SMW7060S701NTT
DIMENSION
( UNIT :mm)
A
7.0±0.5
B
C
D
E
6.0±0.5
3.8Max
3.5Typ
1.5±0.2
F
1.5±0.2
G
1.75±0.2
CIRCUIT DIAGRAM
ELECTRICAL CHARACTERISTIC
Ω
P
P/N
Z( )
@100MHz
Min
Typ
RDC
(Ω)
Max
Rated Current
(A)
Max
IR
(MΩ)
Min
Rated Voltage
(V)
Max
MARK
SMW7060S101NTT
100
140
10
9.0
10
125
101
SMW7060S301NTT
225
300
10
5.0
10
125
301
SMW7060S501NTT
275
350
10
5.0
10
125
501
SMW7060S601NTT
500
700
15
4.0
10
125
601
SMW7060S701NTT
500
700
15
4.0
10
125
701
SMW7060S102NTT
800
1020
17
3.0
10
80
102
Rev.01
Page 1 of 3
www. sunltech.com
SMW7060S701NTT
MATERIAL LIST
NO.
ITEM
DESCRIPTION
SUPPLIER
1
CORE
FERRITE
SINCORES OR EQ
2
WIRE
2UEW P180
ELEKTRISOLA OR EQ
3
胶带
DM 胶带
HENGRENXIN OR EQ
4
SOLDER
Sn Cu
SHENMAO OR EQ
5
EPOXY
ME-5890
PENGNO OR EQ
6
INK
黑色
BON MARK
五.编带规格/TAPING SPECFICATIONS
16
12
后導帶
前導帶
200m/m
COMPONENTS
400m/m
Transparent carrier and cover tape
Adhesive strength of cover tape is 20 to 120 gf
The conduction band direction
80
165~1
Rev.01
Page 2 of 3
www. sunltech.com
SMW7060S701NTT
RELIABILITY TESTING
℃ ( Contain Heating coil )
Operating Temperature
- 30 to + 100
Appearance Inspection
No external defects by visual inspection
Terminal Strength
After soldering , between copper plaet and terminals
of coils , push in two directions of X , Y with
standing 10N(1.02kg) for10+/-2 sec.
Terminal should not peel off. ( Refer to figure at right )
Heat endurance of reflow
Refer to figure
soldering
Insulating resistance
Over 100 MΩ at 100V D.C . between wire and core .
Dielectric Strength
Apply at 0.5KV 3mA for 1 minute between wire and core .
Temperature characteristics
Inductance coefficient ( 0~2,000 ) × 10 /
Humidity characteristics
Inductance deviation within ± 10% , after 96 hours in 90~95%
relative humidity at 40 ± 2
℃( - 30 ~ + 100 ℃ )
℃ and 1 hours drying under normal condition .
A test is made under the above mentioned condition , and it is kept for 2 hours in the normal
IR Reflow profile
Temperature
300
250
Soldering
255
200
150
preheating
Natural cooling
100
50
Time
1 to 4 min
10 sec more than 2 min
Temperature and humidity . After that , no mechanical and electrical defect should be found .
Rev.01
Page 3 of 3
www. sunltech.com
很抱歉,暂时无法提供与“SMW7060S701NTT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.87720
- 10+3.26160
- 30+2.95920
- 100+2.72160
- 500+2.50560
- 1500+2.38680
- 国内价格
- 1+3.80770
- 10+3.19880
- 30+2.90080
- 100+2.66750
- 500+2.45570
- 1500+2.33920
- 国内价格
- 1+3.55410
- 10+2.98980
- 300+2.49480
- 600+2.29680
- 1500+2.18790
- 国内价格
- 1+3.80770
- 10+3.19880
- 30+2.90080
- 100+2.66750
- 500+2.45570
- 1500+2.33920
