BZX84C4V3
BZX84C4V3
    JSMSEMI(杰盛微)
    SOT-23
    350mw表面安装齐纳二极管
BZX84C4V3 数据手册
BZX84C2V4-BZX84C51 350mW Surface Mount Zener Diode FEATURES Planar Die Construction. z 350mw Power Dissipation. z Zener Voltages From 2.4V -51V z Ideally Suited For Automated Assembly Prcesses. to r z APPLICATIONS 350Mw Surface mount zener diode uc z Package Code See Table on page2 mi BZX84C2V4-BZX84C51 Marking co Type No. nd ORDERING INFORMATION SOT-23 MAXIMUM RATING @ Ta=25℃ unless otherwise specified Symbol Value Unit VF 0.9 V Power Dissipation Pd 350 mW Thermal Resistance, Junction to Ambient Air RθjA 357 ℃/W Operating and Storage Temperature Range Tj,Tstg -65 to+150 ℃ JS MI CR O Forward Valtage@IF=10mA Se Characteristic Notes: 1. Valid provided that device terminals are kept at ambient temperature. 2. Tested with pulses, 300μs pulse width, period = 5ms. 3. f = 1KHz. www.jsmsemi.com 第1页,共5页 BZX84C2V4-BZX84C51 350mW Surface Mount Zener Diode ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified Maximum Zener Marking Number Code Impedance IZT ZZT@IZT ZZK@IZK IR VR (μA) (V) Nom(V) Min(V) Max(V) (mA) (Ω) (Ω) (mA) 600 1.0 50 nd VZ@IZT Current uc Type Reverse Typical Temperature Coefficient @IZT mV/℃ to r Zerner Voltage Range Maximum Min Max 1.0 -3.5 0 Z11 2.4 2.2 2.6 5.0 100 BZX84C2V7 Z12 2.7 2.5 2.9 5.0 100 600 1.0 20 1.0 -3.5 0 BZX84C3V0 Z13 3.0 2.8 3.2 5.0 95 600 1.0 10 1.0 -3.5 0 BZX84C3V3 Z14 3.3 3.1 3.5 5.0 95 600 1.0 5.0 1.0 -3.5 0 BZX84C3V6 Z15 3.6 3.4 3.8 5.0 90 600 1.0 5.0 1.0 -3.5 0 BZX84C3V9 Z16 3.9 3.7 4.1 5.0 90 600 1.0 3.0 1.0 -3.5 0 BZX84C4V3 Z17 4.3 4.0 4.6 5.0 90 600 1.0 3.0 1.0 -3.5 0 BZX84C4V7 Z1 4.7 4.4 5.0 5.0 80 500 1.0 3.0 2.0 -3.5 0.2 BZX84C5V1 Z2 BZX84C5V6 Z3 BZX84C6V2 Z4 BZX84C6V8 CR O Se mi co BZX84C2V4 4.8 5.4 5.0 60 480 1.0 2.0 2.0 -2.7 1.2 5.6 5.2 6.0 5.0 40 400 1.0 1.0 2.0 -2.0 2.5 6.2 5.8 6.6 5.0 10 150 1.0 3.0 4.0 0.4 3.7 Z5 6.8 6.4 7.2 5.0 15 80 1.0 2.0 4.0 1.2 4.5 BZX84C7V5 Z6 7.5 7.0 7.9 5.0 15 80 1.0 1.0 5.0 2.5 5.3 BZX84C8V2 Z7 8.2 7.7 8.7 5.0 15 80 1.0 0.7 5.0 3.2 6.2 BZX84C9V1 Z8 9.1 8.5 9.6 5.0 15 100 1.0 0.5 6.0 3.8 7.0 BZX84C10 Z9 10 9.4 10.6 5.0 20 150 1.0 0.2 7.0 4.5 8.0 BZX84C11 Y1 11 10.4 11.6 5.0 20 150 1.0 0.1 8.0 5.4 9.0 JS MI 5.1 www.jsmsemi.com 第2页,共5页 BZX84C2V4-BZX84C51 350mW Surface Mount Zener Diode Maximum Zener Type Marking Number Code Impedance VZ@IZT IZT ZZT@IZT Reverse Current ZZK@IZK Nom(V) Min(V) Max(V) (mA) (Ω) (Ω) (mA) IR Typical Temperature Coefficient @IZT mV/℃ VR to r Zerner Voltage Range Maximum Min Max (μA) (V) 0.1 8.0 6.0 10.0 0.1 8.0 7.0 11.0 Y2 12 11.4 12.7 5.0 25 150 1.0 BZX84C13 Y3 13 12.4 14.1 5.0 30 170 1.0 BZX84C15 Y4 15 13.8 15.6 5.0 30 200 1.0 0.1 10.5 9.2 13.0 BZX84C16 Y5 16 15.3 17.1 5.0 40 200 1.0 0.1 11.2 10.4 14.0 BZX84C18 Y6 18 16.8 19.1 5.0 45 225 1.0 0.1 12.6 12.4 16.0 BZX84C20 Y7 20 18.8 21.2 5.0 55 225 1.0 0.1 14.0 14.4 18.0 BZX84C22 Y8 22 20.8 23.3 5.0 55 250 1.0 0.1 15.4 16.4 20.0 BZX84C24 Y9 24 22.8 25.6 5.0 70 250 1.0 0.1 16.8 18.4 22.0 BZX84C27 Y10 27 25.1 28.9 2.0 80 300 0.5 0.1 18.9 21.4 25.3 BZX84C30 Y11 BZX84C33 Y12 BZX84C36 Y13 BZX84C39 nd co mi Se CR O uc BZX84C12 28.0 32.0 2.0 80 300 0.5 0.1 21.0 24.4 29.4 33 31.0 35.0 2.0 80 325 0.5 0.1 23.1 27.4 33.4 36 34.0 38.0 2.0 90 350 0.5 0.1 25.2 30.4 37.4 Y14 39 37.0 41.0 2.0 130 350 0.5 0.1 27.3 33.4 41.2 BZX84C43 Y15 43 40.0 46.0 2.0 150 375 0.5 0.1 30.1 10.0 12.0 BZX84C47 Y16 47 44.0 50.0 2.0 170 375 0.5 0.1 32.9 10.0 12.0 BZX84C51 Y17 51 48.0 54.0 2.0 180 400 0.5 0.1 35.7 10.0 12.0 JS MI 30 www.jsmsemi.com 第3页,共5页 BZX84C2V4-BZX84C51 350mW Surface Mount Zener Diode JS MI CR O Se mi co nd uc to r TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified www.jsmsemi.com 第4页,共5页 BZX84C2V4-BZX84C51 350mW Surface Mount Zener Diode PACKAGE OUTLINE Plastic surface mounted package SOT-23 SOT-23 A K B Dim Min Max A 2.85 2.95 B 1.25 C E H G 1.85 1.95 H 0.02 0.1 0.1Typical 2.35 2.45 All Dimensions in mm JS MI CR O Se mi co K SOLDERING FOOTPRINT 0.43 0.48 J C 0.37 0.35 nd G 1.35 1.0Typical uc D J D to r E Unit : mm PACKAGE INFORMATION Device Package Shipping BZX84C2V4-BZX84C51 SOT-23 3000/Tape&Reel www.jsmsemi.com 第5页,共5页
BZX84C4V3
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器。
2. 器件简介:该器件是意法半导体公司生产的高性能微控制器,广泛应用于工业控制、消费电子等领域。
3. 引脚分配:该器件共有48个引脚,包括电源引脚、地引脚、I/O引脚等。
4. 参数特性:工作电压范围为2.0V至3.6V,工作频率可达72MHz,内置64KB Flash和20KB RAM。
5. 功能详解:具备多种通信接口,如I2C、SPI、UART等,支持多种外设功能,如ADC、DAC、定时器等。
6. 应用信息:适用于需要高性能处理和丰富外设接口的应用场景。
BZX84C4V3 价格&库存
很抱歉,暂时无法提供与“BZX84C4V3”相匹配的价格&库存,您可以联系我们找货
