SMBJ-AT SERIES
Transient Voltage Suppressors (TVS) Data Sheet
Features
For surface mounted applications in order to optimize board space
Low profile package
Built-in strain relief
Glass passivated junction
Low inductance
Excellent clamping capability
600W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01%
Fast response time
Typical IR less than 1μA above 12V
High Temperature soldering: 260℃/10 seconds at terminals
Plastic package has underwriters laboratory flammability 94V-0
Meets MSL level 1, per J-STD-020
Safety certification: UL: E244458
AEC-Q101 qualified
IEC61000-4-2 ESD 30KV Air, 30KV contact compliance
Mechanical Data
Case: JEDEC DO-214AA. Molded plastic over glass passivated junction
Terminal: Tin plated, solderable per MIL-STD-750, Method 2026
Polarity: Color band denotes cathode except bi-directional models
Standard Packaging: 12mm tape (EIA STD RS-481)
Weight: 0.10g
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
Minimum 600
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
5.0
Watts
IFSM
100
Amps
TJ,TSTG
-55 to +150
RθJL
℃/W
Steady state power dissipation at TA=50℃ (Fig.5)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note3, Fig.6)
Operating junction and Storage Temperature Range.
Typical thermal resistance junction to lead
Typical thermal resistance junction to ambient
RθJA
100
℃/W
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. Mounted on 5.0mm×5.0mm (0.03mm thick) copper pads to each terminal.
3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
Revision:TVS-SMBJ-AT SERIES-001(A2)
1/7
http://brightking.yageo.com
SMBJ-AT SERIES
Dimensions (SMB/DO-214AA)
Millimeters
Cathode Band
Inches
Symbol
D1 D
Min.
Max.
Min.
Max.
L
4.06
4.57
0.160
0.180
D
3.30
3.94
0.130
0.155
D1
1.95
2.20
0.077
0.086
T
5.21
5.59
0.205
0.220
T1
0.76
1.52
0.030
0.060
d
0.203
0.008
H
2.15
2.65
0.085
0.104
H1
2.13
2.47
0.084
0.097
L
H1 H
d
T1
T
Electrical Characteristics (TA=25℃)
Part Number
Device
Marking
Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMBJ5.0A-AT
SMBJ5.0CA-AT
KE
AE
5.0
6.40~7.00
10
9.2
65.3
800
SMBJ6.0A-AT
SMBJ6.0CA-AT
KG
AG
6.0
6.67~7.37
10
10.3
58.3
800
SMBJ6.5A-AT
SMBJ6.5CA-AT
KK
AK
6.5
7.22~7.98
10
11.2
53.6
500
SMBJ7.0A-AT
SMBJ7.0CA-AT
KM
AM
7.0
7.78~8.60
10
12.0
50.0
200
SMBJ7.5A-AT
SMBJ7.5CA-AT
KP
AP
7.5
8.33~9.21
1
12.9
46.6
100
SMBJ8.0A-AT
SMBJ8.0CA-AT
KR
AR
8.0
8.89~9.83
1
13.6
44.2
50
SMBJ8.5A-AT
SMBJ8.5CA-AT
KT
AT
8.5
9.44~10.40
1
14.4
41.7
SMBJ9.0A-AT
SMBJ9.0CA-AT
KV
AV
9.0
10.00~11.10
1
15.4
39.0
10
SMBJ10A-AT
SMBJ10CA-AT
KX
AX
10.0
11.10~12.30
1
17.0
35.3
5
SMBJ11A-AT
SMBJ11CA-AT
KZ
AZ
11.0
12.20~13.50
1
18.2
33.0
1
SMBJ12A-AT
SMBJ12CA-AT
LE
BE
12.0
13.30~14.70
1
19.9
30.2
1
SMBJ13A-AT
SMBJ13CA-AT
LG
BG
13.0
14.40~15.90
1
21.5
28.0
1
SMBJ14A-AT
SMBJ14CA-AT
LK
BK
14.0
15.60~17.20
1
23.2
25.9
1
SMBJ15A-AT
SMBJ15CA-AT
LM
BM
15.0
16.70~18.50
1
24.4
24.6
1
SMBJ16A-AT
SMBJ16CA-AT
LP
BP
16.0
17.80~19.70
1
26.0
23.1
1
SMBJ17A-AT
SMBJ17CA-AT
LR
BR
17.0
18.90~20.90
1
27.6
21.8
1
SMBJ18A-AT
SMBJ18CA-AT
LT
BT
18.0
20.00~22.10
1
29.2
20.6
1
SMBJ20A-AT
SMBJ20CA-AT
LV
BV
20.0
22.20~24.50
1
32.4
18.6
1
SMBJ22A-AT
SMBJ22CA-AT
LX
BX
22.0
24.40~26.90
1
35.5
16.9
1
SMBJ24A-AT
SMBJ24CA-AT
LZ
BZ
24.0
26.70~29.50
1
38.9
15.5
1
SMBJ26A-AT
SMBJ26CA-AT
ME
CE
26.0
28.90~31.90
1
42.1
14.3
1
SMBJ28A-AT
SMBJ28CA-AT
MG
CG
28.0
31.10~34.40
1
45.4
13.3
1
SMBJ30A-AT
SMBJ30CA-AT
MK
CK
30.0
33.30~36.80
1
48.4
12.4
1
2/7
SMBJ-AT SERIES
Part Number
Device
Marking
Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMBJ33A-AT
SMBJ33CA-AT
MM
CM
33.0
36.70~40.60
1
53.3
11.3
1
SMBJ36A-AT
SMBJ36CA-AT
MP
CP
36.0
40.00~44.20
1
58.1
10.4
1
SMBJ40A-AT
SMBJ40CA-AT
MR
CR
40.0
44.40~49.10
1
64.5
9.3
1
SMBJ43A-AT
SMBJ43CA-AT
MT
CT
43.0
47.80~52.80
1
69.4
8.7
1
SMBJ45A-AT
SMBJ45CA-AT
MV
CV
45.0
50.00~55.30
1
72.7
8.3
1
SMBJ48A-AT
SMBJ48CA-AT
MX
CX
48.0
53.30~58.90
1
77.4
7.8
1
SMBJ51A-AT
SMBJ51CA-AT
MZ
CZ
51.0
56.70~62.70
1
82.4
7.3
1
SMBJ54A-AT
SMBJ54CA-AT
NE
DE
54.0
60.00~66.30
1
87.1
6.9
1
SMBJ58A-AT
SMBJ58CA-AT
NG
DG
58.0
64.40~71.20
1
93.6
6.5
1
SMBJ60A-AT
SMBJ60CA-AT
NK
DK
60.0
66.70~73.70
1
96.8
6.2
1
SMBJ64A-AT
SMBJ64CA-AT
NM
DM
64.0
71.10~78.60
1
103.0
5.9
1
SMBJ70A-AT
SMBJ70CA-AT
NP
DP
70.0
77.80~86.00
1
113.0
5.3
1
SMBJ75A-AT
SMBJ75CA-AT
NR
DR
75.0
83.30~92.10
1
121.0
5.0
1
SMBJ78A-AT
SMBJ78CA-AT
NT
DT
78.0
86.70~95.80
1
126.0
4.8
1
SMBJ85A-AT
SMBJ85CA-AT
NV
DV
85.0
94.40~104.00
1
137.0
4.4
1
SMBJ90A-AT
SMBJ90CA-AT
NX
DX
90.0
100.00~111.00
1
146.0
4.1
1
SMBJ100A-AT
SMBJ100CA-AT
NZ
DZ
100.0
111.00~123.00
1
162.0
3.7
1
SMBJ110A-AT
SMBJ110CA-AT
PE
EE
110.0
122.00~135.00
1
177.0
3.4
1
SMBJ120A-AT
SMBJ120CA-AT
PG
EG
120.0
133.00~147.00
1
193.0
3.1
1
SMBJ130A-AT
SMBJ130CA-AT
PK
EK
130.0
144.00~159.00
1
209.0
2.9
1
SMBJ150A-AT
SMBJ150CA-AT
PM
EM
150.0
167.00~185.00
1
243.0
2.5
1
SMBJ160A-AT
SMBJ160CA-AT
PP
EP
160.0
178.00~197.00
1
259.0
2.3
1
SMBJ170A-AT
SMBJ170CA-AT
PR
ER
170.0
189.00~209.00
1
275.0
2.2
1
SMBJ180A-AT
SMBJ180CA-AT
PT
ET
180.0
201.00~222.00
1
292.0
2.1
1
SMBJ190A-AT
SMBJ190CA-AT
PA
EC
190.0
211.00~233.00
1
308.0
2.0
1
SMBJ200A-AT
SMBJ200CA-AT
PV
EV
200.0
224.00~247.00
1
324.0
1.9
1
SMBJ210A-AT
SMBJ210CA-AT
PB
ED
210.0
237.00~263.00
1
340.0
1.8
1
SMBJ220A-AT
SMBJ220CA-AT
PX
EX
220.0
246.00~272.00
1
356.0
1.7
1
SMBJ250A-AT
SMBJ250CA-AT
PZ
EZ
250.0
279.00~309.00
1
405.0
1.5
1
SMBJ300A-AT
SMBJ300CA-AT
QE
FE
300.0
335.00~371.00
1
486.0
1.3
1
SMBJ350A-AT
SMBJ350CA-AT
QG
FG
350.0
391.00~432.00
1
567.0
1.1
1
SMBJ400A-AT
SMBJ400CA-AT
QK
FK
400.0
447.00~494.00
1
648.0
0.9
1
SMBJ440A-AT
SMBJ440CA-AT
QM
FM
440.0
492.00~543.00
1
713.0
0.9
1
3/7
SMBJ-AT SERIES
Ratings and Characteristic Curves (T A=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM - Peak Pulse Power (kW)
100
10
1
0.2×0.2″(5.0×5.0mm)
Copper Pad Area
0.1
1
100
10
100
80
60
40
td-Pulse Width (µs)
td
100
1
2.0
3.0
Bi-directional @VR
4.0
TJ=25℃
f=1.0MHz
Vsig=50mVp-p
1
6
5
4
3
2
1
75
100
125
150
175
1000
120
100
80
60
40
10
100
Number of Cycles at 60Hz
TA-Ambient Temperature (℃)
100
Figure 6. Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
IFSM - Peak Forward Surve Current (A)
PM(AV), Steady State Power Dissipation (W)
Figure 5. Steady State Power Dissipation Derating
Curve
25
10
VBR-Reverse Breakdown Voltage (V)
t-Time (ms)
Uni-directional V=0V
10
10/1000µs Waveform
as defined by R.E.A
1.0
150
Uni-directional @VR
Cj (pF)
IPPM - Peak Pulse Current, %IRSM
1000
50
Bi-directional V=0V
Half Value IPPM (IPPM/2)
10000
Peak Value IPPM
100
75
Figure 4. Typical Junction Capacitance
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
tr=10µs
50
Figure 3. Pulse Waveform
150
25
4/7
SMBJ-AT SERIES
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (tS)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
20-40 seconds
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
8 minutes max.
5/7
SMBJ-AT SERIES
Marking Code
Cathode Band
YXXX
YXXX
KE
AE
Logo
Intermal Control Code
Logo
Marking Code
Marking Code
Part Number Code
SMBJ XXX C A
AT / XXXX
Package code
TR7: 7 inch reel package
TR13: 13 inch reel package
Internal Control Code
5% VBR Voltage Tolerance
Bidirectional
VRWM Voltage
Series Code
Ordering Code for Different Package
7 inch reel package: Add suffix “ /TR7” at the end of the part number, such as SMBJXXXCA-AT/TR7
13 inch reel package: Add suffix “ /TR13” at the end of the part number, such as SMBJXXXCA-AT/TR13
6/7
SMBJ-AT SERIES
Packaging
Tape
P0
P1
P2
D0
B
T
E
F
W
B0
D1
A
A
K0
B
SECTION B-B
Symbol
Dimension (mm)
W
12.00±0.20
P0
4.00±0.10
P1
8.00±0.10
P2
2.00±0.10
D0
Φ1.55±0.10
D1
Φ1.5±0.10
E
1.75±0.10
F
5.50±0.10
A0
3.86±0.15
B0
5.65±0.10
K0
2.75±0.15
T
0.25±0.05
D2
Φ178.0±2.0
D3
Φ50.0Min.
D4
Φ13.0±0.5
W1
16.0±2.0
A0
SECTION A-A
7” Reel
D4
D3
D2
W1
Quantity: 500PCS
13” Reel
D5
Φ330.0±2.0
D6
Φ13.5±0.5
H
2.5±1.0
W2
16.0±2.0
Quantity: 3000PCS
7/7
很抱歉,暂时无法提供与“SMBJ75A-AT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.41572
- 10+0.37657
- 30+0.35047
- 100+0.31132
- 500+0.29305
- 1000+0.28000
