1.5KE SERIES
Transient Voltage Suppressors (TVS) Data Sheet
Features
Glass passivated junction
Low zener impedance
Excellent clamping capability
1500W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.01%
Fast response time
Typical IR less than 1μA above 12V.
High Temperature soldering guaranteed: 265℃/10 seconds/.375″,
(9.5mm) lead length, 5lbs (2.3kg) tension
Plastic package has underwriters laboratory flammability 94V-0
Meets MSL level 1, per J-STD-020.
Safety certification: UL: E244458
IEC61000-4-2 ESD 30KV Air, 30KV contact compliance
Mechanical Data
Case: JEDEC DO-201 Moulded plastic
Terminal: Plated Axial leads, solderable per MIL-STD-750, Method 2026
Polarity: Color band denotes cathode except bi-directional models
Mounting Position: Any
Weight: 0.97g
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
PPPM
Minimum 1500
Watts
IPPM
PM(AV)
See Table
6.5
Amps
Watts
IFSM
200
Amps
TJ,TSTG
-55 to +150
Typical thermal resistance junction to lead
RθJL
15
℃/W
Typical thermal resistance junction to ambient
RθJA
75
℃/W
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Fig.1)
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
Steady state power dissipation at TL=75℃ (Fig.5)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note2, Fig.6)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
Revision:TVS-1.5KE SERIES-001(A3)
1/6
http://brightking.yageo.com
1.5KE SERIES
Dimensions (DO-201)
Millimeters
Cathode Band
L
T
Inches
Symbol
d
Min.
Max.
Min.
Max.
L
25.40
1.000
T
7.20
9.50
0.285
0.375
d
4.80
5.30
0.190
0.210
s
0.96
1.07
0.038
0.042
Maximum
Peak
Reverse
Clamping
Pulse
Leakage
Voltage @IPP
Current
@VRWM
s
DIA.
DIA.
L
Electrical Characteristics (TA=25℃)
Part Number
Reverse
Breakdown
Stand-Off
Voltage
Voltage
@IT
Test
Current
Unidirectional
Bidirectional
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
1.5KE6.8A
1.5KE6.8CA
5.80
6.45~7.14
10
10.5
144.8
1000
1.5KE7.5A
1.5KE7.5CA
6.40
7.13~7.88
10
11.3
134.5
500
1.5KE8.2A
1.5KE8.2CA
7.02
7.79~8.61
10
12.1
125.6
200
1.5KE9.1A
1.5KE9.1CA
7.78
8.65~9.55
1
13.4
113.4
50
1.5KE10A
1.5KE10CA
8.55
9.50~10.50
1
14.5
104.8
10
1.5KE11A
1.5KE11CA
9.40
10.50~11.60
1
15.6
97.4
5
1.5KE12A
1.5KE12CA
10.20
11.40~12.60
1
16.7
91.0
5
1.5KE13A
1.5KE13CA
11.10
12.40~13.70
1
18.2
83.5
1
1.5KE15A
1.5KE15CA
12.80
14.30~15.80
1
21.2
71.7
1
1.5KE16A
1.5KE16CA
13.60
15.20~16.80
1
22.5
67.6
1
1.5KE18A
1.5KE18CA
15.30
17.10~18.90
1
25.2
60.3
1
1.5KE20A
1.5KE20CA
17.10
19.00~21.00
1
27.7
54.9
1
1.5KE22A
1.5KE22CA
18.80
20.90~23.10
1
30.6
49.7
1
1.5KE24A
1.5KE24CA
20.50
22.80~25.20
1
33.2
45.8
1
1.5KE27A
1.5KE27CA
23.10
25.70~28.40
1
37.5
40.5
1
1.5KE30A
1.5KE30CA
25.60
28.50~31.50
1
41.4
36.7
1
1.5KE33A
1.5KE33CA
28.20
31.40~34.70
1
45.7
33.3
1
1.5KE36A
1.5KE36CA
30.80
34.20~37.80
1
49.9
30.5
1
1.5KE39A
1.5KE39CA
33.30
37.10~41.00
1
53.9
28.2
1
2/6
1.5KE SERIES
Part Number
Reverse
Breakdown
Stand-Off
Voltage
Voltage
@IT
Test
Current
Maximum
Peak
Reverse
Clamping
Pulse
Leakage
Voltage @IPP
Current
@VRWM
Unidirectional
Bidirectional
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
1.5KE43A
1.5KE43CA
36.80
40.90~45.20
1
59.3
25.6
1
1.5KE47A
1.5KE47CA
40.20
44.70~49.40
1
64.8
23.5
1
1.5KE51A
1.5KE51CA
43.60
48.50~53.60
1
70.1
21.7
1
1.5KE56A
1.5KE56CA
47.80
53.20~58.80
1
77.0
19.7
1
1.5KE62A
1.5KE62CA
53.00
58.90~65.10
1
85.0
17.9
1
1.5KE68A
1.5KE68CA
58.10
64.60~71.40
1
92.0
16.5
1
1.5KE75A
1.5KE75CA
64.10
71.30~78.80
1
103.0
14.8
1
1.5KE82A
1.5KE82CA
70.10
77.90~86.10
1
113.0
13.5
1
1.5KE91A
1.5KE91CA
77.80
86.50~95.50
1
125.0
12.2
1
1.5KE100A
1.5KE100CA
85.50
95.00~105.00
1
137.0
11.1
1
1.5KE110A
1.5KE110CA
94.00
105.00~116.00
1
152.0
10.0
1
1.5KE120A
1.5KE120CA
102.00
114.00~126.00
1
165.0
9.2
1
1.5KE130A
1.5KE130CA
111.00
124.00~137.00
1
179.0
8.5
1
1.5KE150A
1.5KE150CA
128.00
143.00~158.00
1
207.0
7.3
1
1.5KE160A
1.5KE160CA
136.00
152.00~168.00
1
219.0
6.9
1
1.5KE170A
1.5KE170CA
145.00
162.00~179.00
1
234.0
6.5
1
1.5KE180A
1.5KE180CA
154.00
171.00~189.00
1
246.0
6.2
1
1.5KE200A
1.5KE200CA
171.00
190.00~210.00
1
274.0
5.5
1
1.5KE220A
1.5KE220CA
185.00
209.00~231.00
1
328.0
4.6
1
1.5KE250A
1.5KE250CA
214.00
237.00~263.00
1
344.0
4.4
1
1.5KE300A
1.5KE300CA
256.00
285.00~315.00
1
414.0
3.7
1
1.5KE350A
1.5KE350CA
300.00
332.00~368.00
1
482.0
3.2
1
1.5KE400A
1.5KE400CA
342.00
380.00~420.00
1
548.0
2.8
1
1.5KE440A
1.5KE440CA
376.00
418.00~462.00
1
602.0
2.5
1
1.5KE480A
1.5KE480CA
408.00
456.00~504.00
1
658.0
2.3
1
1.5KE510A
1.5KE510CA
434.00
485.00~535.00
1
698.0
2.1
1
1.5KE530A
1.5KE530CA
450.00
503.50~556.50
1
725.0
2.1
1
1.5KE540A
1.5KE540CA
459.00
513.00~567.00
1
740.0
2.0
1
1.5KE550A
1.5KE550CA
467.00
522.50~577.50
1
760.0
2.0
1
1.5KE600A
1.5KE600CA
510.00
570.00~630.00
1
828.0
1.8
1
3/6
1.5KE SERIES
Ratings and Characteristic Curves (T A=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
100
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM - Peak Pulse Power (kW)
1000
100
10
1
0.1
0.1
1
10
75
50
25
td-Pulse Width (µs)
75
150 175
200
100000
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
tr=10µs
Bi-directional V=0V
10000
Peak Value IPPM
Uni-directional V=0V
Cj (pF)
100
100 125
Figure 4. Typical Junction Capacitance
150
IPPM - Peak Pulse Current, %IRSM
50
TA-Ambient Temperature (℃)
Figure 3. Pulse Waveform
Half Value IPPM (IPPM/2)
1000
Uni-directional @VR
100
50
10/1000µs Waveform
as defined by R.E.A
1.0
2.0
3.0
Bi-directional @VR
10
td
TJ=25℃
f=1.0MHz
Vsig=50mVp-p
1
Figure 5. Steady State Power Dissipation Derating
Curve
10
100
1000
VBR-Reverse Breakdown Voltage (V)
t-Time (ms)
Figure 6. Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
7
200
IFSM - Peak Forward Surve Current (A)
PM(AV), Steady State Power Dissipation (W)
25
6
5
4
3
L= 0.375″(9.5mm)
Lead Lengths
2
1
50
75
100
125
150
175
200
TL-Lead Temperature (℃)
4/6
180
160
140
120
100
80
60
40
10
Number of Cycles at 60Hz
100
1.5KE SERIES
Recommended Soldering Conditions
Wave Soldering
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds
Soldering
1 time
Marking Code
Cathode Band
YXXX
Logo
1.5KE6.8A
YXXX
Internal control code
Logo
1.5KE6.8CA
Marking Code
Marking Code
Part Number Code
1.5KE
XXX C A / XXXX
Package Code
B: Box package
TR13: Reel package
5% VBR Voltage Tolerance
Bidirectional
VBR Voltage
Series Code
5/6
1.5KE SERIES
Ordering Code for Different Package
Box package: Add suffix “/B” at the end of the part number, such as 1.5KEXXXCA/B
Reel package: Add suffix “/TR13” at the end of the part number, such as 1.5KEXXXCA/TR13
Packaging
Tape
Z
±5°
Symbol
Dimension (mm)
A
10.0±0.5
B
53.0±1.0
Z
1.2Max.
T
6.0±0.4
E
0.8Max.
L1-L2
1.0Max.
L
250.0±5.0
W
75.0±5.0
H
114.0±5.0
A
E
L1
B
L2
T
E
Box
H
L
W
Quantity: 1000PCS
Reel
D0
D1
D
W1
D
330.0±3.0
D0
16.4±2.0
D1
86.0±2.0
W1
76.0±3.0
Quantity: 1200PCS
6/6
很抱歉,暂时无法提供与“1.5KE7.5A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.00000
- 50+0.85000
- 150+0.75000
- 500+0.65000
- 1000+0.54500
- 国内价格
- 10+1.37450
- 100+1.02800
- 500+0.79700
- 1000+0.57750
- 2000+0.54870
- 10000+0.50820
