信 昌 電 子 陶 瓷 股 份 有 限 公 司
PROSPERITY DIELECTRICS CO., LTD.
SPECIFICATION FOR APPROVAL
CUSTOMER
CUST. PART NO.
CUST. DOC. REV.
DESCRIPTION
SAMPLE LOT NO.
PART NO.
DOC. REV.
DATE
HIGH CURRENT POWER CHOKE (ROHS+H.F.)
MCS20FC-XXXMHC
ORIG
Once you approve this part, please sign and return this page to the following marked location.
Customer Signature:___________________
Date:_________________
□This part currently development section.
□Production line can produce this series of products.
■Sales Office-Headquarter
No. 566-1, Kao-Shi Rd., Yangmei, Taoyuan 32668,
Taiwan
TEL: +886-3-475-3355
FAX: +886-3-485-4959
□Yong Zhou Plant
Tao-Yuan Rd., Fenghuang Park, Lengshuitan
District, Yongzhou, Hunan 425000, P.R.C.
TEL: +86-746-8610-180
FAX: +86-746-8610-181
□Sales Office-Dong Guan,China
No.638,Mei Jing West Road Xiniupo Administrative
Zone Dalang Town,Dong Guan City,GuangDong
Province,China.
TEL: +86-769-8555-0979
FAX: +86-769-8555-0972
TESTED BY
CHECKED BY
APPROVED BY
TABLE OF CONTENTS
INDEX
Page
■ Engineering Change Notice - Record ……………………….
2
■ Product Identification …………….……………………………
3
■ Product Dimension …………………………………………….
3
■ Electrical Spec. …………………………………………………
3
■ Electrical Curve …………………………………………………
4
■ Reliability Performance ………………………………………..
5
■ Reflow Chart ……………………………………………………...
6
■ Package Form …………………………………………………..
7
■ Test Report ……………………………………………………….
Rev.B
P1
CUSTOMER
CUSTOMER P/N
REV.
SPL. LOT NO.
PART NAME
REV.
PART NO.
HIGH CURRENT
POWER CHOKE
(ROHS+H.F.)
MCS20FC-XXXMHC
DATE OF ISSUE
Q'TY
ORIG
0 PCS
ENGINEERING CHANGE NOTICE - RECORD
REVISION
NO.
ORIG
Rev.B
REVISION DESCRIPTION
AUTHOR
Zhikai Deng
P2
DATE
REMARK
※This is a RoHS and REACH compliant product whose related documents are available on request.
※ Graphic is only for dimensionally application.
1 .PRODUCT IDENTIFICATION
MCS 20FC - □□□ □ HC
CONTROL NO.
TOLERANCE
INDUCTANCE
DIMENSIONS
PRODUCT SYMBOL
2. PRODUCT DIMENSION
UNIT: mm
DIM.
TOL.
M1
2.0
±0.2
M2
1.6
±0.2
M3
1.0
MAX.
M4
0.5
±0.3
3. ELECTRICAL SPEC.
PART NO.
Inductance
(uH)
±20%
DCR
(mΩ)
Typical
DCR
(mΩ)
MAX.
Irms
(A)
Typical
Irms
(A)
MAX.
I sat
(A)
Typical
I sat
(A)
MAX.
MCS20FC-R33MHC
0.33
21
26
4.7
4.0
6.7
6.1
MCS20FC-R47MHC
0.47
23
30
4.5
4.05
6.1
5.3
MCS20FC-1R0MHC
1.0
48
60
3.2
3.0
3.9
3.3
MCS20FC-1R5MHC
1.5
86
99
2.4
2.2
3.4
3.1
MCS20FC-2R2MHC
2.2
117
140
2.2
2.0
2.6
2.45
(1). Test Freq : 1MHz , 1V
(2). All test referenced to 26℃
℃ ambient.
(3). Operating Temperature range: -40℃
℃ to +125℃
(4). Storage Temperature range: -50℃
℃ to +125℃
(5). Isat means that DC current will cause a 30% inductance reduction from initial value.
(6). Irms means that DC current will cause coil temp. rising to 40℃
℃ whichever is smaller.
Rev.B
P3
4. ELECTRICAL CURVE
Rev.B
P4
5. RELIABILITY PERFORMANCE
Test Item
Resistance to
Solder Heat
Adhesive Test
Temperature
Cycle
Dry Heat Test
Humidity Test
Rev.B
Test Condition
Criteria
1. More than 95% of terminal electrode
should be covered with new solder
2. No mechanical damage
3. Inductance value should be within
±20% of the initial value
1. Solder temperature: 260±5℃
2. Flux: Rosin
3. DIP time: 10±1 sec
1. Reflow temperature: 245℃
℃ It shall be
Soldered on the substrate applying direction 1. No mechanical damage
parallel to the substrate
2. Soldering the products on PCB after
2. Apply force(F): 5N
the pulling test force > 5N
3. Test time: 10 sec
1. Temperature: -50 ~ 125℃
℃ For 30 minutes
each
2. Cycle: 500 cycles
3. Measurement: At ambient temperature 24
hours after test completion
2. Inductance should be within ±20% of
the initial value
1. Temperature: 85±2℃
2. Testing time: 500 hrs
3. Applied current: Full rated current
4. Measurement: At ambient temperature 24
the initial value
1. Temperature: 60±2℃
2. Humidity: 90-95% RH
4. Testing time: 500 hrs
5. Measurement: At ambient temperature 24
the initial value
P5
6. TYPICAL RoHS REFLOW PROFILE
(3~5
Rev.B
P6
7. PACKAGING
7.1 Carrier tape dimensions
UNIT : mm
A0
DIM.
B0
K0
1.82±0.05 2.23±0.05 1.15±0.05 0.22±0.05
7.2 Taping reel dimensions
Qty.(pcs)
BOX
Rev.B
t
3,000
5 reels / inner box
P7
很抱歉,暂时无法提供与“MCS20FC-2R2MMP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.19836
- 100+0.19538
- 600+0.18952
- 1200+0.18099
- 3000+0.17013
