5Φ SERIES
Metal Oxide Varistors (MOV) Data Sheet
Features
Wide operating voltage (V1mA) range from 18V to 750V
Fast responding to transient over-voltage
Large absorbing transient energy capability
Low clamping ratio and no follow-on current
Meets MSL level 1, per J-STD-020
■ Operating Temperature:-40℃ ~ +105℃
■ Storage Temperature:-40℃ ~ +125℃
■ Safety certification:UL、CSA、VDE
Applications
■ Transistor, diode, IC, thyristor or triac semiconductor protection
■ Surge protection in consumer electronics
■ Surge protection in industrial electronics
■ Surge protection in electronic home appliances, gas and petroleum appliances
■ Relay and electromagnetic valve surge absorption
Part Number Code
4
7
1
K
D
J
O
TR
Packing
No suffix: Bulk
TB: Tape & Box & P0=12.7mm
TR: Tape & Reel & P0=12.7mm
Tolerance
K: ±10%
Type
D: Disk
Varistor Voltage
180: 18V
101: 100V
Revision: MOV-5Φ SERIES-001(A5)
Surge Series
No suffix: Standard type
J: High Surge type
Lead Shape
No suffix: Straight leads
O: Outside crimped leads
F: Y Kinked leads
Element Diameter
05
2 / 12
http://brightking.yageo.com
5Φ SERIES
Dimensions
D
D
T
D
H1
H1
H
T
K≤3.0
L1
L1
F
L
d1
d
K≤3.0
d
e
d
F
O Type
F Type
Table 1
Table 2
Unit: mm
Unit: mm
Symbol
Dimension
Model
T
e
Model
T
e
H
5.5~10.0
180K
1.5~4.5
1.3
221K
2.0~4.5
1.9
H1
8.0~13.0
220K
1.6~4.6
1.4
241K
2.1~4.6
2.0
L(min.)
20.0
270K
1.6~4.7
1.6
271K
2.1~4.9
2.2
L1(min.)
15.0
330K
1.7~4.9
1.5
301K
2.2~5.0
2.3
D
5.0~7.5
390K
1.6~4.8
1.6
331K
2.2~5.1
2.3
F(±0.8)
5.0
470K
1.7~4.9
1.7
361K
2.4~5.2
2.5
T
Table 2
560K
1.8~5.0
1.9
391K
2.5~5.4
2.6
e(±0.8)
Table 2
680K
1.9~5.2
2.2
431K
2.7~5.7
2.8
d(±0.05)
0.6
820K
1.6~4.1
1.6
471K
2.8~6.0
3.0
d1(±0.4)
1.2
101K
1.9~4.3
1.8
511K
2.9~6.2
3.2
121K
1.9~4.5
2.0
561K
3.1~6.5
3.4
151K
1.7~4.8
1.6
621K
3.3~6.5
3.7
181K
1.8~4.3
1.7
681K
3.5~6.8
4.0
201K
1.9~4.4
1.8
751K
3.8~6.9
4.1
3 / 12
5Φ SERIES
Electrical Characteristics
Part
Number
Maximum
Allowable
Voltage
Varistor
Voltage
Maximum
Clamping
Voltage
Withstanding
Surge
Current
Maximum
Energy
(10/1000μs)
Rated
Power
Typical
Capacitance
(Reference)
Standard
High
Surge
VAC(V)
VDC(V)
V1mA(V)
IP(A)
VC(V)
I (A)
Standard
I (A)
High
Surge
(J)
Standard
(J)
High
Surge
(W)
@1KHz (pf)
180KD05
180KD05J
11
14
18(15~21.6)
1
40
100
250
0.4
0.6
0.01
1400
220KD05
220KD05J
14
18
22(19.5~26)
1
48
100
250
0.5
0.7
0.01
1150
270KD05
270KD05J
17
22
27(24~31)
1
60
100
250
0.6
0.9
0.01
930
330KD05
330KD05J
33(29.5~36.5)
1
73
100
250
0.8
1.1
0.01
760
390KD05
390KD05J
25
31
39(35~43)
1
80
100
250
0.9
1.2
0.01
640
470KD05
470KD05J
30
38
47(42~52)
1
104
100
250
1.1
1.5
0.01
530
560KD05
560KD05J
35
45
56(50~62)
1
123
100
250
1.3
1.8
0.01
450
680KD05
680KD05J
40
56
68(61~75)
1
145
100
250
1.6
2.2
0.01
370
820KD05
820KD05J
50
65
82(74~90)
5
150
400
800
2.5
4.0
0.1
300
101KD05
101KD05J
60
85
100(90~110)
5
177
400
800
3.0
4.1
0.1
250
121KD05
121KD05J
75
100
120(108~132)
5
210
400
800
4.0
4.9
0.1
210
151KD05
151KD05J
95
125
150(135~165)
5
260
400
800
4.1
6.5
0.1
165
181KD05
181KD05J
115
150
180(162~198)
5
320
400
800
4.9
7.5
0.1
140
201KD05
201KD05J
130
170
200(180~220)
5
355
400
800
6.5
8.5
0.1
125
221KD05
221KD05J
140
180
220(198~242)
5
380
400
800
7.5
9.0
0.1
110
241KD05
241KD05J
150
200
240(216~264)
5
415
400
800
8.0
10.5
0.1
100
271KD05
271KD05J
175
225
270(243~297)
5
475
400
800
8.5
11.0
0.1
95
301KD05
301KD05J
190
250
300(270~330)
5
520
400
800
9.0
12.0
0.1
85
331KD05
331KD05J
210
275
330(297~363)
5
570
400
800
9.5
13.0
0.1
75
361KD05
361KD05J
230
300
360(324~396)
5
620
400
800
10.0
16.0
0.1
70
391KD05
391KD05J
250
320
390(351~429)
5
675
400
800
12.0
17.0
0.1
65
431KD05
431KD05J
275
350
430(387~473)
5
745
400
800
13.0
20.0
0.1
60
471KD05
471KD05J
300
385
470(423~517)
5
810
400
800
15.0
21.0
0.1
55
511KD05
511KD05J
320
415
510(459~561)
5
845
400
800
16.0
22.5
0.1
50
561KD05
561KD05J
350
460
560(504~616)
5
920
400
800
16.8
24.0
0.1
45
621KD05
621KD05J
385
505
620(558~682)
5
1025
400
800
17.7
25.0
0.1
40
681KD05
681KD05J
420
560
680(612~748)
5
1120
400
800
21.0
29.0
0.1
35
751KD05
751KD05J
460
615
750(675~825)
5
1240
400
800
22.4
32.0
0.1
30
Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%.
2. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K) ; IR≤25μA (820K~751K)
4 / 12
5Φ SERIES
Maximum Surge Current Derating Curve
820KD05 to 751KD05
10000
10000
1000
1000
100
1
10
2
10
102
103
1045
10
106
Max. Surge Current (A)
180KD05 to 680KD05
1
100
10
100
1000
0.1
10
10000
180KD05J to 680KD05J
820KD05J to 751KD05J
1000
1000
1
2
10
102
103
1045
10
106
100
10
10000
1
2
10
102
103
104
105
106
1
1
0.1
10
1000
Td (μs)
10000
10
100
Td (μs)
10000
100
10
1023
10
1045
106
10
1
0.1
10
1
2
100
1000
0.1
10
10000
1000
10000
Td (μs)
Td (μs)
100
5 / 12
5Φ SERIES
Maximum Leakage Current and Maximum Clamping Voltage Curve
6 / 12
5Φ SERIES
7 / 12
5Φ SERIES
Reliability
Items
Standard
Test conditions / Methods
Specifications
Gradually applying the force specified and keeping the unit
fixed for 10±1 sec.
Tensile Strength
of Terminals
Bending Strength
of Terminals
IEC60068-2-21
Terminal diameter (mm)
0.5<d≤0.8
0.8<d≤1.25
1.25<d
Force (kg)
No visible damage
1.0
2.0
4.0
|ΔV1mA/V1mA |≤5%
Hold specimen and apply the force specified below to each
lead. Bend the specimen to 90°, then return to the original
position. Repeat the procedure in the opposite direction.
0.5<d≤0.8
0.8<d≤1.25
1.25<d
IEC60068-2-21
Force (kg)
0.5
1.0
2.0
Vibration
IEC60068-2-6
Frequency range: 10~55 Hz
2
Amplitude: 0.75mm or 98m/s
Direction: 3 mutually perpendicular directions, 2hrs each.
Solderability
IEC60068-2-20
Solder Temp: 245±5℃
Dipping Time: 2±0.5 sec
Resistance to
Soldering Heat
High Temperature
Storage
Low Temperature
Storage
Damp Heat,
Steady State
High Temperature Load
No visible damage
|ΔV1mA/V1mA |≤5%
No visible damage
|ΔV1mA/V1mA |≤5%
Solder Temp: 260±5℃
Dipping Time: 10±1 sec
Ambient Temp: 125±2℃
Duration: 1000±24hrs
At least 95% of terminal
electrode is covered by
new solder
No visible damage
|ΔV1mA/V1mA |≤5%
No visible damage
|ΔV1mA/V1mA |≤5%
Ambient Temp: -40±2℃
No visible damage
|ΔV1mA/V1mA |≤5%
IEC60068-2-78
The test is divided into two groups .
a. 40±2℃ , 90~95% RH for 1344±24hrs
b. 40±2℃ , 90~95% RH,at 10%VDC ,1344±24 hrs
No visible damage
|ΔV1mA/V1mA|≤10%
Insulation
Resistance≧100MΩ
MIL-STD-202
Ambient Temp: 105±2℃
Method 108
Load: Max. Allowable Voltage In AC.
IEC60068-2-20
IEC60068-2-2
IEC60068-2-1
|ΔV1mA/V1mA|≤10%
The conditions shown below shall be repeated 5 cycles
Temperature Cycle
IEC60068-2-14
Temperature (℃)
Period (minutes)
1
-40±3
30±3
No visible damage
2
Room temperature
5±3
|ΔV1mA/V1mA |≤5%
3
125±3
30±3
4
Room temperature
5±3
8/20µS waveform,10 surge currents, unipolar, interval
8/20uS
IEC61051-1
Surge Life
30secs,amplitude corresponding to max. surge current
derating curves for 20µS.
10/1000µS waveform,10 surge currents, unipolar, interval
10/1000µS
IEC61051-1
Surge Life
Voltage Proof
Step
2mins,amplitude corresponding to max. surge current
No visible damage
△Vb(1mA)≦±10%
No visible damage
|ΔV1mA/V1mA |≤10%
derating curves for 1000µS.
IEC61051-1
Metal balls method, 2500Vac 1 min.
8 / 12
No visible damage
5Φ SERIES
Soldering Recommendation
Lead-free Wave Soldering Recommendation
300
Maximum Wave 265℃
Preheating
Soldering
Cooling
Temperature (℃)
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds (max.)
Soldering
1 time
Recommendation Reworking Conditions with Soldering Iron
Item
Conditions
Temperature of Soldering Iron-tip
360℃ (max.)
Soldering Time
3 seconds (max.)
Distance from Varistor
2mm (min.)
Marking Code
① Brightking Logo
② Varistor Voltage
①
③ UL Accreditation Logo
XXXKDXXX
②
③
④
XXX Y
VDE
⑤
⑥
⑦
④ VDE Accreditation Logo
⑤“J”is High Surge Code, no“J”is Standard Surge
⑥ Disk Size
⑦ Internal control code
9 / 12
5Φ SERIES
Taping Dimensions
P
P2
h
B
W0
W
H0
W2
D0
I
F
P1
P0
W1
t
P2
h
P
B
W0
W
H0
W2
D0
I
F
P1
P0
W1
t
10 / 12
Symbol
Dimension (mm)
P
12.7±1.0
P0
12.7±0.3
P1
3.85±0.7
P2
6.35±1.3
F
5.0±0.8
h
0±2
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H0
16.0±1.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
32max
Symbol
Dimension (mm)
P
12.7±1.0
P0
12.7±0.3
P1
3.85±0.7
P2
6.35±1.3
F
5.0±0.8
h
0±2
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H0
16.0±1.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
32max
5Φ SERIES
Taping Dimensions
P2
P
h
B
W0
W
H2
W2
D0
I
F
P1
P0
W1
t
Symbol
Dimension (mm)
P
12.7±1.0
P0
12.7±0.3
P1
3.85±0.7
P2
6.35±1.3
F
5.0±0.8
h
0±2
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H2
20.0±2.0
I
2.0max
D0
4.0±0.2
t
0.6±0.3
B
32max
Quantity
Packaging Dimensions (Unit: mm)
Quantity
In bulk for Terminals Untrimmed Products
1000pcs/bag
4bags/box
5M
ax
(180K~751K)
16
130 Max.
250 Max.
1000pcs/bag
4bags/box
(180K~751K)
11 / 12
5M
ax
16
In bulk for Terminals Trimmed Products
66 Max.
252 Max.
5Φ SERIES
Quantity
Quantity
0M
ax
1500pcs/box
(180K~391K)
25
60 Max.
1000pcs/box
340 Max.
(431K~751K)
5M
ax
2000pcs/reel
(180K~391K)
36
60 Max.
365 Max.
1500pcs/reel
(431K~751K)
55 Max.
30±1
Φ365 Max.
Storage Condition of Products
(I) Storage Conditions :
1.Storage Temperature : -10℃ ~ +40℃
2.Relative Humidity : ≦80%RH
3.Keep away from corrosive atmosphere and sunlight.
(II) Period of Storage : 1 year
12 / 12
很抱歉,暂时无法提供与“201KD05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.24725
- 200+0.19453
- 国内价格
- 20+0.27249
- 200+0.21438
- 1000+0.18209
- 2000+0.16265
- 10000+0.14591
- 20000+0.13684
- 国内价格
- 10+0.49900
- 100+0.29760
- 500+0.20840
- 1000+0.14880
- 2000+0.14880
- 10000+0.14880
- 国内价格
- 1+0.15290
- 1000+0.13750
