:5704
RS0101YH6
库存:10201
RS0101YH6
  • 1+0.84480
  • 200+0.58300
  • 1500+0.52910
  • 3000+0.49500
库存:9768
RS0101YH6
  • 3000+1.277223000+0.15975
  • 6000+1.240416000+0.15515
  • 9000+1.221979000+0.15284
  • 15000+1.2015415000+0.15029
  • 21000+1.1895921000+0.14879
  • 30000+1.1781030000+0.14736
  • 75000+1.1533875000+0.14426
库存:5704
