UAD03C05L01
ElectroStatic Discharged Protection Devices (ESD) Data Sheet
Description
The UAD03C05L01 includes back-to-back TVS diodes fabricated in
a proprietary silicon avalanche technology to provide protection for
electronic equipment that may experience destructive electrostatic
discharge (ESD). These robust diodes can safely absorb repetitive
ESD strikes up to the maximum level specified in the IEC61000-4-2
international standard without performance degradation.
The back-to-back configuration provides symmetrical ESD protection
for data lines when AC signals are present.
Features
IEC61000-4-2 ESD 15KV Air, 8KV contact compliance
DFN1608 surface mount package
Working voltage: 5V
Low leakage current
Low operating and clamping voltages
Lead Free/RoHS compliant
Flammability rating UL 94V-0
Meets MSL level 1, per J-STD-020
Marking: C1
1
2
Applications
Pin Configuration
USB 3.0/USB 2.0
MHL/MIPI/MDDI
HDMI, Video Port, eSATA
Set Top Boxes, Game Consoles
Smart Phones
External Storage
Ultrabooks, Notebooks
Tablets, eReaders
Maximum Ratings
Rating
Symbol
ESD voltage (Contact discharge)
Value
Unit
±8
VESD
ESD voltage (Air discharge)
Storage & operating temperature range
Revision:ESD-UAD03C05L01-001(A2)
kV
±15
TSTG ,TJ
1/4
-55~+150
http://brightking.yageo.com
UAD03C05L01
Electrical Characteristics (TJ=25℃)
Parameter
Symbol
Reverse stand-off voltage
Condition
Min.
Typ.
Max.
Unit
5
V
9
V
VRWM
Reverse breakdown voltage
VBR
IBR=1mA
6
Reverse leakage current
IR
VR=5V
0.5
μA
Clamping voltage (tp=8/20μs)
VC
IPP=1A
11
V
VC
IPP=2A
14
V
Peak pulse current (tp=8/20μs)
IPP
3
A
Off state junction capacitance
CJ
0Vdc,f=1MHz
0.5
pF
Typical Characteristics Curves
Figure 1. Capacitance vs. Bias Voltage
Figure 2. Insertion Loss (S21) I/O to GND
1
5
0.9
0.7
Attenuation (dB)
Capacitance (pF)
0.8
0.6
0.5
0.4
0.3
-15
-20
-25
0.2
-30
0.1
-35
2
3
4
-40
5
DC Bias (V)
Figure 3. Pulse Waveform
tr
Peak value Ipp
Waveform
Parameters:
tr=8µs
td=20µs
90
80
70
60
50
40
td=t|PP/2
30
10
10
100
1000
Frequency (MHz)
Figure 4. Transmission Line Pulsing (TLP) Plot
TLP Current (A)
110
100
% of Peak Power Current
-10
15
Time (μs)
30
18
16
14
12
10
8
6
4
2
-4
-6
-8
-10
-12
-14
-16
-18
-25 -20 -15 -10 -5
10
TLP Voltage (V)
2/4
15
UAD03C05L01
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (ts)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
20-40 seconds
8 minutes max.
3/4
UAD03C05L01
Dimensions (DFN1608)
Dimension (mm)
Symbol
A1 A
A
1.05
0.65
A1
D
0.80
Millimeters
Inches
Min.
Max.
Min.
Max.
0.45
0.65
0.018
0.026
0.04Typ.
0.002
D
1.55
1.65
0.061
0.065
E
0.67
0.75
0.026
0.030
F
0.75
0.85
0.030
0.033
L1
0.72
0.80
0.028
0.031
L2
0.32
0.50
0.013
0.020
E F
1.90
L1
L2
Recommended Soldering Pad Layout
Packaging
Tape
P0
P1
P2
K
B
F
W
E
øD0
øD1
t
A
Symbol
Dimension (mm)
W
8.00±0.30
P0
4.00±0.10
P1
4.00±0.10
P2
2.00±0.10
D0
Φ1.50±0.10
D1
Φ0.50±0.05
E
1.75±0.10
F
3.50±0.10
A
0.93±0.05
B
1.74±0.05
K
0.70±0.05
t
0.20±0.05
D
Φ178.0±2.0
D2
Φ13.0
W1
9.5
Reel
D2
D
W1
Quantity: 5000PCS
4/4
很抱歉,暂时无法提供与“UAD03C05L01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.39442
- 100+0.31126
- 1000+0.23849
- 2000+0.23491
- 5000+0.21354
- 国内价格
- 10+0.43028
- 100+0.33956
- 300+0.29420
- 1000+0.26018
- 5000+0.23296
- 国内价格
- 20+0.93510
- 100+0.55770
- 500+0.39040
- 5000+0.27890
- 10000+0.26500
- 50000+0.24540
