1.5SMC18A
1.5SMC18A
    BRIGHTKING(君耀)
    SMC(DO-214AB)
    TVS二极管 VRWM=15.3 V VBR(Min)=17.1 V VC=25.2 V IPP=60.3 A Ppp=1500 W SMC
1.5SMC18A 数据手册
1.5SMC SERIES Transient Voltage Suppressors (TVS) Data Sheet Features ■ For surface mounted applications in order to optimize board space ■ Low profile package ■ Built-in strain relief ■ Glass passivated junction ■ Low inductance ■ Excellent clamping capability ■ 1500W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% ■ Fast response time ■Typical IR less than 1μA above 12V ■ High Temperature soldering: 260℃/10 seconds at terminals ■ Plastic package has underwriters laboratory flammability 94V-0 ■ Meets MSL level 1, per J-STD-020 ■ Safety certification: UL: E244458 ■ IEC61000-4-2 ESD 30KV Air, 30KV contact compliance Mechanical Data ■ ■ ■ ■ ■ Case: JEDEC DO-214AB. Molded plastic over glass passivated junction Terminal: Tin plated, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode except bi-directional models Standard Packaging: 16mm tape (EIA STD RS-481) Weight: 0.26g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) PPPM Minimum 1500 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 6.5 Watts IFSM 200 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 15 ℃/W Typical thermal resistance junction to ambient RθJA 75 ℃/W Steady state power dissipation at TA=50℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. Mounted on 8.0mm×8.0mm copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. Revision:TVS-1.5SMC SERIES-001(A3) 1/7 http://brightking.yageo.com 1.5SMC SERIES Dimensions (SMC/DO-214AB) Millimeters Inches Symbol Cathode Band D1 D Min. Max. Min. Max. L 6.60 7.11 0.260 0.280 D 5.59 6.22 0.220 0.245 D1 2.90 3.20 0.114 0.126 T 7.75 8.13 0.305 0.320 T1 0.76 1.52 0.030 0.060 d - 0.203 - 0.008 H 2.20 2.80 0.087 0.110 H1 2.06 2.62 0.079 0.103 L H1 H d T1 T Electrical Characteristics (TA=25℃) Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage@IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) 1.5SMC6.8A 1.5SMC6.8CA 6V8A 6V8C 5.80 6.45~7.14 10 10.5 144.8 1000 1.5SMC7.5A 1.5SMC7.5CA 7V5A 7V5C 6.40 7.13~7.88 10 11.3 134.5 500 1.5SMC8.2A 1.5SMC8.2CA 8V2A 8V2C 7.02 7.79~8.61 10 12.1 125.6 200 1.5SMC9.1A 1.5SMC9.1CA 9V1A 9V1C 7.78 8.65~9.55 1 13.4 113.4 50 1.5SMC10A 1.5SMC10CA 10A 10C 8.55 9.50~10.50 1 14.5 104.8 10 1.5SMC11A 1.5SMC11CA 11A 11C 9.40 10.50~11.60 1 15.6 97.4 5 1.5SMC12A 1.5SMC12CA 12A 12C 10.20 11.40~12.60 1 16.7 91.0 5 1.5SMC13A 1.5SMC13CA 13A 13C 11.10 12.40~13.70 1 18.2 83.5 1 1.5SMC15A 1.5SMC15CA 15A 15C 12.80 14.30~15.80 1 21.2 71.7 1 1.5SMC16A 1.5SMC16CA 16A 16C 13.60 15.20~16.80 1 22.5 67.6 1 1.5SMC18A 1.5SMC18CA 18A 18C 15.30 17.10~18.90 1 25.2 60.3 1 1.5SMC20A 1.5SMC20CA 20A 20C 17.10 19.00~21.00 1 27.7 54.9 1 1.5SMC22A 1.5SMC22CA 22A 22C 18.80 20.90~23.10 1 30.6 49.7 1 1.5SMC24A 1.5SMC24CA 24A 24C 20.50 22.80~25.20 1 33.2 45.8 1 1.5SMC27A 1.5SMC27CA 27A 27C 23.10 25.70~28.40 1 37.5 40.5 1 1.5SMC30A 1.5SMC30CA 30A 30C 25.60 28.50~31.50 1 41.4 36.7 1 1.5SMC33A 1.5SMC33CA 33A 33C 28.20 31.40~34.70 1 45.7 33.3 1 1.5SMC36A 1.5SMC36CA 36A 36C 30.80 34.20~37.80 1 49.9 30.5 1 1.5SMC39A 1.5SMC39CA 39A 39C 33.30 37.10~41.00 1 53.9 28.2 1 Revision:TVS-1.5SMC SERIES-001(A3) 2/7 http://brightking.yageo.com 1.5SMC SERIES Electrical Characteristics (TA=25℃) Part Number Device Marking Code Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage@IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional UNI BI VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) 1.5SMC43A 1.5SMC43CA 43A 43C 36.80 40.90~45.20 1 59.3 25.6 1 1.5SMC47A 1.5SMC47CA 47A 47C 40.20 44.70~49.40 1 64.8 23.5 1 1.5SMC51A 1.5SMC51CA 51A 51C 43.60 48.50~53.60 1 70.1 21.7 1 1.5SMC56A 1.5SMC56CA 56A 56C 47.80 53.20~58.80 1 77.0 19.7 1 1.5SMC62A 1.5SMC62CA 62A 62C 53.00 58.90~65.10 1 85.0 17.9 1 1.5SMC68A 1.5SMC68CA 68A 68C 58.10 64.60~71.40 1 92.0 16.5 1 1.5SMC75A 1.5SMC75CA 75A 75C 64.10 71.30~78.80 1 103.0 14.8 1 1.5SMC82A 1.5SMC82CA 82A 82C 70.10 77.90~86.10 1 113.0 13.5 1 1.5SMC91A 1.5SMC91CA 91A 91C 77.80 86.50~95.50 1 125.0 12.2 1 1.5SMC100A 1.5SMC100CA 100A 100C 85.50 95.00~105.00 1 137.0 11.1 1 1.5SMC110A 1.5SMC110CA 110A 110C 94.00 105.00~116.00 1 152.0 10.0 1 1.5SMC120A 1.5SMC120CA 120A 120C 102.00 114.00~126.00 1 165.0 9.2 1 1.5SMC130A 1.5SMC130CA 130A 130C 111.00 124.00~137.00 1 179.0 8.5 1 1.5SMC150A 1.5SMC150CA 150A 150C 128.00 143.00~158.00 1 207.0 7.3 1 1.5SMC160A 1.5SMC160CA 160A 160C 136.00 152.00~168.00 1 219.0 6.9 1 1.5SMC170A 1.5SMC170CA 170A 170C 145.00 162.00~179.00 1 234.0 6.5 1 1.5SMC180A 1.5SMC180CA 180A 180C 154.00 171.00~189.00 1 246.0 6.2 1 1.5SMC200A 1.5SMC200CA 200A 200C 171.00 190.00~210.00 1 274.0 5.5 1 1.5SMC220A 1.5SMC220CA 220A 220C 185.00 209.00~231.00 1 328.0 4.6 1 1.5SMC250A 1.5SMC250CA 250A 250C 214.00 237.00~263.00 1 344.0 4.4 1 1.5SMC300A 1.5SMC300CA 300A 300C 256.00 285.00~315.00 1 414.0 3.7 1 1.5SMC350A 1.5SMC350CA 350A 350C 300.00 332.00~368.00 1 482.0 3.2 1 1.5SMC400A 1.5SMC400CA 400A 400C 342.00 380.00~420.00 1 548.0 2.8 1 1.5SMC440A 1.5SMC440CA 440A 440C 376.00 418.00~462.00 1 602.0 2.5 1 1.5SMC480A 1.5SMC480CA 480A 480C 408.00 456.00~504.00 1 658.0 2.3 1 1.5SMC510A 1.5SMC510CA 510A 510C 434.00 485.00~535.00 1 698.0 2.1 1 1.5SMC530A 1.5SMC530CA 530A 530C 450.00 503.50~556.50 1 725.0 2.1 1 1.5SMC540A 1.5SMC540CA 540A 540C 459.00 513.00~567.00 1 740.0 2.0 1 1.5SMC550A 1.5SMC550CA 550A 550C 467.00 522.50~577.50 1 760.0 2.0 1 1.5SMC600A 1.5SMC600CA 600A 600C 510.00 570.00~630.00 1 828.0 1.8 1 Revision:TVS-1.5SMC SERIES-001(A3) 3/7 http://brightking.yageo.com 1.5SMC SERIES Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 100 10 1 0.2×0.2″(5.0×5.0mm) Copper Pad Area 0.1 1 100 10 100 80 60 40 20 0 1000 0 td-Pulse Width (µs) 150 175 Bi-directional V=0V Uni-directional V=0V Cj (pF) IPPM - Peak Pulse Current, %IRSM 125 10000 Half Value IPPM (IPPM/2) 1000 Uni-directional @VR 100 50 10/1000µs Waveform as defined by R.E.A 0 1 1.0 2.0 3.0 Bi-directional @VR 10 td 0 4.0 TJ=25℃ f=1.0MHz Vsig=50mVp-p 1 10 100 1000 VBR-Reverse Breakdown Voltage (V) t-Time (ms) Figure 5. Steady State Power Dissipation Derating Curve Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only 200 7 IFSM - Peak Forward Surve Current (A) PM(AV), Steady State Power Dissipation (W) 100 100000 Peak Value IPPM 100 75 Figure 4. Typical Junction Capacitance TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs 50 TA-Ambient Temperature (℃) Figure 3. Pulse Waveform 150 25 6 5 4 3 2 1 0 0 25 50 75 100 125 150 175 TA-Ambient Temperature (℃) Revision:TVS-1.5SMC SERIES-001(A3) 4/7 180 160 140 120 100 80 60 40 20 0 1 10 Number of Cycles at 60Hz 100 http://brightking.yageo.com 1.5SMC SERIES Recommended Soldering Conditions Reflow Soldering Critical Zone TL to TP tP TP Ramp-up TL tL Temperature TS max TS min Ramp-down tS Preheat 25 t 25℃ to Peak Time Recommended Conditions Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) (tS) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate 6℃/second max. Time 25℃ to Peak Temperature Revision:TVS-1.5SMC SERIES-001(A3) 20-40 seconds 8 minutes max. 5/7 http://brightking.yageo.com 1.5SMC SERIES Marking Code Cathode Band YXXX YXXX 6V8C 6V8A Logo Logo Internal control code Internal control code Marking Code Marking Code Part Number Code 1.5SMC XXX C A / XXXX Package Code TR7:7 inch reel package TR13:13 inch reel package 5% VBR Voltage Tolerance Bidirectional VBR Voltage Series Code Ordering Code for Different Package 7 inch reel package: Add suffix “/TR7 ” at the end of the part number, such as 1.5SMCXXXCA/TR7 13 inch reel package: Add suffix “/TR13 or ” at the end of the part number, such as 1.5SMCXXXCA/TR13 Revision:TVS-1.5SMC SERIES-001(A3) 6/7 http://brightking.yageo.com 1.5SMC SERIES Packaging Tape P0 P1 P2 D0 B Symbol Dimension (mm) W 16.00±0.20 P0 4.00±0.10 P1 8.00±0.10 P2 2.00±0.10 D0 Φ1.5±0.10 D1 Φ1.5±0.10 E 1.75±0.10 K0 F 7.50±0.10 SECTION B-B A0 6.27±0.10 B0 8.30±0.10 K0 3.15±0.15 T 0.30±0.05 D2 Φ178.0±2.0 D3 Φ50.0Min. D4 Φ13.0±0.5 W1 20.0±2.0 T E F W B0 D1 A A B A0 SECTION A-A 7” Reel D4 D3 D2 W1 Quantity: 500PCS 13” Reel D5 Φ330.0±2.0 D6 Φ13.5±0.5 H 2.5±1.0 W2 20.0±2.0 Quantity: 3000PCS Revision:TVS-1.5SMC SERIES-001(A3) 7/7 http://brightking.yageo.com
1.5SMC18A
物料型号:1.5SMC系列
器件简介:该系列是专为表面贴装应用设计的瞬态电压抑制二极管,具有低剖面封装、内置应力消除、玻璃钝化结、低电感和优秀的钳位能力。
引脚分配:根据JEDEC DO-214AB标准,带有锡镀层的引脚,符合MIL-STD-750标准。
参数特性:包括1500W的峰值脉冲功率能力、快速响应时间、典型反向漏电流小于1μA(12V以上)、高温焊接能力(260℃/10秒)、UL认证和IEC61000-4-2 ESD 30KV空气和接触合规性。
功能详解:文档提供了详细的电气特性表,包括反向工作电压、击穿电压、测试电流、最大钳位电压、峰值脉冲电流和反向漏电流等参数。
应用信息:适用于I/O接口、交流/直流电源、低频信号传输线(如RS232、RS485等)。
封装信息:提供了详细的尺寸图和封装类型,包括7英寸和13英寸的卷轴包装信息。
1.5SMC18A 价格&库存
很抱歉,暂时无法提供与“1.5SMC18A”相匹配的价格&库存,您可以联系我们找货
1.5SMC18A
  • 1+0.75709
  • 10+0.68826
  • 30+0.64238
  • 100+0.57355
  • 500+0.54144
  • 1000+0.51850
库存:194
