SFD52AXXL01 SERIES
Electrostatic Discharged Protection Devices (ESD) Data Sheet
Description
The SFD52AxxL01 of Transient Voltage Suppressors (TVS) are
designed to replace multilayer varistors (MLVs) in portable
applications such as cell phones, notebook computer, and PDAs.
They offer superior electrical characteristics such as lower clamping
voltage and no device degradation when compared to MLVs. They
are designed to protect sensitive semiconductor components from
damage or upset due to electrostatic discharge (ESD), lightning,
electrical fast transients (EFT), and cable discharge events (CDE).
Contact:±25kV
Air:±25kV
Features
IEC61000-4-2 ESD 30KV Air, 30KV contact compliance
SOD-523 surface mount package
Protects one I/O line
Working voltage: 5V,7V
Low leakage current
Low operating and clamping voltages
Solid-state silicon avalanche technology
Lead Free/RoHS compliant
Solder reflow temperature: Pure Tin-Sn, 260~270℃
Flammability rating UL 94V-0
Meets MSL level 1, per J-STD-020
1
2
Pin Configuration
Applications
Cellular handsets & Accessories
Cordless phones
Personal digital assistants (PDAs)
Notebooks & Handhelds
Portable instrumentation
Digital cameras
Peripherals
MP3 players
Maximum Ratings
Rating
Symbol
ESD voltage (Contact discharge)
Value
±30
VESD
ESD voltage (Air discharge)
kV
±30
Storage & operating temperature range
Revision:ESD-SFD52AXXL01 SERIES-001(A2)
Unit
TSTG ,TJ
1/5
-55~+150
http://brightking.yageo.com
SFD52AXXL01 SERIES
Electrical Characteristics (TJ=25℃)
SFD52A05L01 (Marking: BG)
Parameter
Reverse stand-off voltage
Reverse breakdown voltage
Symbol
Condition
Min.
Typ.
VRWM
Max.
Unit
5.0
V
VBR
IBR=1mA
6.0
V
Reverse leakage current
IR
VR=5V
1.0
μA
Clamping voltage (tp=8/20μs)
VC
IPP=1A
9.8
V
VC
IPP=18A
25.0
V
Peak pulse current (tp=8/20μs)
IPP
18
A
Off state junction capacitance
CJ
0Vdc,f=1MHz
Symbol
Condition
200
pF
SFD52A07L01 (Marking: BH)
Parameter
Min.
Typ.
VRWM
Max.
Unit
7.0
V
VBR
IBR=1mA
IR
VR=7V
1.0
μA
VC
IPP=1A
12.0
V
VC
IPP=16A
25.0
V
IPP
16
A
CJ
0Vdc,f=1MHz
2/5
7.5
V
190
pF
SFD52AXXL01 SERIES
Typical Characteristics Curves
Figure 1. Power Derating Curve
Figure 2. Pulse Waveforms
110
100
90
% of Peak Power Current
Peak Power Dissipation (%)
100
80
70
60
50
40
30
tr
Peak value Ipp
Waveform
Parameters:
tr=8µs
td=20µs
90
80
70
60
50
40
30
td=t|IPP/2
50
100
75
125
150
TA-Ambient Temperature (℃)
10
15
30
t-Time (μs)
Figure 3. Clamping Voltage vs. Peak Pulse Current
Clamping Voltage (V)
25
SFD52A07L01
SFD52A05L01
15
10
Waveform
Parameters:
tr=8µs
tb=20µs
5
4
6
8
10
12
14
16
18
IPP-Peak Pulse Current (A)
3/5
SFD52AXXL01 SERIES
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
20-40 seconds
8 minutes max.
4/5
SFD52AXXL01 SERIES
Dimensions (SOD-523)
Dimension (mm)
Symbol
Millimeters
Min.
Max.
Min.
Max.
A
0.50
0.70
0.020
0.028
B
0.07
0.20
0.003
0.008
C
0.70
0.90
0.028
0.035
D
0.25
0.35
0.010
0.014
E
1.10
1.30
0.043
0.051
F
1.50
1.70
0.059
0.067
G
0.15
0.25
0.006
0.010
D C
0.55
(2X)
0.50
(2X)
E
F
0.80
1.90
A
B
Inches
Recommended Soldering Pad Layout
G
Packaging
Tape
P0
P1
P2
K
F
B0
B
W
E
øD0
A0
øD1
t
A
Symbol
Dimension (mm)
W
8.00±0.30
P0
4.00±0.10
P1
2.00±0.10
P2
2.00±0.10
D0
Φ1.55±0.10
D1
Φ0.50±0.05
E
1.75±0.10
F
3.50±0.10
A
1.00±0.10
A0
0.50±0.10
B
1.80±0.10
B0
1.30±0.10
K
0.65±0.10
t
0.20±0.05
D
Φ178.0±2.0
D2
Φ13.0
W1
9.5
Reel
D2
D
W1
Quantity: 3000PCS
5/5
很抱歉,暂时无法提供与“SFD52A05L01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.32017
- 100+0.26509
- 300+0.23755
- 国内价格
- 10+0.35284
- 100+0.29214
- 300+0.26180
