SDT23C712L02
Electrostatic Discharged Protection Devices (ESD) Data Sheet
Description
Brightking’s SDT23C712L02 component is designed for asymmetrical
(12V to -7V) protection in muti-point data transmission standard RS-485
applications. It may be used to protect devices from transient voltages
resulting from electrostatic discharge (ESD), electrical fast transients
(EFT), and lightning. It features 400W (tp=8/20μs) of power handing
capability to accommodate the higher transient voltage levels which
may be expected in extended common mode applications.
Features
IEC61000-4-2 ESD 30KV Air, 30KV contact compliance
SOT-23 surface mount package
Protects two +12V to -7V lines
Peak power dissipation of 400W under 8/20μs waveform
Low leakage current
Low clamping voltage
Solid-state silicon avalanche technology
Lead Free/RoHS compliant
Solder reflow temperature: Pure Tin-Sn, 260~270℃
Flammability rating UL 94V-0
Meets MSL level 1, per J-STD-020
Marking: B 712
3
1
2
Pin Configuration
Applications
±5V
● Protection of RS-485 transceiver with extended
Common-mode range
● Security Systems
● Automatic Teller Machines
● HFC Systems
● Networks
X
100O
SET23A05L02
D
INPUT
R
OUTPUT
SDT23C712L02
Revision:ESD-SDT23C712L02-001(A2)
1/5
http://brightking.yageo.com
SDT23C712L02
Maximum Ratings
Rating
Peak pulse power (tp=8/20μs waveform)
Symbol
Value
Unit
PPP
400
W
ESD voltage (Contact discharge)
±30
VESD
kV
ESD voltage (Air discharge)
±30
Storage & operating temperature range
TSTG ,TJ
-55~+150
Electrical Characteristics (TJ=25℃)
Pin 1 to Pin3 and Pin2 to Pin3
Parameter
Reverse stand-off voltage
Reverse breakdown voltage
Symbol
Condition
Min.
Typ.
VRWM
Max.
Unit
12
V
VBR
IBR=1mA
13.3
V
Reverse leakage current
IR
VR=12V
1
μA
Clamping voltage (tp=8/20μs)
VC
IPP=5A
V
Peak Pulse Current(tp=8/20μs)
IPP
15
A
Off state junction capacitance
CJ
0Vdc,f=1MHz
Between I/O
pins and GND
75
pF
Symbol
Condition
Max.
Unit
7
V
Pin 3 to Pin1 and Pin3 to Pin2
Parameter
Min.
VRWM
Typ.
VBR
IBR=1mA
IR
VR=7V
μA
VC
IPP=5A
10
V
IPP
15
A
CJ
75
pF
0Vdc,f=1MHz
Between I/O
pins and GND
2/5
7.5
V
SDT23C712L02
Typical Characteristics Curves
Figure 1. Power Derating Curve
Figure 2. Pulse Waveforms
110
100
100
% of Peak Power Current
Peak Power Dissipation (%)
90
80
70
60
50
40
30
tr
Peak value Ipp
Waveform
Parameters:
tr=8µs
td=20µs
90
80
70
60
50
40
30
td=t|IPP/2
50
75
100
125
150
10
15
30
t-Time (μs)
TA-Ambient Temperature (℃)
Figure 3. Non-Repetitive Peak Pulse vs. Pulse Time
Figure 4. Clamping Voltage vs. Peak Pulse Current
10000
Clamping Voltage (V)
PPP - Peak Pulse Power (W)
18
1000
100
16
pin1/pin2 to pin3
14
12
pin3 to pin1/pin2
10
8
6
Waveform
Parameters:
tr=8µs
tb=20µs
4
2
10
0.1
10
100
1000
tP-Pulse Duration (µs)
10000
2
3
4
5
IPP-Peak Pulse Current (A)
3/5
SDT23C712L02
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
20-40 seconds
8 minutes max.
4/5
SDT23C712L02
Dimensions (SOT-23)
Dimension
E
F
A
G
2
Symbol
1
B
C
H I
3
J
D
0.8
(3X)
0.9
(3X)
1.9
0.95
1.8
Recommended Soldering Pad Layout
Millimeters
Inches
Min.
Max.
Min.
Max.
A
0.08
0.18
0.003
0.007
B
0.15
0.006
C
0.13
0.005
D
0.89
1.09
0.035
0.043
E
2.80
3.05
0.110
0.120
F
1.90
0.075
G
0.95
0.037
H
1.19
1.40
0.047
0.055
I
2.10
2.49
0.083
0.098
J
0.35
0.50
0.014
0.020
Packaging
Tape
P0
P1
P2
K
F
B
W
E
øD0
B0
A0
øD1
t
A
Reel
D2
D
W1
Symbol
Dimension (mm)
W
8.00±0.30
P0
4.00±0.10
P1
4.00±0.10
P2
2.00±0.10
D0
Φ1.55±0.10
D1
Φ1.00±0.05
E
1.75±0.10
F
3.50±0.10
A
3.10±0.10
A0
2.10±0.10
B
2.75±0.10
B0
0.65±0.10
K
1.10±0.10
t
0.20±0.05
D
Φ178.0±2.0
D2
Φ13.0
W1
9.5
Quantity: 3000PCS
5/5
很抱歉,暂时无法提供与“SDT23C712L02”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.67576
- 20+0.61635
- 100+0.55694
- 500+0.49753
- 1000+0.46980
- 2000+0.45000
