SLO0530H100MTT
SLO0530H100MTT
    SUNLTECH(顺磁)
    SMD,5.4x5.2mm
    功率电感 10µH ±20% 108mΩ IND_5.4X5.2MM_SM
SLO0530H100MTT 数据手册
SLO0530H Series SMD Molding Power Inductor ◆ Features Pb 、Magnetically shielded construction, low DC resistance; 、The use of magnetic iron powder ensure capability for large current; 3、Low audible core noise; 4、Ideal for DC-DC converter applications in hand held personal computer and etc; 5、Frequency Range: up to 3.0MHz; 6、RoHS compliant。 1 2 ◆ Applications 、Smart phone、MID; 、Next-generation mobile devices with multifunction such as adding color TV and digital movie cameras; 3、Flat-screen TVs, blue-ray disc recorders, set top box; 4、Notebooks, desktop computers, servers, graphic cards; 5、Portable gaming devices, personal navigation systems, personal multimedia devices; 6、Automotive systems; 7、Telecomm base stations。 1 2 ◆ Lead Free Part Numbering SLO (1) 0530 (2) H (3) 2R2 M (4) (5) : : (1) (2) (3) (4) T T (6) (7) Series Type Dimension A X C Material Code Inductance 2R2=2.2μH 100=10μH 101=100μH (5) Inductance Tolerance M= 20%, Y= 30% (6) Company Code (7) Packaging packed in embossed carrier tape ; ; : ± : ± ◆ Dimensions Series SLO0530H Rev.01 A±0.3(mm) B±0.3 (mm) C (mm) D±0.1 (mm) E±0.1 (mm) 5.4 5.2 3.0 Max 2.0 1.0 Page 1 of 4 www.sunltech.com SLO0530H Series ◆ Specification Ω Rdc (m ) Test a condition HEAT RATING CURRENT(Idc) DC AMPS1 (Typ.) SATURATION CURRENT(Isat) DC AMPS2 (Typ.) μ Typ. Max SLO0530HR47MTT 0.47 5.0 7.4 100KHz/1V 12.0 16.0 SLO0530HR68MTT 0.68 9.0 12.0 100KHz/1V 8.5 14.0 SLO0530H1R0MTT 1.0 11.0 14.0 100KHz/1V 7.0 9.0 SLO0530H1R5MTT 1.5 20.0 25.0 100KHz/1V 6.0 8.2 SLO0530H2R2MTT 2.2 25.0 35.0 100KHz/1V 5.5 7.5 SLO0530H3R3MTT 3.3 28.0 38.0 100KHz/1V 5.0 5.5 SLO0530H4R7MTT 4.7 46.0 60.0 100KHz/1V 4.0 4.5 SLO0530H5R6MTT 5.6 53.0 63.0 100KHz/1V 4.0 4.0 SLO0530H6R8MTT 6.8 66.0 76.0 100KHz/1V 4.0 3.5 SLO0530H100MTT 10.0 108.0 128.0 100KHz/1V 2.8 2.5 Part Number INDUCTANCE Lo( H) SLO0530H Series NOTES: △ ℃ 1. DC current (Idc) that will cause an approximate T of 40 2. DC current (Isat) that will cause Lo to drop approximately 20% 3. All test data is referenced to 25 ambient 4. Operating Temperature Range -55 to +150 5. The part temperature (ambient + temp rise) should not exceed 150 under the worst operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. ℃ Rev.01 ℃ ℃ Page 2 of 4 ℃ www.sunltech.com SLO0530H Series ◆ Wave Soldering ◆ Hand soldering Rev.01 Page 3 of 4 www.sunltech.com SLO0530H Series ◆ Reliability Mechanical ℃ ~+125℃ -45℃ ~ + 1 2 5 ℃ -55 Rev.01 Page 4 of 4 www.sunltech.com
SLO0530H100MTT
物料型号:SLO0530H系列,包括不同的电感值,如4.7μH、6.8μH、10μH等。
器件简介:该系列电感器具有磁屏蔽结构,低直流电阻,使用磁性铁粉确保大电流能力,低噪音,适用于手持个人电脑等DC-DC转换器应用,频率范围高达3.0MHz,符合RoHS标准。
引脚分配:未提供具体引脚分配信息。
参数特性:包括直流电阻(Rdc)、电感值(Lo)、额定电流(Idc)和饱和电流(Isat)等。
功能详解:适用于智能手机、MID、下一代移动设备、平板电视、蓝光刻录机、机顶盒、笔记本电脑、台式电脑、服务器、图形卡、便携式游戏设备、个人导航系统、多媒体设备、汽车系统和电信基站。
应用信息:广泛适用于多种电子设备,包括移动设备、消费电子产品、计算机硬件和汽车电子产品。
封装信息:封装尺寸和材料代码在文档中有详细说明,具体尺寸包括A、B、C、D、E等参数。
SLO0530H100MTT 价格&库存
很抱歉,暂时无法提供与“SLO0530H100MTT”相匹配的价格&库存,您可以联系我们找货
SLO0530H100MTT
  • 5+0.91326
  • 50+0.73451
  • 400+0.57810
  • 800+0.56943
  • 2000+0.47755
库存:1165
SLO0530H100MTT
  • 5+0.99640
  • 50+0.79980
  • 150+0.69840
  • 500+0.62500
  • 2000+0.51580
  • 4000+0.48680
库存:1095
SLO0530H100MTT
    • 200+0.61460
    • 500+0.58010
    • 1000+0.55550
    • 2000+0.53100
    库存:1713
