SMIS130804-R15MT
SMIS130804-R15MT
    SXN(顺翔诺)
    IND_12.8X7.8MM_SM
    功率电感 150nH ±20% IND_12.8X7.8MM_SM 4.20mm 12.80 x 7.80mm 0.41mΩ 45A Original
SMIS130804-R15MT 数据手册
诺 -顺 N SX 顺 - XN SMIS130804 Series Ultra-high current SMT power inductors 翔 S 诺 翔 -顺 N SX ◆特征: 顺 - XN S 诺 诺 翔 -顺 N Features: SX ● 低直流电阻和超大电流的薄型设计 -顺 N X S ● Low RDC and ultra-high current thin design 诺 anti- electromagnetic 诺● Magnetic shielding type, strong 诺 翔 翔 Interference, suitable for high-翔density installation 顺 顺 - ● 高可靠性,通过采用一体成型结构享有卓越 ● High-reliability,High vibration - -顺 resistance as result of N N N 的抗震动性 newly developed integral SX SX SX construction ● 磁屏蔽型抗电磁干扰强适用于高密度安装 ● 由于复合结构,超低蜂鸣噪声 ● 频率高达 3MHz ● PDA,笔记本,台式机,服务器应用程序 -顺 -顺 N SX 诺 诺 翔 ● Absolute maximum voltage 30VDC 翔 ● RoHS, Halogen Free and REACH Compliance 顺 顺 - - N Applications: XN SX S ● PDA , notebook ,desktop ,server applications 诺 翔 诺 -顺 N X -顺 N X ◆环境: Environmental Data: S 诺 翔 ◆试验设备: 顺 -WK3260B ● 电感值: 或同等仪器 N X S WK3260B+WK3265B ● 电流: 诺(Including coils self-temperature rise) 诺 翔 Test Equipment: 翔 -顺 ● L: WK3260B LCR meterNor-顺equivalent N SX SX ● Isat & Irms: WK3260B+WK3265B ① 翔 -顺 成型贴片功率电感 N SMIS SMT SX Molding Power Inductor -顺 N SX 诺 翔 R15 ③ -顺M N X ④ S 翔 顺 - XN T ⑤ S ③ 诺 诺Inductance 翔 翔 External Dimensions (L×W×H) 0.15 uH -顺 -顺 (mm) N N X SX 130804 12.8×7.8×4.2 S 外形尺寸(L×W×H) (mm) 类型 Type 诺 翔 SX 诺 Product Identification: ② 诺 顺 - N ● DCR:Chroma 16502 or equivalent 诺 翔 130804 -顺 N SX ② S ● Operating Temperature: -40℃ to +125℃ ● 直流电阻: Chroma 16502 或同等仪器 SMIS ① S 翔 ● Battery powered devices ● DC/DC converters in distributed power systems (包括线圈自身温升) 顺 - XN ● High current POL converters 诺 翔 ● 工作温度:-55℃ 至+125℃ -顺 诺 诺 翔 翔 Small parasitic capacitance 顺 顺 - and low ● High efficiency Low DC resistance of winding N- N X S SX eddy-current loss of the core ● Die-casting by low loss alloy powder low impedance, ● 分布式电源系统中的 DC/DC 转换器 诺 翔 ◆产品型号: S ● Frequency up to 3MHz 诺 ● 绝缘最大电压 翔 30VDC ● 符合 RoHS,无卤和 REACH -顺 N ◆用途: SX 诺● 大电流 POL 转换器 翔 ● 电池供电设备 顺 - N X ● Ultra Low buzz noise, due to composite construction 诺● 低损耗合金粉末压铸低阻抗,小寄生电容 诺 翔 翔 顺 -顺 ● 能效高,可减少绕线的低直流电阻与磁芯的 N SX 涡流损耗 -顺 诺 翔 M o l d i n g S M D P o w e r I n d翔 uctors 诺 翔 诺 翔 http:// www.sxndz.com -顺 N X HENZHEN SHUNXIANGNUO ELECTRONICS CO., LTD. S 1 顺 诺 诺 翔 M o l d i n g S M D P o w e r I n d翔 uctors -顺 N SX ④ 公差 Inductance Tolerance 诺 J:±5%,K: ±10%, L: ±15% 诺 翔 编带Tape & Reel -顺 N SX TF 诺 S -顺 -顺 ● Co-planarity: 0.15Max N SX 诺 翔 ◆规格特性: -顺 N X 诺 翔 S 诺 翔 诺 翔 顺 - Land Pattern N SX Recommended -顺 N X ITEM 诺 B 翔 顺 7.80 N- SX 12.80 ±0.40 顺 - N X S A N X SMIS130804 S -顺 诺 翔 S 诺 -顺 S 诺 -顺 N SX 翔 -顺 N X 翔 顺 Part No 诺 翔 Shape and Dimensions(dimensions are in mm): 翔 诺 翔 S 散装Bulk Package ◆外观尺寸: - XN 顺 - XN S 包装 Packing B 翔 M: ±20%,P: ±25%, N: ±30% 顺 N- X S 顺 - XN ⑤ ±0.40 C D 4.20 3.50 Max ±0.50 诺 翔 诺 翔F E -顺 2.50 N X ±S 0.50 G H 6.00 14.50 5.00 Typ Typ Typ 诺 翔 -顺 N X 翔 ● SMIS130804 Series Electrical Characteristics (Electrical specifications at 25℃) 100KHz 1.0V Part No 诺 翔 Tol Max 0.41 0.55 0.45 0.60 1.12 1.30 SMIS130804-R15M 0.15 SMIS130804-R22M 0.22 顺 ±20% N- SX ±20% SMIS130804-R33M 0.33 ±20% 翔 '@0A S 诺 翔 SMIS130804-R47M 诺 Current Typical -顺 XN -顺 L(μH) Saturation S DCR (mΩ) -顺 N XTemperature SRise Current 诺 翔 Typical -顺 85.00 N X (A) S (A) Typical 顺 - N 45.00 80.00 45.00 70.00 35.00 SX 诺 诺 诺 0.47 翔 ±20% 1.12 1.30 60.00 35.00 翔 翔 ● Saturation Current: DC current 顺 its value without current. -顺 -顺 at which inductance drops 30%N-from N N ● Temperature Rise Current: X the actual value of DC current when X the temperature rise isΔT 40℃SX(Ta=25℃). S S ● Rated DC Current:The less value which is Isat or Irms. ● Special remind:Circuit design, component, PCB trace size and thickness, airflow and other cooling provisions 诺 诺 翔 诺 翔 翔 all affect the part temperature. Part temperature should be verified in the end application. -顺 N X -顺 N SX S 诺 翔 -顺 N SX -顺 N X S 诺 翔 诺 翔 http:// www.sxndz.com -顺 N X HENZHEN SHUNXIANGNUO ELECTRONICS CO., LTD. S S 诺 Specifications: -顺 N SX Inductance 顺 - XN 2 顺 诺 诺 翔 M o l d i n g S M D P o w e r I n d翔 uctors -顺 N SX 顺 - XN ● Saturation current VS temperature rise current curve SMIS130804-R15M 翔 -顺 N X 诺 诺 -顺 -顺 N SX 诺 翔 诺 翔 -顺 N SX -顺 N X S 诺 翔 诺 翔 -顺 N X -顺 N X S S 诺 诺 翔 翔 顺 -顺 N SX S -顺 N SX -顺 N X SX 诺 翔 诺 翔 -顺 N X 顺 - XN S 诺 S 诺 诺 翔 翔 -顺 N SX S -顺 N SX 顺 - N S 诺 翔 翔 顺 - XN S 诺 -顺 S 诺 翔 诺 翔 翔 -顺 N X -顺 N X 诺 S 诺 翔 -顺 N X -顺 N SX 诺 翔 SMIS130804-R47M 翔 顺 - XN S S - XN 顺 - N X S 诺 诺 翔 -顺 N X SMIS130804-R33M 翔 -顺 诺 翔 翔 S 诺 翔 -顺 N X S -顺 N SX 诺 翔 诺 翔 S 顺 S 诺 翔 -顺 N SX - XN S SMIS130804-R22M 诺 翔 顺 - XN -顺 N X S 诺 翔 诺 翔 http:// www.sxndz.com -顺 N X HENZHEN SHUNXIANGNUO ELECTRONICS CO., LTD. S 3 诺 -顺 N SX ◆产品包装: Packaging: 翔 诺 -顺 N X 诺 翔 -顺 N X -顺 N X S S 诺 顺 诺 翔 -顺 N SX S -顺 N SX -顺 N X -顺 N SX S 诺 翔 诺 翔 -顺 N X -顺 N X S S 诺 诺 翔 翔 -顺 N SX -顺 N X SX 诺 翔 诺 翔 -顺 N X 顺 - XN S 诺 S 诺 诺 翔 翔 -顺 N SX S -顺 N SX 顺 - N S 诺 翔 翔 顺 - XN S 诺 翔 诺 翔 ●Tape Dimension (mm) -顺 N SX -顺 S 诺 翔 翔 - XN 顺 - N X S 诺 诺 翔 诺 翔 -顺 N SX 翔 -顺 N X S 诺 S -顺 -顺 N X 翔 顺 诺 翔 诺 翔 -顺 N X 诺 诺 翔 S S 翔 顺 - XN 诺 翔 -顺 N SX - XN 顺 - XN S ● Tape and Reel Specifications: (Dimensions are in mm) 诺 诺 翔 ● Reel dimensions (mm) 翔 顺 -顺 N SX -顺 诺 翔 M o l d i n g S M D P o w e r I n d翔 uctors -顺 N X S 诺 翔 诺 翔 http:// www.sxndz.com -顺 N X HENZHEN SHUNXIANGNUO ELECTRONICS CO., LTD. S 4 顺 诺 诺 翔 M o l d i n g S M D P o w e r I n d翔 uctors ● Cover tape peel off condition 翔 -顺 N SX S 诺 诺 翔 -顺 N SX 诺 翔 -顺 SMIS130804 24.0 P -顺 N SX 12.0 11.5 翔 -顺 诺 翔Outside Carton, 顺 -不足整箱用内盒或填充物装满 N X S Reel Dimensions A 诺 REEL C D翔 (PCS) -顺 13 330 1000 N X S B 24.4 60 Inside Outside Box(PCS) Carton(PCS) -顺 N SX -顺 N SX S 顺 - N SX 诺 翔 诺 翔 -顺 N X 顺 - XN S 诺 诺 翔 翔 -顺 N SX -顺 N SX -顺6000 N X 2000 S S 诺 -顺 N X 诺 翔 翔 S 翔 S 诺 顺 - XN 诺 翔 翔 S 诺 翔 S 诺 顺 -顺 N X 翔 -顺 N X Inside Box -顺 N SX 诺 翔 诺 翔 诺 -顺 N X Tape Dimension W S 诺 翔 诺 诺 翔 W1 顺 - N X S PE 袋 Part No. -顺 N X S 诺 翔 REEL13 顺 N- X S - XN 诺 翔 -顺 N SX 诺 翔 -顺 S 诺 ● Packing quantity 诺 翔 -顺 N X 翔 S 诺 翔 -顺 N X 诺 顺 S b) Noodle strip peeling angle165°to 180° S 翔 顺 - XN a) Cover tape peel force shall be 10 to 120g -顺 N SX - XN 顺 - XN -顺 N X S 诺 翔 诺 翔 http:// www.sxndz.com -顺 N X HENZHEN SHUNXIANGNUO ELECTRONICS CO., LTD. S 5 顺 诺 诺 翔 M o l d i n g S M D P o w e r I n d翔 uctors ◆可靠性测试: Requirements Items -顺 N SX -顺 顺 - XN Reliability Testing: N SX S Test Methods and Remarks 诺 诺the inductor to the testing jig using leadfree Solder 诺 翔 翔 翔 Define: A: sectional area of terminal solder. Then apply a force in the 顺 顺 - force≧5N time:30sec A≦8mm2 - Keep time: 10±1s Speed: 1.0mm/s.N-顺 N N X X force ≧10N time: S10sec S8mm2
SMIS130804-R15MT 价格&库存
很抱歉,暂时无法提供与“SMIS130804-R15MT”相匹配的价格&库存,您可以联系我们找货
SMIS130804-R15MT
  • 5+2.88000
  • 20+2.61000
  • 100+2.34000
  • 500+2.07000
  • 1000+1.94400
  • 2000+1.85400
SMIS130804-R15MT
  • 1+3.60720
  • 10+2.90520
  • 30+2.55960
  • 100+2.20320
  • 500+1.99800
  • 1000+1.89000
库存:202
