SET23AXXL02 SERIES
Electrostatic Discharged Protection Devices (ESD) Data Sheet
Description
Brightking’s SET23AXXL02 siries are designed to protect components which
are connected to data and transmission lines from voltage surges caused
by electrostatic discharge (ESD), electrical fast transients (EFT) and lightning.
TVS diodes are characterized by their high surge capability, low operating
and clamping voltages, and fast response time. This makes them ideal for
use as board level protection of sensitive semiconductor components.
The low profile SOT-23 package allows flexibility in the design of crowded
circuit boards.
Features
● IEC61000-4-2 ESD 30KV Air, 30KV contact compliance
ESD 15KV Air, 8KV contact compliance for SET23A36L02
● SOT-23 surface mount package
● Protects one bidirectional line or two unidirectional lines
● Working voltage: 3.3V, 5V, 12V, 15V, 24V and 36V
● Low leakage current
● Low operating and clamping voltages
● Solid-state silicon avalanche technology
● Lead Free/RoHS compliant
● Solder reflow temperature: Pure Tin-Sn, 260~270℃
● Flammability rating UL 94V-0
● Meets MSL level 1, per J-STD-020
3
1
2
Pin Configuration
LINE 1
LINE 1
X
SET23AXXL02
Applications
LINE 2
LINE 2
Bidirectional Protect Line
Cellular handsets and accessories
Personal digital assistants (PDA’s)
Portable instrumentation
Set Top Box (STB)
Servers, notebook, and desktop PC
Wireless bus protection
RS-232, RS-422, RS-423 protection
LINE 1
LINE 1
LINE 2
LINE 2
SET23AXXL02
Unidirectional Protect Lines
Maximum Ratings
Rating
Symbol
ESD voltage (Contact discharge)
Value
Unit
±8
VESD
ESD voltage (Air discharge)
Storage & operating temperature range
Revision:ESD-SET23AXXL02 SERIES-001(A2)
kV
±15
TSTG ,TJ
1/6
-55~+150
http://brightking.yageo.com
SET23AXXL02 SERIES
Electrical Characteristics (TJ=25℃)
SET23A03L02 (Marking: B 03C)
Parameter
Reverse stand-off voltage
Reverse breakdown voltage
Symbol
Condition
Min.
Typ.
VRWM
Max.
Unit
3.3
V
VBR
IBR=1mA
4
V
Reverse leakage current
IR
VR=3.3V
each I/O pin
125
μA
Clamping voltage (tp=8/20μs)
VC
IPP=1A
7
V
VC
IPP=15A
15
V
Peak Pulse Current(tp=8/20μs)
IPP
15
A
Off state junction capacitance
CJ
0Vdc,f=1MHz
Between I/O
pins and GND
Symbol
Condition
300
pF
SET23A05L02 (Marking: B 05C)
Parameter
Min.
Typ.
VRWM
Max.
Unit
5
V
VBR
IBR=1mA
6
V
IR
VR=5V
each I/O pin
5
μA
VC
IPP=1A
9.8
V
VC
IPP=15A
V
IPP
15
A
CJ
0Vdc,f=1MHz
Between I/O
pins and GND
Symbol
Condition
220
pF
SET23A12L02-E18 (Marking: B 12C)
Parameter
Min.
Typ.
VRWM
Max.
Unit
12
V
VBR
IBR=1mA
IR
VR=12V
Each I/O pin
1
μA
VC
IPP=1A
19
V
VC
IPP=10A
27
V
IPP
18
A
CJ
0Vdc,f=1MHz
Between I/O
pins and GND
2/6
13.3
V
100
pF
SET23AXXL02 SERIES
SET23A15L02 (Marking: B 15C)
Parameter
Symbol
Condition
Min.
Typ.
VRWM
Max.
Unit
15
V
VBR
IBR=1mA
16.7
V
IR
VR=15V
each I/O pin
1
μA
VC
IPP=1A
24
V
VC
IPP=10A
30
V
IPP
10
A
CJ
0Vdc,f=1MHz
Between I/O
pins and GND
Symbol
Condition
90
pF
SET23A24L02 (Marking: B 24C)
Parameter
Min.
Typ.
VRWM
Max.
Unit
24
V
VBR
IBR=1mA
26.7
V
IR
VR=24V
each I/O pin
1
μA
VC
IPP=1A
43
V
VC
IPP=5A
49
V
IPP
6
A
CJ
0Vdc,f=1MHz
Between I/O
pins and GND
Symbol
Condition
80
pF
SET23A36L02 (Marking: B 36C)
Parameter
Min.
Typ.
VRWM
Max.
Unit
36
V
VBR
IBR=1mA
IR
VR=36V
each I/O pin
1
μA
VC
IPP=1A
51
V
VC
IPP=5A
76.8
V
IPP
5
A
CJ
0Vdc,f=1MHz
Between I/O
pins and GND
3/6
40
V
70
pF
SET23AXXL02 SERIES
Typical Characteristics Curves
Figure 1. Power Derating Curve
Figure 2. Pulse Waveforms
110
100
90
% of Peak Power Current
Peak Power Dissipation (%)
100
80
70
60
50
40
30
tr
Peak value Ipp
Waveform
Parameters:
tr=8µs
td=20µs
90
80
70
60
50
40
30
td=t|IPP/2
50
75
100
125
150
10
15
30
t-Time (μs)
TA-Ambient Temperature (℃)
Figure 3. Forward Voltage vs. Forward Current
Figure 4. ESD Clamping(8kV Contact IEC61000-4-2)
3.5
Forward Voltage (V)
3.0
2.5
2.0
1.5
Waveform
Parameters:
tr=8µs
tb=20µs
1.0
0.5
2
4
3
5
Peak Pulse Current (A)
6
7
4/6
SET23AXXL02 SERIES
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
20-40 seconds
8 minutes max.
5/6
SET23AXXL02 SERIES
Dimensions (SOT-23)
Dimension
E
F
A
G
2
Symbol
1
B
C
H I
3
J
D
0.8
(3X)
0.9
(3X)
1.9
0.95
1.8
Millimeters
Inches
Min.
Max.
Min.
Max.
A
0.08
0.18
0.003
0.007
B
0.15
0.006
C
0.13
0.005
D
0.89
1.09
0.035
0.043
E
2.80
3.05
0.110
0.120
F
1.90
0.075
G
0.95
0.037
H
1.19
1.40
0.047
0.055
I
2.10
2.49
0.083
0.098
J
0.35
0.50
0.014
0.020
Recommended Soldering Pad Layout
Packaging
Tape
P0
P1
P2
K
F
B
W
E
øD0
B0
A0
øD1
t
A
Reel
D2
D
W1
Symbol
Dimension (mm)
W
8.00±0.30
P0
4.00±0.10
P1
4.00±0.10
P2
2.00±0.10
D0
Φ1.55±0.10
D1
Φ1.00±0.05
E
1.75±0.10
F
3.50±0.10
A
3.10±0.10
A0
2.10±0.10
B
2.75±0.10
B0
0.65±0.10
K
1.10±0.10
t
0.20±0.05
D
Φ178.0±2.0
D2
Φ13.0
W1
9.5
Quantity: 3000PCS
6/6
很抱歉,暂时无法提供与“SET23A03L02”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.49170
- 200+0.31790
- 1500+0.27610
- 3000+0.24530
- 国内价格
- 20+1.17600
- 100+0.70150
- 800+0.49100
- 3000+0.35070
- 6000+0.33330
- 30000+0.30870
- 国内价格
- 10+0.49518
- 100+0.39312
- 300+0.34204
- 3000+0.30370
- 6000+0.27303
