MCS20FC-1R5MHC
MCS20FC-1R5MHC
    PSA(信昌电陶)
    IND_2X1.6MM_SM
    功率电感 1.5µH ±20% 86mΩ IND_2X1.6MM_SM
MCS20FC-1R5MHC 数据手册
信 昌 電 子 陶 瓷 股 份 有 限 公 司 PROSPERITY DIELECTRICS CO., LTD. SPECIFICATION FOR APPROVAL CUSTOMER CUST. PART NO. CUST. DOC. REV. DESCRIPTION SAMPLE LOT NO. PART NO. DOC. REV. DATE HIGH CURRENT POWER CHOKE (ROHS+H.F.) MCS20FC-XXXMHC ORIG Once you approve this part, please sign and return this page to the following marked location. Customer Signature:___________________ Date:_________________ □This part currently development section. □Production line can produce this series of products. ■Sales Office-Headquarter No. 566-1, Kao-Shi Rd., Yangmei, Taoyuan 32668, Taiwan TEL: +886-3-475-3355 FAX: +886-3-485-4959 □Yong Zhou Plant Tao-Yuan Rd., Fenghuang Park, Lengshuitan District, Yongzhou, Hunan 425000, P.R.C. TEL: +86-746-8610-180 FAX: +86-746-8610-181 □Sales Office-Dong Guan,China No.638,Mei Jing West Road Xiniupo Administrative Zone Dalang Town,Dong Guan City,GuangDong Province,China. TEL: +86-769-8555-0979 FAX: +86-769-8555-0972 TESTED BY CHECKED BY APPROVED BY TABLE OF CONTENTS INDEX Page ■ Engineering Change Notice - Record ………………………. 2 ■ Product Identification …………….…………………………… 3 ■ Product Dimension ……………………………………………. 3 ■ Electrical Spec. ………………………………………………… 3 ■ Electrical Curve ………………………………………………… 4 ■ Reliability Performance ……………………………………….. 5 ■ Reflow Chart ……………………………………………………... 6 ■ Package Form ………………………………………………….. 7 ■ Test Report ………………………………………………………. Rev.B P1 SPECIFICATION FOR APPROVAL CUSTOMER CUSTOMER P/N REV. SPL. LOT NO. - PART NAME REV. PART NO. HIGH CURRENT POWER CHOKE (ROHS+H.F.) MCS20FC-XXXMHC DATE OF ISSUE Q'TY ORIG 0 PCS ENGINEERING CHANGE NOTICE - RECORD REVISION NO. ORIG Rev.B REVISION DESCRIPTION AUTHOR Zhikai Deng P2 DATE REMARK SPECIFICATION FOR APPROVAL ※This is a RoHS and REACH compliant product whose related documents are available on request. ※ Graphic is only for dimensionally application. 1 .PRODUCT IDENTIFICATION MCS 20FC - □□□ □ HC CONTROL NO. TOLERANCE INDUCTANCE DIMENSIONS PRODUCT SYMBOL 2. PRODUCT DIMENSION UNIT: mm DIM. TOL. M1 2.0 ±0.2 M2 1.6 ±0.2 M3 1.0 MAX. M4 0.5 ±0.3 3. ELECTRICAL SPEC. PART NO. Inductance (uH) ±20% DCR (mΩ) Typical DCR (mΩ) MAX. Irms (A) Typical Irms (A) MAX. I sat (A) Typical I sat (A) MAX. MCS20FC-R33MHC 0.33 21 26 4.7 4.0 6.7 6.1 MCS20FC-R47MHC 0.47 23 30 4.5 4.05 6.1 5.3 MCS20FC-1R0MHC 1.0 48 60 3.2 3.0 3.9 3.3 MCS20FC-1R5MHC 1.5 86 99 2.4 2.2 3.4 3.1 MCS20FC-2R2MHC 2.2 117 140 2.2 2.0 2.6 2.45 (1). Test Freq : 1MHz , 1V (2). All test referenced to 26℃ ℃ ambient. (3). Operating Temperature range: -40℃ ℃ to +125℃ ℃ (4). Storage Temperature range: -50℃ ℃ to +125℃ ℃ (5). Isat means that DC current will cause a 30% inductance reduction from initial value. (6). Irms means that DC current will cause coil temp. rising to 40℃ ℃ whichever is smaller. Rev.B P3 SPECIFICATION FOR APPROVAL 4. ELECTRICAL CURVE Rev.B P4 SPECIFICATION FOR APPROVAL 5. RELIABILITY PERFORMANCE Test Item Resistance to Solder Heat Adhesive Test Temperature Cycle Dry Heat Test Humidity Test Rev.B Test Condition Criteria 1. More than 95% of terminal electrode should be covered with new solder 2. No mechanical damage 3. Inductance value should be within ±20% of the initial value 1. Solder temperature: 260±5℃ ℃ 2. Flux: Rosin 3. DIP time: 10±1 sec 1. Reflow temperature: 245℃ ℃ It shall be Soldered on the substrate applying direction 1. No mechanical damage parallel to the substrate 2. Soldering the products on PCB after 2. Apply force(F): 5N the pulling test force > 5N 3. Test time: 10 sec 1. Temperature: -50 ~ 125℃ ℃ For 30 minutes each 2. Cycle: 500 cycles 3. Measurement: At ambient temperature 24 hours after test completion 1. No mechanical damage 2. Inductance should be within ±20% of the initial value 1. Temperature: 85±2℃ ℃ 2. Testing time: 500 hrs 3. Applied current: Full rated current 4. Measurement: At ambient temperature 24 hours after test completion 1. No mechanical damage 2. Inductance should be within ±20% of the initial value 1. Temperature: 60±2℃ ℃ 2. Humidity: 90-95% RH 3. Applied current: Full rated current 4. Testing time: 500 hrs 5. Measurement: At ambient temperature 24 hours after test completion 1. No mechanical damage 2. Inductance should be within ±20% of the initial value P5 SPECIFICATION FOR APPROVAL 6. TYPICAL RoHS REFLOW PROFILE (3~5 Rev.B P6 SPECIFICATION FOR APPROVAL 7. PACKAGING 7.1 Carrier tape dimensions UNIT : mm A0 DIM. B0 K0 1.82±0.05 2.23±0.05 1.15±0.05 0.22±0.05 7.2 Taping reel dimensions Qty.(pcs) BOX Rev.B t 3,000 5 reels / inner box P7
MCS20FC-1R5MHC 价格&库存
很抱歉,暂时无法提供与“MCS20FC-1R5MHC”相匹配的价格&库存,您可以联系我们找货
MCS20FC-1R5MHC
  • 10+0.27507
  • 100+0.25122
  • 500+0.22737
  • 1000+0.20352
  • 2000+0.18762
  • 4000+0.18285
