SLO1365H330MTT
SLO1365H330MTT
    SUNLTECH(顺磁)
    IND_14.4X12.8MM_SM
    功率电感 33µH ±20% 40mΩ IND_14.4X12.8MM_SM
SLO1365H330MTT 数据手册
SLO1365H330MTT 1. Features 1. Magnetic metal powder inductor. 2. Compact design. 3. High current,low DCR,high efficiency. 4. Very low acoustic noise and very low leakage flux noise. 5. High reliability. 6. 100% Lead(Pb)-Free and RoHS compliant. 2. Dimensions(外形尺寸) (外形尺寸) 330 编号 A B C D E 尺寸(mm) 14.40Max. 12.80 0.30 ± 4.00 0.50 ± 6.50Max. 0 0.15 ~ F ± 2.50 0.50 3. Recommend Land Pattern Dimensions(推荐焊盘) (推荐焊盘) A B C 4.50 3.40 14.10 Unit : mm Rev.01 Page 1 of 7 www.Sunltech.com SLO1365H330MTT 4.Specifications DCR ( mΩ) L0 Inductance Part Number ( µH ) @ (0A) SLO1365H330MTT 33 Typ. Max 40 48 NOTES: 1. Idc : DC current (A) that will cause an approximate Heat Rating Current Saturation Current DC Amps. Idc ( A ) DC Amps. Isat ( A ) 5.0 9.0 △T of 40℃, 2. 2. Isat : DC current (A) that will cause Lo to drop approximately 35% ℃ ambient 4. Operating Temperature Range -55℃ to +125℃ 3. All test data is referenced to 25 5. The part temperature (ambient + temp rise) should not exceed 125 ℃under the worst operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 6. TEST FREQUENCY:100KHz,1.0V 7. TESTING INSTRUMENT L :Agilent4284A,WK4235,CH3302/G LCR METER CH1320,CH1320S BIAS CURRENT SOURCE Rdc :CH502BC MICRO OHMMETER Rev.01 Page 2 of 7 www.Sunltech.com SLO1365H330MTT 5. TEST REPORT TEST REPORT L0A 33uH ±20% 32.1 30.8 31.4 31.7 32 31.6 32.2 31.6 32.4 31.3 Specification Tolerance 1 2 3 4 5 6 7 8 9 10 X Specification Tolerance 1 2 3 4 5 6 7 8 9 10 X Rev.01 Electrical Characteristic Item DCR 48mΩ Max 5Amps △T≦40℃ I sat 9Amps L≧65% 35.3℃ 71.22% I rms 40.1 39.8 40.2 39.9 40.4 40.2 40.4 40.1 40.3 40.2 31.71 40.160 A B 14.4 12.8 Max (mm) External Dimensions Item C D F 4.0 6.5 2.5 ± 0.3(mm) ± 0.5(mm) Max (mm) ± 0.5(mm) 14.07 12.75 4.03 6.37 2.59 14.08 12.74 4.02 6.34 2.64 14.13 12.75 4.02 6.31 2.59 14.12 12.74 4.03 6.26 2.59 14.07 12.75 4.03 6.34 2.61 14.12 12.75 4.02 6.35 2.63 14.09 12.74 4.01 6.36 2.61 14.11 12.75 4.01 6.29 2.63 14.08 12.75 4.01 2.61 14.12 12.75 3.99 6.29 6.32 14.099 12.747 4.017 6.323 2.611 Page 3 of 7 2.61 www.Sunltech.com SLO1365H330MTT 6. INDUCTANCE VS DC CURRENT 7.TEMPERATURE RISE VS DC CURRENT Rev.01 Page 4 of 7 www.Sunltech.com SLO1365H330MTT 8. Reliability and Test Condition Item Performance Test Condition ℃ -10~+40℃,50~60%RH (Product without taping) Operating temperature -40~+125 Storage temperature Electrical Performance Test HP4284A,CH11025,CH3302,CH1320,CH1320S Inductance Refer to standard electrical characteristics list. DCR CH16502,Agilent33420A Micro-Ohm Meter. Saturation Current (Isat) △L30% typical. Saturation DC Current (Isat) will cause L0 to drop L(%)(keep quickly). △ Heat Rated Current (Irms) Heat Rated Current (Irms) Heat Rated Current (Irms) will cause the coil Approximately △T≦40℃ △T(℃) without core loss. temperature rise Reliability Test ℃ Temperature:125±2 . Duration:1000±12hrs . High Temperature Exposure Test ℃ Low Temperature Life Test Temperature:-40±2 Low Temperature Life Test . Humidity:85±3%RH. Temperature:85±2 . Duration:1000±12hr s. ℃ Biased Humidity Test Condition for 1 cycle Step1:-40+0 / -2 Thermal shock test Electric specifications should be satisfied ℃ 15±1 min. Step2:Room temperature within ℃ ≦0.2 min. Step3:+125+2 / -0 Frequency: 10-2000-10Hz for15±1min. 20 min. Amplitude: Parts mounted within 2" from any secure Vibration test point. Directions and times: X, Y, Z directions for 20 min. Reflow test Reflow test Solder test Terminals should be covered by over 95% solder on visual inspection Solder test Terminals should be covered by over 95% solder on visual inspection Rev.01 Page 5 of 7 : ±℃ : : ± ℃, , ± ℃, ± Pre-heat 150 5 Duration 5 minutes 20~40 Temperature 260 5 seconds (IPC/JEDEC J-STD-020C) After dip into flux dip into solder 235 5 4 1seconds Flux solder for lead free (ANSI /J-STD-002C Method B) 、 www.Sunltech.com SLO1365H330MTT 9. SOLDERING CONDITION RECOMMENDED 回流焊 9.1 器件焊接方式: 9.1.1 回流焊焊接方式及推荐炉温曲线 9.1.2 高温耐热性描述(在 265℃的熔融铅料中,停留时间不少于 10 秒,3 次最少,无 质量问题。) O 9.1.3 返修温度和时间 (温度:400 C;时间:不少于 5 秒。) 9.1.4 焊接次数 (元器件能承受的焊接次数不少于 3 次。) Rev.01 Page 6 of 7 www.Sunltech.com SLO1365H330MTT 10. Packaging Information F TYPE A B A B C D E F C D 24mm 330 100 21.0 ±0.8 + 0 .5 13 − 0.2 16±0.3 26.4 E Q’TY (PCS) A0 B0 KO W P T 500 14.5±0.1 12.9±0.1 ±0.1 6.6±0.1 24.0±0.3 16.0±0.1 .0±0.1 0.40±0.05 101 一卷包装:500Pcs; ①一卷包装 ② 小箱装两卷:一共 1000Pcs; 00Pcs; ③ 大箱装三小箱: 大箱装三小箱 一共 3000Pcs. 00Pcs. Rev.01 Page 7 of 7 www.Sunltech.com
SLO1365H330MTT
1. 物料型号:SLO1365H330MTT
2. 器件简介: - 该电感器采用磁性金属粉末材料制成。 - 设计紧凑,具有高电流、低直流电阻(DCR)和高效率。 - 非常低的声学噪声和漏磁噪声。 - 高可靠性。 - 100%无铅且符合RoHS标准。
3. 引脚分配:文档中未明确提供引脚分配信息,但通常这类电感器为表面贴装元件,具体引脚分配需参考产品规格书或数据手册。
4. 参数特性: - 典型电感值(LO Inductance):33uH,最大40uH。 - 直流电阻(DCR):最大48mΩ。 - 额定直流电流(Idc):5.0A,当温度上升约40°C时。 - 饱和直流电流(Isat):9.0A,此时电感值下降约35%。
5. 功能详解: - 电感值随直流电流变化的曲线图显示了在不同直流电流下的电感值变化。 - 温度上升与直流电流的关系图显示了在不同直流电流下的温升情况。
6. 应用信息: - 工作温度范围:-55°C至+125°C。 - 存储温度:-10°C至+40°C,相对湿度50-60%(未封装产品)。
7. 封装信息: - 外形尺寸:最大14.40mm x 12.80mm,高度6.50mm,端头宽度2.50mm。 - 推荐焊盘尺寸:长度4.50mm,宽度3.40mm,间距14.10mm。
8. 可靠性和测试条件: - 包括高温暴露、低温寿命测试、偏置湿度测试、热冲击测试、振动测试和回流测试等。
9. 焊接条件推荐: - 推荐使用回流焊,提供了焊接温度曲线和高温耐热性描述。
10. 包装信息: - 提供了不同包装类型的尺寸和数量信息。
SLO1365H330MTT 价格&库存
很抱歉,暂时无法提供与“SLO1365H330MTT”相匹配的价格&库存,您可以联系我们找货
SLO1365H330MTT
  • 1+2.98860
  • 10+2.46920
  • 30+2.23790
  • 100+2.01240
  • 500+1.86360
  • 1000+1.76830
库存:1122
SLO1365H330MTT
  • 1+2.74400
  • 10+2.27360
  • 30+2.06780
库存:60
SLO1365H330MTT
    • 100+2.14370
    • 300+2.01860
    • 500+1.92930
    库存:915
    SLO1365H330MTT
    • 1+3.03600
    • 50+2.32100
    • 500+2.14500
