SLO0420H Series
那天
SMD Molding Power Inductor
◆ Features
Pb
、Magnetically shielded construction, low DC resistance;
、The use of magnetic iron powder ensure capability
for large current;
3、Low audible core noise;
4、Ideal for DC-DC converter applications in hand held
personal computer and etc;
5、Frequency Range: up to 30MHz;
6、RoHS compliant。
1
2
◆ Applications
、Smart phone、MID;
、Next-generation mobile devices with multifunction such
as adding color TV and digital movie cameras;
3、Flat-screen TVs, blue-ray disc recorders, set top box;
4、Notebooks, desktop computers, servers, graphic cards;
5、Portable gaming devices, personal navigation systems,
personal multimedia devices;
6、Automotive systems;
7、Telecomm base stations。
1
2
◆ Lead Free Part Numbering
SLO
(1)
0420
(2)
H
(3)
2R2 M T
T
(4) (5) (6) (7)
(1)
(2)
(3)
(4)
Series Type
Dimension A X C
Material Code
Inductance 2R2=2.2μH
100=10μH 101=100μH
(5) Inductance Tolerance M= 20%, N= 30%
(6) Company Code
(7) Packaging packed in embossed carrier tape
◆ Dimensions
Series
SLO0420H
Rev.01
A±0.2(mm)
B±0.2 (mm)
C (mm)
D±0.1 (mm)
E±0.1 (mm)
4.4
4.2
2.0 Max
1.5
0.8
Page 1 of 4
www.sunltech.com
SLO0420H Series
◆ Specification
Ω
Rdc
(m )
Test a
condition
HEAT RATING
CURRENT(Idc)
DC AMPS1
(Typ.)
SATURATION
CURRENT(Isat)
DC AMPS2
(Typ.)
μ
Typ.
Max
SLO0420HR22MTT
0.22
6.0
6.6
100KHz/1V
9.0
12.5
SLO0420HR47MTT
0.47
10
14
100KHz/1V
7.0
9.5
SLO0420HR56MTT
0.56
12
16
100KHz/1V
6.0
8.5
SLO0420HR68MTT
0.68
16
21
100KHz/1V
5.2
8.5
SLO0420H1R0MTT
1.0
19
27
100KHz/1V
4.5
7.0
SLO0420H1R2MTT
1.2
100KHz/1V
4.5
6.5
SLO0420H1R5MTT
1.5
28
42
100KHz/1V
4.0
6.0
SLO0420H2R2MTT
2.2
42
58
100KHz/1V
3.0
5.0
SLO0420H3R3MTT
3.3
63
87
100KHz/1V
2.5
4.0
SLO0420H4R7MTT
4.7
84
104
100KHz/1V
2.2
3.0
SLO0420H6R8MTT
6.8
130
170
100KHz/1V
2.0
2.5
SLO0420H100MTT
10
205
265
100KHz/1V
1.6
2.2
Part Number
INDUCTANCE
Lo( H)
SLO0420H Series
NOTES:
1. DC current (Idc) that will cause an approximate T of 40
2. DC current (Isat) that will cause Lo to drop approximately 20%
3. All test data is referenced to 25 ambient
4. Operating Temperature Range -55 to +150
5. The part temperature (ambient + temp rise) should not exceed 150
under the worst operating conditions. Circuit design, component placement,
PWB trace size and thickness, airflow and other cooling provisions all affect
the part temperature. Part temperature should be verified in the end application.
Rev.01
Page 2 of 4
www.sunltech.com
SLO0420H Series
◆ Wave Soldering
◆ Hand soldering
Rev.01
Page 3 of 4
www.sunltech.com
SLO0420H Series
◆ Reliability Mechanical
℃ ~+125℃
-45℃ ~ + 1 2 5 ℃
-55
Rev.01
Page 4 of 4
www.sunltech.com
很抱歉,暂时无法提供与“SLO0420H1R5MTT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.88612
- 50+0.74206
- 150+0.68032
- 国内价格
- 5+0.97654
- 50+0.81778
- 150+0.74974
- 500+0.68170
- 3000+0.55502
- 6000+0.52780
