14Φ SERIES
Metal Oxide Varistors (MOV) Data Sheet
Features
■ Wide operating voltage (V1mA) range from 18V to 1800V
■ Fast responding to transient over-voltage
■ Large absorbing transient energy capability
■ Low clamping ratio and no follow-on current
■ Meets MSL level 1, per J-STD-020
■ Operating Temperature:-40℃ ~ +105℃
■ Storage Temperature:-40℃ ~ +125℃
■ Safety certification:UL、CSA、VDE
Applications
■ Transistor, diode, IC, thyristor or triac semiconductor protection
■ Surge protection in consumer electronics
■ Surge protection in industrial electronics
■ Surge protection in electronic home appliances, gas and petroleum appliances
■ Relay and electromagnetic valve surge absorption
Part Number Code
4
7
1
K
D
1
4
J
O
TR
Packing
No suffix: Bulk
TB: Tape & Box & P0=12.7mm
TR: Tape & Reel & P0=12.7mm
EB: Tape & Box & P0=15.0mm
ER: Tape & Reel & P0=15.0mm
Tolerance
K: ±10%
Type
D: Disk
Varistor Voltage
180: 18V
101: 100V
102: 1000V
Revision: MOV-14Φ SERIES-001(A7)
Surge Series
No suffix: Standard type
J: High Surge type
Lead Shape
No suffix: Straight leads
O: Outside crimped leads
F: Y Kinked leads
Element Diameter
14
2 / 16
http://brightking.yageo.com
14Φ SERIES
Dimensions
D
D
T
D
H1
H1
H
T
K≤3.0
L1
L1
F
L
d1
d
K≤3.0
d
e
d
F
O Type
F Type
Notes: Varistor voltage≥1200V, structure diagram is F type.
Table 1
Table 2
Unit: mm
Unit: mm
Symbol
Dimension
Model
T
e
Model
T
e
H
14.5~20.0
180K
2.0~3.9
1.5
361K
2.9~5.2
2.7
H1
17.0~21.0
220K
2.1~4.0
1.6
391K
3.0~5.4
2.8
L(min.)
20.0
270K
2.1~4.1
1.8
431K
3.2~5.6
3.0
L1(min.)
15.0
330K
2.2~4.3
1.7
471K
3.3~5.8
3.2
D
14.0~16.5
390K
2.1~4.1
1.8
511K
3.4~6.1
3.4
F(±0.8)
7.5
470K
2.2~4.3
1.9
561K
3.6~6.4
3.6
T
Table 2
560K
2.3~4.6
2.1
621K
3.8~6.8
3.9
e(±0.8)
Table 2
680K
2.4~4.8
2.4
681K
4.0~7.1
4.2
d(±0.05)
0.8
820K
2.1~4.1
1.8
751K
4.3~7.2
4.3
d1(±0.4)
1.4
101K
2.4~4.2
2.0
781K
4.4~7.3
4.4
121K
2.4~4.4
2.2
821K
4.6~7.5
4.6
151K
2.2~4.1
1.8
911K
4.8~7.5
5.0
181K
2.3~4.2
1.9
102K
5.4~8.0
5.0
201K
2.4~4.3
2.0
112K
5.8~8.5
5.4
221K
2.5~4.4
2.1
122K
5.9~9.0
5.8
241K
2.6~4.5
2.2
142K
6.9~10.5
6.6
271K
2.6~4.6
2.4
162K
7.4~11.0
7.4
301K
2.7~4.6
2.5
182K
7.6~12.0
8.2
331K
2.7~5.0
2.5
3 / 16
14Φ SERIES
Electrical Characteristics
Maximum
Allowable
Voltage
Part
Number
Varistor
Voltage
Maximum
Clamping
Voltage
Withstanding
Surge
Current
Maximum
Energy
(10/1000μs)
Rated
Power
Typical
Capacitance
(Reference)
Standard
High
Surge
VAC(V)
VDC(V)
V1mA(V)
IP(A)
VC(V)
I (A)
Standard
I (A)
High
Surge
(J)
Standard
(J)
High
Surge
(W)
@1KHz (pf)
180KD14
180KD14J
11
14
18(15~21.6)
10
36
1000
2000
4.0
7.0
0.1
11100
220KD14
220KD14J
14
18
22(19.5~26)
10
43
1000
2000
5.0
8.0
0.1
9100
270KD14
270KD14J
17
22
27(24~31)
10
53
1000
2000
6.0
10.0
0.1
7400
330KD14
330KD14J
33(29.5~36.5)
10
65
1000
2000
7.5
12.0
0.1
6100
390KD14
390KD14J
25
31
39(35~43)
10
77
1000
2000
8.6
13.0
0.1
5100
470KD14
470KD14J
30
38
47(42~52)
10
93
1000
2000
10.0
17.0
0.1
4300
560KD14
560KD14J
35
45
56(50~62)
10
110
1000
2000
11.0
20.0
0.1
3600
680KD14
680KD14J
40
56
68(61~75)
10
135
1000
2000
14.0
24.0
0.1
2900
820KD14
820KD14J
50
65
82(74~90)
50
135
4500
6000
22.0
27.0
0.6
2400
101KD14
101KD14J
60
85
100(90~110)
50
165
4500
6000
28.0
33.0
0.6
2000
121KD14
121KD14J
75
100
120(108~132)
50
200
4500
6000
32.0
40.0
0.6
1700
151KD14
151KD14J
95
125
150(135~165)
50
250
4500
6000
40.0
53.0
0.6
1300
181KD14
181KD14J
115
150
180(162~198)
50
300
4500
6000
50.0
60.0
0.6
1100
201KD14
201KD14J
130
170
200(180~220)
50
340
4500
6000
57.0
70.0
0.6
1000
221KD14
221KD14J
140
180
220(198~242)
50
360
4500
6000
60.0
78.0
0.6
900
241KD14
241KD14J
150
200
240(216~264)
50
395
4500
6000
63.0
84.0
0.6
830
271KD14
271KD14J
175
225
270(243~297)
50
455
4500
6000
70.0
99.0
0.6
740
301KD14
301KD14J
190
250
300(270~330)
50
500
4500
6000
77.0
108
0.6
670
331KD14
331KD14J
210
275
330(297~363)
50
550
4500
6000
85.0
115
0.6
610
361KD14
361KD14J
230
300
360(324~396)
50
595
4500
6000
93.0
130
0.6
560
391KD14
391KD14J
250
320
390(351~429)
50
650
4500
6000
100
140
0.6
510
431KD14
431KD14J
275
350
430(387~473)
50
710
4500
6000
115
155
0.6
460
471KD14
471KD14J
300
385
470(423~517)
50
775
4500
6000
118
175
0.6
430
511KD14
511KD14J
320
415
510(459~561)
50
845
4500
6000
121
180
0.6
390
561KD14
561KD14J
350
460
560(504~616)
50
925
4500
6000
125
185
0.6
360
621KD14
621KD14J
385
505
620(558~682)
50
1025
4500
6000
128
190
0.6
320
681KD14
681KD14J
420
560
680(612~748)
50
1120
4500
6000
130
200
0.6
290
751KD14
751KD14J
460
615
750(675~825)
50
1240
4500
6000
143
210
0.6
270
781KD14
781KD14J
485
640
780(702~858)
50
1290
4500
6000
148
220
0.6
260
821KD14
821KD14J
510
670
820(738~902)
50
1355
4500
6000
157
235
0.6
240
911KD14
911KD14J
550
745
910(819~1001)
50
1500
4500
6000
175
255
0.6
220
102KD14
102KD14J
625
825
1000(900~1100)
50
1650
4500
6000
190
280
0.6
200
112KD14
112KD14J
680
895
1100(990~1210)
50
1815
4500
6000
213
310
0.6
180
122KD14
122KD14J
750
990
1200(1080~1320)
50
1980
4500
6000
232
324
0.6
160
142KD14
880
1140
1400(1260~1540)
50
2310
4500
238
0.6
150
4 / 16
14Φ SERIES
Maximum
Allowable
Voltage
Part
Number
Maximum
Clamping
Voltage
Varistor
Voltage
Withstanding
Surge
Current
Maximum
Energy
(10/1000μs)
Rated
Power
Typical
Capacitance
(Reference)
Standard
High
Surge
VAC(V)
VDC(V)
V1mA(V)
IP(A)
VC(V)
I (A)
Standard
I (A)
High
Surge
(J)
Standard
(J)
High
Surge
(W)
@1KHz (pf)
162KD14
1000
1280
1600(1440~1760)
50
2640
4500
243
0.6
140
182KD14
1100
1465
1800(1620~1980)
50
2970
4500
250
0.6
130
Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%;
2. Varistor voltage≥1200V, structure diagram is F type;
3. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K) ; IR≤25μA (820K~182K).
Maximum Surge Current Derating Curve
820KD14 to 182KD14
180KD14 to 680KD14
10000
10000
1000
1
100
2
10
1023
104
10
105
106
1000
Max. Surge Current (A)
1
2
10
100
10
102
103
104
105
106
10
1
1
0.1
10
100
1000
0.1
10
10000
100
Td (μs)
10000
10000
1
2
1
1000
2
10
102
103
104
105
106
100
10
1
0.1
10
10000
820KD14J to 122KD14J
180KD14J to 680KD14J
1000
1000
Td (μs)
100
10
102
103
104
105
106
10
1
100
1000
0.1
10
10000
Td (μs)
100
1000
10000
Td (μs)
5 / 16
14Φ SERIES
Maximum Leakage Current and Maximum Clamping Voltage Curve
6 / 16
14Φ SERIES
7 / 16
14Φ SERIES
8 / 16
14Φ SERIES
Reliability
Items
Standard
Test conditions / Methods
Specifications
Gradually applying the force specified and keeping the unit
fixed for 10±1 sec.
Tensile Strength
of Terminals
Bending Strength
of Terminals
IEC60068-2-21
Terminal diameter (mm)
0.5<d≤0.8
0.8<d≤1.25
1.25<d
Force (kg)
No visible damage
1.0
2.0
4.0
|ΔV1mA/V1mA |≤5%
Hold specimen and apply the force specified below to each
lead. Bend the specimen to 90°, then return to the original
position. Repeat the procedure in the opposite direction.
0.5<d≤0.8
0.8<d≤1.25
1.25<d
IEC60068-2-21
Force (kg)
0.5
1.0
2.0
Vibration
IEC60068-2-6
Frequency range: 10~55 Hz
2
Amplitude: 0.75mm or 98m/s
Direction: 3 mutually perpendicular directions, 2hrs each.
Solderability
IEC60068-2-20
Solder Temp: 245±5℃
Dipping Time: 2±0.5 sec
Resistance to
Soldering Heat
High Temperature
Storage
Low Temperature
Storage
Damp Heat,
Steady State
High Temperature Load
No visible damage
|ΔV1mA/V1mA |≤5%
No visible damage
|ΔV1mA/V1mA |≤5%
Solder Temp: 260±5℃
Dipping Time: 10±1 sec
Ambient Temp: 125±2℃
Duration: 1000±24hrs
At least 95% of terminal
electrode is covered by
new solder
No visible damage
|ΔV1mA/V1mA |≤5%
No visible damage
|ΔV1mA/V1mA |≤5%
Ambient Temp: -40±2℃
No visible damage
|ΔV1mA/V1mA |≤5%
IEC60068-2-78
The test is divided into two groups .
a. 40±2℃ , 90~95% RH for 1344±24hrs
b. 40±2℃ , 90~95% RH,at 10%VDC ,1344±24 hrs
No visible damage
|ΔV1mA/V1mA|≤10%
Insulation
Resistance≧100MΩ
MIL-STD-202
Ambient Temp: 105±2℃
Method 108
Load: Max. Allowable Voltage In AC.
IEC60068-2-20
IEC60068-2-2
IEC60068-2-1
|ΔV1mA/V1mA|≤10%
The conditions shown below shall be repeated 5 cycles
Temperature Cycle
IEC60068-2-14
Temperature (℃)
Period (minutes)
1
-40±3
30±3
No visible damage
2
Room temperature
5±3
|ΔV1mA/V1mA |≤5%
3
125±3
30±3
4
Room temperature
5±3
8/20µS waveform,10 surge currents, unipolar, interval
8/20uS
IEC61051-1
Surge Life
30secs,amplitude corresponding to max. surge current
derating curves for 20µS.
10/1000µS waveform,10 surge currents, unipolar, interval
10/1000µS
IEC61051-1
Surge Life
Voltage Proof
Step
2mins,amplitude corresponding to max. surge current
No visible damage
△Vb(1mA)≦±10%
No visible damage
|ΔV1mA/V1mA |≤10%
derating curves for 1000µS.
IEC61051-1
Metal balls method, 2500Vac 1 min.
9 / 16
No visible damage
14Φ SERIES
Soldering Recommendation
Lead-free Wave Soldering Recommendation
300
Maximum Wave 265℃
Preheating
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds (max.)
Soldering
1 time
Recommendation Reworking Conditions with Soldering Iron
Item
Conditions
Temperature of Soldering Iron-tip
360℃ (max.)
Soldering Time
3 seconds (max.)
Distance from Varistor
2mm (min.)
Marking Code
①
XXXKDXXX
②
③
④
⑤
XXX Y
VDE
① Brightking Logo
② Varistor Voltage
③ CSA Accreditation Logo
⑥
⑦
④ UL Accreditation Logo
⑤ VDE Accreditation Logo
⑧
⑥“J”is High Surge Code, no“J”is Standard Surge
⑦ Disk Size
⑧ Internal control code
10 / 16
14Φ SERIES
Taping Dimensions
P2
P
h
B
W0
W
H0
W2
D0
I
P1
F
W1
P0
t
h
P2
B
P
W0
W
H0
W2
D0
I
P1
P0
F
W1
t
11 / 16
Symbol
Dimension (mm)
P
25.4±1.0
P0
12.7±1.0
P1
8.95±0.7
P2
12.7±1.3
F
7.5±0.8
h
0±4
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H0
16.0±1.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
40max
Symbol
Dimension (mm)
P
30.0±1.0
P0
15.0±1.0
P1
3.85±0.7
P2
7.5±1.3
F
7.5±0.8
h
0±4
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H0
16.0±1.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
40max
14Φ SERIES
Taping Dimensions
P2
h
P
B
W0
W
H0
W2
D0
I
F
P1
W1
P0
t
h
P2
B
P
W0
W
H0
W2
D0
I
P1
F
P0
W1
t
12 / 16
Symbol
Dimension (mm)
P
25.4±1.0
P0
12.7±1.0
P1
8.95±0.7
P2
12.7±1.3
F
7.5±0.8
h
0±4
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H0
16.0±1.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
40max
Symbol
Dimension (mm)
P
30.0±1.0
P0
15.0±1.0
P1
3.85±0.7
P2
7.5±1.3
F
7.5±0.8
h
0±4
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H0
16.0±1.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
40max
14Φ SERIES
Taping Dimensions
P
h
B
P2
W0
W
H2
W2
D0
I
F
P1
W1
P0
t
h
P2
B
P
W0
W
H2
W2
D0
I
P1
F
P0
W1
t
13 / 16
Symbol
Dimension (mm)
P
25.4±1.0
P0
12.7±1.0
P1
8.95±0.7
P2
12.7±1.3
F
7.5±0.8
h
0±4
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H2
20.0±2.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
40max
Symbol
Dimension (mm)
P
30.0±1.0
P0
15.0±1.0
P1
3.85±0.7
P2
7.5±1.3
F
7.5±0.8
h
0±4
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H2
20.0±2.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
40max
14Φ SERIES
Quantity
Packaging Dimensions (Unit: mm)
Quantity
In bulk for Terminals Untrimmed Products
400pcs/bag
4bags/box
(180K~331K)
300pcs/bag
4bags/box
(361K~621K)
5M
ax
250pcs/bag
4bags/box
(681K~112K)
16
130 Max.
250 Max.
150pcs/bag
4bags/box
(122K~182K)
In bulk for Terminals Trimmed Products
400pcs/bag
4bags/box
(180K~331K)
5M
ax
300pcs/bag
4bags/box
(361K~621K)
16
66 Max.
252 Max.
250pcs/bag
4bags/box
(681K~112K)
150pcs/bag
4bags/box
(122K~182K)
Quantity
750pcs/ box
(180K~241K)
0M
ax
600pcs/ box
(271K~331K)
25
60 Max.
500pcs/ box
(361K~621K)
340 Max.
400pcs/ box
(681K~751K)
350pcs/ box
(781K~112K)
14 / 16
14Φ SERIES
Quantity
Quantity
1000pcs/reel
(180K~331K)
5M
ax
750pcs/reel
(361K~621K)
36
60 Max.
500pcs/reel
365 Max.
(681K~751K)
55 Max.
400pcs/reel
(781K~112K)
30±1
Φ365 Max.
Quantity
500pcs/ box
(180K~331K)
0M
ax
400pcs/ box
(361K~751K)
25
60 Max.
340 Max.
300pcs/ box
(781K~112K)
750pcs/reel
5M
ax
(180K~331K)
36
60 Max.
600pcs/reel
(361K~751K)
365 Max.
55 Max.
500pcs/reel
(781K~112K)
30±1
Φ365 Max.
15 / 16
14Φ SERIES
Storage Condition of Products
(I) Storage Conditions :
1.Storage Temperature : -10℃ ~ +40℃
2.Relative Humidity : ≦80%RH
3.Keep away from corrosive atmosphere and sunlight.
(II) Period of Storage : 1 year
16 / 16
很抱歉,暂时无法提供与“680KD14”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.04868
- 50+0.87178
- 150+0.78333
- 国内价格
- 5+0.95158
- 50+0.79106
- 150+0.71079
- 国内价格
- 10+1.82910
- 100+1.09110
- 200+0.76380
- 400+0.54560
- 800+0.54560
- 4000+0.54560
- 国内价格
- 1+0.85140
- 50+0.56760
- 400+0.51480
