20Φ SERIES
Metal Oxide Varistors (MOV) Data Sheet
Features
■ Wide operating voltage (V1mA) range from 18V to 1800V
■ Fast responding to transient over-voltage
■ Large absorbing transient energy capability
■ Low clamping ratio and no follow-on current
■ Meets MSL level 1, per J-STD-020
■ Operating Temperature:-40℃ ~ +105℃
■ Storage Temperature:-40℃ ~ +125℃
■ Safety certification:UL、CSA、VDE
Applications
■ Transistor, diode, IC, thyristor or triac semiconductor protection
■ Surge protection in consumer electronics
■ Surge protection in industrial electronics
■ Surge protection in electronic home appliances, gas and petroleum appliances
■ Relay and electromagnetic valve surge absorption
Part Number Code
4
7
1
K
D
2
J
O
P7.5
TR
Packing
No suffix: Bulk
TB: Tape & Box
TR: Tape & Reel
Tolerance
K: ±10%
Type
D: Disk
Varistor Voltage
180: 18V
101: 100V
102: 1000V
Revision: MOV-20Φ SERIES-001(A6)
Surge Series
No suffix: Standard type
J: High Surge type
Pitch
No suffix:10mm
P7.5:7.5mm
Lead Shape
No suffix: Straight leads
O: Outside crimped leads
F: Y Kinked leads
Element Diameter
http://brightking.yageo.com
20Φ SERIES
Dimensions
D
D
T
D
H1
H1
H
T
K≤3.0
L1
L1
F
L
d1
d
K≤3.0
d
e
d
F
O Type
F Type
Notes: Varistor voltage≥1200V, structure diagram is F type.
Table 1
Table 2
Unit: mm
Unit: mm
Symbol
Dimension
Model
T
e
Model
T
e
H
21.0~26.0
180K
2.1~4.3
1.7
361K
3.0~5.4
2.9
H1
24.0~28.0
220K
2.2~4.4
1.8
391K
3.1~5.5
3.0
L(min.)
20.0
270K
2.2~4.6
2.0
431K
3.3~5.7
3.2
L1(min.)
15.0
330K
2.3~4.8
1.9
471K
3.4~6.0
3.4
D
20.0~23.0
390K
2.2~4.5
2.0
511K
3.5~6.2
3.6
F
7.5±0.8/10.0±1.0
470K
2.3~4.7
2.1
561K
3.7~6.5
3.8
T
Table 2
560K
2.4~5.0
2.3
621K
3.9~6.8
4.1
e(±0.8)
Table 2
680K
2.5~5.3
2.6
681K
4.1~7.1
4.4
d(±0.05)
0.8/1.0
820K
2.2~4.5
2.0
751K
4.4~7.5
4.5
d1(±0.4)
1.4/1.6
101K
2.5~4.6
2.2
781K
4.5~7.7
4.6
121K
2.5~4.8
2.4
821K
4.7~7.9
4.8
151K
2.3~4.5
2.0
911K
4.9~8.1
5.2
181K
2.4~4.6
2.1
102K
5.5~8.6
5.2
201K
2.5~4.7
2.2
112K
5.9~9.1
5.6
221K
2.6~4.8
2.3
122K
6.0~9.7
6.0
241K
2.7~4.9
2.4
142K
7.0~11.2
6.8
271K
2.7~5.0
2.6
162K
7.5~11.8
7.6
301K
2.8~5.0
2.7
182K
7.7~12.8
8.4
331K
2.8~5.2
2.7
3 / 14
20Φ SERIES
Electrical Characteristics
Part
Number
Maximum
Allowable
Voltage
Varistor
Voltage
Maximum
Clamping
Voltage
Withstanding
Surge
Current
Maximum
Energy
(10/1000μs)
Rated
Power
Typical
Capacitance
(Reference)
Standard
High
Surge
VAC(V)
VDC(V)
V1mA(V)
IP(A)
VC(V)
I (A)
Standard
I (A)
High
Surge
(J)
Standard
(J)
High
Surge
(W)
@1KHz (pf)
180KD20
180KD20J
11
14
18(15~21.6)
2000
3000
11
13
0.2
28500
220KD20
220KD20J
14
18
22(19.5~26)
2000
3000
14
16
0.2
18500
270KD20
270KD20J
17
22
27(24~31)
2000
3000
16
19
0.2
13000
330KD20
330KD20J
33(29.5~36.5)
2000
3000
23
24
0.2
11500
390KD20
390KD20J
25
31
39(35~43)
2000
3000
26
28
0.2
8500
470KD20
470KD20J
30
38
47(42~52)
2000
3000
30
34
0.2
7400
560KD20
560KD20J
35
45
56(50~62)
2000
3000
38
44
0.2
6500
680KD20
680KD20J
40
56
68(61~75)
2000
3000
41
49
0.2
5800
820KD20
820KD20J
50
65
82(74~90)
100
135
6500
10000
45
56
1.0
4900
101KD20
101KD20J
60
85
100(90~110)
100
165
6500
10000
50
70
1.0
4000
121KD20
121KD20J
75
100
120(108~132)
100
200
6500
10000
55
85
1.0
3300
151KD20
151KD20J
95
125
150(135~165)
100
250
6500
10000
70
106
1.0
2700
181KD20
181KD20J
115
150
180(162~198)
100
300
6500
10000
85
130
1.0
2200
201KD20
201KD20J
130
170
200(180~220)
100
340
6500
10000
95
140
1.0
2000
221KD20
221KD20J
140
180
220(198~242)
100
360
6500
10000
100
155
1.0
1800
241KD20
241KD20J
150
200
240(216~264)
100
395
6500
10000
108
168
1.0
1650
271KD20
271KD20J
175
225
270(243~297)
100
455
6500
10000
127
190
1.0
1500
301KD20
301KD20J
190
250
300(270~330)
100
500
6500
10000
136
210
1.0
1300
331KD20
331KD20J
210
275
330(297~363)
100
550
6500
10000
150
228
1.0
1200
361KD20
361KD20J
230
300
360(324~396)
100
595
6500
10000
163
255
1.0
1100
391KD20
391KD20J
250
320
390(351~429)
100
650
6500
10000
180
275
1.0
1000
431KD20
431KD20J
275
350
430(387~473)
100
710
6500
10000
190
305
1.0
930
471KD20
471KD20J
300
385
470(423~517)
100
775
6500
10000
204
350
1.0
850
511KD20
511KD20J
320
415
510(459~561)
100
845
6500
10000
210
360
1.0
780
561KD20
561KD20J
350
460
560(504~616)
100
925
6500
10000
215
380
1.0
710
621KD20
621KD20J
385
505
620(558~682)
100
1025
6500
10000
224
390
1.0
650
681KD20
681KD20J
420
560
680(612~748)
100
1120
6500
10000
230
400
1.0
600
751KD20
751KD20J
460
615
750(675~825)
100
1240
6500
10000
255
420
1.0
530
781KD20
781KD20J
485
640
780(702~858)
100
1290
6500
10000
265
440
1.0
510
821KD20
821KD20J
510
670
820(738~902)
100
1355
6500
10000
282
460
1.0
500
911KD20
911KD20J
550
745
910(819~1001)
100
1500
6500
10000
310
510
1.0
440
102KD20
102KD20J
625
825
1000(900~1100)
100
1650
6500
10000
342
565
1.0
400
112KD20
112KD20J
680
895
1100(990~1210)
100
1815
6500
10000
383
620
1.0
360
122KD20
122KD20J
750
990
1200(1080~1320)
100
1980
6500
10000
408
660
1.0
350
142KD20
142KD20J
880
1140
1400(1260~1540)
100
2310
6500
10000
532
784
1.0
340
4 / 14
20Φ SERIES
Maximum
Allowable
Voltage
Part
Number
Maximum
Clamping
Voltage
Varistor
Voltage
Withstanding
Surge
Current
Maximum
Energy
(10/1000μs)
Rated
Power
Typical
Capacitance
(Reference)
Standard
High
Surge
VAC(V)
VDC(V)
V1mA(V)
IP(A)
VC(V)
I (A)
Standard
I (A)
High
Surge
(J)
Standard
(J)
High
Surge
(W)
@1KHz (pf)
162KD20
162KD20J
1000
1280
1600(1440~1760)
100
2640
6500
10000
606
896
1.0
330
182KD20
182KD20J
1100
1465
1800(1620~1980)
100
2970
6500
10000
625
990
1.0
320
Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%;
2. Varistor voltage≥1200V, structure diagram is F type;
3. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K) ; IR≤25μA (820K~182K).
Maximum Surge Current Derating Curve
180KD20 to 680KD20
820KD20 to 182KD20
10000
10000
1
100
10
2
10
102
103
104
105
106
1000
10
102
103
Max. Surge Current (A)
1000
1
2
104
100
105
106
10
1
1
0.1
10
100
1000
0.1
10
10000
100
Td (μs)
180KD20J to 680KD20J
1
2
10
1000
4
10
105
106
10
102
103
104
100
105
106
10
1
1
0.1
10
1
2
10
10000
102
103
100
10000
820KD20J to 182KD20J
10000
1000
1000
Td (μs)
100
1000
0.1
10
10000
1000
10000
Td (μs)
Td (μs)
100
5 / 14
20Φ SERIES
Maximum Leakage Current and Maximum Clamping Voltage Curve
6 / 14
20Φ SERIES
7 / 14
20Φ SERIES
8 / 14
20Φ SERIES
Reliability
Items
Standard
Test conditions / Methods
Specifications
Gradually applying the force specified and keeping the unit
fixed for 10±1 sec.
Tensile Strength
of Terminals
Bending Strength
of Terminals
IEC60068-2-21
Terminal diameter (mm)
0.5<d≤0.8
0.8<d≤1.25
1.25<d
Force (kg)
No visible damage
1.0
2.0
4.0
|ΔV1mA/V1mA |≤5%
Hold specimen and apply the force specified below to each
lead. Bend the specimen to 90°, then return to the original
position. Repeat the procedure in the opposite direction.
0.5<d≤0.8
0.8<d≤1.25
1.25<d
IEC60068-2-21
Force (kg)
0.5
1.0
2.0
Vibration
IEC60068-2-6
Frequency range: 10~55 Hz
2
Amplitude: 0.75mm or 98m/s
Direction: 3 mutually perpendicular directions, 2hrs each.
Solderability
IEC60068-2-20
Solder Temp: 245±5℃
Dipping Time: 2±0.5 sec
Resistance to
Soldering Heat
High Temperature
Storage
Low Temperature
Storage
Damp Heat,
Steady State
High Temperature Load
No visible damage
|ΔV1mA/V1mA |≤5%
No visible damage
|ΔV1mA/V1mA |≤5%
Solder Temp: 260±5℃
Dipping Time: 10±1 sec
Ambient Temp: 125±2℃
Duration: 1000±24hrs
At least 95% of terminal
electrode is covered by
new solder
No visible damage
|ΔV1mA/V1mA |≤5%
No visible damage
|ΔV1mA/V1mA |≤5%
Ambient Temp: -40±2℃
No visible damage
|ΔV1mA/V1mA |≤5%
IEC60068-2-78
The test is divided into two groups .
a. 40±2℃ , 90~95% RH for 1344±24hrs
b. 40±2℃ , 90~95% RH,at 10%VDC ,1344±24 hrs
No visible damage
|ΔV1mA/V1mA|≤10%
Insulation
Resistance≧100MΩ
MIL-STD-202
Ambient Temp: 105±2℃
Method 108
Load: Max. Allowable Voltage In AC.
IEC60068-2-20
IEC60068-2-2
IEC60068-2-1
|ΔV1mA/V1mA|≤10%
The conditions shown below shall be repeated 5 cycles
Temperature Cycle
IEC60068-2-14
Temperature (℃)
Period (minutes)
1
-40±3
30±3
No visible damage
2
Room temperature
5±3
|ΔV1mA/V1mA |≤5%
3
125±3
30±3
4
Room temperature
5±3
8/20µS waveform,10 surge currents, unipolar, interval
8/20uS
IEC61051-1
Surge Life
30secs,amplitude corresponding to max. surge current
derating curves for 20µS.
10/1000µS waveform,10 surge currents, unipolar, interval
10/1000µS
IEC61051-1
Surge Life
Voltage Proof
Step
2mins,amplitude corresponding to max. surge current
No visible damage
△Vb(1mA)≦±10%
No visible damage
|ΔV1mA/V1mA |≤10%
derating curves for 1000µS.
IEC61051-1
Metal balls method, 2500Vac 1 min.
9 / 14
No visible damage
20Φ SERIES
Soldering Recommendation
Lead-free Wave Soldering Recommendation
300
Maximum Wave 265℃
Preheating
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds (max.)
Soldering
1 time
Recommendation Reworking Conditions with Soldering Iron
Item
Conditions
Temperature of Soldering Iron-tip
360℃ (max.)
Soldering Time
3 seconds (max.)
Distance from Varistor
2mm (min.)
Marking Code
①
XXXKDXXX
②
③
④
⑤
XXX Y
VDE
① Brightking Logo
② Varistor Voltage
③ CSA Accreditation Logo
⑥
⑦
④ UL Accreditation Logo
⑤ VDE Accreditation Logo
⑧
⑥“J”is High Surge Code, no“J”is Standard Surge
⑦ Disk Size
⑧ Internal control code
10 / 14
20Φ SERIES
Taping Dimensions
P2
P
h
B
W0
W
H0
W2
D0
I
P1
F
P0
W1
t
P2
h
P
B
I
W0
W
H0
W2
D0
F
P1
P0
W1
t
11 / 14
Symbol
Dimension (mm)
P
25.4±1.0
P0
12.7±1.0
P1
8.95/7.7±0.7
P2
12.7±1.3
F
7.5±0.8/10.0±1.0
h
0±4
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H0
16.0±1.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
45max
Symbol
Dimension (mm)
P
25.4±1.0
P0
12.7±1.0
P1
8.95/7.7±0.7
P2
12.7±1.3
F
7.5±0.8/10.0±1.0
h
0±4
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H0
16.0±1.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
45max
20Φ SERIES
Taping Dimensions
P
h
B
P2
W0
W
H2
W2
D0
I
F
P1
P0
W1
t
Symbol
Dimension (mm)
P
25.4±1.0
P0
12.7±1.0
P1
8.95/7.7±0.7
P2
12.7±1.3
F
7.5±0.8/10.0±1.0
h
0±4
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H2
20.0±2.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
45max
Quantity
Packaging Dimensions (Unit: mm)
Quantity
In bulk for Terminals Untrimmed Products
400pcs/bag
4bags/box
(180K~331K)
5M
ax
300pcs/bag
4bags/box
(361K~621K)
16
130 Max.
250pcs/bag
4bags/box
(681K~112K)
250 Max.
150pcs/bag
4bags/box
(122K~182K)
12 / 14
20Φ SERIES
Quantity
Quantity
In bulk for Terminals Trimmed Products
250pcs/bag
2bags/box
(180K~301K)
ax
200pcs/bag
2bags/box
(331K~561K)
5M
150pcs/bag
2bags/box
(621K~112K)
16
66 Max.
252 Max.
100pcs/bag
2bags/box
(122K~182K)
Quantity
Tape & Box & P0=12.7mm
0M
ax
400pcs/box
(180K~301K)
25
60 Max.
300pcs/box
(331K~561K)
340 Max.
Tape & Reel & P0=12.7mm
5M
ax
400pcs/box
(180K~301K)
36
60 Max.
365 Max.
300pcs/box
(331K~561K)
55 Max.
30±1
Φ365 Max.
13 / 14
20Φ SERIES
Storage Condition of Products
(I) Storage Conditions :
1.Storage Temperature : -10℃ ~ +40℃
2.Relative Humidity : ≦80%RH
3.Keep away from corrosive atmosphere and sunlight.
(II) Period of Storage : 1 year
14 / 14
很抱歉,暂时无法提供与“390KD20”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.24630
- 50+1.77272
- 250+1.56978
- 国内价格
- 5+2.03830
- 50+1.60857
- 100+1.58444
- 250+1.42443
- 国内价格
- 1+1.78200
- 50+1.36400
- 250+1.26500
