SMAJ-AT SERIES
Transient Voltage Suppressors (TVS) Data Sheet
Features
For surface mounted applications in order to optimize board space
Low profile package
Glass passivated junction
Low inductance
Excellent clamping capability
400W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.01%
Fast response time
Typical IR less than 1μA above 10V
High Temperature soldering: 260℃/10 seconds at terminals
Plastic package has underwriters laboratory flammability 94V-0
Meets MSL level 1, per J-STD-020
Safety certification: UL: E244458
AEC-Q101 qualified
IEC61000-4-2 ESD 30KV Air, 30KV contact compliance
Mechanical Data
Case: JEDEC DO-214AC. Molded plastic over glass passivated junction
Terminal: Tin plated, solderable per MIL-STD-750, Method 2026
Polarity: Color band denotes cathode except bi-directional models
Standard Packaging: 12mm tape (EIA STD RS-481)
Weight: 0.07g
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
Symbol
Value
Units
PPPM
Minimum 400
Watts
IPPM
See Table
Amps
PM(AV)
3.3
Watts
IFSM
40
Amps
TJ,TSTG
-55 to +150
Typical thermal resistance junction to lead
RθJL
30
℃/W
Typical thermal resistance junction to ambient
RθJA
120
℃/W
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
Steady state power dissipation at TA=50℃ (Fig.5)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note3, Fig.6)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. Mounted on 5.0mm×5.0mm (0.03mm thick) copper pads to each terminal.
3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
Revision:TVS-SMAJ-AT SERIES-001(A2)
1/7
http://brightking.yageo.com
SMAJ-AT SERIES
Dimensions (SMA/DO-214AC)
Millimeters
Cathode Band
D1 D
L
H1 H
d
Inches
Symbol
T1
T
Min.
Max.
Min.
Max.
L
3.99
4.50
0.157
0.177
D
2.54
2.79
0.100
0.110
D1
1.25
1.65
0.049
0.065
T
4.93
5.28
0.194
0.208
T1
0.76
1.52
0.030
0.060
d
0.203
0.008
H
2.00
2.50
0.079
0.098
H1
1.98
2.29
0.078
0.090
Electrical Characteristics (TA=25℃)
Part Number
Device
Marking
Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMAJ5.0A-AT
SMAJ5.0CA-AT
AE
WE
5.0
6.40~7.00
10
9.2
43.5
800
SMAJ6.0A-AT
SMAJ6.0CA-AT
AG
WG
6.0
6.67~7.37
10
10.3
38.8
800
SMAJ6.5A-AT
SMAJ6.5CA-AT
AK
WK
6.5
7.22~7.98
10
11.2
35.7
500
SMAJ7.0A-AT
SMAJ7.0CA-AT
AM
WM
7.0
7.78~8.60
10
12.0
33.3
200
SMAJ7.5A-AT
SMAJ7.5CA-AT
AP
WP
7.5
8.33~9.21
1
12.9
31.0
100
SMAJ8.0A-AT
SMAJ8.0CA-AT
AR
WR
8.0
8.89~9.83
1
13.6
29.4
50
SMAJ8.5A-AT
SMAJ8.5CA-AT
AT
WT
8.5
9.44~10.40
1
14.4
27.8
SMAJ9.0A-AT
SMAJ9.0CA-AT
AV
WV
9.0
10.00~11.10
1
15.4
26.0
10
SMAJ10A-AT
SMAJ10CA-AT
AX
WX
10.0
11.10~12.30
1
17.0
23.5
5
SMAJ11A-AT
SMAJ11CA-AT
AZ
WZ
11.0
12.20~13.50
1
18.2
22.0
1
SMAJ12A-AT
SMAJ12CA-AT
BE
XE
12.0
13.30~14.70
1
19.9
20.1
1
SMAJ13A-AT
SMAJ13CA-AT
BG
XG
13.0
14.40~15.90
1
21.5
18.6
1
SMAJ14A-AT
SMAJ14CA-AT
BK
XK
14.0
15.60~17.20
1
23.2
17.2
1
SMAJ15A-AT
SMAJ15CA-AT
BM
XM
15.0
16.70~18.50
1
24.4
16.4
1
SMAJ16A-AT
SMAJ16CA-AT
BP
XP
16.0
17.80~19.70
1
26.0
15.4
1
SMAJ17A-AT
SMAJ17CA-AT
BR
XR
17.0
18.90~20.90
1
27.6
14.5
1
SMAJ18A-AT
SMAJ18CA-AT
BT
XT
18.0
20.00~22.10
1
29.2
13.7
1
SMAJ20A-AT
SMAJ20CA-AT
BV
XV
20.0
22.20~24.50
1
32.4
12.3
1
SMAJ22A-AT
SMAJ22CA-AT
BX
XX
22.0
24.40~26.90
1
35.5
11.3
1
SMAJ24A-AT
SMAJ24CA-AT
BZ
XZ
24.0
26.70~29.50
1
38.9
10.3
1
SMAJ26A-AT
SMAJ26CA-AT
CE
YE
26.0
28.90~31.90
1
42.1
9.5
1
SMAJ28A-AT
SMAJ28CA-AT
CG
YG
28.0
31.10~34.40
1
45.4
8.8
1
2/7
SMAJ-AT SERIES
Part Number
Device
Marking
Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMAJ30A-AT
SMAJ30CA-AT
CK
YK
30.0
33.30~36.80
1
48.4
8.3
1
SMAJ33A-AT
SMAJ33CA-AT
CM
YM
33.0
36.70~40.60
1
53.3
7.5
1
SMAJ36A-AT
SMAJ36CA-AT
CP
YP
36.0
40.00~44.20
1
58.1
6.9
1
SMAJ40A-AT
SMAJ40CA-AT
CR
YR
40.0
44.40~49.10
1
64.5
6.2
1
SMAJ43A-AT
SMAJ43CA-AT
CT
YT
43.0
47.80~52.80
1
69.4
5.8
1
SMAJ45A-AT
SMAJ45CA-AT
CV
YV
45.0
50.00~55.30
1
72.7
5.5
1
SMAJ48A-AT
SMAJ48CA-AT
CX
YX
48.0
53.30~58.90
1
77.4
5.2
1
SMAJ51A-AT
SMAJ51CA-AT
CZ
YZ
51.0
56.70~62.70
1
82.4
4.9
1
SMAJ54A-AT
SMAJ54CA-AT
RE
ZE
54.0
60.00~66.30
1
87.1
4.6
1
SMAJ58A-AT
SMAJ58CA-AT
RG
ZG
58.0
64.40~71.20
1
93.6
4.3
1
SMAJ60A-AT
SMAJ60CA-AT
RK
ZK
60.0
66.70~73.70
1
96.8
4.1
1
SMAJ64A-AT
SMAJ64CA-AT
RM
ZM
64.0
71.10~78.60
1
103.0
3.9
1
SMAJ70A-AT
SMAJ70CA-AT
RP
ZP
70.0
77.80~86.00
1
113.0
3.5
1
SMAJ75A-AT
SMAJ75CA-AT
RR
ZR
75.0
83.30~92.10
1
121.0
3.3
1
SMAJ78A-AT
SMAJ78CA-AT
RT
ZT
78.0
86.70~95.80
1
126.0
3.2
1
SMAJ85A-AT
SMAJ85CA-AT
RV
ZV
85.0
94.40~104.00
1
137.0
2.9
1
SMAJ90A-AT
SMAJ90CA-AT
RX
ZX
90.0
100.00~111.00
1
146.0
2.7
1
SMAJ100A-AT
SMAJ100CA-AT
RZ
ZZ
100.0
111.00~123.00
1
162.0
2.5
1
SMAJ110A-AT
SMAJ110CA-AT
SE
VE
110.0
122.00~135.00
1
177.0
2.3
1
SMAJ120A-AT
SMAJ120CA-AT
SG
VG
120.0
133.00~147.00
1
193.0
2.1
1
SMAJ130A-AT
SMAJ130CA-AT
SK
VK
130.0
144.00~159.00
1
209.0
1.9
1
SMAJ150A-AT
SMAJ150CA-AT
SM
VM
150.0
167.00~185.00
1
243.0
1.6
1
SMAJ160A-AT
SMAJ160CA-AT
SP
VP
160.0
178.00~197.00
1
259.0
1.5
1
SMAJ170A-AT
SMAJ170CA-AT
SR
VR
170.0
189.00~209.00
1
275.0
1.5
1
SMAJ180A-AT
SMAJ180CA-AT
ST
VT
180.0
201.00~222.00
1
292.0
1.4
1
SMAJ190A-AT
SMAJ190CA-AT
SU
YU
190.0
211.00~233.00
1
308.0
1.3
1
SMAJ200A-AT
SMAJ200CA-AT
SV
VV
200.0
224.00~247.00
1
324.0
1.2
1
SMAJ210A-AT
SMAJ210CA-AT
SW
YW
210.0
237.00~263.00
1
340.0
1.2
1
SMAJ220A-AT
SMAJ220CA-AT
GE
VX
220.0
246.00~272.00
1
356.0
1.1
1
SMAJ250A-AT
SMAJ250CA-AT
SZ
VZ
250.0
279.00~309.00
1
405.0
1.0
1
SMAJ300A-AT
SMAJ300CA-AT
TE
UE
300.0
335.00~371.00
1
486.0
0.8
1
SMAJ350A-AT
SMAJ350CA-AT
TG
UG
350.0
391.00~432.00
1
567.0
0.7
1
SMAJ400A-AT
SMAJ400CA-AT
TK
UK
400.0
447.00~494.00
1
648.0
0.6
1
SMAJ440A-AT
SMAJ440CA-AT
TM
UM
440.0
492.00~543.00
1
713.0
0.6
1
3/7
SMAJ-AT SERIES
Ratings and Characteristic Curves (T A=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM - Peak Pulse Power (kW)
10
1
0.2×0.2″(5.0×5.0mm)
Copper Pad Area
0.1
1
10
100
100
80
60
40
td-Pulse Width (µs)
75
100
125
150
175
Figure 4. Typical Junction Capacitance
10000
150
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
tr=10µs
Bi-directional V=0V
1000
Uni-directional V=0V
Peak Value IPPM
100
Cj (pF)
IPPM - Peak Pulse Current, %IRSM
50
TA-Ambient Temperature (℃)
Figure 3. Pulse Waveform
Half Value IPPM (IPPM/2)
Uni-directional @VR
100
50
10/1000µs Waveform
as defined by R.E.A
10
td
Bi-directional @VR
TJ=25℃
f=1.0MHz
Vsig=50mVp-p
1
1.0
2.0
3.0
1
4.0
t-Time (ms)
IFSM - Peak Forward Surve Current (A)
3.0
2.4
1.8
1.2
0.6
50
75
100
125
150
175
1000
45
40
35
30
25
10
5
100
Figure 6. Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
3.6
VBR-Reverse Breakdown Voltage (V)
Figure 5. Steady State Power Dissipation Derating
Curve
PM(AV), Steady State Power Dissipation (W)
25
10
100
Number of Cycles at 60Hz
4/7
SMAJ-AT SERIES
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (tS)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃
Temperature (tP)
Ramp-down Rate
of
actual
Peak
6℃/second max.
Time 25℃ to Peak Temperature
20-40 seconds
8 minutes max.
5/7
SMAJ-AT SERIES
Marking Code
Cathode Band
YXXX
YXXX
AE
Logo
WE
Intermal Control Code
Logo
Marking Code
Marking Code
Part Number Code
SMAJ XXX C A
AT / XXXX
Package code
TR7: 7 inch reel package
TR13: 13 inch reel package
Internal Control Code
5% VBR Voltage Tolerance
Bidirectional
VRWM Voltage
Series Code
Ordering Code for Different Package
7 inch reel package: Add suffix “ /TR7” at the end of the part number, such as SMAJXXXCA-AT/TR7
13 inch reel package: Add suffix “ /TR13” at the end of the part number, such as SMAJXXXCA-AT/TR13
6/7
SMAJ-AT SERIES
Packaging
Tape
P0
P1
P2
D0
B
T
E
F
W
B0
D1
A
A
K0
B
SECTION B-B
Symbol
Dimension (mm)
W
12.00±0.20
P0
4.00±0.10
P1
4.00±0.10
P2
2.00±0.10
D0
Φ1.5±0.10
D1
Φ1.5±0.10
E
1.75±0.10
F
5.50±0.05
A0
2.79±0.10
B0
5.33±0.10
K0
2.55±0.15
T
0.25±0.05
D2
Φ178.0±2.0
D3
Φ50.0Min.
D4
Φ13.0±0.5
W1
16.0±2.0
A0
SECTION A-A
7” Reel
D4
D3
D2
W1
Quantity: 1000PCS
13” Reel
D5
Φ330.0±2.0
D6
Φ13.5±0.5
H
2.5±1.0
W2
16.0±2.0
Quantity: 5000PCS
7/7
很抱歉,暂时无法提供与“SMAJ70CA-AT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.36134
- 100+0.28191
- 200+0.27768
- 400+0.27351
- 1000+0.26530
- 5000+0.25336
- 国内价格
- 20+0.98810
- 100+0.58950
- 500+0.41260
- 5000+0.29470
- 10000+0.28000
- 50000+0.25930
