SA16CA
SA16CA
    BRIGHTKING(君耀)
    DO-15
    TVS DO15 Ppp=500W VC=26V Ipp=19.6A VRWM=16V
SA16CA 数据手册
SA SERIES Transient Voltage Suppressors (TVS) Data Sheet Features ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ Glass passivated junction Low inductance Excellent clamping capability 500W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% Fast response time Typical IR less than 1μA above 10V High Temperature soldering guaranteed: 265℃/10 seconds/.375″, (9.5mm) lead length, 5lbs (2.3kg) tension Plastic package has underwriters laboratory flammability 94V-0 Meets MSL level 1, per J-STD-020 Safety certification: UL: E244458 IEC61000-4-2 ESD 30KV Air, 30KV contact compliance Mechanical Data ■ ■ ■ ■ ■ Case: JEDEC DO-15 Moulded plastic Terminal: Axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode except bi-directional models Mounting Position: Any Weight: 0.42g Applications ■ I/O interface ■ AC/DC power supply ■ Low frequency signal transmission line (RS232, RS485, etc.) Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Fig.1) PPPM Minimum 500 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 3.0 Watts IFSM 70 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 20 ℃/W Typical thermal resistance junction to ambient RθJA 75 ℃/W Steady state power dissipation at TL=75℃ (Fig.5) Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note2, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. Revision:TVS-SA SERIES-001(A2) 1/6 http://brightking.yageo.com SA SERIES Dimensions (DO-204AC/DO-15) Millimeters Cathode Band L T d s DIA. Inches Symbol DIA. L Min. Max. Min. Max. L 25.40 - 1.000 - T 5.80 7.60 0.230 0.300 d 2.60 3.60 0.104 0.140 s 0.71 0.86 0.028 0.034 Electrical Characteristics (TA=25℃) Part Number Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) SA5.0A SA5.0CA 5.0 6.40~7.00 10 9.2 55.4 600 SA6.0A SA6.0CA 6.0 6.67~7.37 10 10.3 49.5 600 SA6.5A SA6.5CA 6.5 7.22~7.98 10 11.2 45.5 400 SA7.0A SA7.0CA 7.0 7.78~8.60 10 12.0 42.5 150 SA7.5A SA7.5CA 7.5 8.33~9.21 1 12.9 39.5 50 SA8.0A SA8.0CA 8.0 8.89~9.83 1 13.6 37.5 25 SA8.5A SA8.5CA 8.5 9.44~10.40 1 14.4 35.4 10 SA9.0A SA9.0CA 9.0 10.00~11.10 1 15.4 33.1 5 SA10A SA10CA 10.0 11.10~12.30 1 17.0 30.0 3 SA11A SA11CA 11.0 12.20~13.50 1 18.2 28.0 1 SA12A SA12CA 12.0 13.30~14.70 1 19.9 25.6 1 SA13A SA13CA 13.0 14.40~15.90 1 21.5 23.7 1 SA14A SA14CA 14.0 15.60~17.20 1 23.2 22.0 1 SA15A SA15CA 15.0 16.70~18.50 1 24.4 20.9 1 SA16A SA16CA 16.0 17.80~19.70 1 26.0 19.6 1 SA17A SA17CA 17.0 18.90~20.90 1 27.6 18.5 1 SA18A SA18CA 18.0 20.00~22.10 1 29.2 17.5 1 SA20A SA20CA 20.0 22.20~24.50 1 32.4 15.7 1 SA22A SA22CA 22.0 24.40~26.90 1 35.5 14.4 1 SA24A SA24CA 24.0 26.70~29.50 1 38.9 13.1 1 SA26A SA26CA 26.0 28.90~31.90 1 42.1 12.1 1 SA28A SA28CA 28.0 31.10~34.40 1 45.4 11.2 1 SA30A SA30CA 30.0 33.30~36.80 1 48.4 10.5 1 Revision:TVS-SA SERIES-001(A2) 2/6 http://brightking.yageo.com SA SERIES Part Number Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Unidirectional Bidirectional VRWM(V) VBR(V) IT(mA) VC(V) IPP(A) IR(μA) SA33A SA33CA 33.0 36.70~40.60 1 53.3 9.6 1 SA36A SA36CA 36.0 40.00~44.20 1 58.1 8.8 1 SA40A SA40CA 40.0 44.40~49.10 1 64.5 7.9 1 SA43A SA43CA 43.0 47.80~52.80 1 69.4 7.3 1 SA45A SA45CA 45.0 50.00~55.30 1 72.7 7.0 1 SA48A SA48CA 48.0 53.30~58.90 1 77.4 6.6 1 SA51A SA51CA 51.0 56.70~62.70 1 82.4 6.2 1 SA54A SA54CA 54.0 60.00~66.30 1 87.1 5.9 1 SA58A SA58CA 58.0 64.40~71.20 1 93.6 5.4 1 SA60A SA60CA 60.0 66.70~73.70 1 96.8 5.3 1 SA64A SA64CA 64.0 71.10~78.60 1 103.0 5.0 1 SA70A SA70CA 70.0 77.80~86.00 1 113.0 4.5 1 SA75A SA75CA 75.0 83.30~92.10 1 121.0 4.2 1 SA78A SA78CA 78.0 86.70~95.80 1 126.0 4.0 1 SA85A SA85CA 85.0 94.40~104.00 1 137.0 3.7 1 SA90A SA90CA 90.0 100.00~111.00 1 146.0 3.5 1 SA100A SA100CA 100.0 111.00~123.00 1 162.0 3.1 1 SA110A SA110CA 110.0 122.00~135.00 1 177.0 2.9 1 SA120A SA120CA 120.0 133.00~147.00 1 193.0 2.6 1 SA130A SA130CA 130.0 144.00~159.00 1 209.0 2.4 1 SA150A SA150CA 150.0 167.00~185.00 1 243.0 2.1 1 SA160A SA160CA 160.0 178.00~197.00 1 259.0 2.0 1 SA170A SA170CA 170.0 189.00~209.00 1 275.0 1.9 1 SA180A SA180CA 180.0 201.00~222.00 1 292.0 1.7 1 SA190A SA190CA 190.0 211.00~233.00 1 308.0 1.6 1 SA200A SA200CA 200.0 224.00~247.00 1 324.0 1.5 1 SA210A SA210CA 210.0 237.00~263.00 1 340.0 1.5 1 SA220A SA220CA 220.0 246.00~272.00 1 356.0 1.4 1 Revision:TVS-SA SERIES-001(A2) 3/6 http://brightking.yageo.com SA SERIES Ratings and Characteristic Curves (T A=25℃ unless otherwise noted) PPPM - Peak Pulse Power (kW) 100 Figure 2. Pulse Derating Curve Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % Figure 1. Peak Pulse Power Rating Curve Non-repetitive pulse waveform shown in fig.3 TA=25℃ 10 P 1 Exponentia l Td P Td P Td 0.1 0.1 Half SINE Square 1 10 100 1000 100 75 50 25 0 0 10000 Figure 3. Pulse Waveform 75 100 125 150 175 200 Figure 4. Typical Junction Capacitance 10000 150 TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs Bi-directional V=0V 1000 Uni-directional V=0V Peak Value IPPM 100 Cj (pF) IPPM - Peak Pulse Current, %IRSM 50 TA-Ambient Temperature (℃) td-Pulse Width (µs) Half Value IPPM (IPPM/2) Uni-directional @VR 100 50 10/1000µs Waveform as defined by R.E.A 10 Bi-directional @VR TJ=25℃ f=1.0MHz Vsig=50mVp-p td 0 0 1.0 2.0 3.0 1 4.0 1 t-Time (ms) IFSM - Peak Forward Surve Current (A) 3 2.5 2 1.5 L= 0.375″(9.5mm) Lead Lengths 0.5 0 0 25 50 75 100 125 150 175 200 1000 80 70 60 50 40 30 20 10 0 1 10 100 Number of Cycles at 60Hz TL-Lead Temperature (℃) Revision:TVS-SA SERIES-001(A2) 100 Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only 3.5 1 10 VBR-Reverse Breakdown Voltage (V) Figure 5. Steady State Power Dissipation Derating Curve Steady State Power Dissipation (W) 25 4/6 http://brightking.yageo.com SA SERIES Recommended Soldering Conditions Wave Soldering 300 Preheating Maximum Wave 265℃ Soldering Cooling Temperature (℃) 250 200 150 100 50 0 0 0.5 1 1.5 2 2.5 3 3.5 4 Time (minutes) Recommended Conditions Item Conditions Peak Temperature 265℃ Dipping Time 10 seconds Soldering 1 time Marking Code Cathode Band YXXX YXXX Logo SA5.0A Logo Intermal Control Code SA5.0CA Intermal Control Code Marking Code Marking Code Part Number Code SA XXX C A / XXXX Package Code B: Box package TR13: Reel package 5% VBR Voltage Tolerance Bidirectional VRWM Voltage Series Code Revision:TVS-SA SERIES-001(A2) 5/6 http://brightking.yageo.com SA SERIES Ordering Code for Different Package Box package: Add suffix “/B” at the end of the part number, such as SAXXXCA/B Reel package: Add suffix “/TR13” at the end of the part number, such as SAXXXCA/TR13 Packaging Tape Z ±5° A E Symbol Dimension (mm) A 5.0±0.5 B 53.0±1.0 Z 1.2Max. T 6.0±0.4 E 0.8Max. L1-L2 1.0Max. L 250.0±5.0 W 75.0±5.0 H 114.0±5.0 L1 B L2 T E Box H L Quantity: 2000PCS W Reel D 330.0±3.0 D0 16.4±2.0 D1 86.0±2.0 W1 76.0±3.0 D0 D1 D Revision:TVS-SA SERIES-001(A2) W1 Quantity: 4000PCS 6/6 http://brightking.yageo.com
SA16CA 价格&库存
很抱歉,暂时无法提供与“SA16CA”相匹配的价格&库存,您可以联系我们找货
SA16CA
  • 5+0.58650
  • 20+0.53475
  • 100+0.48300
  • 500+0.43125
  • 1000+0.40710
  • 2000+0.38985
SA16CA
  • 20+1.76400
  • 100+1.05220
  • 500+0.73660
  • 2000+0.52610
  • 4000+0.49980
  • 20000+0.46300
