SIM7020E
SIM7020E
    SIMCOM(芯讯通)
    LCC42_17.6X15.7MM
    NB-IoT模块 LCC42_17.6X15.7MM 2.1~3.6V
SIM7020E 数据手册
V: 2020.03 SIM7020 Series SIMCom NB-IoT Module Product Description The SIM7020 series is the LPWA module which supports wireless communication mode of Cat-NB. The SIM7020 series adopts LCC1 form factor and has a compact size of 17.6mm*15.7mm which makes it ideal for compact products design. MultiBand NB-IoT MQTT The SIM7020 series has powerful expansibility with abundant interfaces including UART, GPIO, I2C etc. The SIM7020 series is designed for applications that need low latency, low throughput data communication LWM2M Compact Size FOTA in a variety of radio propagation conditions. Due to the unique combination of performance, security and flexibility, this module is ideally suited for M2M applications, such as metering, asset tracking, remote TCP/UDP PSM/eDRX HTTP/SSL monitoring, E-health etc. NOTE 1: The form factor of SIM7020G and SIM7020G R13 is LCC+LGA Key Benefits  With Power Saving Mode(PSM) and Extended Discontinuous Reception(eDRX), the SIM7020 series can extend battery life up to 10 years  The SIM7020 series provides deeper coverage enhancement compared to GSM  The form factor and AT commands of the SIM7020 series are compatible with SIM800C Copyright © 2020 SIMCom Wireless Solutions Limited All Rights Reserved Building B, SIM Technology Building, No.633, Jinzhong Road Changning District, Shanghai P.R.China Tel: 86-21-31575100 Email: support@simcom.com Web: www.simcom.com Product SIM7020E SIM7020E-ND SIM7020E-D Form Factor LCC, 42PIN LCC, 42PIN LCC, 42PIN Dimensions(mm) 17.6*15.7*2.3 17.6*15.7*2.3 17.6*15.7*2.3 B1/B3/B5/B8/B20/B28 B1/B3/B5/B8/B20/B28 B1/B3/B5/B8/B20/B28 -40℃ ~ +85℃ -40℃ ~ +85℃ -40℃ ~ +85℃ 2.1~ 3.6 3.0~ 3.6 2.1~ 3.6 @PSM(uA) 3.4 3.4 3.4 @Sleep(mA) 0.4 0.4 0.4 @Idle(mA) 5.6 5.6 5.6 @eDRX=655.36s(uA) 30 30 30 26.15(DL)/62.5(UL) 26.15(DL)/62.5(UL) Frequency Bands Cat-NB Temperature Electrical Features Supply Voltage Range(V) Power Consumption Data Transfer NB-IoT(kbps) 26.15(DL)/62.5(UL) Software Features Protocol TCP/UDP/HTTP/HTTPS/TLS/DTLS/D TCP/UDP/HTTP/HTTPS/TLS/DTL TCP/UDP/HTTP/HTTPS/TLS/DTL NS/NTP/PING/LWM2M/COAP/MQTT/ S/DNS/NTP/PING/LWM2M/COAP/ S/DNS/NTP/PING/LWM2M/COAP/ MQTTS MQTT/MQTTS MQTT/MQTTS FOTA ● ● ● Embedded AT ● ● ● Firmware Upgrade UART/FOTA UART/FOTA UART/FOTA SIM Card 1.8V/3.0V 1.8V/3.0V 1.8V/3.0V UART ● ● ● USB ● ● ● ADC ● ● ● Embedded SIM o o o Regulatory CE/NCC/IMDA/ATEX/RoHS/REACH CE/NCC/IMDA/ATEX/RoHS/ REACH CE/NCC/IMDA/ATEX/RoHS/ REACH Carrier Deutsche Telekom Deutsche Telekom Deutsche Telekom Interfaces Certification ●: support o: optional * : on going Copyright © 2020 SIMCom Wireless Solutions Limited All Rights Reserved Building B, SIM Technology Building, No.633, Jinzhong Road Changning District, Shanghai P.R.China Tel: 86-21-31575100 Email: support@simcom.com Web: www.simcom.com 2 Product SIM7020G SIM7020G R13 Form Factor LCC+LGA, 77PIN LCC+LGA, 77PIN Dimensions(mm) 17.6*15.7*2.3 17.6*15.7*2.3 B1/B2/B3/B4/B5/B8/B12/B13/B17/B18/B19/ B20/B25/B26/B28/B66/B70/B71/B85 B1/B2/B3/B4/B5/B8/B12/B13/B17/B18/ B19/B20/B25/B26/B28/B66/B70/B71/B85 -40℃ ~ +85℃ -40℃ ~ +85℃ 2.1~ 3.6 3.0~ 3.6 @PSM(uA) 3.4 3.4 @Sleep(mA) 0.4 0.4 @Idle(mA) 5.6 5.6 @eDRX=655.36s(uA) 30 30 126(DL)/150(UL) 26.15(DL)/62.5(UL) Protocol TCP/UDP/HTTP/HTTPS/TLS/DTLS/DNS/ NTP/PING/LWM2M/COAP/MQTT/MQTTS TCP/UDP/HTTP/HTTPS/TLS/DTLS/DNS/NTP/ PING/LWM2M/COAP/MQTT/MQTTS FOTA ● ● Embedded AT ● ● Firmware Upgrade UART/FOTA UART/FOTA SIM Card 1.8V/3.0V 1.8V/3.0V UART ● ● USB ● ● ADC ● ● Embedded SIM o o Regulatory CE/FCC/GCF/PTCRB/ATEX/RoHS/REACH CE/FCC/GCF/PTCRB/ATEX/RoHS/REACH Carrier Telstra*/Vodafone/Deutsche Telekom Telstra*/Vodafone/Deutsche Telekom Frequency Bands Cat-NB Temperature Electrical Features Supply Voltage Range(V) Power Consumption Data Transfer NB-IoT (kbps) Software Features Interfaces Certification ●: support o: optional * : on going Copyright © 2020 SIMCom Wireless Solutions Limited All Rights Reserved Building B, SIM Technology Building, No.633, Jinzhong Road Changning District, Shanghai P.R.China Tel: 86-21-31575100 Email: support@simcom.com Web: www.simcom.com 3
SIM7020E 价格&库存
很抱歉,暂时无法提供与“SIM7020E”相匹配的价格&库存,您可以联系我们找货
SIM7020E
  • 1+52.64999
  • 10+50.69999
  • 100+46.01999
  • 500+43.67999
