STI3411A
STI3411A
    TMI(拓尔微)
    SOT23-5
    DC-DC电源芯片 SOT23-5 Vi=2.3~6V Io=2A
STI3411A 数据手册
STI 3411A 1.0MHz, 2A Synchronous Step-Down Converter FEATURES GENERAL DESCRIPTION • • • • • • • • • • • • • • • The STI3411A is a 1.0MHz constant frequency, current mode step-down converter. It is ideal for portable equipment requiring very high current up to 2A from single-cell Lithium-ion batteries while still achieving over 90% efficiency during peak load conditions. The STI3411A also can run at 100% duty cycle for low dropout operation, extending battery life in portable systems while light load operation provides very low output ripple for noise sensitive applications. The STI3411A can supply up to 2A output load current from a 2.3V to 6V input voltage and the output voltage can be regulated as low as 0.6V. The high switching frequency minimizes the size of external components while keeping switching losses low. The internal slope compensation setting allows the device to operate with smaller inductor values to optimize size and provide efficient operation. The STI3411A is offered in a low profile (1mm) 6-pin, thin SOT package, and is available in an adjustable version. This device offers two operation modes, PWM control and PFM Mode switching control, which allows a high efficiency over the wider range of the load. High Efficiency: Up to 96% 1.0MHz Constant Frequency Operation 2A Output Current No Schottky Diode Required 2.3V to 6V Input Voltage Range Output Voltage as Low as 0.6V PFM Mode for High Efficiency in Light Load 100% Duty Cycle in Dropout Operation Low Quiescent Current: 40μA Short Circuit Protection Thermal Fault Protection Inrush Current Limit and Soft Start Input overvoltage protection(OVP)
STI3411A 价格&库存
很抱歉,暂时无法提供与“STI3411A”相匹配的价格&库存,您可以联系我们找货
STI3411A
  • 1+0.63280
  • 200+0.40880
  • 1500+0.35420
  • 3000+0.31360
库存:1749
STI3411A
  • 10+0.48243
  • 100+0.38026
  • 600+0.29086
  • 1200+0.28650
库存:940
